The i.MX 8M reference manual mentions a JTAG_SMODE[1:0] and a SJC DISABLE e-fuse that are necessary to disable JTAG access. But I can't find the address or location of the fuses. Where can I find them? Is there some document describing it?
Solved! Go to Solution.
Here is the description of these fuse bits:
| Fuse Address | Fuse Name | Function | Setting |
| 0x470[21] | SJC_DISABLE | Disable/Enable the Secure JTAG Controller module. This fuse is used to create highest JTAG security level, where JTAG is totally blocked. | 0 - Secure JTAG Controller is enabled 1 - Secure JTAG Controller is disabled |
| 0x470[23:22] | JTAG_SMODE[1:0] | JTAG Security Mode. Controls the security mode of the JTAG debug interface | 00 - JTAG enable mode 01 - Secure JTAG mode 1x - No debug mode |
Thanks, igorpadykov, very helpful to answer this by mail!
How about others like us who are also wondering about all this?
Hello Igor,
thank you. That solved my question.
Christian
