How To Rotate 90 Degree Video For Display In I.MX8X
20,405 次查看
alighieri
Here According To Datasheet And Reference Manual The New Follower Of I.MX Series Processor I.MX8X Is Designed Without IPU Which Is Built-In In Previous Series I.MX6 Processor. My Questions Is How To Rotate 90 / 180 Degree For Target Display In Wanted Orientation? Is Here Also Contain FRAMEBUFFER.C In BSP For Doing That?
26 回复数
8,709 次查看
alighieri
HI IGOR
Thank You For Your Kindly Help To Have Patch For I.MX8X Display Rotation. Looks The Feature Is Performed By GPU?
Bright
8,022 次查看
aber
hello alighieri
    Can you share the patch, thank you。
6,262 次查看
28658180
Hello,Bright
Will you please send me a copy of the patch? I met with the same problem, thanks
frank
3,595 次查看
aber
The system sets this property, and others can be changed as needed。
hwc.enable.overlay=0
3,557 次查看
jeniceks
Hello Aber
It seems your post is valid for android. How can I rotate screen (180 deg) on imx8x, linux without weston runnig QT application on eglfs plaform?
thx for help
3,553 次查看
aber
Hi jeniceks
    that configuration is for android, try configuring weston.ini under linux.
