How To Rotate 90 Degree Video For Display In I.MX8X
20,390件の閲覧回数
alighieri
Here According To Datasheet And Reference Manual The New Follower Of I.MX Series Processor I.MX8X Is Designed Without IPU Which Is Built-In In Previous Series I.MX6 Processor. My Questions Is How To Rotate 90 / 180 Degree For Target Display In Wanted Orientation? Is Here Also Contain FRAMEBUFFER.C In BSP For Doing That?
26 返答(返信)
8,701件の閲覧回数
alighieri
HI IGOR
Thank You For Your Kindly Help To Have Patch For I.MX8X Display Rotation. Looks The Feature Is Performed By GPU?
Bright
8,014件の閲覧回数
aber
hello alighieri
    Can you share the patch, thank you。
6,254件の閲覧回数
28658180
Hello,Bright
Will you please send me a copy of the patch? I met with the same problem, thanks
frank
3,587件の閲覧回数
aber
The system sets this property, and others can be changed as needed。
hwc.enable.overlay=0
3,549件の閲覧回数
jeniceks
Hello Aber
It seems your post is valid for android. How can I rotate screen (180 deg) on imx8x, linux without weston runnig QT application on eglfs plaform?
thx for help
3,545件の閲覧回数
aber
Hi jeniceks
    that configuration is for android, try configuring weston.ini under linux.
