H.264 Encoder + Decoder performance
3,834 次查看
duduakler
Does the iMX6 supports 1080p@30fps encoding and decoding simultaneously?
标签 (2)
4 回复数
2,376 次查看
saurabh206
Senior Contributor III
Which BSP are you using?
From specification it is possible to do.
2,376 次查看
duduakler
Not yet using.
It is one of my system requirements and I could not find it explicitly.
Can you direct me to the document?
2,376 次查看
saurabh206
Check following document for the VPU performance detail.
Q&A: MX6 VPU H.264 Dual Stream Encode Limits
Saurabh
2,376 次查看
duduakler
Hi Saurabh,
Great Info.
Dudu
