H.264 Encoder + Decoder performance
3,923件の閲覧回数
duduakler
Does the iMX6 supports 1080p@30fps encoding and decoding simultaneously?
ラベル(2)
4 返答(返信)
2,465件の閲覧回数
saurabh206
Senior Contributor III
Which BSP are you using?
From specification it is possible to do.
2,465件の閲覧回数
duduakler
Not yet using.
It is one of my system requirements and I could not find it explicitly.
Can you direct me to the document?
2,465件の閲覧回数
saurabh206
Check following document for the VPU performance detail.
Q&A: MX6 VPU H.264 Dual Stream Encode Limits
Saurabh
2,465件の閲覧回数
duduakler
Hi Saurabh,
Great Info.
Dudu
