Enable Phonegap framework and java for IMX6q using LTIB
1,583 次查看
shalinikp
Is it possible to enable phonegap and java on LTIB for imx6q.  Please reply if any one has enabled it.
标签 (2)
1,464 次查看
b36401
Java virtual machines are able to run on the MX6x BSPs. However we do not offer any java VM in the BSP.
Oracle has pre-built versions of Java Virtual Machine for ARM Processors. It's possible to download them here:
http://www.oracle.com/technetwork/java/embedded/embedded-se/downloads/index.html
You can find mode details in this document:
https://community.freescale.com/docs/DOC-1478
