Does miracast function have relationship with LCD resolution
3,299 次查看
xiaoqianlin
One customer used MX6DL with 480X800 LCD RGB interface(JB4.2.2) and reported  error  when connecting two devices using miracast, I attached the log, can you help to check?
Linda
Linda Lin
3,123 次查看
Ivan_liu
Hi Linda,
Does the customer use the wifi display sink apk developed by themselves.
The display size doesn't impact the miracast function.
BRs,
Ivan
3,124 次查看
Ivan_liu
Hi Linda,
BRs,
Ivan
3,123 次查看
xiaoqianlin
Thanks. Checked with customer, they downloaded the source code and compile it.
Linda Lin
3,123 次查看
YixingKong
Senior Contributor IV
Ivan.liu, could you hep the customer's issue?
Yixing
