One customer used MX6DL with 480X800 LCD RGB interface(JB4.2.2) and reported error when connecting two devices using miracast, I attached the log, can you help to check?
Linda
Solved! Go to Solution.
Hi Linda,
Does the customer use the wifi display sink apk developed by themselves.
The display size doesn't impact the miracast function.
BRs,
Ivan
Thanks. Checked with customer, they downloaded the source code and compile it.
Ivan.liu, could you hep the customer's issue?
Yixing
