Hello community,
I am trying to compile the chromium-ozone-wayland based on Yocto hardknott (imx-5.10.35-2.0.0.xml) on IMX8MQEVK board, but the compilation fails with the error:
| Package dri was not found in the pkg-config search path.
| Perhaps you should add the directory containing `dri.pc'
| to the PKG_CONFIG_PATH environment variable
| No package 'dri' found
| See //content/gpu/BUILD.gn:141:18: which caused the file to be included.
| configs += [ "//build/config/linux/dri" ]
| WARNING: exit code 1 from a shell command.
In my previous version (Yocto Warrior) I was able to fix it by adding this dependency:
DEPENDS += " mesa "
but this trick no longer works, has anyone successfully compiled chromium?
I know... There is no support for Chromium, I am just asking.
