Chromium on IMX8
Chromium on IMX8
Giacomo_
Hello community,
I am trying to compile the chromium-ozone-wayland based on Yocto hardknott (imx-5.10.35-2.0.0.xml) on IMX8MQEVK board, but the compilation fails with the error:
| Package dri was not found in the pkg-config search path.
| Perhaps you should add the directory containing `dri.pc'
| to the PKG_CONFIG_PATH environment variable
| No package 'dri' found
| See //content/gpu/BUILD.gn:141:18: which caused the file to be included.
| configs += [ "//build/config/linux/dri" ]
| WARNING: exit code 1 from a shell command.
In my previous version (Yocto Warrior) I was able to fix it by adding this dependency:
DEPENDS += " mesa "
but this trick no longer works, has anyone successfully compiled chromium?
I know... There is no support for Chromium, I am just asking.
Labels (2)
Jeroen_H
Just to let you know, I'm trying to buildby using this patch right now:
https://github.com/OSSystems/meta-browser/issues/528
Seach for "0013-Only-DRI-for-x11.txt" and adapt to your code version.
But, it takes a while to build Chromium, I'll post my finding later.
Hopefully DRI isn't needed on iMX8 and Wayland.
Cheers,
Jeroen.
Rita_Wang
Jeroen_H
Hi!
Thanks for pointing us out to the document. I've already gone through these steps.
Unfortunately, adding mesa to the depends, and building seperately still produced errors during do_configure().
Kind regards,
Jeroen.
Giacomo_
Backporting? Yes, I can evaluate this too, thanks.
Giacomo_
here you are my bbappend:
chromium-ozone-wayland_83.0.4103.116.bbappend
it contains only one line:
DEPENDS += " mesa "
Jeroen_H
Okay, thanks, I'll have a look
Jeroen_H
Cheers,
Jeroen.
Giacomo_
Yes please, let me know the outcome.
Jeroen_H
Building succeeded, I have chromium (83.0.4103.116) running now on iMX8M Mini, weston-wayland, and using the GPU of the iMX.
I'm using Zeus btw.
Performance looks good.
Still doing some testing, but I think you can take it from here
Jeroen.
r_trivedi123
Hi Jeroen,
Can you share,
Which BSP you used ?
How did you build (for wayland running on GPU ) ? , basically build step doc or pointers.
Any performance statistics or issues you found ?
Appreciate your guidance.
Rutvij
Giacomo_
Kudos to Jeroen (not the button only).
This is the way to go.
Thank you for helping!
Jeroen_H
I have the same issue (iMX8M Mini, using Zeus 5.4.47) , no solution found yet.
Can you tell me the exact version of Yocto Warrior (or actually the version of Chromium) you've been using previously?
Just wanted to have a look at the differences....
