Applying LPDDR2 on MX6DQ issues
2,840 次查看
raymondwang
Senior Contributor I
Recently we are trying to apply LPDDR2 on MX6DQ. There are some questions we need to know. Please help us if you has same experience.
1. How about LPDDR2 single channel or dual channel?
    We use an eMCP packged LPDDR2 chip from Samsung with PN KMK7X000VM. It including two internal LPDDR2 chips (two cs,128Mbx32,totally 8Gb).
    How can set mx6 MMDC controller? For our design, can use config it with single channel or dual channel freely?
   Any patch is welcome!
2.Currently our kernel version is 3.0.25 (android 4.2.2 1.1.0 based on). I think it does have LPDDR2 support in kernel mx6_mmdc.c and suspend/resume handling
code.
  Any one has patch for linux kernel mx6q LPDDR2?
标签 (2)
标记 (1)
2,210 次查看
igorpadykov
Hi Raymond
you can use both single channel or dual channel, also
please look at links below
https://community.freescale.com/message/338104#338104
i.MX6DL LPDDR2 Support for L3.0.35_4.0.0
chip
2,211 次查看
igorpadykov
Hi Raymond
chip
2,210 次查看
raymondwang
Great! Thanks!
