Add a LCD panel (ST7701 controller) on linux 5.4.47 with i.MX8M mini
Hardevsinh_Palaniya
I tried to add a new panel in i.MX8M Mini with ST7701 controller on Yocto kernel 5.4.47. I got error "imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi"
After that probe completed successfully with sending init sequence. I can also confirm fbset on board, but can not see anything on display.
Can you please guide me how to solve the issue?
Any help will be appreciated.
Senior Embedded Engineer | hardevsinh.palaniya@siliconsignals.io | www.siliconsignals.io
Hardevsinh_Palaniya
Thanks for your reply. My problem is already solved.
I follow the link bellow and replace driver with @fangkai 's   driver.
https://community.nxp.com/t5/i-MX-Processors/how-to-add-a-new-panel-with-imx8mm-evk-I-got-some-probl...
With above link and minor changes, My LCD panel worked.
Zhiming_Liu
Hi @Hardevsinh_Palaniya
Can you share your dts changes?
Hardevsinh_Palaniya
Hardevsinh_Palaniya
Can somebody assist me with this?
