Updating MCUXpresso Compile Problem
已解决
跳至解决方案
2,374 次查看
accatpaliz
After updating my MCUXpresso IDE . i cant  compile my working projects any more.
i was working with 11.3.0 and now i have 11.5.1
its link result (error in last line: ignoring invalid character `\333' in script):
Building target: sln_viznas_iot_elock_oobe.axf
Invoking: MCU C++ Linker
arm-none-eabi-c++ -nostdlib -L"H:\MCUXpresso prj\workspace3-conv\sln_viznas_iot_elock_oobe\libs\oasis" -L"H:\MCUXpresso prj\workspace3-conv\sln_viznas_iot_elock_oobe\wiced\43xxx_BLE\wiced_bt\BTE" -u _printf_float -Xlinker -Map="sln_viznas_iot_elock_oobe.map" -Xlinker --gc-sections -Xlinker -print-memory-usage -Xlinker --sort-section=alignment -Xlinker --cref -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -T sln_viznas_iot_elock_oobe_Debug.ld -u _printf_float -o "sln_viznas_iot_elock_oobe.axf" ./xip/fsl_flexspi_nor_boot.o ./xip/sln_viznas_iot_flexspi_nor_config.o ./wiced/43xxx_Wi-Fi/libraries/test/wl_tool/4343WA1/wl/exe/wlu_pipe.o ./wiced/43xxx_Wi-Fi/libraries/test/wl_tool/4343WA1/wl/exe/wlu_server_shared.o ./wiced/43xxx_Wi-Fi/libraries/test/wl_tool/wlu_server.o ./wiced/43xxx_Wi-Fi/app/dhcp_server.o ./wiced/43xxx_Wi-Fi/app/test_apsta.o ./wiced/43xxx_Wi-Fi/app/test_scan.o ./wiced/43xxx_Wi-Fi/app/wlanif_add.o ./wiced/43xxx_Wi-Fi/WICED/platform/MCU/LPC/WWD/wwd_SDIO.o ./wiced/43xxx_Wi-Fi/WICED/platform/MCU/LPC/WWD/wwd_platform.o ./wiced/43xxx_Wi-Fi/WICED/platform/MCU/wwd_platform_separate_mcu.o ./wiced/43xxx_Wi-Fi/WICED/platform/MCU/wwd_resources.o ./wiced/43xxx_Wi-Fi/WICED/network/LwIP/WWD/wwd_buffer.o ./wiced/43xxx_Wi-Fi/WICED/network/LwIP/WWD/wwd_network.o ./wiced/43xxx_Wi-Fi/WICED/internal/wifi.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/chips/4343W/resources.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/chips/4343W/wwd_ap.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/chips/4343W/wwd_chip_specific_functions.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/bus_protocols/SDIO/wwd_bus_protocol.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/bus_protocols/wwd_bus_common.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/tlv.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_ap_common.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_clm.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_debug.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_eapol.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_internal.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_management.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_rtos_interface.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_sdpcm.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_thread.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_thread_internal.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_wifi.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_wifi_chip_common.o ./wiced/43xxx_Wi-Fi/WICED/WWD/internal/wwd_wifi_sleep.o ./wiced/43xxx_Wi-Fi/WICED/RTOS/FreeRTOS/WWD/wwd_rtos.o ./wiced/43xxx_BLE/wiced_bt/imxrt_port/bt_firmware_controller.o ./wiced/43xxx_BLE/wiced_bt/imxrt_port/platform_bluetooth.o ./wiced/43xxx_BLE/wiced_bt/imxrt_port/platform_imxrt.o ./wiced/43xxx_BLE/wiced_bt/imxrt_port/wiced_rtos.o ./video-utilities/fonts/cambo.o ./video-utilities/fonts/font.o ./video-utilities/fonts/open_sans.o ./video-utilities/fonts/raleway.o ./video-utilities/calibration.o ./video-utilities/camera.o ./video-utilities/database.o ./video-utilities/display.o ./video-utilities/featuredb.o ./video-utilities/flashdb.o ./video-utilities/oasis.o ./video-utilities/pxp.o ./video-utilities/userid_ui.o ./video-utilities/util.o ./video/fsl_csi_camera_adapter.o ./video/fsl_gc0308.o ./video/fsl_mt9m114.o ./video/fsl_video_common.o ./video/fsl_video_i2c.o ./utilities/fsl_assert.o ./utilities/fsl_debug_console.o ./utilities/fsl_shell.o ./utilities/fsl_str.o ./usb/phy/usb_phy.o ./usb/device/source/ehci/usb_device_ehci.o ./usb/device/source/usb_device_dci.o ./usb/device/class/video/usb_device_video.o ./startup/startup_mimxrt106f.o ./source/usb_composite/composite.o ./source/usb_composite/sln_usb_composite.o ./source/usb_composite/video_camera.o ./source/usb_composite/virtual_com.o ./source/config_files/wiced_bt_cfg.o ./source/ble/ble_connection.o ./source/ble/ble_server.o ./source/device_utils.o ./source/fault_handlers.o ./source/main.o ./source/network_connection.o ./source/os_hooks.o ./source/remote_cmds.o ./source/semihost_hardfault.o ./source/sln_RT10xx_RGB_LED_driver.o ./source/sln_RT10xx_RGB_LED_driver_pcal.o ./source/sln_api.o ./source/sln_api_init.o ./source/sln_app_fwupdate.o ./source/sln_audio.o ./source/sln_cli.o ./source/sln_connection.o ./source/sln_encrypt.o ./source/sln_flash.o ./source/sln_flash_config.o ./source/sln_flash_mgmt.o ./source/sln_lpm.o ./source/sln_oasis_state.o ./source/sln_shell.o ./source/sln_system_state.o ./source/sln_tcp_connection.o ./source/sln_timers.o ./source/sln_wdog.o ./source/specific.o ./source/switch.o ./source/udp_message_handler.o ./source/udp_server.o ./source/wifi_credentials.o ./sdmmc/src/fsl_sdio.o ./sdmmc/src/fsl_sdmmc_common.o ./sdmmc/osa/fsl_sdmmc_osa.o ./sdmmc/host/fsl_sdmmc_host.o ./riverdi/host_layer/rt1060/platform_disp.o ./riverdi/eve_layer/CoPro_Cmds.o ./riverdi/eve_layer/Gpu_Hal.o ./riverdi/eve_layer/Hal_Utils.o ./riverdi/eve_layer/ili9341.o ./riverdi/app_layer/App_Common.o ./riverdi/sln_rvdisp.o ./mbedtls/port/ksdk/aes_alt.o ./mbedtls/port/ksdk/des_alt.o ./mbedtls/port/ksdk/ecp_alt.o ./mbedtls/port/ksdk/ecp_alt_ksdk.o ./mbedtls/port/ksdk/ecp_curves_alt.o ./mbedtls/port/ksdk/ksdk_mbedtls.o ./mbedtls/library/aes.o ./mbedtls/library/aesni.o ./mbedtls/library/arc4.o ./mbedtls/library/aria.o ./mbedtls/library/asn1parse.o ./mbedtls/library/asn1write.o ./mbedtls/library/base64.o ./mbedtls/library/bignum.o ./mbedtls/library/blowfish.o ./mbedtls/library/camellia.o ./mbedtls/library/ccm.o ./mbedtls/library/certs.o ./mbedtls/library/chacha20.o ./mbedtls/library/chachapoly.o ./mbedtls/library/cipher.o ./mbedtls/library/cipher_wrap.o ./mbedtls/library/cmac.o ./mbedtls/library/ctr_drbg.o ./mbedtls/library/debug.o ./mbedtls/library/des.o ./mbedtls/library/dhm.o ./mbedtls/library/ecdh.o ./mbedtls/library/ecdsa.o ./mbedtls/library/ecjpake.o ./mbedtls/library/ecp.o ./mbedtls/library/ecp_curves.o ./mbedtls/library/entropy.o ./mbedtls/library/entropy_poll.o ./mbedtls/library/error.o ./mbedtls/library/gcm.o ./mbedtls/library/havege.o ./mbedtls/library/hkdf.o ./mbedtls/library/hmac_drbg.o ./mbedtls/library/md.o ./mbedtls/library/md2.o ./mbedtls/library/md4.o ./mbedtls/library/md5.o ./mbedtls/library/md_wrap.o ./mbedtls/library/memory_buffer_alloc.o ./mbedtls/library/net_sockets.o ./mbedtls/library/nist_kw.o ./mbedtls/library/oid.o ./mbedtls/library/padlock.o ./mbedtls/library/pem.o ./mbedtls/library/pk.o ./mbedtls/library/pk_wrap.o ./mbedtls/library/pkcs11.o ./mbedtls/library/pkcs12.o ./mbedtls/library/pkcs5.o ./mbedtls/library/pkparse.o ./mbedtls/library/pkwrite.o ./mbedtls/library/platform.o ./mbedtls/library/platform_util.o ./mbedtls/library/poly1305.o ./mbedtls/library/ripemd160.o ./mbedtls/library/rsa.o ./mbedtls/library/rsa_internal.o ./mbedtls/library/sha1.o ./mbedtls/library/sha256.o ./mbedtls/library/sha512.o ./mbedtls/library/ssl_cache.o ./mbedtls/library/ssl_ciphersuites.o ./mbedtls/library/ssl_cli.o ./mbedtls/library/ssl_cookie.o ./mbedtls/library/ssl_srv.o ./mbedtls/library/ssl_ticket.o ./mbedtls/library/ssl_tls.o ./mbedtls/library/threading.o ./mbedtls/library/timing.o ./mbedtls/library/version.o ./mbedtls/library/version_features.o ./mbedtls/library/x509.o ./mbedtls/library/x509_create.o ./mbedtls/library/x509_crl.o ./mbedtls/library/x509_crt.o ./mbedtls/library/x509_csr.o ./mbedtls/library/x509write_crt.o ./mbedtls/library/x509write_csr.o ./mbedtls/library/xtea.o ./lwip/src/netif/ppp/auth.o ./lwip/src/netif/ppp/ccp.o ./lwip/src/netif/ppp/chap-md5.o ./lwip/src/netif/ppp/chap-new.o ./lwip/src/netif/ppp/chap_ms.o ./lwip/src/netif/ppp/demand.o ./lwip/src/netif/ppp/eap.o ./lwip/src/netif/ppp/eui64.o ./lwip/src/netif/ppp/fsm.o ./lwip/src/netif/ppp/ipcp.o ./lwip/src/netif/ppp/ipv6cp.o ./lwip/src/netif/ppp/lcp.o ./lwip/src/netif/ppp/lwip_ecp.o ./lwip/src/netif/ppp/magic.o ./lwip/src/netif/ppp/mppe.o ./lwip/src/netif/ppp/multilink.o ./lwip/src/netif/ppp/ppp.o ./lwip/src/netif/ppp/pppapi.o ./lwip/src/netif/ppp/pppcrypt.o ./lwip/src/netif/ppp/pppoe.o ./lwip/src/netif/ppp/pppol2tp.o ./lwip/src/netif/ppp/pppos.o ./lwip/src/netif/ppp/upap.o ./lwip/src/netif/ppp/utils.o ./lwip/src/netif/ppp/vj.o ./lwip/src/netif/bridgeif.o ./lwip/src/netif/bridgeif_fdb.o ./lwip/src/netif/ethernet.o ./lwip/src/netif/lowpan6.o ./lwip/src/netif/lowpan6_ble.o ./lwip/src/netif/lowpan6_common.o ./lwip/src/netif/slipif.o ./lwip/src/netif/zepif.o ./lwip/src/core/ipv6/dhcp6.o ./lwip/src/core/ipv6/ethip6.o ./lwip/src/core/ipv6/icmp6.o ./lwip/src/core/ipv6/inet6.o ./lwip/src/core/ipv6/ip6.o ./lwip/src/core/ipv6/ip6_addr.o ./lwip/src/core/ipv6/ip6_frag.o ./lwip/src/core/ipv6/mld6.o ./lwip/src/core/ipv6/nd6.o ./lwip/src/core/ipv4/acd.o ./lwip/src/core/ipv4/autoip.o ./lwip/src/core/ipv4/dhcp.o ./lwip/src/core/ipv4/etharp.o ./lwip/src/core/ipv4/icmp.o ./lwip/src/core/ipv4/igmp.o ./lwip/src/core/ipv4/ip4.o ./lwip/src/core/ipv4/ip4_addr.o ./lwip/src/core/ipv4/ip4_frag.o ./lwip/src/core/altcp.o ./lwip/src/core/altcp_alloc.o ./lwip/src/core/altcp_tcp.o ./lwip/src/core/def.o ./lwip/src/core/dns.o ./lwip/src/core/inet_chksum.o ./lwip/src/core/init.o ./lwip/src/core/ip.o ./lwip/src/core/mem.o ./lwip/src/core/memp.o ./lwip/src/core/netif.o ./lwip/src/core/pbuf.o ./lwip/src/core/raw.o ./lwip/src/core/stats.o ./lwip/src/core/sys.o ./lwip/src/core/tcp.o ./lwip/src/core/tcp_in.o ./lwip/src/core/tcp_out.o ./lwip/src/core/timeouts.o ./lwip/src/core/udp.o ./lwip/src/api/api_lib.o ./lwip/src/api/api_msg.o ./lwip/src/api/err.o ./lwip/src/api/if_api.o ./lwip/src/api/netbuf.o ./lwip/src/api/netdb.o ./lwip/src/api/netifapi.o ./lwip/src/api/sockets.o ./lwip/src/api/tcpip.o ./lwip/port/sys_arch.o ./freertos/freertos_kernel/portable/MemMang/heap_4.o ./freertos/freertos_kernel/portable/GCC/ARM_CM4F/port.o ./freertos/freertos_kernel/croutine.o ./freertos/freertos_kernel/event_groups.o ./freertos/freertos_kernel/list.o ./freertos/freertos_kernel/queue.o ./freertos/freertos_kernel/stream_buffer.o ./freertos/freertos_kernel/tasks.o ./freertos/freertos_kernel/timers.o ./fatfs/source/fsl_nor_disk/fsl_nor_disk.o ./fatfs/source/diskio.o ./fatfs/source/ff.o ./fatfs/source/ffsystem.o ./fatfs/source/ffunicode.o ./fatfs/fatfs_source/fatfs_op.o ./drivers/freertos/fsl_lpi2c_freertos.o ./drivers/freertos/fsl_lpspi_freertos.o ./drivers/freertos/fsl_lpuart_freertos.o ./drivers/flexspi_hyper_flash_ops.o ./drivers/fsl_cache.o ./drivers/fsl_clock.o ./drivers/fsl_common.o ./drivers/fsl_csi.o ./drivers/fsl_dcdc.o ./drivers/fsl_dcp.o ./drivers/fsl_dmamux.o ./drivers/fsl_edma.o ./drivers/fsl_elcdif.o ./drivers/fsl_flexram.o ./drivers/fsl_flexram_allocate.o ./drivers/fsl_flexspi.o ./drivers/fsl_gpc.o ./drivers/fsl_gpio.o ./drivers/fsl_lpi2c.o ./drivers/fsl_lpspi.o ./drivers/fsl_lpspi_edma.o ./drivers/fsl_lpuart.o ./drivers/fsl_pit.o ./drivers/fsl_pxp.o ./drivers/fsl_qtmr.o ./drivers/fsl_sai.o ./drivers/fsl_sai_edma.o ./drivers/fsl_trng.o ./drivers/fsl_usdhc.o ./drivers/fsl_wdog.o ./drivers/sln_pcal.o ./device/system_MIMXRT106F.o ./component/uart/lpuart_adapter.o ./component/serial_manager/usb_cdc_adapter/usb_device_cdc_acm.o ./component/serial_manager/usb_cdc_adapter/usb_device_ch9.o ./component/serial_manager/usb_cdc_adapter/usb_device_class.o ./component/serial_manager/usb_cdc_adapter/usb_device_descriptor.o ./component/serial_manager/serial_manager.o ./component/serial_manager/serial_port_uart.o ./component/osa/fsl_os_abstraction_free_rtos.o ./component/lists/generic_list.o ./component/i2c/lpi2c_adapter.o ./component/i2c/lpi2c_adapter_freertos.o ./common/fsl_time.o ./common/sln_dev_cfg.o ./codec/tfa9xxx/vas_tfa_drv/tfa2_container.o ./codec/tfa9xxx/vas_tfa_drv/tfa2_dev.o ./codec/tfa9xxx/vas_tfa_drv/tfa2_haptic.o ./codec/tfa9xxx/vas_tfa_drv/tfa2_init.o ./codec/tfa9xxx/vas_tfa_drv/tfa_container_crc32.o ./codec/tfa9xxx/fsl_tfa9xxx.o ./codec/tfa9xxx/fsl_tfa9xxx_IMX.o ./codec/fsl_codec_adapter.o ./codec/fsl_codec_common.o ./codec/fsl_codec_i2c.o ./cjson/src/cJSON.o ./cjson/src/cJSON_Utils.o ./board/board.o ./board/clock_config.o ./board/dcd.o ./board/hardware_init.o ./board/peripherals.o ./board/pin_mux.o ./board/sdmmc_config.o ./audio/streamer/sln_streamer_pcm.o ./audio/sln_amplifier.o -loasis_lite_ae -lwicedble
g:/nxp/mcuxpressoide_11.5.1_7266/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.5.1.202201181444/tools/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe:sln_viznas_iot_elock_oobe_Debug_memory.ld:33: ignoring invalid character `\333' in script
1 解答
2,368 次查看
accatpaliz
ok. using windows, go to region and language -> formats and change format to English(united states) then delete *memory.ld file from project and rebuild the project. it solved the problem
在原帖中查看解决方案
2 回复数
2,369 次查看
accatpaliz
2,368 次查看
accatpaliz
it seems new MCUXpresso IDE version uses my windows text defaults to generate .ld file
so __base_Flash3  in memory.ld  changed to __base_Flash[#]
where [#] is '3' character in my native language.
