1. To setup the Yocto environment, from the BASE folder run
fsl-community-bsp $ . setup-environment build
2. Build the toolchain
build $ bitbake meta-toolchain
# Other toolchains:
# Qt Embedded toolchain build: bitbake meta-toolchain-qte
# Qt X11 toolchain build: bitbake meta-toolchain-qt
3. Install it on your PC
build $ sudo sh \
tmp/deploy/sdk/poky-eglibc-x86_64-arm-toolchain-<version>.sh
4. Setup the toolchain environment
build $ source \
/opt/poky/<version>/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
5. Get the Linux Kernel's source code.
$ git clone git://git.freescale.com/imx/linux-2.6-imx.git linux-imx
$ cd linux-imx
6. Create a local branch
linux-imx $ BRANCH=imx_3.0.35_4.0.0 # Change to any branch you want,
# Use 'git branch -a' to list all
linux-imx $ git checkout -b ${BRANCH} origin/${BRANCH}
7. Export ARCH and CROSS_COMPILE
linux-imx $ export ARCH=arm
linux-imx $ export CROSS_COMPILE=arm-poky-linux-gnueabi-
linux-imx $ unset LDFLAGS
8. Choose configuration and compile
linux-imx $ make imx6_defconfig
linux-imx $ make uImage
9. To Test your changes, copy the `uImage` into your SD Card
linux-imx $ sudo cp arch/arm/boot/uImage /media/boot
10. If case you want your changes to be reflected on your Yocto Framework, create the patches following the document i.MX Yocto Project: How can I patch the kernel?
