Measure (RAW) NAND flash performances
Using a RAW NAND is more difficult compared to eMMC, but for lower capacity it is still cheaper.
Even with the ONFI (Open NAND Flash Interface) you can face initialization issue you can find by measure performance.
I will take example of a non-well supported flash, I have installed on my evaluation board (SABRE AI).
I wanted to do a simple performance test, to check roughly the MB/s I can expected with this NAND.
One of a simplest test is to use the dd command:
root@imx6qdlsolo:~# time dd if=/dev/mtd4 of=/dev/null
851968+0 records in
851968+0 records out
436207616 bytes (436 MB, 416 MiB) copied, 131.8884 s, 3.3 MB/s ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
As my RAW was supposed to work in EDO Mode 5, I could expect more than 20MB/s.
To check what was wrong, read you kernel startup log:
Booting Linux on physical CPU 0x0
Linux version 4.1.15-2.0.0+gb63f3f5 (bamboo@yb6) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Fri Sep 16 15:02:15 CDT 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 DualLite/Solo SABRE Automotive Board
Amd/Fujitsu Extended Query Table at 0x0040
 Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
nand: Macronix MX30LF4G18AC
nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
gpmi-nand 112000.gpmi-nand: mode:5 ,failed in set feature.
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
nand_read_bbt: bad block at 0x00000a7e0000
nand_read_bbt: bad block at 0x00000dc80000
4 cmdlinepart partitions found on MTD device gpmi-nand
Creating 4 MTD partitions on "gpmi-nand":‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
On line 13 you can read "mode:5, failed in set feature", meaning you are not in mode 5... so you have the "relaxed" timing you have at boot.
After debuging your code (I have just remove the NAND back reading security check), you can redo the test:
851968+0 records in
436207616 bytes (436 MB, 416 MiB) copied, 32.9721 s, 13.2 MB/s‍‍‍‍‍‍‍‍
So you multiplied the performances by 4!
Anyway, you have a better tool to measure your NAND performance, it is mtd_speedtest, but you have to rebuild your kernel.
In Yocto, reconfigure your kernel (on your PC of couse!):
bitbake virtual/kernel -c menuconfig‍‍
Choose in the menu "Device Drivers" -> "Memory Technology Device (MTD) support" -> "MTD tests support", even it it not recommended!
bitbake virtual/kernel -f -c compile
bitbake virtual/kernel -f -c build
bitbake virtual/kernel -f -c deploy‍‍‍‍‍‍
Then reflash you board (kernel + rootfs as tests are .ko files):
Then you can do more accurate performance test:
insmod /lib/modules/4.1.29-fslc+g59b38c3/kernel/drivers/mtd/tests/mtd_speedtest.ko dev=2
mtd_speedtest: MTD device: 2
mtd_speedtest: MTD device size 16777216, eraseblock size 131072, page size 2048, count of eraseblocks 128, pages per eraseblock 64, OOB size 64
mtd_test: scanning for bad eraseblocks
mtd_test: scanned 128 eraseblocks, 0 are bad
mtd_speedtest: testing eraseblock write speed
mtd_speedtest: eraseblock write speed is 4537 KiB/s
mtd_speedtest: testing eraseblock read speed
mtd_speedtest: eraseblock read speed is 16384 KiB/s
mtd_speedtest: testing page write speed
mtd_speedtest: page write speed is 4250 KiB/s
mtd_speedtest: testing page read speed
mtd_speedtest: page read speed is 15784 KiB/s
mtd_speedtest: testing 2 page write speed
mtd_speedtest: 2 page write speed is 4426 KiB/s
mtd_speedtest: testing 2 page read speed
mtd_speedtest: 2 page read speed is 16047 KiB/s
mtd_speedtest: Testing erase speed
mtd_speedtest: erase speed is 244537 KiB/s
mtd_speedtest: Testing 2x multi-block erase speed
mtd_speedtest: 2x multi-block erase speed is 252061 KiB/s
mtd_speedtest: Testing 4x multi-block erase speed
mtd_speedtest: 4x multi-block erase speed is 256000 KiB/s
mtd_speedtest: Testing 8x multi-block erase speed
mtd_speedtest: 8x multi-block erase speed is 260063 KiB/s
mtd_speedtest: Testing 16x multi-block erase speed
mtd_speedtest: 16x multi-block erase speed is 260063 KiB/s
mtd_speedtest: Testing 32x multi-block erase speed
mtd_speedtest: 32x multi-block erase speed is 256000 KiB/s
mtd_speedtest: Testing 64x multi-block erase speed
mtd_speedtest: 64x multi-block erase speed is 260063 KiB/s
mtd_speedtest: finished
You can now achieve almost 16MB/s, better than the dd test. Of course you cannot achieve more than 20MB/s, but you are not that far, and the NAND driver need optimizations.
To redo the test:
rmmod /lib/modules/4.1.29-fslc+g59b38c3/kernel/drivers/mtd/tests/mtd_speedtest.ko
To check your NAND is in EDO mode 5, you can check your clock tree:
/unit_tests/dump-clocks.sh
clock          parent   flags    en_cnt pre_cnt      rate
gpmi_bch_apb   ---      00000005   0       0       198000000
gpmi_bch       ---      00000005   0       0       198000000
gpmi_io        ---      00000005   0       0        99000000
gpmi_apb       ---      00000005   0       0       198000000‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The IO are clocked now at 99MHz, thus you can read at 49.5MHz (20ns in EDO mode 5 definition).
Comments
mus
How did you remove the "NAND back reading security check"? Is there any side effects of removing it?
I have in fact forced the NAND to be in EDO mode 5.
There were a bug in the RAW NAND, supposed to support EDO mode 5, but the NAND did not answer that.
Forcing EDO mode 5 is dangerous if you change the NAND supplier during production lifetime.
I have enclosed my modified gpmi-lib.c in the main post (modification with NXA22167 comments)
V.
It's weird on our imx6d board: dd is much slower than mtd_speedtest, ~3.5MB/s vs ~20MB/s
P.S. EDO mode is 5 is enabled by linux-imx 4.14.98, without modifying source code.
For the dd command, I am pretty sure the "bs" argument (forced transfer size) is slowing down the transfer, see in this article: Tuning dd block size - tdg5
Can you please try a bigger one (200M for instance).
V.
vincent.aubineau‌, Thanks! It's about block_size:
%3CLINGO-SUB%20id%3D%22lingo-sub-1117283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMeasure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUsing%20a%20RAW%20NAND%20is%20more%20difficult%20compared%20to%20eMMC%2C%20but%20for%20lower%20capacity%20it%20is%20still%20cheaper.%3C%2FP%3E%3CP%3EEven%20with%20the%20ONFI%20(Open%20NAND%20Flash%20Interface)%20you%26nbsp%3Bcan%20face%20initialization%20issue%20you%20can%20find%20by%20measure%20performance.%3C%2FP%3E%3CP%3EI%20will%20take%20example%20of%20a%20non-well%20supported%20flash%2C%20I%20have%20installed%20on%20my%20evaluation%20board%20(SABRE%20AI).%3C%2FP%3E%3CP%3EI%20wanted%20to%20do%20a%20simple%20performance%20test%2C%20to%20check%20roughly%20the%20MB%2Fs%20I%20can%20expected%20with%20this%20NAND.%3C%2FP%3E%3CP%3EOne%20of%20a%20simplest%20test%20is%20to%20use%20the%20dd%20command%3A%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3Eroot%40imx6qdlsolo%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%23%20time%20dd%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edev%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Emtd4%20of%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edev%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Enull%0A%3CSPAN%20class%3D%22number%20token%22%3E851968%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20records%20in%0A%3CSPAN%20class%3D%22number%20token%22%3E851968%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20records%20out%0A%3CSPAN%20class%3D%22number%20token%22%3E436207616%3C%2FSPAN%3E%20bytes%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E436%3C%2FSPAN%3E%20MB%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E416%3C%2FSPAN%3E%20MiB%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20copied%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E131.8884%3C%2FSPAN%3E%20s%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3.3%3C%2FSPAN%3E%20MB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%20%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EAs%20my%20RAW%20was%20supposed%20to%20work%20in%20EDO%20Mode%205%2C%20I%20could%20expect%20more%20than%2020MB%2Fs.%3C%2FP%3E%3CP%3ETo%20check%20what%20was%20wrong%2C%20read%20you%20kernel%20startup%20log%3A%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3EBooting%20Linux%20on%20physical%20CPU%20%3CSPAN%20class%3D%22number%20token%22%3E0x0%3C%2FSPAN%3E%0ALinux%20version%20%3CSPAN%20class%3D%22number%20token%22%3E4.1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E15%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2.0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3Egb63f3f5%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Ebamboo%40yb6%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Egcc%20version%20%3CSPAN%20class%3D%22number%20token%22%3E5.3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EGCC%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%23%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20SMP%20PREEMPT%20Fri%20Sep%20%3CSPAN%20class%3D%22number%20token%22%3E16%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E15%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E02%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E15%3C%2FSPAN%3E%20CDT%20%3CSPAN%20class%3D%22number%20token%22%3E2016%3C%2FSPAN%3E%0ACPU%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20ARMv7%20Processor%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E412fc09a%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20revision%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EARMv7%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20cr%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E10c53c7d%0ACPU%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20PIPT%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%20VIPT%20nonaliasing%20data%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20VIPT%20aliasing%20instruction%20cache%0AMachine%20model%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Freescale%20i%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EMX6%20DualLite%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3ESolo%20SABRE%20Automotive%20Board%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%0AAmd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EFujitsu%20Extended%20Query%20Table%20at%20%3CSPAN%20class%3D%22number%20token%22%3E0x0040%3C%2FSPAN%3E%0A%20Amd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EFujitsu%20Extended%20Query%20version%20%3CSPAN%20class%3D%22number%20token%22%3E1.3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0Anumber%20of%20CFI%20chips%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%0Anand%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20device%20found%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20Manufacturer%20ID%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0xc2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20Chip%20ID%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0xdc%3C%2FSPAN%3E%0Anand%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Macronix%20MX30LF4G18AC%0Anand%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E512%3C%2FSPAN%3E%20MiB%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20SLC%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20erase%20size%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E128%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20page%20size%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2048%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20OOB%20size%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%0Agpmi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Enand%20%3CSPAN%20class%3D%22number%20token%22%3E112000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egpmi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Enand%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20mode%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3Efailed%20in%20set%20feature%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0ABad%20block%20table%20found%20at%20page%20%3CSPAN%20class%3D%22number%20token%22%3E262080%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20version%20%3CSPAN%20class%3D%22number%20token%22%3E0x01%3C%2FSPAN%3E%0ABad%20block%20table%20found%20at%20page%20%3CSPAN%20class%3D%22number%20token%22%3E262016%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20version%20%3CSPAN%20class%3D%22number%20token%22%3E0x01%3C%2FSPAN%3E%0Anand_read_bbt%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20bad%20block%20at%20%3CSPAN%20class%3D%22number%20token%22%3E0x00000a7e0000%3C%2FSPAN%3E%0Anand_read_bbt%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20bad%20block%20at%20%3CSPAN%20class%3D%22number%20token%22%3E0x00000dc80000%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20cmdlinepart%20partitions%20found%20on%20MTD%20device%20gpmi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Enand%0ACreating%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20MTD%20partitions%20on%20%3CSPAN%20class%3D%22string%20token%22%3E%22gpmi-nand%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EOn%20line%2013%20you%20can%20read%20%22mode%3A5%2C%20failed%20in%20set%20feature%22%2C%20meaning%20you%20are%20not%20in%20mode%205...%20so%20you%20have%26nbsp%3Bthe%20%22relaxed%22%20timing%20you%20have%20at%20boot.%3C%2FP%3E%3CP%3EAfter%20debuging%20your%20code%20(I%20have%20just%20remove%20the%20NAND%20back%20reading%20security%20check)%2C%20you%20can%20redo%20the%20test%3A%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3Eroot%40imx6qdlsolo%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%23%20time%20dd%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edev%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Emtd4%20of%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edev%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Enull%0A%3CSPAN%20class%3D%22number%20token%22%3E851968%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20records%20in%0A%3CSPAN%20class%3D%22number%20token%22%3E851968%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20records%20out%0A%3CSPAN%20class%3D%22number%20token%22%3E436207616%3C%2FSPAN%3E%20bytes%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E436%3C%2FSPAN%3E%20MB%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E416%3C%2FSPAN%3E%20MiB%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20copied%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E32.9721%3C%2FSPAN%3E%20s%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E13.2%3C%2FSPAN%3E%20MB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3ESo%20you%20multiplied%20the%20performances%20by%204!%3C%2FP%3E%3CP%3EAnyway%2C%20you%20have%20a%20better%20tool%20to%20measure%20your%20NAND%20performance%2C%20it%20is%20mtd_speedtest%2C%20but%20you%20have%20to%20rebuild%20your%20kernel.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EIn%20Yocto%2C%20reconfigure%20your%20kernel%20(on%20your%20PC%20of%20couse!)%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3Ebitbake%20virtual%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ekernel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ec%20menuconfig%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EChoose%20in%20the%20menu%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%22Device%20Drivers%22%20-%26gt%3B%20%22Memory%20Technology%20Device%20(MTD)%20support%22%20-%26gt%3B%20%22MTD%20tests%20support%22%3C%2FSPAN%3E%2C%20even%20it%20it%20not%20recommended!%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3Ebitbake%20virtual%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ekernel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ec%20compile%0Abitbake%20virtual%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ekernel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ec%20build%0Abitbake%20virtual%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ekernel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ec%20deploy%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%23000000%3B%22%3EThen%20reflash%20you%20board%20(kernel%20%2B%20rootfs%20as%20tests%20are%20.ko%20files)%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%23000000%3B%22%3EThen%20you%20can%20do%20more%20accurate%20performance%20test%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3Einsmod%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Elib%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Emodules%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E4.1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E29%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Efslc%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3Eg59b38c3%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ekernel%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edrivers%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Emtd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etests%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Emtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eko%20dev%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20MTD%20device%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20MTD%20device%20size%20%3CSPAN%20class%3D%22number%20token%22%3E16777216%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20eraseblock%20size%20%3CSPAN%20class%3D%22number%20token%22%3E131072%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20page%20size%20%3CSPAN%20class%3D%22number%20token%22%3E2048%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20count%20of%20eraseblocks%20%3CSPAN%20class%3D%22number%20token%22%3E128%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20pages%20per%20eraseblock%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20OOB%20size%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%0Amtd_test%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20scanning%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20bad%20eraseblocks%0Amtd_test%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20scanned%20%3CSPAN%20class%3D%22number%20token%22%3E128%3C%2FSPAN%3E%20eraseblocks%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%20are%20bad%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20eraseblock%20write%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20eraseblock%20write%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E4537%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20eraseblock%20read%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20eraseblock%20read%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E16384%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20page%20write%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20page%20write%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E4250%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20page%20read%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20page%20read%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E15784%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20page%20write%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20page%20write%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E4426%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20testing%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20page%20read%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20page%20read%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E16047%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E244537%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%202x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%202x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E252061%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%204x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%204x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E256000%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%208x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%208x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E260063%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%2016x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%2016x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E260063%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%2032x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%2032x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E256000%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Testing%2064x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%2064x%20multi%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eblock%20erase%20speed%20is%20%3CSPAN%20class%3D%22number%20token%22%3E260063%3C%2FSPAN%3E%20KiB%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Es%0Amtd_speedtest%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20finished%0A%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EYou%20can%20now%20achieve%20almost%2016MB%2Fs%2C%20better%20than%20the%20dd%20test.%20Of%20course%20you%20cannot%20achieve%20more%20than%2020MB%2Fs%2C%20but%20you%20are%20not%20that%20far%2C%20and%20the%20NAND%20driver%20need%20optimizations.%3C%2FP%3E%3CP%3ETo%20redo%20the%20test%3A%3C%2FP%3E%3CP%3Ermmod%20%2Flib%2Fmodules%2F4.1.29-fslc%2Bg59b38c3%2Fkernel%2Fdrivers%2Fmtd%2Ftests%2Fmtd_speedtest.ko%3CBR%20%2F%3Einsmod%20%2Flib%2Fmodules%2F4.1.29-fslc%2Bg59b38c3%2Fkernel%2Fdrivers%2Fmtd%2Ftests%2Fmtd_speedtest.ko%20dev%3D2%3C%2FP%3E%3CP%3ETo%20check%20your%20NAND%20is%20in%20EDO%20mode%205%2C%20you%20can%20check%20your%20clock%20tree%3A%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eunit_tests%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edump%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eclocks%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Esh%0Aclock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20parent%26nbsp%3B%26nbsp%3B%20flags%26nbsp%3B%26nbsp%3B%26nbsp%3B%20en_cnt%20pre_cnt%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rate%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%0Agpmi_bch_apb%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22operator%20token%22%3E--%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E00000005%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E198000000%3C%2FSPAN%3E%0Agpmi_bch%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22operator%20token%22%3E--%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E00000005%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E198000000%3C%2FSPAN%3E%0Agpmi_io%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22operator%20token%22%3E--%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E00000005%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E99000000%3C%2FSPAN%3E%0Agpmi_apb%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22operator%20token%22%3E--%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E00000005%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E198000000%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EThe%20IO%20are%20clocked%20now%20at%2099MHz%2C%20thus%20you%20can%20read%20at%2049.5MHz%20(20ns%20in%20EDO%20mode%205%20definition).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DualPlus6QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SoloX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Measure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fvincent.aubineau%22%20target%3D%22_blank%22%3Evincent.aubineau%3C%2FA%3E%E2%80%8C%2C%20Thanks!%20It's%20about%20block_size%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F88738i76ACB2E96E6732BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Measure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFor%20the%20dd%20command%2C%20I%20am%20pretty%20sure%20the%20%22bs%22%20argument%20(forced%20transfer%20size)%20is%20slowing%20down%20the%20transfer%2C%20see%20in%20this%20article%3A%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fblog.tdg5.com%2Ftuning-dd-block-size%2F%23targetText%3DReading%2520from%2520%252Fdev%252Fzero%2520and%2Cjust%2520north%2520of%252026%2520hours.%22%20title%3D%22http%3A%2F%2Fblog.tdg5.com%2Ftuning-dd-block-size%2F%23targetText%3DReading%2520from%2520%252Fdev%252Fzero%2520and%2Cjust%2520north%2520of%252026%2520hours.%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETuning%20dd%20block%20size%20-%20tdg5%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3ECan%20you%20please%20try%20a%20bigger%20one%20(200M%20for%20instance).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EV.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Measure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt's%20weird%20on%20our%20imx6d%20board%3A%20%3CSTRONG%3Edd%3C%2FSTRONG%3E%20is%20much%20slower%20than%20%3CSTRONG%3Emtd_speedtest%3C%2FSTRONG%3E%2C%20~3.5MB%2Fs%20vs%20~20MB%2Fs%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20803px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F83024i2964D4870FEA3E85%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F83548i6133C70EB6E65C7A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EP.S.%20EDO%20mode%20is%205%20is%20enabled%20by%20linux-imx%204.14.98%2C%26nbsp%3Bwithout%20modifying%20source%26nbsp%3Bcode.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20875px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F83655i444A879FC3FB42D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Measure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20in%20fact%20forced%20the%20NAND%20to%20be%20in%20EDO%20mode%205.%3C%2FP%3E%3CP%3EThere%20were%20a%20bug%20in%20the%20RAW%20NAND%2C%20supposed%20to%20support%20EDO%20mode%205%2C%20but%20the%20NAND%20did%20not%20answer%20that.%3C%2FP%3E%3CP%3EForcing%20EDO%20mode%205%20is%20dangerous%20if%20you%20change%20the%20NAND%20supplier%20during%20production%20lifetime.%3C%2FP%3E%3CP%3EI%20have%20enclosed%20my%20modified%20gpmi-lib.c%20in%20the%20main%20post%20(modification%20with%20NXA22167%20comments)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EV.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Measure%20(RAW)%20NAND%20flash%20performances%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHow%20did%20you%20remove%20the%20%22NAND%20back%20reading%20security%20check%22%3F%20Is%20there%20any%20side%20effects%20of%20removing%20it%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-10-2020 02:35 AM
Updated by:
