Window Covering Server Cluster
2,696 次查看
nguyenanhgiau10
Hi all,
I am developing a smart curtain device. It use Window Covering Server Cluster.
But I see something wrong with this cluster in "ZigBee Cluster Library Specification".
Window Covering Information Attribute Set and Window Covering Setting Attribute Set use the same attribute ID.
I think it should be:
Window Covering Information Attribute Set: 0x0000 - 0x000F
Window Covering Setting Attribute Set: 0x0010 - 0x001F
Can you explain it?
标记 (1)
2,610 次查看
nguyenanhgiau10
2,299 次查看
dmsherazi
Did you manage to add the Window Covering Server Cluster for NXP? I am trying to add it to our Gateway /Control Bridge. Can you let me know the steps to follow and possibly share the code that will help me?
2,610 次查看
mario_castaneda
Hi Giau.
The server attributes for the Windows Covering has an Attribute Set depending on the description that you want, in this case.
Hope it helps.
Mario
2,611 次查看
nguyenanhgiau10
Hi mario_castaneda
I got it.
Thanks!
