Suddenly getting File format not recognized error while compiling Zigbee Control Bridge
1,445 次查看
dmsherazi
Suddenly started getting this error while building the Zigbee Control bridget app Note
c:/nxp/mcuxpressoide_11.6.1_8255/ide/tools/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libm.a: file not recognized: file format not recognized
collect2.exe: error: ld returned 1 exit status
make: *** [Makefile:437: ../../Binaries/ControlBridge_Full_GpProxy_115200/ControlBridge_Full_GpProxy_115200.axf] Error 1
"make TRACE=0 NODE=FULL_FUNC_DEVICE GP_SUPPORT=1 BAUD=115200 -r all" terminated with exit code 2. Build might be incomplete.
Although the file does exist and seems to be a valid one
1,425 次查看
EduardoZamora
Hello @dmsherazi
Hope you are doing well.
Could you please help us with more details?
Which device are you using?
What is your SDK version?
Which version of the Control Bridge Application Note are you using? By any chance, have you modified the source code? Are you able to build the project with no modifications? Have you changed the path of the AN folder?
Eduardo.
