Freescale Cup Shield for the Freedom KL25Z
Overview
The FRDM-TFC is a convenient "shield" that can drive up to two DC motors (5A per channel), two servos and I/O for the Freescale cup line scan camera and Hall effect sensors.  This board mates with the KL25Z Freedom board for primary usage with a Freescale Cup car.
Features:
  • 2 channel Motor Driver ICs (MC33887APVW)
  • 2 channel servo Outputs
  • Dual Linescan Camera interfaces
  • Two inputs for speed sensors
  • Two potentiometers for user functions
  • Two push buttons for user functions
  • 4 Position DIP Switch for user function
  • 4 LEDs (green) for battery indicator or user functions
Design Files
Rev A is attached to this document.
Rev B is attached to this document
Code Examples
Codewarrior "Bare Metal" Example Code:
All Codewarrior based code examples for the FRDM-TFC are hosted on in a Subversion repository on Google Code:
frdm-tfc -   Example code for the FRDM-TFC Shield - Google Project Hosting
You can check out the code with your favorite SVN client.   Static releases are available in the attachments section of this page.  The current release is "R1.0"
mbed.org Example Code:
https://mbed.org/components/Freescale-Cup-with-FRDM-KL25Z/
Videos
FRDM TFC EXAMPLE CODE GETTING STARTED
FRDM-TFC_DEMO 0 and 1
FRDM-TFC_DEMO 2 and 3
附件
评论
thanks for your answers. We tryed to do this changes at the servo but unfortunately the servo doesnt rotates.
Maybe our processorsetup in the KDS or the wireing is not correct.
Can you tell us at the example of the servo what we have to change at the connections and at the code?
I'm sorry but we are very new at microcontrolers.
David
David:
I would suggest you 1st try to get the system working with the KL25Z board.   It is a known working configuration with working example code. If you are new to micro controllers, it will save you a lot of time.  Once you understand the initialization code for that platform, them move on.   Also, if you are using processor expert you may get stuck for awhile.  It is better to 1st understand how to program the timer units from scratch using the reference manual so you understand what operations you are doing.
Some resources:
1.)  https://community.freescale.com/docs/DOC-95170
2.)   Some have used the Kwikstik for the car.  It uses a K40 which has the same FTM unit as the K64.   That code may be helpful to you.
https://community.freescale.com/docs/DOC-1057
hello sir,
in NI Device drivers there are so many drivers so which drivers i need to install for the same problem
please help
Azaj Vahora
Hey ,
I have a big problem with mi FRDM KL25Z ...
I have made a lot of test and all were good ! i success to do several thing and now i am friend with the code and code warrior !
So i intent to make my own code to the CUP , using the camera in order to control the car BUT
during the execution of the program all the shiel froze totally ... and the moto are in FULL POWER !! in my code i put the LED blinking and it Froze also !! i have to press the reset button and it is good for some seconde and again it froze in full power ...
I take the time with a chronometer between the beginning and the Froze , and it depend of the number of execution in my loop ... 50 times and Froze !!
explanation : my code is :
main(){
while(1) {
     if( ticker[0] > T)
     ticker = 0
     instruction;
     instruction ;
So i notice that the car froze in full power when the code do 50 times the " if ticker ..... " .
so it go out of the while after 50*T ... and all the power of the motor a the maximum ...
A dont understand why ???!!! I really need help because in 1 big month there are the qualification EMEAa ...
More over the gears of the motor transmission was broken during the shield froze because of the full power in the motor .. Do you know where i can by a new ?
BEST , thanksss
LUCAS mAHIEU
PS : Sorry i am french and my english is not really good ...
Hello Lucas:
Let's start here...   Can you zip your test project where you said the LED was freezing?  I need to see the code in the context of your entire project.
Also,   what happens when you load the example/test code from this page:
https://community.freescale.com/docs/DOC-93914
thank a lot, but i fixed the problem ! it was the dynamic allocation the problem … I didn’t made the FREE …
but today a very BIZARRE thing happen … When i plug the FRDM KL25Z to send my program all is good the car do what i want ! , but when i unplug he usb cable the car do nothing … first i thought that it is the batterie , but it is full … and we saw that the board is VERY VERY VERY hot at the bottom !! near to the component with 3 pin in one side an 1 big pin in the other side … today it was the first time that we saw that !!
do you have an idea ?
Le 18 déc. 2014 à 13:56, Eli Hughes <admin@community.freescale.com> a écrit :
<https://community.freescale.com/> <https://community.freescale.com/>
new comment by Eli Hughes <https://community.freescale.com/people/eli_hughes?et=watches.email.document_comment> View all comments on this document <https://community.freescale.com/docs/DOC-93914?et=watches.email.document_comment#comment-15266>
Hello Lucas:
https://community.freescale.com/docs/DOC-93914 <https://community.freescale.com/docs/DOC-93914>
Reply to this email to respond to Eli Hughes's comment.
Following Freescale Cup Shield for the Freedom KL25Z <https://community.freescale.com/docs/DOC-93914?et=watches.email.document_comment#comment-15266> in these streams: Inbox
hello,
one of the features of the TFC is the H-bridge IFA\IFB. I ave few things that i didn't understand:
1. what are they use for?
2. they give us the feedback from the H-bridge of the PWM output? if yes, can we use them as speed sensors of the car?
3. is there a way to check the status of the battery with the KL25Z (the voltage of the battery)? if yes, how can we check it.
thank you for this examples!!!
1.)   Look in the MC33887APVW datasheet.    The are current feedback signals you could use for torque control on the motor.
2.)   Yes.  Look at the schematic and you will find your answer.
Hello, We participat to the Freeacale cup for the EMEA in 3 weeks.
But we have a big probleme ...
We have made our code on code warrior.
All was corect and the car did what we wanted ...
but suddenly the shield was very HOT and a litte connection burn on the FRDM-TFC !! betwen the pin 16 (J9) and the VBAT ... More over we try again with another shiel and we had the same problem and the R8 resistance burned to  ...
So we descided to take an other shiel (  new one ) and we try with a litte and simple program ! juste with the "chemillards". bat led in the main.c of heli huges in the quick start program at the begining all was good...
but after about 4 minutes the connection on the shield burn too ...
We are very disaponted because we don't find the probleme and we realy don't understand why we had not this problem a the begining when the car was eficient ...
thanks before !
all progrmag are running but in a flew time a connection burn ...
How Can I add speed sensor in my Car?
I am in India. Any store available in India to buy speed sensor
Hello Jawahar,
Check the videos for some reference. But you will have to acquire locally in any electronics store a Hall Effect Sensor. I suggest you to research on the Internet how they work. And depending on the package of the sensor, you can create your own case to be able to add it to the wheels on your car.
I have an issue with the speed sensor. I use the Kinetis FRDM-KL25Z. On the FRDM-TFC there are 3 pins for a speed sensor. But I do not know how to use. I looked at the sample code but there is nothing.
Do you have a code to exploit this sensor.
thank you
The sample code for a speed sensor was intentionally left out.  The speed sensor design is up to the student team as an exercise.  You will need to design your own and write the code.   There are many clues in this video:
See "Designing a Speed Sensor II & II" on this page
The Book of Eli - Microcontrollers, robotics and warp drives
Hello Mr. Hughes,
How can I manage to handle the SDA, the UART0 and the Speed Sensor on the same ports like wired on the TFC-shield. I have written an c-file and a header file for the speed sensor. My ISR did not start up in case of overflow or reaching the mod. value. Could there be a conflict  with the SDA or UART0?
MB
If you look at the schematics for the KL25Z and the FRDM_TFC,    you will see that the timers used for the speed sense cannot be used if you are also using the UART for the SDA.    IT is possible to change the uart function (which some jumper wires) to connect UART2 to the SDA interface.  I believe Daniel Hadad did this already.  There may be some instructions on the forum, I will look around.
thanks for the reply
How can I access the i/o ports on the board after attatching the shield to the FRDM-KL25Z ?
1.)   Solder leads to the terminals on the shield
2.)   Do a web search for an arduino shield that has a pass through connector and some protoyping area.
Hello Mr. Hughes,
for building a connection board between K64F an TFC Shield i need some information about the pin layout of the K64F. Unfortunately I cant find any information on which Pins the PTA10, PTA11, PTB12, PTB13, PTD5, PTD6, PTD7, PTE1 signals are available at the K64F. Can you please give me this information or some advice where it is written?
I also want to know for what the V_Batterie Signal on TFC Pin Jx9 is standing for and if it is necessary to connect this signal with the K64F Board.
Thank you very much,
David
When I turn the exposure time lower then 50 ms I receive some weird noise in the Lab View application that let's me see the signal from the video camera. There are random pikes in the signal that appear rapidly and disappear or the image is unstable is moving very fast up and down like it's "shivering" very fast. Any idea why ? This happens at low exposure time , below 50-45 ms .
with my team we would like to create a Rx connection on the car.
In the start package there is the code to the Tx with the UART but not the Rx.
One other words, we can receive information FROM the car but not to give information TO the car.
And the UART fils is VERY VERY difficult to understand for us... is it possible to receive help from somebody ?
Thanks a lot before
%3CLINGO-SUB%20id%3D%22lingo-sub-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Freedom%20KL25Z%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380609040%22%20id%3D%22toc-hId-1304187822%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1060667410%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1751228884%22%20target%3D%22_blank%22%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1863680042%22%20target%3D%22_blank%22%3E%E8%AE%BE%E8%AE%A1%E6%96%87%E4%BB%B6%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-623832791%22%20target%3D%22_blank%22%3E%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1183621672%22%20target%3D%22_blank%22%3EVideos%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--493060198%22%20target%3D%22_blank%22%3EFRDM%20TFC%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%85%A5%E9%97%A8%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1994452635%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%200%20%E5%92%8C%201%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--508165307%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%202%20%E5%92%8C%203%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1426845423%22%20id%3D%22toc-hId--503266641%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1060667410%22%20id%3D%22toc-hId-1984246192%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM-TFC%20%E6%98%AF%E4%B8%80%E4%B8%AA%E6%96%B9%E4%BE%BF%E7%9A%84%E2%80%9C%E5%B1%8F%E8%94%BD%E2%80%9D%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%A9%B1%E5%8A%A8%E6%9C%80%E5%A4%9A%E4%B8%A4%E4%B8%AA%E7%9B%B4%E6%B5%81%E7%94%B5%E6%9C%BA%EF%BC%88%E6%AF%8F%E9%80%9A%E9%81%93%205A%EF%BC%89%E3%80%81%E4%B8%A4%E4%B8%AA%E4%BC%BA%E6%9C%8D%E5%99%A8%E4%BB%A5%E5%8F%8A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E7%BA%BF%E6%89%AB%E6%8F%8F%E7%9B%B8%E6%9C%BA%E5%92%8C%E9%9C%8D%E5%B0%94%E6%95%88%E5%BA%94%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%20I%2FO%E3%80%82%E8%AF%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2FFRDM-KL25Z%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKL25Z%3C%2FA%3E%20Freedom%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%EF%BC%8C%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E8%B5%9B%E8%BD%A6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40270iD0A099A2D21084FC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-TFC.png%22%20alt%3D%22FRDM-TFC.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84347i98F4482AEB143621%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture%20004.jpg%22%20alt%3D%22Picture%20004.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751228884%22%20id%3D%22toc-hId--1620159630%22%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%8F%8C%E9%80%9A%E9%81%93%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E5%99%A8IC%EF%BC%88MC33887APVW%EF%BC%89%3C%2FLI%3E%3CLI%3E2%E9%80%9A%E9%81%93%E4%BC%BA%E6%9C%8D%E8%BE%93%E5%87%BA%3C%2FLI%3E%3CLI%3E%E5%8F%8C%E7%BA%BF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1058%22%20target%3D%22_blank%22%3E%E6%89%AB%E6%8F%8F%E7%9B%B8%E6%9C%BA%3C%2FA%3E%E6%8E%A5%E5%8F%A3%3C%2FLI%3E%3CLI%3E%E4%B8%A4%E4%B8%AA%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E8%BE%93%E5%85%A5%3C%2FLI%3E%3CLI%3E%E4%B8%A4%E4%B8%AA%E7%94%A8%E4%BA%8E%E7%94%A8%E6%88%B7%E5%8A%9F%E8%83%BD%E7%9A%84%E7%94%B5%E4%BD%8D%E5%99%A8%3C%2FLI%3E%3CLI%3E%E4%B8%A4%E4%B8%AA%E7%94%A8%E4%BA%8E%E7%94%A8%E6%88%B7%E5%8A%9F%E8%83%BD%E7%9A%84%E6%8C%89%E9%92%AE%3C%2FLI%3E%3CLI%3E4%20%E4%BD%8D%20DIP%20%E5%BC%80%E5%85%B3%EF%BC%8C%E7%94%A8%E4%BA%8E%E7%94%A8%E6%88%B7%E5%8A%9F%E8%83%BD%3C%2FLI%3E%3CLI%3E4%20%E4%B8%AA%20LED%EF%BC%88%E7%BB%BF%E8%89%B2%EF%BC%89%E7%94%A8%E4%BA%8E%E7%94%B5%E6%B1%A0%E6%8C%87%E7%A4%BA%E7%81%AF%E6%88%96%E7%94%A8%E6%88%B7%E5%8A%9F%E8%83%BD%3C%2FLI%3E%3C%2FUL%3E%3CH1%20id%3D%22toc-hId-1740725780%22%20id%3D%22toc-hId--1630662734%22%3E%3C%2FH1%3E%3CH2%20id%3D%22toc-hId--1863680042%22%20id%3D%22toc-hId--940101260%22%3E%E8%AE%BE%E8%AE%A1%E6%96%87%E4%BB%B6%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-254727%2FFRDM-TFC-REVA-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3E%E4%BF%AE%E8%AE%A2%E7%89%88%20A%20%E9%99%84%E4%BA%8E%E6%9C%AC%E6%96%87%E4%BB%B6%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-257650%2FFRDM-TFC-REVB-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3E%E4%BF%AE%E8%AE%A2%E7%89%88%20B%20%E9%99%84%E4%BA%8E%E6%9C%AC%E6%96%87%E4%BB%B6%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-623832791%22%20id%3D%22toc-hId-1547411573%22%3E%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3ECodewarrior%E2%80%9C%E8%A3%B8%E6%9C%BA%E2%80%9D%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%89%80%E6%9C%89%E5%9F%BA%E4%BA%8E%20Codewarrior%20%E7%9A%84%20FRDM-TFC%20%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E9%83%BD%E6%89%98%E7%AE%A1%E5%9C%A8%20Google%20Code%20%E4%B8%8A%E7%9A%84%20Subversion%20%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Efrdm-tfc%20-%20FRDM-TFC%20Shield%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%20-%20Google%20%E9%A1%B9%E7%9B%AE%E6%89%98%E7%AE%A1%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%82%A8%E6%9C%80%E5%96%9C%E6%AC%A2%E7%9A%84%20SVN%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%A3%80%E6%9F%A5%E4%BB%A3%E7%A0%81%E3%80%82%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-264428%2FFRDM-TFC_R1.0.zip%22%20target%3D%22_blank%22%3E%E9%9D%99%E6%80%81%E5%8F%91%E5%B8%83%E5%8F%AF%E5%9C%A8%E6%9C%AC%E9%A1%B5%E7%9A%84%E9%99%84%E4%BB%B6%E9%83%A8%E5%88%86%E6%89%BE%E5%88%B0%E3%80%82%3C%2FA%3E%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E6%98%AF%E2%80%9CR1.0%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Embed.org%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1183621672%22%20id%3D%22toc-hId--260042890%22%3EVideos%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--493060198%22%20id%3D%22toc-hId-430518584%22%3EFRDM%20TFC%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%85%A5%E9%97%A8%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FplL3U2MYLxk%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1994452635%22%20id%3D%22toc-hId--1376935879%22%3EFRDM-TFC_DEMO%200%20%E5%92%8C%201%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FxypYb2jfLPQ%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--508165307%22%20id%3D%22toc-hId-415413475%22%3EFRDM-TFC_DEMO%202%20%E5%92%8C%203%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FjE_5q8pqy9w%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E5%86%85%E5%AE%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%92%8C%E6%88%91%E7%9A%84%E5%9B%A2%E9%98%9F%E6%83%B3%E5%9C%A8%E6%B1%BD%E8%BD%A6%E4%B8%8A%E5%BB%BA%E7%AB%8B%20Rx%20%E8%BF%9E%E6%8E%A5%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%8C%85%E4%B8%AD%EF%BC%8C%E6%9C%89%E5%B8%A6%E6%9C%89%20UART%20%E7%9A%84%20Tx%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%20Rx%20%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%8D%A2%E5%8F%A5%E8%AF%9D%E8%AF%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%B1%BD%E8%BD%A6%E6%8E%A5%E6%94%B6%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E5%90%91%E6%B1%BD%E8%BD%A6%E6%8F%90%E4%BE%9B%E4%BF%A1%E6%81%AF%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%94%20UART%20%E6%96%87%E4%BB%B6%E5%AF%B9%E4%BA%8E%E6%88%91%E4%BB%AC%E6%9D%A5%E8%AF%B4%E9%9D%9E%E5%B8%B8%E9%9D%9E%E5%B8%B8%E9%9A%BE%E7%90%86%E8%A7%A3...%20%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%88%91%E5%B0%86%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%E8%B0%83%E4%BD%8E%E8%87%B3%2050%20%E6%AF%AB%E7%A7%92%E4%BB%A5%E4%B8%8B%E6%97%B6%EF%BC%8C%E6%88%91%E5%9C%A8%20Lab%20View%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%94%B6%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E5%A5%87%E6%80%AA%E7%9A%84%E5%99%AA%E9%9F%B3%EF%BC%8C%E8%AE%A9%E6%88%91%E7%9C%8B%E5%88%B0%E6%9D%A5%E8%87%AA%E6%91%84%E5%83%8F%E6%9C%BA%E7%9A%84%E4%BF%A1%E5%8F%B7%E3%80%82%E4%BF%A1%E5%8F%B7%E4%B8%AD%E5%AD%98%E5%9C%A8%E9%9A%8F%E6%9C%BA%E5%B0%96%E5%B3%B0%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%B0%96%E5%B3%B0%E4%BC%9A%E5%BF%AB%E9%80%9F%E5%87%BA%E7%8E%B0%E5%B9%B6%E6%B6%88%E5%A4%B1%EF%BC%8C%E6%88%96%E8%80%85%E5%9B%BE%E5%83%8F%E4%B8%8D%E7%A8%B3%E5%AE%9A%EF%BC%8C%E4%BC%9A%E5%BF%AB%E9%80%9F%E4%B8%8A%E4%B8%8B%E7%A7%BB%E5%8A%A8%EF%BC%8C%E5%B0%B1%E5%83%8F%E5%BF%AB%E9%80%9F%E2%80%9C%E9%A2%A4%E6%8A%96%E2%80%9D%E4%B8%80%E6%A0%B7%E3%80%82%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%E8%BF%99%E5%8F%91%E7%94%9F%E5%9C%A8%E6%9B%9D%E5%85%89%E6%97%B6%E9%97%B4%E8%BE%83%E7%9F%AD%EF%BC%88%E4%BD%8E%E4%BA%8E%2050-45%20%E6%AF%AB%E7%A7%92%EF%BC%89%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BC%91%E6%96%AF%E5%85%88%E7%94%9F%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%9C%A8%20K64F%20%E5%92%8C%20TFC%20Shield%20%E4%B9%8B%E9%97%B4%E6%9E%84%E5%BB%BA%E8%BF%9E%E6%8E%A5%E6%9D%BF%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%9C%89%E5%85%B3%20K64F%20%E5%BC%95%E8%84%9A%E5%B8%83%E5%B1%80%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E6%9C%89%E5%85%B3%20K64F%20%E4%B8%8A%E5%93%AA%E4%BA%9B%E5%BC%95%E8%84%9A%E5%8F%AF%E7%94%A8%20PTA10%E3%80%81PTA11%E3%80%81PTB12%E3%80%81PTB13%E3%80%81PTD5%E3%80%81PTD6%E3%80%81PTD7%E3%80%81PTE1%20%E4%BF%A1%E5%8F%B7%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BF%A1%E6%81%AF%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E6%8F%90%E4%BE%9B%E6%AD%A4%E4%BF%A1%E6%81%AF%E6%88%96%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%83%B3%E7%9F%A5%E9%81%93%20TFC%20Pin%20Jx9%20%E4%B8%8A%E7%9A%84%20V_Batterie%20%E4%BF%A1%E5%8F%B7%E4%BB%A3%E8%A1%A8%E4%BB%80%E4%B9%88%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%98%AF%E5%90%A6%E6%9C%89%E5%BF%85%E8%A6%81%E5%B0%86%E6%AD%A4%E4%BF%A1%E5%8F%B7%E4%B8%8E%20K64F%20%E6%9D%BF%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.)%20%E5%B0%86%E5%AF%BC%E7%BA%BF%E7%84%8A%E6%8E%A5%E5%88%B0%E5%B1%8F%E8%94%BD%E5%B1%82%E4%B8%8A%E7%9A%84%E7%AB%AF%E5%AD%90%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E5%9C%A8%E7%BD%91%E4%B8%8A%E6%90%9C%E7%B4%A2%E5%85%B7%E6%9C%89%E7%9B%B4%E9%80%9A%E8%BF%9E%E6%8E%A5%E5%99%A8%E5%92%8C%E4%B8%80%E4%BA%9B%E5%8E%9F%E5%9E%8B%E5%8C%BA%E5%9F%9F%E7%9A%84%20arduino%20%E5%B1%8F%E8%94%BD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%86%E5%B1%8F%E8%94%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20FRDM-KL25Z%20%E5%90%8E%EF%BC%8C%E5%A6%82%E4%BD%95%E8%AE%BF%E9%97%AE%E6%9D%BF%E4%B8%8A%E7%9A%84%20I%2FO%20%E7%AB%AF%E5%8F%A3%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9F%A5%E7%9C%8B%20KL25Z%20%E5%92%8C%20FRDM_TFC%20%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%8C%E6%82%A8%E4%BC%9A%E5%8F%91%E7%8E%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E8%BF%98%E5%B0%86%20UART%20%E7%94%A8%E4%BA%8E%20SDA%EF%BC%8C%E5%88%99%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E7%94%A8%E4%BA%8E%E9%80%9F%E5%BA%A6%E6%84%9F%E5%BA%94%E7%9A%84%E8%AE%A1%E6%97%B6%E5%99%A8%E3%80%82%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%94%B9%20uart%20%E5%8A%9F%E8%83%BD%EF%BC%88%E4%B8%80%E4%BA%9B%E8%B7%B3%E7%BA%BF%EF%BC%89%E4%BB%A5%E5%B0%86%20UART2%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20SDA%20%E6%8E%A5%E5%8F%A3%E3%80%82%E6%88%91%E7%9B%B8%E4%BF%A1%20Daniel%20Hadad%20%E5%B7%B2%E7%BB%8F%E8%BF%99%E6%A0%B7%E5%81%9A%E4%BA%86%E3%80%82%E8%AE%BA%E5%9D%9B%E4%B8%8A%E5%8F%AF%E8%83%BD%E6%9C%89%E4%B8%80%E4%BA%9B%E8%AF%B4%E6%98%8E%EF%BC%8C%E6%88%91%E4%BC%9A%E6%9F%A5%E7%9C%8B%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BC%91%E6%96%AF%E5%85%88%E7%94%9F%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E8%AE%BE%E6%B3%95%E5%9C%A8%E4%B8%8E%20TFC-shield%20%E4%B8%8A%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%9B%B8%E5%90%8C%E7%AB%AF%E5%8F%A3%E4%B8%8A%E5%A4%84%E7%90%86%20SDA%E3%80%81UART0%20%E5%92%8C%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%BA%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%BC%96%E5%86%99%E4%BA%86%E4%B8%80%E4%B8%AA%20c%20%E6%96%87%E4%BB%B6%E5%92%8C%E4%B8%80%E4%B8%AA%E5%A4%B4%E6%96%87%E4%BB%B6%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%91%E7%94%9F%E6%BA%A2%E5%87%BA%E6%88%96%E5%88%B0%E8%BE%BE%E6%A8%A1%E5%9D%97%EF%BC%8C%E6%88%91%E7%9A%84%20ISR%20%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%90%AF%E5%8A%A8%E3%80%82%E4%BB%B7%E5%80%BC%E3%80%82%E6%98%AF%E5%90%A6%E4%BC%9A%E4%B8%8E%20SDA%20%E6%88%96%20UART0%20%E5%8F%91%E7%94%9F%E5%86%B2%E7%AA%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EMB%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E8%A2%AB%E6%95%85%E6%84%8F%E7%9C%81%E7%95%A5%E4%BA%86%E3%80%82%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E8%AE%BE%E8%AE%A1%E7%94%B1%E5%AD%A6%E7%94%9F%E5%9B%A2%E9%98%9F%E4%BD%9C%E4%B8%BA%E7%BB%83%E4%B9%A0%E6%9D%A5%E5%AE%8C%E6%88%90%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E8%AE%BE%E8%AE%A1%E8%87%AA%E5%B7%B1%E7%9A%84%E5%B9%B6%E7%BC%96%E5%86%99%E4%BB%A3%E7%A0%81%E3%80%82%E8%BF%99%E6%AE%B5%E8%A7%86%E9%A2%91%E9%87%8C%E6%9C%89%E5%BE%88%E5%A4%9A%E7%BA%BF%E7%B4%A2%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E9%A1%B5%E7%9A%84%E2%80%9C%E8%AE%BE%E8%AE%A1%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%20II%20%26amp%3B%20II%E2%80%9D%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3E%E3%80%8A%E8%89%BE%E5%88%A9%E4%B9%8B%E4%B9%A6%E3%80%8B%E2%80%94%E2%80%94%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%81%E6%9C%BA%E5%99%A8%E4%BA%BA%E5%92%8C%E6%9B%B2%E9%80%9F%E5%BC%95%E6%93%8E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E8%A2%AB%E6%95%85%E6%84%8F%E7%9C%81%E7%95%A5%E4%BA%86%E3%80%82%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E8%AE%BE%E8%AE%A1%E7%94%B1%E5%AD%A6%E7%94%9F%E5%9B%A2%E9%98%9F%E4%BD%9C%E4%B8%BA%E7%BB%83%E4%B9%A0%E6%9D%A5%E5%AE%8C%E6%88%90%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E8%AE%BE%E8%AE%A1%E8%87%AA%E5%B7%B1%E7%9A%84%E5%B9%B6%E7%BC%96%E5%86%99%E4%BB%A3%E7%A0%81%E3%80%82%E8%BF%99%E6%AE%B5%E8%A7%86%E9%A2%91%E9%87%8C%E6%9C%89%E5%BE%88%E5%A4%9A%E7%BA%BF%E7%B4%A2%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E9%A1%B5%E7%9A%84%E2%80%9C%E8%AE%BE%E8%AE%A1%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%20II%20%26amp%3B%20II%E2%80%9D%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3E%E3%80%8A%E8%89%BE%E5%88%A9%E4%B9%8B%E4%B9%A6%E3%80%8B%E2%80%94%E2%80%94%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%81%E6%9C%BA%E5%99%A8%E4%BA%BA%E5%92%8C%E6%9B%B2%E9%80%9F%E5%BC%95%E6%93%8E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%E6%88%91%E7%9A%84%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%87%BA%E4%BA%86%E7%82%B9%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%94%A8%E7%9A%84%E6%98%AFKinetis%20FRDM-KL25Z%E3%80%82FRDM-TFC%E4%B8%8A%E6%9C%893%E4%B8%AA%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%BC%95%E8%84%9A%E3%80%82%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BD%86%E6%88%91%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B8%8D%E7%9F%A5%E9%81%93%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%80%8E%E4%B9%88%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%88%91%E7%9C%8B%E4%BA%86%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BD%86%E4%BB%80%E4%B9%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B9%9F%E6%B2%A1%E6%89%BE%E5%88%B0%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22hps%22%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E5%88%A9%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E8%AF%A5%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E8%B0%A2%E8%B0%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CJawahar%EF%BC%8C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9F%A5%E7%9C%8B%E8%A7%86%E9%A2%91%E4%BB%A5%E8%8E%B7%E5%8F%96%E4%B8%80%E4%BA%9B%E5%8F%82%E8%80%83%E3%80%82%E4%BD%86%E6%98%AF%E6%82%A8%E5%BF%85%E9%A1%BB%E5%9C%A8%E5%BD%93%E5%9C%B0%E7%9A%84%E4%BB%BB%E4%BD%95%E7%94%B5%E5%AD%90%E4%BA%A7%E5%93%81%E5%95%86%E5%BA%97%E8%B4%AD%E4%B9%B0%E9%9C%8D%E5%B0%94%E6%95%88%E5%BA%94%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%9C%A8%E4%BA%92%E8%81%94%E7%BD%91%E4%B8%8A%E7%A0%94%E7%A9%B6%E4%B8%80%E4%B8%8B%E5%AE%83%E4%BB%AC%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%E3%80%82%E6%A0%B9%E6%8D%AE%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E5%8C%85%E8%A3%85%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E5%A4%96%E5%A3%B3%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%B1%BD%E8%BD%A6%E7%9A%84%E8%BD%A6%E8%BD%AE%E4%B8%8A%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E6%88%91%E7%9A%84%E6%B1%BD%E8%BD%A6%E4%B8%8A%E6%B7%BB%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%8D%B0%E5%BA%A6%E3%80%82%E5%8D%B0%E5%BA%A6%E6%9C%89%E5%93%AA%E5%AE%B6%E5%95%86%E5%BA%97%E5%8F%AF%E4%BB%A5%E4%B9%B0%E5%88%B0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E6%9C%89%E7%A8%8B%E5%BA%8F%E9%83%BD%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%BE%88%E5%BF%AB%E8%BF%9E%E6%8E%A5%E5%B0%B1%E7%83%A7%E6%AF%81%E4%BA%86......%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E5%8F%82%E5%8A%A0%E4%B8%89%E5%91%A8%E5%90%8E%E4%B8%BE%E8%A1%8C%E7%9A%84%20EMEA%20%E9%A3%9E%E5%88%A9%E6%B5%A6%E6%9D%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%BD%86%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%80%E4%B8%AA%E5%A4%A7%E9%97%AE%E9%A2%98......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%BB%A3%E7%A0%81%E6%88%98%E5%A3%AB%E4%B8%8A%E7%BC%96%E5%86%99%E4%BA%86%E6%88%91%E4%BB%AC%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%B8%80%E5%88%87%E9%83%BD%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%B1%BD%E8%BD%A6%E6%8C%89%E7%85%A7%E6%88%91%E4%BB%AC%E7%9A%84%E8%A6%81%E6%B1%82%E8%BF%90%E8%A1%8C%E2%80%A6%E2%80%A6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%BD%86%E7%AA%81%E7%84%B6%E9%97%B4%E5%B1%8F%E8%94%BD%E5%8F%98%E5%BE%97%E9%9D%9E%E5%B8%B8%E7%83%AD%EF%BC%8C%E5%B9%B6%E4%B8%94%20FRDM-TFC%20%E4%B8%8A%E7%9A%84%E4%B8%80%E7%82%B9%E8%BF%9E%E6%8E%A5%E7%83%A7%E6%AF%81%E4%BA%86%EF%BC%81%E4%BD%8D%E4%BA%8E%E5%BC%95%E8%84%9A%2016%EF%BC%88J9%EF%BC%89%E5%92%8C%20VBAT%20%E4%B9%8B%E9%97%B4%E2%80%A6%E2%80%A6%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E4%BB%AC%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%B1%8F%E8%94%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E4%B8%94%20R8%20%E7%94%B5%E9%98%BB%E7%83%A7%E6%AF%81%E4%BA%86......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%AC%E5%86%B3%E5%AE%9A%E6%8D%A2%E4%B8%80%E4%B8%AA%E7%9B%BE%E7%89%8C%EF%BC%88%E6%96%B0%E7%9A%84%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%9D%E8%AF%95%E7%94%A8%E4%B8%80%E4%B8%AA%E5%B0%8F%E8%80%8C%E7%AE%80%E5%8D%95%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%81%E5%8F%AA%E9%9C%80%E7%94%A8%E2%80%9Cchemillards%E2%80%9D%E5%8D%B3%E5%8F%AF%E3%80%82%E5%9C%A8%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E5%9C%A8%20heli%20huges%20%E7%9A%84%20main.c%20%E4%B8%AD%E8%BF%90%E8%A1%8C%20bat%EF%BC%8C%E4%B8%80%E5%BC%80%E5%A7%8B%E4%B8%80%E5%88%87%E9%83%BD%E5%BE%88%E5%A5%BD%E2%80%A6%E2%80%A6%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%BD%86%E5%A4%A7%E7%BA%A6%204%20%E5%88%86%E9%92%9F%E5%90%8E%EF%BC%8C%E5%B1%8F%E8%94%BD%E5%B1%82%E4%B8%8A%E7%9A%84%E8%BF%9E%E6%8E%A5%E4%B9%9F%E7%83%A7%E6%AF%81%E4%BA%86%E2%80%A6%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E4%BB%AC%E9%9D%9E%E5%B8%B8%E5%A4%B1%E6%9C%9B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9C%9F%E7%9A%84%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%80%E5%BC%80%E5%A7%8B%E6%B1%BD%E8%BD%A6%E6%95%88%E7%8E%87%E5%BE%88%E9%AB%98%E6%97%B6%E5%8D%B4%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98......%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.)%20%E6%9F%A5%E7%9C%8B%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMC33887APVW%20%E6%95%B0%E6%8D%AE%E8%A1%A8%E3%80%82%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E5%8F%AF%E7%94%A8%E4%BA%8E%E7%94%B5%E6%9C%BA%E6%89%AD%E7%9F%A9%E6%8E%A7%E5%88%B6%E7%9A%84%E7%94%B5%E6%B5%81%E5%8F%8D%E9%A6%88%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E6%98%AF%E7%9A%84%E3%80%82%E7%9C%8B%E4%B8%80%E4%B8%8B%E7%A4%BA%E6%84%8F%E5%9B%BE%E4%BD%A0%E5%B0%B1%E4%BC%9A%E6%89%BE%E5%88%B0%E7%AD%94%E6%A1%88%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETFC%20%E7%9A%84%E7%89%B9%E7%82%B9%E4%B9%8B%E4%B8%80%E6%98%AF%20H%20%E6%A1%A5%20IFA%5CIFB%E3%80%82%E6%88%91%E6%9C%89%E5%87%A0%E4%BB%B6%E4%BA%8B%E4%B8%8D%E6%98%8E%E7%99%BD%EF%BC%9A%3CBR%20%2F%3E%201.%20%E5%AE%83%E4%BB%AC%E6%9C%89%E4%BB%80%E4%B9%88%E7%94%A8%E9%80%94%EF%BC%9F%3C%2FP%3E%3CP%3E2.%20%E5%AE%83%E4%BB%AC%E8%83%BD%E7%BB%99%E6%88%91%E4%BB%AC%20PWM%20%E8%BE%93%E5%87%BA%E7%9A%84%20H%20%E6%A1%A5%E7%9A%84%E5%8F%8D%E9%A6%88%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AE%83%E4%BB%AC%E7%94%A8%E4%BD%9C%E6%B1%BD%E8%BD%A6%E7%9A%84%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E7%94%A8KL25Z%E6%A3%80%E6%9F%A5%E7%94%B5%E6%B1%A0%E7%9A%84%E7%8A%B6%E6%80%81%EF%BC%88%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%EF%BC%89%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BA%9B%E4%BE%8B%E5%AD%90%EF%BC%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E4%B8%8D%E8%BF%87%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%81%E6%98%AF%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E7%9A%84%E9%97%AE%E9%A2%98%E2%80%A6%E2%80%A6%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20FREE%E2%80%A6%E2%80%A6%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E4%BB%8A%E5%A4%A9%E5%8F%91%E7%94%9F%E4%BA%86%E4%B8%80%E4%BB%B6%E9%9D%9E%E5%B8%B8%E5%A5%87%E6%80%AA%E7%9A%84%E4%BA%8B%E6%83%85......%E5%BD%93%E6%88%91%E6%8F%92%E5%85%A5%20FRDM%20KL25Z%20%E5%8F%91%E9%80%81%E6%88%91%E7%9A%84%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E9%83%BD%E5%BE%88%E5%A5%BD%EF%BC%8C%E6%B1%BD%E8%BD%A6%E6%8C%89%E7%85%A7%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E6%96%B9%E5%BC%8F%E8%BF%90%E8%A1%8C%EF%BC%81%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E6%8B%94%E6%8E%89%20USB%20%E7%BA%BF%E6%97%B6%EF%BC%8C%E6%B1%BD%E8%BD%A6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%8D%E5%BA%94%E2%80%A6%E2%80%A6%E4%B8%80%E5%BC%80%E5%A7%8B%E6%88%91%E4%BB%A5%E4%B8%BA%E6%98%AF%E7%94%B5%E6%B1%A0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E7%94%B5%E6%B1%A0%E5%B7%B2%E7%BB%8F%E6%BB%A1%E4%BA%86%E2%80%A6%E2%80%A6%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%BA%95%E9%83%A8%E9%9D%9E%E5%B8%B8%E9%9D%9E%E5%B8%B8%E7%83%AD%EF%BC%81%EF%BC%81%E9%9D%A0%E8%BF%91%E7%BB%84%E4%BB%B6%E7%9A%84%E5%9C%B0%E6%96%B9%EF%BC%8C%E4%B8%80%E4%BE%A7%E6%9C%89%203%20%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%BE%A7%E6%9C%89%201%20%E4%B8%AA%E5%A4%A7%E5%BC%95%E8%84%9A%E2%80%A6%E2%80%A6%E4%BB%8A%E5%A4%A9%E6%88%91%E4%BB%AC%E7%AC%AC%E4%B8%80%E6%AC%A1%E7%9C%8B%E5%88%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%81%EF%BC%81%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E4%B8%BB%E6%84%8F%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3ELe%2018%20d%C3%A9c.%202014%20%C3%A0%2013%3A56%2C%20Eli%20Hughes%20%3CADMIN%3E%20a%20%C3%A9crit%20%3A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Freedom%20KL25Z%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%3C%2FP%3E%3CP%3EEli%20Hughes%20%E7%9A%84%E6%96%B0%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%E6%9F%A5%E7%9C%8B%E6%AD%A4%E6%96%87%E6%A1%A3%E7%9A%84%E6%89%80%E6%9C%89%E8%AF%84%E8%AE%BA%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E4%BB%8E%E8%BF%99%E9%87%8C%E5%BC%80%E5%A7%8B...%E6%82%A8%E8%83%BD%E5%8E%8B%E7%BC%A9%E4%B8%80%E4%B8%8B%E6%82%A8%E6%89%80%E8%AF%B4%E7%9A%84%20LED%20%E5%86%BB%E7%BB%93%E7%9A%84%E6%B5%8B%E8%AF%95%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%83%8C%E6%99%AF%E4%B8%8B%E6%9F%A5%E7%9C%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%82%A8%E4%BB%8E%E6%AD%A4%E9%A1%B5%E9%9D%A2%E5%8A%A0%E8%BD%BD%E7%A4%BA%E4%BE%8B%2F%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%E6%97%B6%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E5%9B%9E%E5%A4%8D%E6%AD%A4%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E4%BB%A5%E5%9B%9E%E5%BA%94%20Eli%20Hughes%20%E7%9A%84%E8%AF%84%E8%AE%BA%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E6%B3%A8%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%20%26lt%3B%26gt%3B%20%E5%85%B3%E6%B3%A8%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%E6%B5%81%EF%BC%9A%E6%94%B6%E4%BB%B6%E7%AE%B1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E4%BB%8E%E8%BF%99%E9%87%8C%E5%BC%80%E5%A7%8B...%E6%82%A8%E8%83%BD%E5%8E%8B%E7%BC%A9%E4%B8%80%E4%B8%8B%E6%82%A8%E6%89%80%E8%AF%B4%E7%9A%84%20LED%20%E5%86%BB%E7%BB%93%E7%9A%84%E6%B5%8B%E8%AF%95%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%83%8C%E6%99%AF%E4%B8%8B%E6%9F%A5%E7%9C%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%82%A8%E4%BB%8E%E6%AD%A4%E9%A1%B5%E9%9D%A2%E5%8A%A0%E8%BD%BD%E7%A4%BA%E4%BE%8B%2F%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%E6%97%B6%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%EF%BC%9A%3C%2FP%3E%3CP%3E%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222003%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293914%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%98%BF%20%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20FRDM%20KL25Z%20%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%A4%A7%E9%97%AE%E9%A2%98......%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%81%9A%E4%BA%86%E5%BE%88%E5%A4%9A%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%BB%93%E6%9E%9C%E9%83%BD%E5%BE%88%E5%A5%BD%EF%BC%81%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%B0%E5%81%9A%E4%BA%86%E5%87%A0%E4%BB%B6%E4%BA%8B%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E5%92%8C%E4%BB%A3%E7%A0%81%E5%92%8C%E4%BB%A3%E7%A0%81%E6%88%98%E5%A3%AB%E6%88%90%E4%BA%86%E6%9C%8B%E5%8F%8B%EF%BC%81%20%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E6%89%93%E7%AE%97%E4%B8%BA%20CUP%20%E7%BC%96%E5%86%99%E8%87%AA%E5%B7%B1%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%BF%E7%94%A8%E6%91%84%E5%83%8F%E5%A4%B4%E6%9D%A5%E6%8E%A7%E5%88%B6%E6%B1%BD%E8%BD%A6%EF%BC%8C%E4%BD%86%E6%98%AF%20%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%A8%8B%E5%BA%8F%E6%89%A7%E8%A1%8C%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%89%80%E6%9C%89%E5%B1%8F%E8%94%BD%E9%83%BD%E5%AE%8C%E5%85%A8%E5%86%BB%E7%BB%93%E4%BA%86%E2%80%A6%E2%80%A6%E8%80%8Cmoto%E5%A4%84%E4%BA%8E%E5%85%A8%E5%8A%9F%E7%8E%87%E7%8A%B6%E6%80%81%EF%BC%81%E5%9C%A8%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E6%88%91%E8%AE%A9LED%E9%97%AA%E7%83%81%EF%BC%8C%E5%AE%83%E4%B9%9F%E5%86%BB%E7%BB%93%E4%BA%86%EF%BC%81%E6%88%91%E5%BF%85%E9%A1%BB%E6%8C%89%E4%B8%8B%E9%87%8D%E7%BD%AE%E6%8C%89%E9%92%AE%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%A5%BD%E5%87%A0%E7%A7%92%E9%92%9F%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%83%E5%86%8D%E6%AC%A1%E4%BB%A5%E5%85%A8%E5%8A%9F%E7%8E%87%E5%86%BB%E7%BB%93%E2%80%A6%E2%80%A6%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E6%B5%8B%E9%87%8F%E4%BB%8E%E5%BC%80%E5%A7%8B%E5%88%B0%E5%86%BB%E7%BB%93%E4%B9%8B%E9%97%B4%E7%9A%84%E6%97%B6%E9%97%B4%EF%BC%8C%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E5%BE%AA%E7%8E%AF%E4%B8%AD%E7%9A%84%E6%89%A7%E8%A1%8C%E6%AC%A1%E6%95%B0......%2050%20%E6%AC%A1%E7%84%B6%E5%90%8E%E5%86%BB%E7%BB%93%EF%BC%81%EF%BC%81%20%3C%2FP%3E%3CP%3E%E8%A7%A3%E9%87%8A%EF%BC%9A%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E6%98%AF%EF%BC%9A%20%3C%2FP%3E%3CP%3Emain()%7B%3C%2FP%3E%3CP%3Ewhile(1)%7B%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%EF%BC%88%E8%82%A1%E7%A5%A8%E4%BB%A3%E7%A0%81%5B0%5D%20%26gt%3B%20T%EF%BC%89%3C%2FP%3E%3CP%3E%E8%82%A1%E7%A5%A8%E4%BB%A3%E7%A0%81%20%3D%200%3C%2FP%3E%3CP%3E%E6%93%8D%E4%BD%9C%E8%AF%B4%E6%98%8E%3B%20%3C%2FP%3E%3CP%3E%E6%93%8D%E4%BD%9C%E8%AF%B4%E6%98%8E%20%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%E4%BB%A3%E7%A0%81%E6%89%A7%E8%A1%8C%2050%20%E6%AC%A1%E2%80%9Cif%20ticker%20.....%E2%80%9D%E6%97%B6%EF%BC%8C%E6%B1%BD%E8%BD%A6%E4%BC%9A%E5%85%A8%E9%80%9F%E5%86%BB%E7%BB%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E5%AE%83%E5%9C%A8%2050*T%20%E4%B9%8B%E5%90%8E%E5%B0%B1%E6%B6%88%E5%A4%B1%E4%BA%86...%E5%B9%B6%E4%B8%94%E6%89%80%E6%9C%89%E7%94%B5%E6%9C%BA%E7%9A%84%E5%8A%9F%E7%8E%87%E9%83%BD%E8%BE%BE%E5%88%B0%E6%9C%80%E5%A4%A7%E5%80%BC...%20%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%3F%3F%3F!!!%E6%88%91%E7%9C%9F%E7%9A%84%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E4%B8%80%E4%B8%AA%E6%9C%88%E5%86%85%E5%B0%B1%E6%9C%89%20EMEA%20%E8%B5%84%E6%A0%BC%E8%AE%A4%E8%AF%81......%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%80%8C%E4%B8%94%EF%BC%8C%E7%94%B1%E4%BA%8E%E7%94%B5%E6%9C%BA%E5%8A%9F%E7%8E%87%E8%BF%87%E5%A4%A7%EF%BC%8C%E5%9C%A8%E5%B1%8F%E8%94%BD%E5%86%BB%E7%BB%93%E6%9C%9F%E9%97%B4%EF%BC%8C%E7%94%B5%E6%9C%BA%E4%BC%A0%E5%8A%A8%E8%A3%85%E7%BD%AE%E7%9A%84%E9%BD%BF%E8%BD%AE%E8%A2%AB%E6%8D%9F%E5%9D%8F%E4%BA%86%E3%80%82%E6%82%A8%E7%9F%A5%E9%81%93%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E4%B9%B0%E5%88%B0%E6%96%B0%E7%9A%84%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8D%A2%E5%8D%A1%E6%96%AF%C2%B7%E9%A9%AC%E4%BC%91%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%99%84%E8%A8%80%EF%BC%9A%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%98%AF%E6%B3%95%E5%9B%BD%E4%BA%BA%EF%BC%8C%E6%88%91%E7%9A%84%E8%8B%B1%E8%AF%AD%E4%B8%8D%E6%98%AF%E5%BE%88%E5%A5%BD%E2%80%A6%E2%80%A6%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E5%85%88%E7%94%9F%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9C%A8%20NI%20%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%9C%89%E5%BE%88%E5%A4%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E5%93%AA%E4%BA%9B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9D%A5%E8%A7%A3%E5%86%B3%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAzaj%20Vahora%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDavid%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E9%A6%96%E5%85%88%E5%B0%9D%E8%AF%95%E8%AE%A9%E7%B3%BB%E7%BB%9F%E4%B8%8E%20KL25Z%20%E6%9D%BF%E4%B8%80%E8%B5%B7%E5%B7%A5%E4%BD%9C%E3%80%82%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E7%9A%84%E5%B7%A5%E4%BD%9C%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%B8%A6%E6%9C%89%E5%B7%A5%E4%BD%9C%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E7%86%9F%E6%82%89%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E5%AE%83%E5%B0%86%E4%B8%BA%E6%82%A8%E8%8A%82%E7%9C%81%E5%A4%A7%E9%87%8F%E6%97%B6%E9%97%B4%E3%80%82%E4%B8%80%E6%97%A6%E6%82%A8%E4%BA%86%E8%A7%A3%E4%BA%86%E8%AF%A5%E5%B9%B3%E5%8F%B0%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E5%89%8D%E8%BF%9B%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E9%99%B7%E5%85%A5%E5%9B%B0%E5%A2%83%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%E3%80%82%E6%9C%80%E5%A5%BD%E9%A6%96%E5%85%88%E4%BD%BF%E7%94%A8%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E5%AF%B9%E8%AE%A1%E6%97%B6%E5%99%A8%E5%8D%95%E5%85%83%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%82%A8%E4%BA%86%E8%A7%A3%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%93%8D%E4%BD%9C%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E4%BA%9B%E8%B5%84%E6%BA%90%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%EF%BC%89%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E6%9C%89%E4%BA%9B%E4%BA%BA%E5%B0%86%20Kwikstik%20%E7%94%A8%E4%BA%8E%E6%B1%BD%E8%BD%A6%E3%80%82%E5%AE%83%E4%BD%BF%E7%94%A8%E5%85%B7%E6%9C%89%E4%B8%8E%20K64%20%E7%9B%B8%E5%90%8C%20FTM%20%E5%8D%95%E5%85%83%E7%9A%84%20K40%E3%80%82%E8%AF%A5%E4%BB%A3%E7%A0%81%E5%8F%AF%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1057%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E5%9C%A8%E4%BC%BA%E6%9C%8D%E5%99%A8%E4%B8%8A%E8%BF%9B%E8%A1%8C%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E4%BC%BA%E6%9C%8D%E5%99%A8%E6%B2%A1%E6%9C%89%E6%97%8B%E8%BD%AC%E3%80%82%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E4%BB%AC%E7%9A%84%20KDS%20%E4%B8%AD%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%E6%88%96%E6%8E%A5%E7%BA%BF%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E4%BB%A5%E4%BC%BA%E6%9C%8D%E5%99%A8%E4%B8%BA%E4%BE%8B%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%92%8C%E4%BB%A3%E7%A0%81%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%AF%B9%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E8%BF%98%E5%BE%88%E9%99%8C%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8A%8A%E5%AE%83%E6%8E%A5%E5%A5%BD%E7%BA%BF%E4%BA%86%EF%BC%8C%E6%83%85%E5%86%B5%E8%BF%98%E5%A5%BD%E3%80%82%E4%B8%80%E4%BA%9B%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A1%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%20FRDM%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20I%2FO%20%E9%80%89%E6%8B%A9%E5%9F%BA%E4%BA%8E%20TPM%EF%BC%88%E5%AE%9A%E6%97%B6%E5%99%A8%E8%84%89%E5%86%B2%E5%AE%BD%E5%BA%A6%E8%B0%83%E5%88%B6%E5%99%A8%EF%BC%89%E7%9A%84%E5%8F%AF%E7%94%A8%E6%80%A7%EF%BC%8C%E4%BB%A5%E4%BC%98%E5%8C%96%E7%A1%AC%E4%BB%B6%E7%9A%84%E4%BD%BF%E7%94%A8%E3%80%82%E5%AE%83%E6%B2%A1%E6%9C%89%E6%98%A0%E5%B0%84%E5%88%B0%20Arduino%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%BC%AA%E6%A0%87%E5%87%86%E5%BC%95%E8%84%9A%E6%8E%92%E5%88%97%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8%20FRDM%20%E6%9D%BF%E6%9D%A5%E8%AF%B4%E5%B9%B6%E4%B8%8D%E7%90%86%E6%83%B3%E3%80%82Arduino%20%E5%85%BC%E5%AE%B9%E6%80%A7%E5%AE%9E%E9%99%85%E4%B8%8A%E4%BB%85%E6%84%8F%E5%91%B3%E7%9D%80%E7%94%B5%E6%BA%90%E5%92%8C%E4%B8%80%E4%BA%9B%20I%2FO%20%E6%8E%92%E5%88%97%E4%BB%A5%E5%8F%8A%E6%BB%A1%E8%B6%B3%E6%9C%BA%E6%A2%B0%E5%8D%A0%E5%9C%B0%E9%9D%A2%E7%A7%AF%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20TPM0%EF%BC%88%E5%9C%A8%E7%94%B5%E5%AD%90%E8%A1%A8%E6%A0%BC%E4%B8%AD%E6%A0%87%E8%AE%B0%E4%B8%BA%20FTM0%EF%BC%89%E6%98%AF%E7%9B%B4%E6%B5%81%E7%94%B5%E6%9C%BA%20PWM%20%E7%9A%84%E6%97%B6%E9%97%B4%E5%9F%BA%E5%87%86%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E4%BA%92%E8%A1%A5%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%E5%90%8C%E4%B8%80%E6%97%B6%E9%97%B4%E5%9F%BA%E5%87%86%E4%B8%8A%E7%9A%84%202%20%E4%B8%AA%20TPM%20%E9%80%9A%E9%81%93%EF%BC%88%405-10Khz%20%E5%88%87%E6%8D%A2%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.)%20TPM1%20%E9%80%9A%E9%81%93%200%20%E5%92%8C%201%20%E7%94%A8%E4%BA%8E%E4%BC%BA%E6%9C%8D%E6%97%B6%E9%97%B4%E5%9F%BA%E5%87%86%E3%80%82%E5%AE%83%E7%9A%84%E5%91%A8%E6%9C%9F%E6%AF%94%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E6%85%A2%E5%BE%97%E5%A4%9A%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E9%9C%80%E8%A6%81%E8%87%AA%E5%B7%B1%E7%9A%84%E6%97%B6%E9%97%B4%E5%9F%BA%E5%87%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.)%20%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E6%97%B6%E9%97%B4%E5%9F%BA%E5%87%86%EF%BC%88TPM2%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5.)%20K64%20CPU%20%E6%9C%89%20FTM%20%E5%8D%95%E5%85%83%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%83%8F%20KL25Z%20%E9%82%A3%E6%A0%B7%E7%9A%84%20TPM%E3%80%82FTM%20%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E6%9B%B4%E5%8A%A0%E5%A4%8D%E6%9D%82%EF%BC%8C%E6%82%A8%E5%B0%86%E9%9C%80%E8%A6%81%E7%A7%BB%E6%A4%8D%E5%8A%9F%E8%83%BD%EF%BC%81%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%82%A8%E9%9C%80%E8%A6%81%E9%98%85%E8%AF%BB%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E5%B9%B6%E7%BC%96%E5%86%99%E4%B8%80%E4%BA%9B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E5%BC%80%E5%A7%8B%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%82%A8%E5%AE%8C%E5%85%A8%E4%BA%86%E8%A7%A3%E9%A9%B1%E5%8A%A8%E7%94%B5%E6%9C%BA%EF%BC%88%4010KHz%20%E4%BA%92%E8%A1%A5%20PWM%EF%BC%89%E5%92%8C%E4%BC%BA%E6%9C%8D%EF%BC%880.5mS%20%E8%87%B3%202mS%20%E8%84%89%E5%86%B2%4020mS%20%E5%91%A8%E6%9C%9F%EF%BC%89%E6%89%80%E9%9C%80%E7%9A%84%E4%BF%A1%E5%8F%B7%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E8%BF%99%E4%BA%9B%E4%BF%A1%E5%8F%B7%E6%98%A0%E5%B0%84%E5%88%B0%20K64%20%E4%B8%8A%E7%9A%84%E5%BC%B9%E6%80%A7%E5%AE%9A%E6%97%B6%E5%99%A8%E5%8D%95%E5%85%83%E4%B8%8A%E3%80%82%E6%9C%89%E4%BA%9B%E4%BF%A1%E5%8F%B7%E5%AF%B9%E9%BD%90%EF%BC%8C%E6%9C%89%E4%BA%9B%E5%88%99%E4%B8%8D%E5%AF%B9%E9%BD%90%E3%80%82%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E5%87%A0%E6%A0%B9%E7%94%B5%E7%BA%BF%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%E6%9B%B4%E5%A4%A7%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%98%AF%E5%B0%86%E4%BB%A3%E7%A0%81%E6%9B%B4%E6%96%B0%E5%88%B0%20FTM%20%E8%80%8C%E4%B8%8D%E6%98%AF%20TPM%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E5%AD%A6%E6%9C%AF%E7%BB%83%E4%B9%A0%EF%BC%8C%E4%BD%86%E4%BD%A0%E5%BF%85%E9%A1%BB%E9%A6%96%E5%85%88%E4%BB%8E%E6%A0%B9%E6%9C%AC%E4%B8%8A%E4%BA%86%E8%A7%A3%20FRDM-TFC%20%E4%B8%8A%E7%9A%84%20IO%E3%80%82%E4%B8%80%E6%97%A6%E6%82%A8%E4%BA%86%E8%A7%A3%E4%BA%86%20IO%20%E5%92%8C%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%82%A8%E5%B0%B1%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%B0%86%E5%85%B6%E8%BF%9E%E6%8E%A5%E5%88%B0*%E4%BB%BB%E4%BD%95*%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3ETFC-Shield%20%E5%92%8C%20K64F%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%90%88%E4%B9%8E%E9%80%BB%E8%BE%91%E7%9A%84%E7%BB%84%E5%90%88%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E8%BF%99%E5%B9%B6%E4%B8%8D%E5%AE%B9%E6%98%93%E3%80%82%E7%94%B1%E4%BA%8E%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%B2%A1%E6%9C%89%E5%85%BC%E5%AE%B9%E7%9A%84%E5%BC%95%E8%84%9A%E6%8E%92%E5%88%97%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%94%E4%B8%8D%E8%83%BD%E7%AB%8B%E5%8D%B3%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E6%9D%BF%E5%AD%90%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%89%BE%E5%88%B0%E6%AF%94%E8%BE%83%E8%A1%A8%EF%BC%88%E5%85%B6%E4%B8%AD%E4%B9%9F%E5%8C%85%E6%8B%AC%20Arduino%20Uno%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%9F%E4%BA%A7%E5%95%86%E5%A3%B0%E6%98%8E%E8%AF%A5%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8E%20Arduino%20%E6%89%A9%E5%B1%95%E6%9D%BF%E5%85%BC%E5%AE%B9%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%20%3CA%20href%3D%22http%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E9%80%82%E5%BD%93%E7%9A%84%E4%BF%A1%E5%8F%B7%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh_ng%22%20target%3D%22_blank%22%3ERichardBalogh_ng%3C%2FA%3E%E6%9C%89%202%20%E4%B8%AA%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E8%BF%99%E4%B8%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E8%BF%87%E4%BA%86%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E4%B8%8E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmassimoviolante%22%20target%3D%22_blank%22%3Emassimoviolante%3C%2FA%3E%E5%92%8C%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh%22%20target%3D%22_blank%22%3ERichardBalogh%3C%2FA%3E%E5%8F%96%E5%BE%97%E8%81%94%E7%B3%BB%EF%BC%8C%E4%BB%96%E4%BB%AC%E5%B7%B2%E7%BB%8F%E8%87%B4%E5%8A%9B%E4%BA%8E%E6%AD%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%9B%A2%E9%98%9F%E6%AD%A3%E5%9C%A8%E5%8F%82%E5%8A%A0%E5%88%9B%E6%96%B0%E6%9D%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E5%B0%86%E8%BF%99%E4%B8%AA%20TFC-Shield%20%E4%B8%8E%20FRDM%20K64F%20%E6%9D%BF%E7%BB%93%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BE%8B%E5%AD%90%EF%BC%8C%E5%A6%82%E4%BD%95%E5%9C%A8%20K64F%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%20TFC-Shield%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9C%8B%E7%9C%8B%E7%94%B5%E6%B1%A0%E7%9A%84%E8%A7%84%E6%A0%BC%E3%80%827.2%20%E6%98%AF%E6%A0%87%E7%A7%B0%E7%94%B5%E5%8E%8B%EF%BC%8C%E4%BD%86%E6%82%A8%E4%B8%8D%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%BF%87%E5%BA%A6%E5%85%85%E7%94%B5%E3%80%82%EF%BC%88IE%E7%81%AB%EF%BC%81%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%8F%90%E5%88%B0%E4%BA%86%2012v%20%E5%85%85%E7%94%B5%E5%99%A8%E3%80%82%E4%BD%A0%E8%83%BD%E6%8B%8D%E5%BC%A0%E7%85%A7%E7%89%87%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E4%B8%BA%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%A5%97%E4%BB%B6%E5%92%8C%2012V%20%E5%85%85%E7%94%B5%E5%99%A8%E6%8F%90%E4%BE%9B%E4%BA%86%207.2V%202000mAh%20%E9%95%8D%E9%95%89%E7%94%B5%E6%B1%A0%E3%80%82%E9%82%A3%E4%B9%88%EF%BC%8C%E9%95%8D%E9%95%89%E7%94%B5%E6%B1%A0%E5%85%85%E6%BB%A1%E7%94%B5%E5%90%8E%E7%9A%84%E6%9C%80%E5%A4%A7%E7%94%B5%E5%8E%8B%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%9C%89%E4%B8%80%E6%AC%A1%E6%88%91%E5%85%85%E7%94%B5%E6%97%B6%EF%BC%8C%E7%94%B5%E5%8E%8B%E9%AB%98%E8%BE%BE%208.5V%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%8B%85%E5%BF%83%E4%BC%9A%E6%8D%9F%E5%9D%8F%E7%94%B5%E6%B1%A0%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E7%94%A8%E7%BB%99%E5%AE%9A%E7%9A%84%E5%85%85%E7%94%B5%E5%99%A8%E7%BB%99%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E5%B9%B6%E5%B0%86%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E8%87%B3%209V%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B7%A5%E4%BD%9C%E5%BE%88%E5%BF%99%E3%80%82%E4%B8%80%E4%BA%9B%E6%BA%90%E4%BB%A3%E7%A0%81%E5%B0%86%E4%BC%9A%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%8C%9C%E6%B5%8B%E6%98%AF%E7%8E%AF%E5%A2%83%E8%A2%AB%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E7%A0%B4%E5%9D%8F%E4%BA%86%E3%80%82%E6%88%91%E6%9C%80%E5%A5%BD%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%98%AF%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E6%A3%80%E6%9F%A5%E8%AE%BE%E5%A4%87%E5%AF%84%E5%AD%98%E5%99%A8%E5%B9%B6%E6%9F%A5%E7%9C%8B%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%82%A8%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AA%E9%9C%80%E8%B7%B3%E8%BF%87%20PE%20%E5%B9%B6%E5%BC%80%E5%A7%8B%E7%BC%96%E5%86%99%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Femh203%22%20target%3D%22_blank%22%3Eemh203%3C%2FA%3E%E4%BD%A0%E6%9C%89%E6%9C%BA%E4%BC%9A%E7%9C%8B%E7%9C%8B%E8%BF%99%E4%B8%AA%E5%90%97%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BD%A0%E6%9C%89%E4%B8%AA%E6%83%B3%E6%B3%95%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E6%9D%A5%E7%94%9F%E6%88%90%E4%B8%80%E4%BA%9B%E9%85%8D%E7%BD%AE%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E7%BA%BF%E6%89%AB%E6%8F%8F%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20PTD6%20%E6%88%96%20PTD5%20%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%9C%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%8B%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E5%BC%95%E8%84%9A%E6%9D%A5%E6%89%A7%E8%A1%8C%20ADC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%8D%E6%98%AF%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B9%9F%E8%83%BD%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E4%BB%85%E9%99%90%E4%BA%8E%E5%85%B6%E4%BB%96%20ADC%20%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%82%A8%E7%9C%8B%E8%BF%87%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3EFreescale%20Cup%20Shield%20%E4%B8%BB%E9%A2%98%E4%B8%8B%E9%92%88%E5%AF%B9%20Freedom%20KL25Z%20%E7%9A%84%3C%2FA%3E%E8%A7%86%E9%A2%91%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98....%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%E2%80%9C%E6%9E%84%E5%BB%BA%E5%8C%85%E2%80%9D%E5%BA%94%E7%94%A8%E4%BA%8E%E4%BB%A3%E7%A0%81%E6%88%98%E5%A3%AB%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9C%89%E4%BA%BA%E5%9B%9E%E7%AD%94%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%91%9E%E5%85%B8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%AA%E9%9C%80%E4%B8%8B%E8%AE%A2%E5%8D%95%E5%8D%B3%E5%8F%AF%E3%80%82%E7%BA%A6%E7%BF%B0%E6%8F%90%E5%88%B0%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%89%80%E6%9C%89%E5%95%86%E5%93%81%E9%83%BD%E6%9C%89%E5%BA%93%E5%AD%98%EF%BC%8C%E5%9C%A8%E7%BA%BF%E7%B3%BB%E7%BB%9F%E4%B9%9F%E7%BB%8F%E5%B8%B8%E4%BC%9A%E6%8A%A5%E5%91%8A%E5%BE%88%E9%95%BF%E7%9A%84%E4%BA%A4%E8%B4%A7%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%9C%A8%E5%93%AA%E4%B8%AA%E5%9B%BD%E5%AE%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E5%98%BF%EF%BC%8C%E7%BA%A6%E7%BF%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E6%82%A8%E8%83%BD%E5%8F%91%E9%80%81%2F%E5%8D%96%E7%BB%99%E6%88%91%E5%90%97%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20FRDM-TFC%20%E6%89%A9%E5%B1%95%E6%9D%BF%20rev1.0%EF%BC%88%E6%88%96%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%89%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20TFC-CAMERA-ASY%E7%BA%BF%E6%89%AB%E6%8F%8F%E7%9B%B8%E6%9C%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E7%BD%91%E7%AB%99%E4%B8%8A%E8%AF%B4%E7%9A%84%E5%8F%91%E8%B4%A7%E6%97%B6%E9%97%B4%E6%98%AF%E5%85%AB%E6%9C%88%E4%BB%BD%EF%BC%8C%E8%BF%99%E6%AC%A1%E6%88%91%E5%B7%B2%E7%BB%8F%E7%AD%89%E4%B8%8D%E5%8F%8A%E4%BA%86%E3%80%82%E5%BC%97%E6%8B%89%E7%BB%B4%E5%A5%A5%C2%B7%E6%96%AF%E8%92%82%E5%87%A1%3CSPAN%20style%3D%22color%3A%20%23a9a9a9%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3E%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%96%E8%BA%AB%E4%B8%8A%E6%B2%A1%E6%9C%89%E8%BF%99%E4%BA%9B%E7%A1%AC%E4%BB%B6%E2%80%A6%E2%80%A6%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%E4%BA%86%E8%A7%A3%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E5%AE%9E%E7%8E%B0%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%88%91%E4%BC%9A%E5%9C%A8%E5%85%AC%E5%BC%80%E8%AE%BA%E5%9D%9B%E6%88%96%E6%82%A8%E6%89%80%E5%9C%A8%E7%9A%84%E5%9C%B0%E5%8C%BA%E5%8F%91%E5%B8%83%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E7%9C%8B%E7%9C%8B%E5%85%B6%E4%BB%96%E5%9B%A2%E9%98%9F%E7%9A%84%E6%88%90%E5%91%98%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%B8%8E%E6%82%A8%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E6%99%BA%E8%83%BD%E6%B1%BD%E8%BD%A6%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%A7%81%E6%AD%A4%E5%A4%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E6%99%BA%E8%83%BD%E6%B1%BD%E8%BD%A6%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E7%BA%A6%E7%BF%B0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E5%8F%91%E9%80%81%E4%BA%86%E7%A7%81%E4%BF%A1%E5%92%8C%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%EF%BC%88%E5%9C%A8%E6%82%A8%E7%9A%84%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%9C%B0%E5%9D%80%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BD%86%E6%98%AF%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E5%9B%9E%E5%A4%8D%E3%80%82%E4%BD%A0%E6%94%B6%E5%88%B0%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8CEli%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%BE%E6%B3%95%E8%AE%A9%E4%BB%A3%E7%A0%81%E8%BF%90%E8%A1%8C%E8%B5%B7%E6%9D%A5%E3%80%82%E4%BA%8B%E5%AE%9E%E8%AF%81%E6%98%8E%EF%BC%8C%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E5%B0%86%20ENABLE%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%AB%98%EF%BC%8C%E5%B9%B6%E5%90%91%20A-IN1%E3%80%81A-IN2%20%E5%8F%91%E9%80%81%E4%BA%92%E8%A1%A5%20PWM%20%E4%BF%A1%E5%8F%B7%E6%9D%A5%E6%8E%A7%E5%88%B6%E7%94%B5%E6%9C%BA%20A%20%E7%9A%84%E9%80%9F%E5%BA%A6%E5%92%8C%E6%96%B9%E5%90%91%EF%BC%8C%E5%B9%B6%E5%90%91%20B-IN1%E3%80%81B-IN2%20%E5%8F%91%E9%80%81%E4%BA%92%E8%A1%A5%20PWM%20%E4%BF%A1%E5%8F%B7%E6%9D%A5%E6%8E%A7%E5%88%B6%E7%94%B5%E6%9C%BA%20B%20%E7%9A%84%E9%80%9F%E5%BA%A6%E5%92%8C%E6%96%B9%E5%90%91%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E5%B0%B1%E4%BC%9A%E9%99%B7%E5%85%A5%E5%9B%B0%E5%A2%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E6%9C%89%E7%A4%BA%E6%84%8F%E5%9B%BE%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E8%BF%99%E6%A0%B7%E5%81%9A%E4%BA%86%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%E5%8C%85%E5%90%AB%202%20%E4%B8%AA%20H%20%E6%A1%A5%E5%92%8C%E4%BF%A1%E5%8F%B7%E6%98%A0%E5%B0%84%E7%9A%84%E9%A1%B5%E9%9D%A2%E3%80%82%E6%AF%8F%E4%B8%AAH%E6%A1%A5%E6%9C%892%E7%BB%84%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%B0%86%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%8A%E7%9A%84%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E4%B8%8E%E6%88%91%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%8A%E6%89%BE%E5%88%B0%E7%9A%84%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%E6%88%91%E9%80%9A%E8%BF%87%E5%8D%95%E5%87%BB%E6%AD%A4%E9%A1%B5%E9%9D%A2%E4%B8%8A%E7%9A%84%20mbed.org%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E9%93%BE%E6%8E%A5%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20title%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%B8%A6%E6%9C%89%20FRDM-KL25Z%20%7C%20mbed%20%E7%9A%84%20Freescale%20Cup%3C%2FA%3E%20%EF%BC%89%E8%8E%B7%E5%8F%96%E4%BA%86%E8%AF%A5%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%8C%E5%8D%95%E5%87%BB%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1284%22%20target%3D%22_blank%22%3EFreescale%20Cup%20%E7%9F%A5%E8%AF%86%E4%B8%AD%E5%BF%83%3C%2FA%3E%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93309%22%20target%3D%22_blank%22%3EFreescale%20Cup%20%E7%9B%B4%E6%B5%81%E7%94%B5%E6%9C%BA%E8%A7%84%E6%A0%BC%3C%2FA%3E%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%20H%20%E6%A1%A5%E8%A7%84%E6%A0%BC%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20title%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%EF%BC%9Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dt%E2%80%A6%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%84%8F%E8%AF%86%E5%88%B0%E9%82%A3%E6%98%AF%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E5%AE%83%E4%BB%8D%E7%84%B6%E5%90%91%E6%88%91%E6%98%BE%E7%A4%BA%E8%BE%83%E5%B0%91%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%88IN1%E3%80%81IN2%E3%80%81D1%E3%80%81D2%E3%80%81EN%EF%BC%89%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%AE%83%E4%BB%AC%E5%A6%82%E4%BD%95%E4%B8%8E%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%AD%E7%9A%84%E5%BC%95%E8%84%9A%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%EF%BC%88A-IN1%E3%80%81A-IN2%E3%80%81A-IFB%E3%80%81ENABLE%E3%80%81FAULT%E3%80%81B-IN1%E3%80%81B-IN2%E3%80%81B-IFB%EF%BC%89%E6%88%96%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E5%BC%95%E8%84%9A%E7%9B%B8%E5%AF%B9%E5%BA%94%E3%80%82%3C%2FSPAN%3E%E6%82%A8%E7%9A%84%E8%A7%81%E8%A7%A3%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%88%E5%8F%AF%E4%BB%8E%E4%B8%8A%E9%9D%A2%E4%B8%8B%E8%BD%BD%EF%BC%89%E6%98%BE%E7%A4%BA%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E4%B8%BA%20MC33887%E3%80%82%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%82%A8%E5%9C%A8%E5%93%AA%E9%87%8C%E6%89%BE%E5%88%B0%E8%AF%A5%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Eli%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%88%20%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%3C%2FA%3E%20%EF%BC%89%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E6%98%BE%E7%A4%BA%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%88IN1%E3%80%81IN2%E3%80%81D1%E3%80%81D2%EF%BC%89%E6%AF%94%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%8A%E7%9A%84%E8%A6%81%E5%B0%91%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%AE%83%E4%BB%AC%E5%A6%82%E4%BD%95%E4%B8%8E%20TFC%20%E5%B1%8F%E8%94%BD%E4%B8%8A%E7%9A%84%E5%BC%95%E8%84%9A%E7%9B%B8%E5%AF%B9%E5%BA%94%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%A6%82%E4%BD%95%E4%B8%8E%20KL25Z%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%BC%95%E8%84%9A%E7%9B%B8%E5%AF%B9%E5%BA%94%E3%80%82%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%99%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E5%BC%95%E8%84%9A%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%88%91%E7%A0%94%E7%A9%B6%E4%BA%86%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E6%8E%A7%E5%88%B6%E7%94%B5%E6%9C%BA%E7%9A%84%E4%BB%A3%E7%A0%81%E5%92%8C%E8%A7%86%E9%A2%91%E4%BB%A5%E5%8F%8A%E6%BC%94%E7%A4%BA%E8%A7%86%E9%A2%91%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E4%BA%86%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B9%B6%E4%B8%94%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E3%80%82%E6%88%91%E5%9C%A8%E7%BC%96%E5%86%99%E5%83%8F%E6%82%A8%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%A0%81%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%BA%BB%E7%83%A6%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%20PE%20%E7%BB%84%E4%BB%B6%E3%80%82%E4%B9%9F%E8%AE%B8%E9%80%9A%E8%BF%87%E9%97%AE%E9%A2%98%201)%20%E7%9A%84%E7%AD%94%E6%A1%88%EF%BC%8C%E6%88%91%E4%BC%9A%E6%98%8E%E7%99%BD%E6%88%91%E6%89%80%E7%BC%BA%E5%B0%91%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EValentin%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%20%E6%82%A8%E7%9C%8B%E8%BF%87%E8%AF%A5%E9%83%A8%E4%BB%B6%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E5%90%97%EF%BC%9F%E5%AE%83%E6%9C%89%E4%B8%80%E5%BC%A0%E5%BE%88%E5%A5%BD%E7%9A%84%E5%86%85%E9%83%A8%E5%9B%BE%E7%89%87%EF%BC%81%E5%8D%B3%E4%BD%BF%E6%98%AF%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E4%B9%9F%E4%B8%8D%E4%BC%9A%E5%91%8A%E8%AF%89%E4%BD%A0%E8%8A%AF%E7%89%87%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%E3%80%82%E5%9C%A8%E7%BC%96%E5%86%99%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E7%A0%94%E7%A9%B6%E6%95%B0%E6%8D%AE%E8%A1%A8%E9%9D%9E%E5%B8%B8%E9%87%8D%E8%A6%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E7%A0%94%E7%A9%B6%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BB%A5%E4%BA%86%E8%A7%A3%E5%85%B6%E5%B7%A5%E4%BD%9C%E5%8E%9F%E7%90%86%E3%80%82%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E4%BA%92%E8%A1%A5%E4%BF%A1%E5%8F%B7%E9%A9%B1%E5%8A%A8%E5%88%B0%E6%AF%8F%E4%B8%AA%E6%A1%A5%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20H%20%E6%A1%A5%E6%8E%A7%E5%88%B6%E7%9A%84%E8%BE%93%E5%85%A5%EF%BC%9F%E6%88%91%E4%BB%8E%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%8A%E5%BE%97%E7%9F%A5%E6%9C%89%208%20%E4%B8%AA%E8%BE%93%E5%85%A5%EF%BC%88A-IN1%E3%80%81A-IN2%E3%80%81A-IFB%E3%80%81ENABLE%E3%80%81FAULT%E3%80%81B-IN1%E3%80%81B-IN2%E3%80%81B-IFB%EF%BC%89%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8E%9F%E7%90%86%E5%9B%BE%E6%98%BE%E7%A4%BA%E4%BA%86%E5%AE%83%E4%BB%AC%E5%AF%B9%E5%BA%94%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%A6%81%E7%BB%99%E5%AE%83%E4%BB%AC%E4%BB%80%E4%B9%88%E4%BF%A1%E5%8F%B7%E3%80%82%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%EF%BC%8C%E6%88%91%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20Processor%20Expert%20%E7%BB%84%E4%BB%B6%E7%BC%96%E5%86%99%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%9F%90%E5%A4%84%E6%89%BE%E5%88%B0%E8%A7%84%E6%A0%BC%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%9F%EF%BC%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E4%BA%BA%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%A4%BE%E5%8C%BA%E4%B8%8A%E7%BB%99%E6%88%91%E5%8F%91%E7%A7%81%E4%BF%A1%E3%80%82%E7%82%B9%E5%87%BB%E6%AD%A4%E9%A1%B5%E9%9D%A2%E9%A1%B6%E9%83%A8%E7%9A%84%E5%88%9B%E5%BB%BA-%26gt%3B%E6%B6%88%E6%81%AF%EF%BC%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%BA%A6%E7%BF%B0%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B9%9F%E6%98%AF%EF%BC%81%EF%BC%81%E6%88%91%E5%8F%AF%E4%BB%A5%E7%BB%99%E4%BD%A0%E5%8F%91%E7%A7%81%E4%BA%BA%E9%82%AE%E4%BB%B6%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E7%BB%99%E6%88%91%E5%8F%91%E9%80%81%E4%B8%80%E5%B0%81%E7%A7%81%E4%BA%BA%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%EF%BC%8C%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E9%9C%80%E8%A6%81%E5%A4%9A%E5%B0%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E5%8D%95%E7%8B%AC%E8%B4%AD%E4%B9%B0%20FRDM-TFC%20%E6%9D%BF%EF%BC%88%E8%80%8C%E4%B8%8D%E6%98%AF%20TFC%20%E5%A5%97%E4%BB%B6%EF%BC%89%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%20FRDM-KL46Z%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B7%B2%E6%9B%B4%E6%96%B0%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Embed%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E7%9A%84%E9%93%BE%E6%8E%A5%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.-%20%E9%A6%96%E5%85%88%E5%AE%89%E8%A3%85%20LabVIEW%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2-%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%20NI%20%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI%20%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%202013.02%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.-%20%E6%9C%80%E5%90%8E%E5%AE%89%E8%A3%85%20NI%20VISA%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Juan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Juan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E5%BF%85%E9%A1%BB%E5%9C%A8%E5%AE%89%E8%A3%85%20Labview%20%E4%B9%8B%E5%89%8D%E8%BF%98%E6%98%AF%E4%B9%8B%E5%90%8E%E5%AE%89%E8%A3%85%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B7%B2%E4%BB%8E%20National%20Instrument%20%E7%BD%91%E7%AB%99%E5%AE%89%E8%A3%85%E4%BA%86%20NI%20VISA%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E9%93%BE%E6%8E%A5%EF%BC%9A%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20%E7%BE%8E%E5%9B%BD%E5%9B%BD%E5%AE%B6%E4%BB%AA%E5%99%A8%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%20%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E7%BA%BF%E6%89%AB%E6%8F%8F%E7%9B%B8%E6%9C%BA%E7%9A%84%20labview%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%20style%3D%22width%3A%20351px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40618i265604713BE33895%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Error_Labview.PNG.png%22%20alt%3D%22Error_Labview.PNG.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E6%88%91%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20FRDM%20%E5%92%8C%E5%B1%8F%E8%94%BD%E7%9A%84%20RCA%20%E7%9B%B8%E6%9C%BA%E6%BC%94%E7%A4%BA%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EEli%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E2%80%94%E2%80%94%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%83%B3%E6%B5%8B%E9%87%8F%E5%AE%9E%E9%99%85%E7%9A%84%E7%94%B5%E6%9C%BA%E7%94%B5%E5%8E%8B%EF%BC%8C%E8%80%8C%E6%98%AF%E5%BE%88%E5%BF%AB%E6%B5%8B%E9%87%8F%20Hbridge%20%E7%9A%84%20PWM%20%E8%BE%93%E5%85%A5%EF%BC%8C%E4%BB%A5%E7%A1%AE%E8%AE%A4%20David%20%E5%8F%91%E7%8E%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%88%E5%85%B6%E4%B8%AD%20openSDA%20%E4%BC%BC%E4%B9%8E%E5%BC%95%E8%B5%B7%E4%BA%86%E4%BA%89%E7%94%A8%EF%BC%89%E2%80%94%E2%80%94%E5%9B%A0%E4%B8%BA%E6%88%91%E5%9C%A8%E6%93%8D%E4%BD%9C%E6%BC%94%E7%A4%BA%E4%BB%A3%E7%A0%81%E6%97%B6%E7%9C%8B%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E6%9C%89%E8%B6%A3%E7%9A%84%E4%B8%9C%E8%A5%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDan%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E5%9F%BA%E4%BA%8E%20KL25Z%20%E7%9A%84%20TFC%20%E6%9D%BF%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E7%94%B5%E6%B1%A0%E7%9A%84%E5%9B%9E%E8%B7%AF%E5%92%8C%20USB%20%E7%9A%84%E5%9B%9E%E8%B7%AF%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%82%E8%80%83%E7%94%B5%E4%BD%8D%E4%BF%9D%E6%8C%81%E4%B8%BA%E7%9B%B8%E5%90%8C%E7%9A%84%E5%80%BC%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%9D%E8%99%BD%E5%A6%82%E6%AD%A4......%E8%BF%99%E6%98%AF%E6%82%A8%E5%8F%AF%E8%83%BD%E9%81%87%E5%88%B0%E7%9A%84%E5%94%AF%E4%B8%80%E9%97%AE%E9%A2%98%E3%80%82%E5%88%87%E5%8B%BF%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%9C%9F%E9%97%B4%E9%80%9A%E8%BF%87%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%BB%BB%E4%B8%80%E4%BE%A7%E7%9A%84%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%8E%A5%E5%9C%B0%E6%9D%A5%E6%B5%8B%E9%87%8F%E7%94%B5%E6%9C%BA%E4%B8%A4%E7%AB%AF%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%B7%AF%E5%BE%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%BF%E7%94%A8%20H%20%E6%A1%A5%EF%BC%8C%E8%BE%93%E5%87%BA%E5%8F%82%E8%80%83%201%2F2%20VCC%E3%80%82%E9%99%A4%E9%9D%9E%E6%82%A8%E7%9A%84%E7%A4%BA%E6%B3%A2%E5%99%A8%E5%A4%84%E4%BA%8E%E6%B5%AE%E5%8A%A8%E7%8A%B6%E6%80%81%E6%88%96%E4%BE%9D%E9%9D%A0%E7%94%B5%E6%B1%A0%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%90%A6%E5%88%99%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E7%94%B5%E6%9C%BA%EF%BC%88H-BRIDGE%EF%BC%89%E7%9A%84%E6%AF%8F%E4%B8%80%E4%BE%A7%E7%9B%B8%E5%AF%B9%E4%BA%8E%20PCB%20%E4%B8%8A%E7%9A%84%20GND%20%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E7%A1%AE%E8%AE%A4%E6%97%A0%E8%AF%AF%E5%90%8E%E5%86%8D%E8%BF%9B%E8%A1%8C%E4%B8%8D%E5%90%8C%E7%9A%84%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Eli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E6%98%AF%E8%AF%A5%E8%AE%BE%E7%BD%AE%E7%9A%84%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%E4%BB%8E%E6%9B%B4%E5%B9%BF%E6%B3%9B%E7%9A%84%E8%A7%92%E5%BA%A6%E6%9D%A5%E7%9C%8B%EF%BC%8C%E5%AE%83%E4%BB%8D%E7%84%B6%E6%98%AF%E4%B8%80%E7%A7%8D%E6%9C%89%E6%95%88%E7%9A%84%E9%A2%84%E9%98%B2%E6%80%A7%E8%AD%A6%E5%91%8A%E3%80%82%E4%B8%8D%E8%A6%81%E8%87%86%E6%96%AD%EF%BC%81%E9%98%85%E8%AF%BB%E5%8E%9F%E7%90%86%E5%9B%BE%E5%B9%B6%E4%BA%86%E8%A7%A3%E5%BA%95%E5%B1%82%E7%94%B5%E8%B7%AF%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B1%87%E7%BC%96%E6%89%8B%E5%86%8C%20PUB%20%E6%96%87%E6%A1%A3%E6%9C%AB%E5%B0%BE%E9%99%84%E8%BF%91%E7%9A%84%E8%AF%84%E8%AE%BA%EF%BC%9A%E2%80%9C%E5%88%87%E5%8B%BF%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E7%94%B5%E6%BA%90%E4%B8%BA%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BE%9B%E7%94%B5%EF%BC%81%E5%9C%A8%E5%B0%86%20MCU%20%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%AF%B7%E5%85%88%E5%85%B3%E9%97%AD%20MCU%20%E6%9D%BF%E3%80%82%E2%80%9D%E5%8F%A6%E8%AF%B7%E5%8F%82%E8%A7%81%EF%BC%9Ahttps%3A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1020%22%20target%3D%22_blank%22%3E%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1020%3C%2FA%3E%E5%85%B6%E4%B8%AD%E6%8F%90%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20red%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E5%88%87%E5%8B%BF%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E7%94%B5%E6%BA%90%E4%B8%BA%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E6%9D%BF%E5%92%8C%E6%8E%A5%E5%8F%A3%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%81%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%8F%8C%E6%96%B9%E5%A7%94%E5%91%98%E4%BC%9A%E7%9A%84%E7%90%86%E7%94%B1%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%9C%AA%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%8D%9F%E5%9D%8F%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%E8%BF%9E%E6%8E%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E7%9A%84%E7%81%B0%E8%89%B2%E6%89%81%E5%B9%B3%E5%B8%A6%E7%8A%B6%E7%94%B5%E7%BC%86%E4%BB%85%E7%94%A8%E4%BA%8E%E4%BF%A1%E5%8F%B7%E4%BC%A0%E8%BE%93%EF%BC%8C%E6%B2%A1%E6%9C%89%E9%80%9A%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EGND%E8%BF%9E%E6%8E%A5%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E7%89%B9%E5%AE%9A%E4%BA%8E%20Qorriva%20%E7%9A%84%E5%AE%9E%E7%8E%B0%E2%80%94%E2%80%94%E5%8F%AA%E6%98%AF%E6%83%B3%E5%9C%A8%E7%85%8E%E7%82%B8%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E4%B9%8B%E5%89%8D%E7%A1%AE%E5%AE%9A%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaniel%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%9C%A8%E5%93%AA%E9%87%8C%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E8%AD%A6%E5%91%8A%EF%BC%9F%E6%88%91%E5%B7%B2%E7%BB%8F%E5%90%8C%E6%97%B6%E8%BF%9E%E6%8E%A5%E4%BA%86%E7%94%B5%E6%B1%A0%E5%92%8C%20USB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8D%E5%9C%A8%E9%98%85%E8%AF%BB%E8%A7%84%E6%A0%BC%EF%BC%8C%E4%BD%86%E6%88%91%E5%81%87%E8%AE%BE%20KL25Z%20%E6%98%AF%E4%BB%8E%20TFC%20%E5%B1%8F%E8%94%BD%E7%9A%84%E7%94%B5%E6%BA%90%E8%8E%B7%E5%8F%96%E7%94%B5%E5%8A%9B%E7%9A%84%EF%BC%9F%E7%9C%8B%E5%88%B0%E6%9C%89%E5%85%B3%E6%97%A0%E6%B3%95%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8%E4%B8%A4%E8%80%85%E7%9A%84%E5%9C%B0%E9%9D%A2%E8%AD%A6%E5%91%8A%EF%BC%88TFC%20%E4%BD%BF%E7%94%A8%E7%94%B5%E6%B1%A0%EF%BC%8C%E8%80%8C%20KL25Z%20%E4%BD%BF%E7%94%A8%20USB%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E5%8F%AF%E8%83%BD%E5%BF%85%E9%A1%BB%E5%85%88%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%88%E6%97%A0%E7%94%B5%E6%B1%A0%EF%BC%89%E2%80%94%E2%80%94%E7%84%B6%E5%90%8E%E6%8B%94%E4%B8%8B%20USB%20%E4%BB%A5%E4%BD%BF%E7%94%A8%E7%94%B5%E6%B1%A0%EF%BC%88%E6%88%96%E5%85%B6%E4%BB%96%207.2V%E3%80%810.1A%20%E7%94%B5%E6%BA%90%EF%BC%89%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%E5%8F%AF%E4%BB%A5%E8%AF%B4%EF%BC%8C%E6%B2%A1%E6%9C%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E2%80%9C%E5%9C%A8%E7%BA%BF%E2%80%9D%E6%B5%8B%E8%AF%95%E6%B1%BD%E8%BD%A6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%83%E5%B0%86%E5%87%BA%E7%8E%B0%E5%9C%A8%E6%96%B0%E7%9A%84%20TFC-KIT%20%E4%B8%AD%E3%80%82%E7%9B%AE%E5%89%8D%E6%88%91%E4%BB%AC%E4%B8%8D%E5%8D%95%E7%8B%AC%E9%94%80%E5%94%AE%EF%BC%8C%E4%BD%86%E6%AD%A3%E5%9C%A8%E5%8A%AA%E5%8A%9B%E4%B8%BA%E6%9C%AA%E6%9D%A5%E5%81%9A%E5%A5%BD%E5%87%86%E5%A4%87%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E4%B9%B0%E5%88%B0%E9%80%82%E7%94%A8%E4%BA%8E%E8%87%AA%E7%94%B1%E6%9D%BF%E7%9A%84%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E5%9C%B0%E5%8C%BA%E8%80%8C%E5%BC%82%E3%80%82%E4%BD%86%E6%98%AF%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BB%8E%202014%20%E5%B9%B4%E5%BC%80%E5%A7%8B%E6%88%91%E4%BB%AC%E5%B0%86%E6%8F%90%E4%BE%9B%E5%9F%BA%E4%BA%8E%E8%87%AA%E7%94%B1%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%E6%82%A8%E5%9C%A8%E4%B8%8A%E9%9D%A2%E7%9C%8B%E5%88%B0%E7%9A%84%E5%B0%B1%E6%98%AF%E6%88%91%E4%BB%AC%E4%BB%8A%E5%A4%A9%E4%B8%BA%E5%81%9A%E5%A5%BD%E5%87%86%E5%A4%87%E8%80%8C%E8%BF%9B%E8%A1%8C%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%E8%A7%84%E5%88%99%E5%8F%AF%E8%83%BD%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2032%20%E4%BD%8D%20MCU%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFreescale%20%E6%9D%AF%E5%BD%A2%E9%98%B2%E6%8A%A4%E7%BD%A9%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%E8%87%AA%E7%94%B1%E6%9D%BF%E5%8F%82%E5%8A%A0%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9D%AF%E6%AF%94%E8%B5%9B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎01-06-2013 05:28 PM
更新人:
