Freescale Cup Shield for the Freedom KL25Z
Overview
The FRDM-TFC is a convenient "shield" that can drive up to two DC motors (5A per channel), two servos and I/O for the Freescale cup line scan camera and Hall effect sensors.  This board mates with the KL25Z Freedom board for primary usage with a Freescale Cup car.
Features:
  • 2 channel Motor Driver ICs (MC33887APVW)
  • 2 channel servo Outputs
  • Dual Linescan Camera interfaces
  • Two inputs for speed sensors
  • Two potentiometers for user functions
  • Two push buttons for user functions
  • 4 Position DIP Switch for user function
  • 4 LEDs (green) for battery indicator or user functions
Design Files
Rev A is attached to this document.
Rev B is attached to this document
Code Examples
Codewarrior "Bare Metal" Example Code:
All Codewarrior based code examples for the FRDM-TFC are hosted on in a Subversion repository on Google Code:
frdm-tfc -   Example code for the FRDM-TFC Shield - Google Project Hosting
You can check out the code with your favorite SVN client.   Static releases are available in the attachments section of this page.  The current release is "R1.0"
mbed.org Example Code:
https://mbed.org/components/Freescale-Cup-with-FRDM-KL25Z/
Videos
FRDM TFC EXAMPLE CODE GETTING STARTED
FRDM-TFC_DEMO 0 and 1
FRDM-TFC_DEMO 2 and 3
Comments
thanks for your answers. We tryed to do this changes at the servo but unfortunately the servo doesnt rotates.
Maybe our processorsetup in the KDS or the wireing is not correct.
Can you tell us at the example of the servo what we have to change at the connections and at the code?
I'm sorry but we are very new at microcontrolers.
David
David:
I would suggest you 1st try to get the system working with the KL25Z board.   It is a known working configuration with working example code. If you are new to micro controllers, it will save you a lot of time.  Once you understand the initialization code for that platform, them move on.   Also, if you are using processor expert you may get stuck for awhile.  It is better to 1st understand how to program the timer units from scratch using the reference manual so you understand what operations you are doing.
Some resources:
1.)  https://community.freescale.com/docs/DOC-95170
2.)   Some have used the Kwikstik for the car.  It uses a K40 which has the same FTM unit as the K64.   That code may be helpful to you.
https://community.freescale.com/docs/DOC-1057
hello sir,
in NI Device drivers there are so many drivers so which drivers i need to install for the same problem
please help
Azaj Vahora
Hey ,
I have a big problem with mi FRDM KL25Z ...
I have made a lot of test and all were good ! i success to do several thing and now i am friend with the code and code warrior !
So i intent to make my own code to the CUP , using the camera in order to control the car BUT
during the execution of the program all the shiel froze totally ... and the moto are in FULL POWER !! in my code i put the LED blinking and it Froze also !! i have to press the reset button and it is good for some seconde and again it froze in full power ...
I take the time with a chronometer between the beginning and the Froze , and it depend of the number of execution in my loop ... 50 times and Froze !!
explanation : my code is :
main(){
while(1) {
     if( ticker[0] > T)
     ticker = 0
     instruction;
     instruction ;
So i notice that the car froze in full power when the code do 50 times the " if ticker ..... " .
so it go out of the while after 50*T ... and all the power of the motor a the maximum ...
A dont understand why ???!!! I really need help because in 1 big month there are the qualification EMEAa ...
More over the gears of the motor transmission was broken during the shield froze because of the full power in the motor .. Do you know where i can by a new ?
BEST , thanksss
LUCAS mAHIEU
PS : Sorry i am french and my english is not really good ...
Hello Lucas:
Let's start here...   Can you zip your test project where you said the LED was freezing?  I need to see the code in the context of your entire project.
Also,   what happens when you load the example/test code from this page:
https://community.freescale.com/docs/DOC-93914
thank a lot, but i fixed the problem ! it was the dynamic allocation the problem … I didn’t made the FREE …
but today a very BIZARRE thing happen … When i plug the FRDM KL25Z to send my program all is good the car do what i want ! , but when i unplug he usb cable the car do nothing … first i thought that it is the batterie , but it is full … and we saw that the board is VERY VERY VERY hot at the bottom !! near to the component with 3 pin in one side an 1 big pin in the other side … today it was the first time that we saw that !!
do you have an idea ?
Le 18 déc. 2014 à 13:56, Eli Hughes <[email protected]> a écrit :
<https://community.freescale.com/> <https://community.freescale.com/>
new comment by Eli Hughes <https://community.freescale.com/people/eli_hughes?et=watches.email.document_comment> View all comments on this document <https://community.freescale.com/docs/DOC-93914?et=watches.email.document_comment#comment-15266>
Hello Lucas:
https://community.freescale.com/docs/DOC-93914 <https://community.freescale.com/docs/DOC-93914>
Reply to this email to respond to Eli Hughes's comment.
Following Freescale Cup Shield for the Freedom KL25Z <https://community.freescale.com/docs/DOC-93914?et=watches.email.document_comment#comment-15266> in these streams: Inbox
hello,
one of the features of the TFC is the H-bridge IFA\IFB. I ave few things that i didn't understand:
1. what are they use for?
2. they give us the feedback from the H-bridge of the PWM output? if yes, can we use them as speed sensors of the car?
3. is there a way to check the status of the battery with the KL25Z (the voltage of the battery)? if yes, how can we check it.
thank you for this examples!!!
1.)   Look in the MC33887APVW datasheet.    The are current feedback signals you could use for torque control on the motor.
2.)   Yes.  Look at the schematic and you will find your answer.
Hello, We participat to the Freeacale cup for the EMEA in 3 weeks.
But we have a big probleme ...
We have made our code on code warrior.
All was corect and the car did what we wanted ...
but suddenly the shield was very HOT and a litte connection burn on the FRDM-TFC !! betwen the pin 16 (J9) and the VBAT ... More over we try again with another shiel and we had the same problem and the R8 resistance burned to  ...
So we descided to take an other shiel (  new one ) and we try with a litte and simple program ! juste with the "chemillards". bat led in the main.c of heli huges in the quick start program at the begining all was good...
but after about 4 minutes the connection on the shield burn too ...
We are very disaponted because we don't find the probleme and we realy don't understand why we had not this problem a the begining when the car was eficient ...
thanks before !
all progrmag are running but in a flew time a connection burn ...
How Can I add speed sensor in my Car?
I am in India. Any store available in India to buy speed sensor
Hello Jawahar,
Check the videos for some reference. But you will have to acquire locally in any electronics store a Hall Effect Sensor. I suggest you to research on the Internet how they work. And depending on the package of the sensor, you can create your own case to be able to add it to the wheels on your car.
I have an issue with the speed sensor. I use the Kinetis FRDM-KL25Z. On the FRDM-TFC there are 3 pins for a speed sensor. But I do not know how to use. I looked at the sample code but there is nothing.
Do you have a code to exploit this sensor.
thank you
The sample code for a speed sensor was intentionally left out.  The speed sensor design is up to the student team as an exercise.  You will need to design your own and write the code.   There are many clues in this video:
See "Designing a Speed Sensor II & II" on this page
The Book of Eli - Microcontrollers, robotics and warp drives
Hello Mr. Hughes,
How can I manage to handle the SDA, the UART0 and the Speed Sensor on the same ports like wired on the TFC-shield. I have written an c-file and a header file for the speed sensor. My ISR did not start up in case of overflow or reaching the mod. value. Could there be a conflict  with the SDA or UART0?
MB
If you look at the schematics for the KL25Z and the FRDM_TFC,    you will see that the timers used for the speed sense cannot be used if you are also using the UART for the SDA.    IT is possible to change the uart function (which some jumper wires) to connect UART2 to the SDA interface.  I believe Daniel Hadad did this already.  There may be some instructions on the forum, I will look around.
thanks for the reply
How can I access the i/o ports on the board after attatching the shield to the FRDM-KL25Z ?
1.)   Solder leads to the terminals on the shield
2.)   Do a web search for an arduino shield that has a pass through connector and some protoyping area.
Hello Mr. Hughes,
for building a connection board between K64F an TFC Shield i need some information about the pin layout of the K64F. Unfortunately I cant find any information on which Pins the PTA10, PTA11, PTB12, PTB13, PTD5, PTD6, PTD7, PTE1 signals are available at the K64F. Can you please give me this information or some advice where it is written?
I also want to know for what the V_Batterie Signal on TFC Pin Jx9 is standing for and if it is necessary to connect this signal with the K64F Board.
Thank you very much,
David
When I turn the exposure time lower then 50 ms I receive some weird noise in the Lab View application that let's me see the signal from the video camera. There are random pikes in the signal that appear rapidly and disappear or the image is unstable is moving very fast up and down like it's "shivering" very fast. Any idea why ? This happens at low exposure time , below 50-45 ms .
with my team we would like to create a Rx connection on the car.
In the start package there is the code to the Tx with the UART but not the Rx.
One other words, we can receive information FROM the car but not to give information TO the car.
And the UART fils is VERY VERY difficult to understand for us... is it possible to receive help from somebody ?
Thanks a lot before
%3CLINGO-SUB%20id%3D%22lingo-sub-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-380609040%22%20id%3D%22toc-hId-1297666294%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1060667410%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1751228884%22%20target%3D%22_blank%22%3EFeatures%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1863680042%22%20target%3D%22_blank%22%3EDesign%20Files%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-623832791%22%20target%3D%22_blank%22%3ECode%20Examples%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1183621672%22%20target%3D%22_blank%22%3EVideos%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--493060198%22%20target%3D%22_blank%22%3EFRDM%20TFC%20EXAMPLE%20CODE%20GETTING%20STARTED%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1994452635%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%200%20and%201%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--508165307%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%202%20and%203%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1426845423%22%20id%3D%22toc-hId--509788169%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1060667410%22%20id%3D%22toc-hId-1977724664%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20FRDM-TFC%20is%20a%20convenient%20%22shield%22%20that%20can%20drive%20up%20to%20two%20DC%20motors%20(5A%20per%20channel)%2C%20two%20servos%20and%20I%2FO%20for%20the%20Freescale%20cup%20line%20scan%20camera%20and%20Hall%20effect%20sensors.%26nbsp%3B%20This%20board%20mates%20with%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2FFRDM-KL25Z%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKL25Z%3C%2FA%3E%20Freedom%20board%20for%20primary%20usage%20with%20a%20Freescale%20Cup%20car.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40270iD0A099A2D21084FC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-TFC.png%22%20alt%3D%22FRDM-TFC.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFRDM-TFC.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84347i98F4482AEB143621%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture%20004.jpg%22%20alt%3D%22Picture%20004.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture%20004.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751228884%22%20id%3D%22toc-hId--1626681158%22%3EFeatures%3A%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E2%20channel%20Motor%20Driver%20ICs%20(MC33887APVW)%3C%2FLI%3E%3CLI%3E2%20channel%20servo%20Outputs%3C%2FLI%3E%3CLI%3EDual%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1058%22%20target%3D%22_blank%22%3ELinescan%20Camera%20%3C%2FA%3Einterfaces%3C%2FLI%3E%3CLI%3ETwo%20inputs%20for%20speed%20sensors%3C%2FLI%3E%3CLI%3ETwo%20potentiometers%20for%20user%20functions%3C%2FLI%3E%3CLI%3ETwo%20push%20buttons%20for%20user%20functions%3C%2FLI%3E%3CLI%3E4%20Position%20DIP%20Switch%20for%20user%20function%3C%2FLI%3E%3CLI%3E4%20LEDs%20(green)%20for%20battery%20indicator%20or%20user%20functions%3C%2FLI%3E%3C%2FUL%3E%3CH1%20id%3D%22toc-hId-1740725780%22%20id%3D%22toc-hId--1637184262%22%3E%3C%2FH1%3E%3CH2%20id%3D%22toc-hId--1863680042%22%20id%3D%22toc-hId--946622788%22%3EDesign%20Files%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-254727%2FFRDM-TFC-REVA-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3ERev%20A%20is%20attached%20to%20this%20document.%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-257650%2FFRDM-TFC-REVB-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3ERev%20B%20is%20attached%20to%20this%20document%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-623832791%22%20id%3D%22toc-hId-1540890045%22%3ECode%20Examples%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3ECodewarrior%20%22Bare%20Metal%22%20Example%20Code%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAll%20Codewarrior%20based%20code%20examples%20for%20the%20FRDM-TFC%20are%20hosted%20on%20in%20a%20Subversion%20repository%20on%20Google%20Code%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Efrdm-tfc%20-%26nbsp%3B%26nbsp%3B%20Example%20code%20for%20the%20FRDM-TFC%20Shield%20-%20Google%20Project%20Hosting%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20can%20check%20out%20the%20code%20with%20your%20favorite%20SVN%20client.%26nbsp%3B%26nbsp%3B%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-264428%2FFRDM-TFC_R1.0.zip%22%20target%3D%22_blank%22%3EStatic%20releases%20are%20available%20in%20the%20attachments%20section%20of%20this%20page.%3C%2FA%3E%26nbsp%3B%20The%20current%20release%20is%20%22R1.0%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Embed.org%20Example%20Code%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1183621672%22%20id%3D%22toc-hId--266564418%22%3EVideos%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--493060198%22%20id%3D%22toc-hId-423997056%22%3EFRDM%20TFC%20EXAMPLE%20CODE%20GETTING%20STARTED%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FplL3U2MYLxk%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1994452635%22%20id%3D%22toc-hId--1383457407%22%3EFRDM-TFC_DEMO%200%20and%201%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FxypYb2jfLPQ%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--508165307%22%20id%3D%22toc-hId-408891947%22%3EFRDM-TFC_DEMO%202%20and%203%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FjE_5q8pqy9w%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreescale%20Cup%20Content%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewith%20my%20team%20we%20would%20like%20to%20create%20a%20Rx%20connection%20on%20the%20car.%20%3C%2FP%3E%3CP%3EIn%20the%20start%20package%20there%20is%20the%20code%20to%20the%20Tx%20with%20the%20UART%20but%20not%20the%20Rx.%3C%2FP%3E%3CP%3EOne%20other%20words%2C%20we%20can%20receive%20information%20FROM%20the%20car%20but%20not%20to%20give%20information%20TO%20the%20car.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnd%20the%20UART%20fils%20is%20VERY%20VERY%20difficult%20to%20understand%20for%20us...%20is%20it%20possible%20to%20receive%20help%20from%20somebody%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20a%20lot%20before%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20I%20turn%20the%20exposure%20time%20lower%20then%2050%20ms%20I%20receive%20some%20weird%20noise%20in%20the%20Lab%20View%20application%20that%20let's%20me%20see%20the%20signal%20from%20the%20video%20camera.%20There%20are%20random%20pikes%20in%20the%20signal%20that%20appear%20rapidly%20and%20disappear%20or%20the%20image%20is%20unstable%20is%20moving%20very%20fast%20up%20and%20down%20like%20it's%20%22shivering%22%20very%20fast.%20Any%20idea%20why%20%3F%20This%20happens%20at%20low%20exposure%20time%20%2C%20below%2050-45%20ms%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Mr.%20Hughes%2C%3C%2FP%3E%3CP%3Efor%20building%20a%20connection%20board%20between%20K64F%20an%20TFC%20Shield%20i%20need%20some%20information%20about%20the%20pin%20layout%20of%20the%20K64F.%20Unfortunately%20I%20cant%20find%20any%20information%20on%20which%20Pins%20the%20PTA10%2C%20PTA11%2C%20PTB12%2C%20PTB13%2C%20PTD5%2C%20PTD6%2C%20PTD7%2C%20PTE1%20signals%20are%20available%20at%20the%20K64F.%20Can%20you%20please%20give%20me%20this%20information%20or%20some%20advice%20where%20it%20is%20written%3F%3C%2FP%3E%3CP%3EI%20also%20want%20to%20know%20for%20what%20the%20V_Batterie%20Signal%20on%20TFC%20Pin%20Jx9%20is%20standing%20for%20and%20if%20it%20is%20necessary%20to%20connect%20this%20signal%20with%20the%20K64F%20Board.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much%2C%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.)%26nbsp%3B%26nbsp%3B%20Solder%20leads%20to%20the%20terminals%20on%20the%20shield%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%26nbsp%3B%26nbsp%3B%20Do%20a%20web%20search%20for%20an%20arduino%20shield%20that%20has%20a%20pass%20through%20connector%20and%20some%20protoyping%20area.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20can%20I%20access%20the%20i%2Fo%20ports%20on%20the%20board%20after%20attatching%20the%20shield%20to%20the%20FRDM-KL25Z%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20for%20the%20reply%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20you%20look%20at%20the%20schematics%20for%20the%20KL25Z%20and%20the%20FRDM_TFC%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%20you%20will%20see%20that%20the%20timers%20used%20for%20the%20speed%20sense%20cannot%20be%20used%20if%20you%20are%20also%20using%20the%20UART%20for%20the%20SDA.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IT%20is%20possible%20to%20change%20the%20uart%20function%20(which%20some%20jumper%20wires)%20to%20connect%20UART2%20to%20the%20SDA%20interface.%26nbsp%3B%20I%20believe%20Daniel%20Hadad%20did%20this%20already.%26nbsp%3B%20There%20may%20be%20some%20instructions%20on%20the%20forum%2C%20I%20will%20look%20around.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Mr.%20Hughes%2C%3C%2FP%3E%3CP%3EHow%20can%20I%20manage%20to%20handle%20the%20SDA%2C%20the%20UART0%20and%20the%20Speed%20Sensor%20on%20the%20same%20ports%20like%20wired%20on%20the%20TFC-shield.%20I%20have%20written%20an%20c-file%20and%20a%20header%20file%20for%20the%20speed%20sensor.%20My%20ISR%20did%20not%20start%20up%20in%20case%20of%20overflow%20or%20reaching%20the%20mod.%20value.%20Could%20there%20be%20a%20conflict%26nbsp%3B%20with%20the%20SDA%20or%20UART0%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CP%3EMB%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20sample%20code%20for%20a%20speed%20sensor%20was%20intentionally%20left%20out.%26nbsp%3B%20The%20speed%20sensor%20design%20is%20up%20to%20the%20student%20team%20as%20an%20exercise.%26nbsp%3B%20You%20will%20need%20to%20design%20your%20own%20and%20write%20the%20code.%26nbsp%3B%26nbsp%3B%20There%20are%20many%20clues%20in%20this%20video%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESee%20%22Designing%20a%20Speed%20Sensor%20II%20%26amp%3B%20II%22%20on%20this%20page%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3EThe%20Book%20of%20Eli%20-%20Microcontrollers%2C%20robotics%20and%20warp%20drives%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20sample%20code%20for%20a%20speed%20sensor%20was%20intentionally%20left%20out.%26nbsp%3B%20The%20speed%20sensor%20design%20is%20up%20to%20the%20student%20team%20as%20an%20exercise.%26nbsp%3B%20You%20will%20need%20to%20design%20your%20own%20and%20write%20the%20code.%26nbsp%3B%26nbsp%3B%20There%20are%20many%20clues%20in%20this%20video%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESee%20%22Designing%20a%20Speed%20Sensor%20II%20%26amp%3B%20II%22%20on%20this%20page%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3EThe%20Book%20of%20Eli%20-%20Microcontrollers%2C%20robotics%20and%20warp%20drives%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3EI%20have%20an%20issue%20with%20the%20speed%20sensor.%20I%20use%20the%20Kinetis%20FRDM-KL25Z.%20On%20the%20FRDM-TFC%20there%20are%203%20pins%20for%20a%20speed%20sensor.%20%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3EBut%20I%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Edo%20not%20know%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Ehow%20to%20use.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3EI%20looked%20at%20the%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Esample%20code%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Ebut%20there%20is%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Enothing.%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22hps%22%3EDo%20you%20have%20a%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Ecode%20to%20exploit%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Ethis%20sensor.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3Ethank%20you%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Jawahar%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECheck%20the%20videos%20for%20some%20reference.%20But%20you%20will%20have%20to%20acquire%20locally%20in%20any%20electronics%20store%20a%20Hall%20Effect%20Sensor.%20I%20suggest%20you%20to%20research%20on%20the%20Internet%20how%20they%20work.%20And%20depending%20on%20the%20package%20of%20the%20sensor%2C%20you%20can%20create%20your%20own%20case%20to%20be%20able%20to%20add%20it%20to%20the%20wheels%20on%20your%20car.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20Can%20I%20add%20speed%20sensor%20in%20my%20Car%3F%3C%2FP%3E%3CP%3EI%20am%20in%20India.%20Any%20store%20available%20in%20India%20to%20buy%20speed%20sensor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eall%20progrmag%20are%20running%20but%20in%20a%20flew%20time%20a%20connection%20burn%20...%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EHello%2C%20We%20participat%20to%20the%20Freeacale%20cup%20for%20the%20EMEA%20in%203%20weeks.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EBut%20we%20have%20a%20big%20probleme%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EWe%20have%20made%20our%20code%20on%20code%20warrior.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EAll%20was%20corect%20and%20the%20car%20did%20what%20we%20wanted%20...%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ebut%20suddenly%20the%20shield%20was%20very%20HOT%20and%20a%20litte%20connection%20burn%20on%20the%20FRDM-TFC%20!!%20betwen%20the%20pin%2016%20(J9)%20and%20the%20VBAT%20...%20More%20over%20we%20try%20again%20with%20another%20shiel%20and%20we%20had%20the%20same%20problem%20and%20the%20R8%20resistance%20burned%20to%26nbsp%3B%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3ESo%20we%20descided%20to%20take%20an%20other%20shiel%20(%26nbsp%3B%20new%20one%20)%20and%20we%20try%20with%20a%20litte%20and%20simple%20program%20!%20juste%20with%20the%20%22chemillards%22.%20bat%20led%20in%20the%20main.c%20of%20heli%20huges%20in%20the%20quick%20start%20program%20at%20the%20begining%20all%20was%20good...%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ebut%20after%20about%204%20minutes%20the%20connection%20on%20the%20shield%20burn%20too%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EWe%20are%20very%20disaponted%20because%20we%20don't%20find%20the%20probleme%20and%20we%20realy%20don't%20understand%20why%20we%20had%20not%20this%20problem%20a%20the%20begining%20when%20the%20car%20was%20eficient%20...%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ethanks%20before%20!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.)%26nbsp%3B%26nbsp%3B%20Look%20in%20the%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMC33887APVW%20datasheet.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20are%20current%20feedback%20signals%20you%20could%20use%20for%20torque%20control%20on%20the%20motor.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%26nbsp%3B%26nbsp%3B%20Yes.%26nbsp%3B%20Look%20at%20the%20schematic%20and%20you%20will%20find%20your%20answer.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eone%20of%20the%20features%20of%20the%20TFC%20is%20the%20H-bridge%20IFA%5CIFB.%20I%20ave%20few%20things%20that%20i%20didn't%20understand%3A%3CBR%20%2F%3E1.%20what%20are%20they%20use%20for%3F%3C%2FP%3E%3CP%3E2.%20they%20give%20us%20the%20feedback%20from%20the%20H-bridge%20of%20the%20PWM%20output%3F%20if%20yes%2C%20can%20we%20use%20them%20as%20speed%20sensors%20of%20the%20car%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20is%20there%20a%20way%20to%20check%20the%20status%20of%20the%20battery%20with%20the%20KL25Z%20(the%20voltage%20of%20the%20battery)%3F%20if%20yes%2C%20how%20can%20we%20check%20it.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ethank%20you%20for%20this%20examples!!!%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethank%20a%20lot%2C%20but%20i%20fixed%20the%20problem%20!%20it%20was%20the%20dynamic%20allocation%20the%20problem%20%E2%80%A6%20I%20didn%E2%80%99t%20made%20the%20FREE%20%E2%80%A6%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebut%20today%20a%20very%20BIZARRE%20thing%20happen%20%E2%80%A6%20When%20i%20plug%20the%20FRDM%20KL25Z%20to%20send%20my%20program%20all%20is%20good%20the%20car%20do%20what%20i%20want%20!%20%2C%20but%20when%20i%20unplug%20he%20usb%20cable%20the%20car%20do%20nothing%20%E2%80%A6%20first%20i%20thought%20that%20it%20is%20the%20batterie%20%2C%20but%20it%20is%20full%20%E2%80%A6%20and%20we%20saw%20that%20the%20board%20is%20VERY%20VERY%20VERY%20hot%20at%20the%20bottom%20!!%20near%20to%20the%20component%20with%203%20pin%20in%20one%20side%20an%201%20big%20pin%20in%20the%20other%20side%20%E2%80%A6%20today%20it%20was%20the%20first%20time%20that%20we%20saw%20that%20!!%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edo%20you%20have%20an%20idea%20%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3ELe%2018%20d%C3%A9c.%202014%20%C3%A0%2013%3A56%2C%20Eli%20Hughes%20%3CADMIN%3E%20a%20%C3%A9crit%20%3A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3EFreescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FP%3E%3CP%3Enew%20comment%20by%20Eli%20Hughes%20%26lt%3B%26gt%3B%20View%20all%20comments%20on%20this%20document%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3EHello%20Lucas%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ELet's%20start%20here...%20%20%20Can%20you%20zip%20your%20test%20project%20where%20you%20said%20the%20LED%20was%20freezing%3F%20%20I%20need%20to%20see%20the%20code%20in%20the%20context%20of%20your%20entire%20project.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EAlso%2C%20%20%20what%20happens%20when%20you%20load%20the%20example%2Ftest%20code%20from%20this%20page%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3EReply%20to%20this%20email%20to%20respond%20to%20Eli%20Hughes's%20comment.%3C%2FP%3E%3CP%3EFollowing%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%20%26lt%3B%26gt%3B%20in%20these%20streams%3A%20Inbox%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Lucas%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELet's%20start%20here...%26nbsp%3B%26nbsp%3B%20Can%20you%20zip%20your%20test%20project%20where%20you%20said%20the%20LED%20was%20freezing%3F%26nbsp%3B%20I%20need%20to%20see%20the%20code%20in%20the%20context%20of%20your%20entire%20project.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlso%2C%26nbsp%3B%26nbsp%3B%20what%20happens%20when%20you%20load%20the%20example%2Ftest%20code%20from%20this%20page%3A%3C%2FP%3E%3CP%3E%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222003%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293914%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20a%20big%20problem%20with%20mi%20FRDM%20KL25Z%20...%20%3C%2FP%3E%3CP%3EI%20have%20made%20a%20lot%20of%20test%20and%20all%20were%20good%20!%20i%20success%20to%20do%20several%20thing%20and%20now%20i%20am%20friend%20with%20the%20code%20and%20code%20warrior%20!%20%3C%2FP%3E%3CP%3ESo%20i%20intent%20to%20make%20my%20own%20code%20to%20the%20CUP%20%2C%20using%20the%20camera%20in%20order%20to%20control%20the%20car%20BUT%20%3C%2FP%3E%3CP%3Eduring%20the%20execution%20of%20the%20program%20all%20the%20shiel%20froze%20totally%20...%20and%20the%20moto%20are%20in%20FULL%20POWER%20!!%20in%20my%20code%20i%20put%20the%20LED%20blinking%20and%20it%20Froze%20also%20!!%20i%20have%20to%20press%20the%20reset%20button%20and%20it%20is%20good%20for%20some%20seconde%20and%20again%20it%20froze%20in%20full%20power%20...%20%3C%2FP%3E%3CP%3EI%20take%20the%20time%20with%20a%20chronometer%20between%20the%20beginning%20and%20the%20Froze%20%2C%20and%20it%20depend%20of%20the%20number%20of%20execution%20in%20my%20loop%20...%2050%20times%20and%20Froze%20!!%20%3C%2FP%3E%3CP%3Eexplanation%20%3A%20my%20code%20is%20%3A%20%3C%2FP%3E%3CP%3Emain()%7B%3C%2FP%3E%3CP%3Ewhile(1)%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if(%20ticker%5B0%5D%20%26gt%3B%20T)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ticker%20%3D%200%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20instruction%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20instruction%20%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3ESo%20i%20notice%20that%20the%20car%20froze%20in%20full%20power%20when%20the%20code%20do%2050%20times%20the%20%22%20if%20ticker%20.....%20%22%20.%3C%2FP%3E%3CP%3Eso%20it%20go%20out%20of%20the%20while%20after%2050*T%20...%20and%20all%20the%20power%20of%20the%20motor%20a%20the%20maximum%20...%20%3C%2FP%3E%3CP%3EA%20dont%20understand%20why%20%3F%3F%3F!!!%20I%20really%20need%20help%20because%20in%201%20big%20month%20there%20are%20the%20qualification%20EMEAa%20...%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMore%20over%20the%20gears%20of%20the%20motor%20transmission%20was%20broken%20during%20the%20shield%20froze%20because%20of%20the%20full%20power%20in%20the%20motor%20..%20Do%20you%20know%20where%20i%20can%20by%20a%20new%20%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBEST%20%2C%20thanksss%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELUCAS%20mAHIEU%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS%20%3A%20Sorry%20i%20am%20french%20and%20my%20english%20is%20not%20really%20good%20...%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%20sir%2C%3C%2FP%3E%3CP%3Ein%20NI%20Device%20drivers%20there%20are%20so%20many%20drivers%20so%20which%20drivers%20i%20need%20to%20install%20for%20the%20same%20problem%3C%2FP%3E%3CP%3Eplease%20help%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAzaj%20Vahora%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDavid%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20would%20suggest%20you%201st%20try%20to%20get%20the%20system%20working%20with%20the%20KL25Z%20board.%26nbsp%3B%26nbsp%3B%20It%20is%20a%20known%20working%20configuration%20with%20working%20example%20code.%20If%20you%20are%20new%20to%20micro%20controllers%2C%20it%20will%20save%20you%20a%20lot%20of%20time.%26nbsp%3B%20Once%20you%20understand%20the%20initialization%20code%20for%20that%20platform%2C%20them%20move%20on.%26nbsp%3B%26nbsp%3B%20Also%2C%20if%20you%20are%20using%20processor%20expert%20you%20may%20get%20stuck%20for%20awhile.%26nbsp%3B%20It%20is%20better%20to%201st%20understand%20how%20to%20program%20the%20timer%20units%20from%20scratch%20using%20the%20reference%20manual%20so%20you%20understand%20what%20operations%20you%20are%20doing.%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESome%20resources%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%26nbsp%3B%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%26nbsp%3B%26nbsp%3B%20Some%20have%20used%20the%20Kwikstik%20for%20the%20car.%26nbsp%3B%20It%20uses%20a%20K40%20which%20has%20the%20same%20FTM%20unit%20as%20the%20K64.%26nbsp%3B%26nbsp%3B%20That%20code%20may%20be%20helpful%20to%20you.%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1057%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ethanks%20for%20your%20answers.%20We%20tryed%20to%20do%20this%20changes%20at%20the%20servo%20but%20unfortunately%20the%20servo%20doesnt%20rotates.%3C%2FP%3E%3CP%3EMaybe%20our%20processorsetup%20in%20the%20KDS%20or%20the%20wireing%20is%20not%20correct.%3C%2FP%3E%3CP%3ECan%20you%20tell%20us%20at%20the%20example%20of%20the%20servo%20what%20we%20have%20to%20change%20at%20the%20connections%20and%20at%20the%20code%3F%3C%2FP%3E%3CP%3EI'm%20sorry%20but%20we%20are%20very%20new%20at%20microcontrolers.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20wired%20it%20up%20and%20it%20isn't%20too%20bad.%26nbsp%3B%26nbsp%3B%20Some%20notes%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20selection%20of%20I%2FO%20on%20the%20FRDM%20board%20was%20based%20upon%20TPM%20(Timer%20Pulse%20Width%20Modulators)%20availability%20to%20optimize%20the%20usage%20of%20the%20hardware.%26nbsp%3B%20It%20was%20not%20mapped%20to%20Arduino%20as%20the%20psuedo%20standard%20pinout%20was%20not%20optimal%20for%20using%20the%20the%20FRDM%20board.%26nbsp%3B%26nbsp%3B%20Arduino%20compatibility%20really%20only%20means%20power%20and%20some%20I%2FO%20line%20up%20and%20that%20it%20meets%20a%20mechanical%20footprint.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%26nbsp%3B%20TPM0%20(labeled%20as%20FTM0%20in%20the%20spreadsheet)%20is%20the%20Timebase%20for%20the%20PWM%20to%20the%20DC%20motors.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20You%20need%20complimentary%20drive%20so%20you%20need%202%20channels%20of%20TPM%20on%20the%20same%20time%20base%20(%405-10Khz%20switching)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.)%26nbsp%3B%20TPM1%20channels%200%20and%201%20are%20for%20the%20servo%20time%20base.%26nbsp%3B%26nbsp%3B%20It%20is%20*much*%20slower%20period%20than%20the%20motor%20drive%20so%20it%20needs%20it's%20own%20time%20base.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.)%26nbsp%3B%20The%20speed%20sensors%20are%20on%20there%20own%20time%20base%20(TPM2).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5.)%20The%20K64%20CPU%20has%20FTM%20units%2C%20not%20TPM%20like%20the%20KL25Z.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20FTM%20peripherals%20are%20more%20complex%20are%20you%20will%20need%20to%20port%20functionality!%26nbsp%3B%20This%20means%20you%20will%20need%20to%20read%20the%20reference%20manual%20and%20write%20some%20code.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESo%2C%26nbsp%3B%20before%20you%20start%2C%26nbsp%3B%26nbsp%3B%20make%20sure%20you%20absolutely%20understand%20what%20signals%20are%20needed%20to%20drive%20the%20motors%20(%4010KHz%20complimentary%20PWM)%20and%20servo%20(0.5mS%20to%202mSec%20pulse%20%40%2020mS%20period).%26nbsp%3B%26nbsp%3B%26nbsp%3B%20You%20need%20map%20these%20signals%20onto%20the%20flex%20timer%20units%20on%20the%20K64.%26nbsp%3B%26nbsp%3B%20Some%20of%20the%20signals%20line%20up%20and%20others%20do%20not.%26nbsp%3B%20I%20only%20needed%20a%20couple%20of%20air%20wires%20to%20make%20the%20connections.%26nbsp%3B%26nbsp%3B%20The%20bigger%20job%20is%20updating%20the%20code%20to%20the%20FTM%20and%20not%20TPM.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt%20is%20a%20good%20academic%20exercise%20but%20you%20must%20first%20fundamentally%20understand%20the%20IO%20on%20the%20FRDM-TFC.%26nbsp%3B%26nbsp%3B%20Once%20you%20understand%20the%20IO%20and%20peripherals%20you%20should%20be%20able%20to%20wire%20it%20up%20to%20*any*%20microcontroller.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3ETFC-Shield%20and%20K64F%20is%20a%20logical%20combination%2C%20but%20unfortunately%20not%20an%20easy%20one.%20As%20the%20boards%20don't%20have%20the%20compatible%20pinouts%2C%20you'll%20need%20to%20rewire%20the%20connections%3C%2FP%3E%3CP%3Eand%20can't%20use%20the%20boards%20immediately.%20Here%20you%20can%20find%20the%20comparison%20table%20(also%20Arduino%20Uno%20included%2C%20as%20the%20producer%20declared%20the%20boards%20compatible%20with%20Arduino%20shields)%3A%3C%2FP%3E%3CP%3E%20%3CA%20href%3D%22http%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%3C%2FA%3E%3C%2FP%3E%3CP%3EAs%20you%20can%20see%2C%20the%20appropriate%20signals%20don't%20match.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh_ng%22%20target%3D%22_blank%22%3ERichardBalogh_ng%3C%2FA%3E%20has%202%20addresses%2C%20you%20can%20also%20try%20on%20this%20one%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3EYes%2C%20it%20has%20been%20tested.%20I%20recommend%20you%20get%20in%20touch%20with%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmassimoviolante%22%20target%3D%22_blank%22%3Emassimoviolante%3C%2FA%3E%20and%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh%22%20target%3D%22_blank%22%3ERichardBalogh%3C%2FA%3E%2C%20they%20have%20worked%20on%20that.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Emy%20team%20is%20starting%20at%20the%20innovation%20cup%20and%20we%20want%20to%20use%20this%20TFC-Shield%20combined%20with%20the%20FRDM%20K64F%20board.%20Is%20there%20any%20example%20like%20this%2C%20how%20to%20use%20the%20TFC-Shield%20in%20a%20K64F%20project%3F%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETake%20a%20look%20at%20the%20specs%20for%20the%20battery.%26nbsp%3B%26nbsp%3B%26nbsp%3B%207.2%20is%20nominal%20voltage%20BUT%20you%20do%20not%20want%20it%20overcharging.%26nbsp%3B%26nbsp%3B%20(i.e.%20Fire!)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20mention%20a%2012v%20charger.%26nbsp%3B%26nbsp%3B%20Can%20you%20take%20a%20picture%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20have%20been%20provided%207.2V%202000mAh%20Ni-Cd%20battery%20with%20the%20freescale%20kit%20and%2012V%20charger.So%2C%20what%20can%20be%20the%20maximum%20voltage%20of%20the%20Ni-Cd%20battery%20when%20fully%20charged%3F%20once%20when%20i%20charged%2C%20it%20reaches%20upto%208.5V%2C%20so%20I%20fear%20of%20damaging%20the%20battery.%3C%2FP%3E%3CP%3ESo%2C%20Should%20I%20charge%20it%20with%20given%20charger%20and%20Charge%20battery%20upto%209V%3F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20quite%20backed%20up%20with%20work%20right%20now.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Some%20source%20code%20would%20be%20helpful.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMy%20guess%20is%20that%20the%20environment%20is%20getting%20trashed%20by%20Processor%20Expert.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20My%20best%20advice%20is%20to%20inspect%20the%20device%20registers%20with%20the%20debugger%20and%20see%20what%20isn't%20configured%20right.%26nbsp%3B%26nbsp%3B%20Also%2C%26nbsp%3B%20since%20you%20have%20working%20drivers%2C%26nbsp%3B%20just%20skip%20PE%20and%20get%20to%20writing%20your%20application.%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Femh203%22%20target%3D%22_blank%22%3Eemh203%3C%2FA%3E%20would%20you%20have%20a%20chance%20to%20look%20at%20this%2C%20maybe%20you%20have%20an%20idea.%20Thanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20Processor%20expert%20to%20generate%20some%20configuration%20code.%3C%2FP%3E%3CP%3EThe%20problem%20I%20have%20is%20that%20I%20can't%20get%20to%20work%20the%20PTD6%20or%20PTD5%20pins%20used%20by%20the%20linescan%20sensor.%3C%2FP%3E%3CP%3EBut%20with%20the%20same%20configuartion%20I%20can%20use%20other%20pins%20to%20do%20the%20ADC.%3C%2FP%3E%3CP%3EI%20don't%20think%20this%20is%20a%20hardware%20problem%20because%20sample%20code%20works%20fine.%3C%2FP%3E%3CP%3EAnd%20my%20code%20works%20too%20but%20only%20on%20other%20ADC%20pins.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20have%20you%20looked%20at%20the%20videos%20under%20thread%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3EFreescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FA%3E%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3C%2FP%3E%3CP%3EI%20have%201%20question....%3C%2FP%3E%3CP%3EI%20can't%20know%20how%20I%20apply%20'build%20package'%20to%20code%20warrior.%3C%2FP%3E%3CP%3Eplz%20someone%20answer%20my%20question.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESweden%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20would%20just%20place%20the%20order.%26nbsp%3B%20John%20mentioned%20that%20the%20online%20system%20often%20reports%20very%20long%20delivery%20times%20even%20though%20eveything%20is%20in%20stock.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20country%20are%20you%20in%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3EHey%20John%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3ECould%20you%20send%2Fsell%20me%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20FRDM-TFC%20shield%20rev1.0%20(or%20newest%20version)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20TFC-CAMERA-ASY%20line%20scan%20camera%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3EIn%20the%20website%20the%20delivery%20time%20is%20in%20August%20and%20I%20can't%20wait%20this%20time.%20Flavio%20Stiffan%3CSPAN%20style%3D%22color%3A%20%23a9a9a9%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3Etold%20me%20he%20doesn't%20have%20these%20hardware%20with%20him....%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20see%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%20for%20the%20implementation%20of%20the%20speed%20sensor.%20To%20my%20knowledge%20there%20is%20no%20sample%20code%20readily%20available%20from%20Freescale%20but%20I%20would%20post%20the%20question%20in%20the%20open%20forum%20or%20your%20respective%20region%20to%20see%20if%20a%20team%20member%20from%20another%20group%20can%20share%20one%20with%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIs%20there%20any%20example%20code%20for%20the%20speed%20sensor%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%3A%20The%20Freescale%20Cup%20Intelligent%20Car%20Development%20System%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESee%20here%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%3A%20The%20Freescale%20Cup%20Intelligent%20Car%20Development%20System%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20can%20by%20the%20board%20here%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20John%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20sent%20a%20private%20message%20and%20a%20e-mail%20also%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E(in%20your%20Freescale%20address)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20but%20I%20didn't%20receive%20any%20response.%20Did%20you%20receive%20them%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Eli!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20managed%20to%20get%20the%20code%20working.%20Turns%20out%20I%20only%20need%20to%20set%20ENABLE%20to%20High%20and%20send%20complementary%20PWM%20signals%20to%20A-IN1%2C%20A-IN2%20to%20controll%20the%20speed%20and%20direction%20of%20motor%20A%2C%20and%20send%20complementary%20PWM%20signals%20to%20B-IN1%2C%20B-IN2%20to%20controll%20the%20speed%20and%20direction%20of%20motor%20B.%20I%20would%20have%20been%20stuck%20without%20your%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDid%20you%20get%20schematics%3F%26nbsp%3B%26nbsp%3B%20If%20you%20did%2C%20you%20will%20see%20the%20page%20that%20has%20the%202%20H-Bridges%20and%20the%20signal%20mapping.%26nbsp%3B%26nbsp%3B%20There%20are%202%20sets%20of%20signals%20for%20each%20H-Bridge%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%2C%20I%20didn't%20compare%20the%20part%20number%20from%20the%20schematic%20with%20the%20part%20number%20from%20the%20datasheet%20I%20found.%20I%20got%20that%20datasheet%20by%20clicking%20the%20mbed.org%20Example%20Code%20link%20on%20this%20page%20(%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20title%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreescale%20Cup%20with%20FRDM-KL25Z%20%7C%20mbed%3C%2FA%3E)%2C%20clicked%20under%20Datasheet%20(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1284%22%20target%3D%22_blank%22%3EThe%20Freescale%20Cup%20Knowledge%20Center%3C%2FA%3E)%2C%20then%20on%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93309%22%20target%3D%22_blank%22%3EFreescale%20Cup%20DC%20Motor%20Specifications%3C%2FA%3E%20and%20then%20on%20H-Bridge%20Specifications%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20title%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dt%E2%80%A6%3C%2FA%3E%3C%2FP%3E%3CP%3EI%20realize%20now%20that%20it%20was%20a%20mistake.%3C%2FP%3E%3CP%3EAnyway%2C%20it%20still%20shows%20me%20less%20pins%20(IN1%2C%20IN2%2C%20D1%2C%20D2%2C%20EN)%20and%20I%20don't%20know%20how%20they%20corespond%20to%20the%20ones%20from%20the%20schematic%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E(A-IN1%2C%20A-IN2%2C%20A-IFB%2C%20ENABLE%2C%20FAULT%2C%20B-IN1%2C%20B-IN2%2C%20B-IFB)%20or%20the%20ones%20in%20your%20code.%3C%2FSPAN%3E%20Your%20insight%20would%20be%20most%20helpful.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20schematic%20(available%20to%20download%20above)%20says%20the%20part%20number%20is%20a%20MC33887.%26nbsp%3B%26nbsp%3B%20Not%20sure%20where%20you%20found%20that%20part%20number.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Eli%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20replying.%3C%2FP%3E%3COL%3E%3CLI%3EI%20think%20I%20have%20the%20wrong%20datasheet(%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%3C%2FA%3E)%20because%20it%20shows%20me%20less%20pins%20(IN1%2C%20IN2%2C%20D1%2C%20D2)%20than%20the%20ones%20from%20the%20schematic%2C%20and%20I'm%20not%20sure%20how%20they%20correspond%20to%20those%20from%20the%20TFC%20shield%20and%20therefore%2C%20to%20those%20from%20the%20KL25Z%20board.%20Can%20you%20tell%20me%20if%20it's%20the%20right%20one%20and%20if%20it%20is%2C%20how%20to%20deal%20with%20the%20pin%20problem%3F%3C%2FLI%3E%3CLI%3EI've%20studied%20the%20code%20and%20your%20videos%20on%20how%20to%20control%20the%20motors%2C%20and%20the%20demo%20videos.%20I've%20tested%20your%20code%20and%20it%20works.%20I%20have%20some%20troubles%20in%20writing%20code%20like%20yours%2C%20but%20with%20PE%20components.%20Maybe%20with%20the%20answer%20from%20question%201)%2C%20I'll%20understand%20what%20I'm%20missing.%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EValentin%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%26nbsp%3B%26nbsp%3B%20Have%20you%20looked%20at%20the%20Datasheet%20for%20the%20part%3F%26nbsp%3B%26nbsp%3B%20It%20has%20a%20good%20picture%20of%20the%20internals!%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Even%20processor%20expert%20won't%20tell%20you%20how%20the%20chip%20works.%26nbsp%3B%20It%20is%20important%20to%20study%20datasheet%20*before*%20you%20write%20any%20code%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%26nbsp%3B%20Study%20the%20source%20code%20for%20the%20example%20code%20to%20see%20how%20it%20works.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Basically%2C%20you%20need%20to%20drive%20complementary%20signals%20into%20each%20bridge.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EHow%20can%20I%20find%20out%20how%20to%20use%20the%20inputs%20of%20the%20H-Bridge%20control%3F%20I%20get%20from%20the%20schematic%20that%20there%20are%208%20inputs%20(A-IN1%2C%20A-IN2%2C%20A-IFB%2C%20ENABLE%2C%20FAULT%2C%20B-IN1%2C%20B-IN2%2C%20B-IFB)%20and%20the%20schematic%20shows%20their%20corresponding%20pins%2C%20but%20I%20don't%20know%20what%20signals%20to%20give%20them.%20The%20example%20code%20doesn't%20seem%20to%20be%20using%20all%20of%20them%2C%20and%20I'm%20planning%20to%20write%20code%20using%20Processor%20Expert%20components.%20Can%20I%20find%20the%20specs%20somewhere%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%3F%3F%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnyone%20can%20send%20me%20private%20message%20on%20the%20community.%26nbsp%3B%20Click%20Create-%26gt%3BMessage%20at%20the%20top%20of%20this%20page!%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJohn%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMe%20too!!%20Can%20I%20also%20send%20you%20a%20private%20email%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESend%20me%20a%20private%20email%20with%20how%20many%20you%20need.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3EIs%20it%20still%20not%20possible%20to%20buy%20FRDM-TFC%20board%20alone(not%20the%20TFC%20kit)%3F%20%3C%2FP%3E%3CP%3EBest%20Regards%2C%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20example%20code%20works%20also%20for%20the%20FRDM-KL46Z%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUpdated.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20link%20for%20mbed%20example%20code%20doesn't%20work.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.-%20First%20install%20the%20LabVIEW.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2-%20Then%20install%20the%20NI%20Device%20drivers%3A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI%20Device%20Drivers%202013.02%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.-%20Finally%20install%20the%20NI%20VISA%20drivers%3A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Juan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Juan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%20I%20have%20to%20install%20the%20drivers%20before%20or%20after%20install%20Labview%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20have%20installed%20the%20NI%20VISA%20drivers%20from%20National%20Instrument%20Website%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHere%20is%20the%20link%3A%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%20I%20have%20a%20problem%20trying%20to%20run%20the%20labview%20application%20for%20the%20line%20scan%20camera.%20I%20got%20the%20following%20error%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%20style%3D%22width%3A%20351px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40618i265604713BE33895%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Error_Labview.PNG.png%22%20alt%3D%22Error_Labview.PNG.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EError_Labview.PNG.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3ECan%20someone%20help%20me%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3EBest%20Regards%2C%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20happened%20with%20RCA%20camera%20demo%20with%20the%20FRDM%20and%20the%20shield%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEli%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%E2%80%94Was%20not%20looking%20to%20measure%20the%20actual%20motor%20voltage%20but%20the%20PWM%20inputs%20to%20the%20Hbridge%20very%20soon%20to%20confirm%20the%20issue%20that%20David%20found%20(where%20openSDA%20appears%20to%20cause%20contention)%E2%80%94as%20I%20saw%20some%20funny%20stuff%20when%20operating%20the%20demo%20code.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDan%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20is%20not%20an%20issue%20KL25Z%20based%20TFC%20board.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20return%20for%20the%20battery%20and%20the%20return%20for%20the%20USB%20are%20tied%20together%20so%20the%20reference%20potential%20is%20held%20to%20the%20same%20value.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThat%20being%20said....%20Here%20is%20the%20only%20issue%20you%20may%20have.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20NEVER%20measure%20the%20voltage%20across%20the%20motors%20during%26nbsp%3B%20operation%20with%20a%20scope%20ground%20connected%20to%20either%20side.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20This%20could%20cause%20a%20path%20issue.%26nbsp%3B%20With%20an%20H-Bridge%2C%26nbsp%3B%20The%20outputs%20are%20references%20to%201%2F2%20VCC.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20This%20could%20cause%20an%20issue%20unless%20you%20scope%20is%20floating%20or%20running%20on%26nbsp%3B%20battery.%26nbsp%3B%26nbsp%3B%20You%20can%20look%20at%20each%20side%20of%20the%20motor%20(H-BRIDGE)%20with%20respect%20the%20GND%20on%20the%20PCB%20and%20be%20OK%20or%20take%20a%20different%20measurement.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Eli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20was%20an%20issue%20with%20that%20setup.%26nbsp%3B%20More%20broadly%20though%2C%20it%20is%20still%20a%20valid%20preventative%20caution.%26nbsp%3B%20Don't%20assume!%20Read%20the%20schematics%20and%20understand%20what%20the%20underlying%20circuitry%20is%20doing.%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EComment%20in%20the%20assembly%20manual%20PUB%20doc%20near%20the%20end%3A%20%22Never%20power%20the%20microcontroller%20from%20different%20power%20sources!%20Switch%20off%20the%20MCU%20board%20before%20you%20connect%20your%20it%20to%20your%20PC.%22%26nbsp%3B%26nbsp%3B%20Also%20here%3A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1020%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1020%3C%2FA%3E%20where%20it%20mentions%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20red%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ENOTE%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20Never%20power%20the%20microprocessor%20board%20and%20interface%20boards%20from%20different%20power%20supplies!%20In%20such%20case%20the%20grounds%20on%20both%20boards%20are%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Enot%20connected%20and%20you%20can%20damage%20the%20board.%20The%20grey%20flat%20ribbon%20cable%20that%20interconnects%20the%20boards%20is%20for%20signals%20only%2C%20there%20is%20no%20common%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EGND%20connection!%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20could%20be%20specific%20to%20the%20Qorriva%20implementation--%20just%20wanted%20to%20be%20sure%20before%20frying%20anything.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDaniel%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhere%20did%20you%20see%20this%20warning%3F%26nbsp%3B%20I%20have%20had%20the%20battery%20and%20USB%20hooked%20up%20at%20the%20same%20time.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EStill%20reading%20the%20specs%20but%20I%20assume%20the%20KL25Z%20is%20getting%20power%20from%20the%20power%20up%20of%20the%20TFC%20shield%3F%26nbsp%3B%20Saw%20the%20ground%20warnings%20about%20not%20powering%20up%20both%20(TFC%20with%20battery%20while%20KL25Z%20from%20USB)%20so%20likely%20we%20have%20to%20program%20first%20(no%20batt)--%20then%20unplug%20USB%20to%20test%20with%20battery%20(or%20other%207.2V%2C%200.1A%20source).%26nbsp%3B%26nbsp%3B%20There%20is%20no%20direct%20way%20to%20test%20the%20car%20'online'%20so%20to%20speak.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20will%20be%20in%20the%20new%20TFC-KIT.%26nbsp%3B%20Currently%20we%20don't%20sell%20individually%2C%20but%20working%20to%20set%20that%20up%20for%20the%20future.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhere%20I%20can%20buy%20the%20freescale%20cup%20shield%20for%20the%20freedom%20board%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EVaries%20by%20region.%26nbsp%3B%20But%20yes%2C%20starting%20in%202014%20we%20will%20be%20offering%20a%20freedom%20based%20version.%26nbsp%3B%20What%20you%20see%20above%20is%20the%20work%20we%20are%20doing%20today%20to%20get%20it%20ready.%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**The%20rules%20will%20likely%20stay%20the%20same%20that%20you%20can%20use%20any%20Freescale%2032-bit%20MCU.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20Cup%20Shield%20for%20the%20Freedom%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAre%20you%20going%20to%20use%20the%20freedom%20board%20for%20the%20Freescale%20Cup%20competitions%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎01-06-2013 05:28 PM
Updated by:
