Freescale Cup Shield for the Freedom KL25Z
Overview
The FRDM-TFC is a convenient "shield" that can drive up to two DC motors (5A per channel), two servos and I/O for the Freescale cup line scan camera and Hall effect sensors.  This board mates with the KL25Z Freedom board for primary usage with a Freescale Cup car.
Features:
  • 2 channel Motor Driver ICs (MC33887APVW)
  • 2 channel servo Outputs
  • Dual Linescan Camera interfaces
  • Two inputs for speed sensors
  • Two potentiometers for user functions
  • Two push buttons for user functions
  • 4 Position DIP Switch for user function
  • 4 LEDs (green) for battery indicator or user functions
Design Files
Rev A is attached to this document.
Rev B is attached to this document
Code Examples
Codewarrior "Bare Metal" Example Code:
All Codewarrior based code examples for the FRDM-TFC are hosted on in a Subversion repository on Google Code:
frdm-tfc -   Example code for the FRDM-TFC Shield - Google Project Hosting
You can check out the code with your favorite SVN client.   Static releases are available in the attachments section of this page.  The current release is "R1.0"
mbed.org Example Code:
https://mbed.org/components/Freescale-Cup-with-FRDM-KL25Z/
Videos
FRDM TFC EXAMPLE CODE GETTING STARTED
FRDM-TFC_DEMO 0 and 1
FRDM-TFC_DEMO 2 and 3
添付
コメント
Are you going to use the freedom board for the Freescale Cup competitions?
Varies by region.  But yes, starting in 2014 we will be offering a freedom based version.  What you see above is the work we are doing today to get it ready.
**The rules will likely stay the same that you can use any Freescale 32-bit MCU.
Where I can buy the freescale cup shield for the freedom board?
It will be in the new TFC-KIT.  Currently we don't sell individually, but working to set that up for the future.
Still reading the specs but I assume the KL25Z is getting power from the power up of the TFC shield?  Saw the ground warnings about not powering up both (TFC with battery while KL25Z from USB) so likely we have to program first (no batt)-- then unplug USB to test with battery (or other 7.2V, 0.1A source).   There is no direct way to test the car 'online' so to speak.
Daniel:
Where did you see this warning?  I have had the battery and USB hooked up at the same time.
Comment in the assembly manual PUB doc near the end: "Never power the microcontroller from different power sources! Switch off the MCU board before you connect your it to your PC."   Also here: https://community.freescale.com/docs/DOC-1020 where it mentions:
NOTE: Never power the microprocessor board and interface boards from different power supplies! In such case the grounds on both boards are
not connected and you can damage the board. The grey flat ribbon cable that interconnects the boards is for signals only, there is no common
GND connection!"
This could be specific to the Qorriva implementation-- just wanted to be sure before frying anything.
It was an issue with that setup.  More broadly though, it is still a valid preventative caution.  Don't assume! Read the schematics and understand what the underlying circuitry is doing.
Dan:
This is not an issue KL25Z based TFC board.    The return for the battery and the return for the USB are tied together so the reference potential is held to the same value.
That being said.... Here is the only issue you may have.     NEVER measure the voltage across the motors during  operation with a scope ground connected to either side.    This could cause a path issue.  With an H-Bridge,  The outputs are references to 1/2 VCC.        This could cause an issue unless you scope is floating or running on  battery.   You can look at each side of the motor (H-BRIDGE) with respect the GND on the PCB and be OK or take a different measurement.
-Eli
Eli,
Thanks—Was not looking to measure the actual motor voltage but the PWM inputs to the Hbridge very soon to confirm the issue that David found (where openSDA appears to cause contention)—as I saw some funny stuff when operating the demo code.
Dan
What happened with RCA camera demo with the FRDM and the shield?
I have a problem trying to run the labview application for the line scan camera. I got the following error:
Can someone help me?
Dear Andres,
Do you have installed the NI VISA drivers from National Instrument Website?
Here is the link:
NI-VISA 5.4 - National Instruments
Hi Juan,
Thanks for your help. I have to install the drivers before or after install Labview?
Best,
Dear Andres,
1.- First install the LabVIEW.
2- Then install the NI Device drivers: NI Device Drivers 2013.02 - National Instruments
3.- Finally install the NI VISA drivers: NI-VISA 5.4 - National Instruments
-Juan
The link for mbed example code doesn't work.
Updated.
This example code works also for the FRDM-KL46Z?
Is it still not possible to buy FRDM-TFC board alone(not the TFC kit)?
Send me a private email with how many you need.
Me too!! Can I also send you a private email?
John?
Yes???
Anyone can send me private message on the community.  Click Create->Message at the top of this page!
How can I find out how to use the inputs of the H-Bridge control? I get from the schematic that there are 8 inputs (A-IN1, A-IN2, A-IFB, ENABLE, FAULT, B-IN1, B-IN2, B-IFB) and the schematic shows their corresponding pins, but I don't know what signals to give them. The example code doesn't seem to be using all of them, and I'm planning to write code using Processor Expert components. Can I find the specs somewhere?
Valentin:
1.)   Have you looked at the Datasheet for the part?   It has a good picture of the internals!    Even processor expert won't tell you how the chip works.  It is important to study datasheet *before* you write any code
2.)  Study the source code for the example code to see how it works.    Basically, you need to drive complementary signals into each bridge.
Hello Eli,
Thank you for replying.
  1. I think I have the wrong datasheet(http://cache.freescale.com/files/analog/doc/data_sheet/MC33931.pdf) because it shows me less pins (IN1, IN2, D1, D2) than the ones from the schematic, and I'm not sure how they correspond to those from the TFC shield and therefore, to those from the KL25Z board. Can you tell me if it's the right one and if it is, how to deal with the pin problem?
  2. I've studied the code and your videos on how to control the motors, and the demo videos. I've tested your code and it works. I have some troubles in writing code like yours, but with PE components. Maybe with the answer from question 1), I'll understand what I'm missing.
The schematic (available to download above) says the part number is a MC33887.   Not sure where you found that part number.
Sorry, I didn't compare the part number from the schematic with the part number from the datasheet I found. I got that datasheet by clicking the mbed.org Example Code link on this page (Freescale Cup with FRDM-KL25Z | mbed), clicked under Datasheet (The Freescale Cup Knowledge Center), then on Freescale Cup DC Motor Specifications and then on H-Bridge Specifications http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC33931&webpageId=M98446&nodeId=01435...
I realize now that it was a mistake.
Anyway, it still shows me less pins (IN1, IN2, D1, D2, EN) and I don't know how they corespond to the ones from the schematic (A-IN1, A-IN2, A-IFB, ENABLE, FAULT, B-IN1, B-IN2, B-IFB) or the ones in your code. Your insight would be most helpful.
Did you get schematics?   If you did, you will see the page that has the 2 H-Bridges and the signal mapping.   There are 2 sets of signals for each H-Bridge
Thank you Eli!
I managed to get the code working. Turns out I only need to set ENABLE to High and send complementary PWM signals to A-IN1, A-IN2 to controll the speed and direction of motor A, and send complementary PWM signals to B-IN1, B-IN2 to controll the speed and direction of motor B. I would have been stuck without your help.
Hi John
I sent a private message and a e-mail also (in your Freescale address) but I didn't receive any response. Did you receive them?
Is there any example code for the speed sensor?
Hi, see https://community.freescale.com/docs/DOC-95170 for the implementation of the speed sensor. To my knowledge there is no sample code readily available from Freescale but I would post the question in the open forum or your respective region to see if a team member from another group can share one with you.
Hey John
Could you send/sell me:
1 x FRDM-TFC shield rev1.0 (or newest version)
1 x TFC-CAMERA-ASY line scan camera
In the website the delivery time is in August and I can't wait this time. Flavio Stiffan told me he doesn't have these hardware with him....
I would just place the order.  John mentioned that the online system often reports very long delivery times even though eveything is in stock.
What country are you in?
Sweden
hi,
I have 1 question....
I can't know how I apply 'build package' to code warrior.
plz someone answer my question.
Best Regards
Hi, have you looked at the videos under thread Freescale Cup Shield for the Freedom KL25Z?
I'm using Processor expert to generate some configuration code.
The problem I have is that I can't get to work the PTD6 or PTD5 pins used by the linescan sensor.
But with the same configuartion I can use other pins to do the ADC.
I don't think this is a hardware problem because sample code works fine.
And my code works too but only on other ADC pins.
emh203 would you have a chance to look at this, maybe you have an idea. Thanks
I am quite backed up with work right now.    Some source code would be helpful.
My guess is that the environment is getting trashed by Processor Expert.    My best advice is to inspect the device registers with the debugger and see what isn't configured right.   Also,  since you have working drivers,  just skip PE and get to writing your application.
We have been provided 7.2V 2000mAh Ni-Cd battery with the freescale kit and 12V charger.So, what can be the maximum voltage of the Ni-Cd battery when fully charged? once when i charged, it reaches upto 8.5V, so I fear of damaging the battery.
So, Should I charge it with given charger and Charge battery upto 9V??
Take a look at the specs for the battery.    7.2 is nominal voltage BUT you do not want it overcharging.   (i.e. Fire!)
You mention a 12v charger.   Can you take a picture?
my team is starting at the innovation cup and we want to use this TFC-Shield combined with the FRDM K64F board. Is there any example like this, how to use the TFC-Shield in a K64F project?
Hi David,
Yes, it has been tested. I recommend you get in touch with massimoviolante and RichardBalogh, they have worked on that.
RichardBalogh_ng has 2 addresses, you can also try on this one
TFC-Shield and K64F is a logical combination, but unfortunately not an easy one. As the boards don't have the compatible pinouts, you'll need to rewire the connections
and can't use the boards immediately. Here you can find the comparison table (also Arduino Uno included, as the producer declared the boards compatible with Arduino shields):
http://robotika.sk/tfc/PinoutComparison.xls
As you can see, the appropriate signals don't match.
I have wired it up and it isn't too bad.   Some notes:
1.)    The selection of I/O on the FRDM board was based upon TPM (Timer Pulse Width Modulators) availability to optimize the usage of the hardware.  It was not mapped to Arduino as the psuedo standard pinout was not optimal for using the the FRDM board.   Arduino compatibility really only means power and some I/O line up and that it meets a mechanical footprint.
2.)  TPM0 (labeled as FTM0 in the spreadsheet) is the Timebase for the PWM to the DC motors.    You need complimentary drive so you need 2 channels of TPM on the same time base (@5-10Khz switching)
3.)  TPM1 channels 0 and 1 are for the servo time base.   It is *much* slower period than the motor drive so it needs it's own time base.
4.)  The speed sensors are on there own time base (TPM2).
5.) The K64 CPU has FTM units, not TPM like the KL25Z.    FTM peripherals are more complex are you will need to port functionality!  This means you will need to read the reference manual and write some code.
So,  before you start,   make sure you absolutely understand what signals are needed to drive the motors (@10KHz complimentary PWM) and servo (0.5mS to 2mSec pulse @ 20mS period).    You need map these signals onto the flex timer units on the K64.   Some of the signals line up and others do not.  I only needed a couple of air wires to make the connections.   The bigger job is updating the code to the FTM and not TPM.
It is a good academic exercise but you must first fundamentally understand the IO on the FRDM-TFC.   Once you understand the IO and peripherals you should be able to wire it up to *any* microcontroller.
%3CLINGO-SUB%20id%3D%22lingo-sub-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%20KL25Z%E7%94%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380609040%22%20id%3D%22toc-hId-1304187823%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1060667410%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1751228884%22%20target%3D%22_blank%22%3E%E7%89%B9%E9%95%B7%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1863680042%22%20target%3D%22_blank%22%3E%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-623832791%22%20target%3D%22_blank%22%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--1183621672%22%20target%3D%22_blank%22%3EVideos%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--493060198%22%20target%3D%22_blank%22%3EFRDM%20TFC%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E5%85%A5%E9%96%80%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId-1994452635%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%200%20%E3%81%8A%E3%82%88%E3%81%B3%201%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-Cup-Shield-for-the-Freedom-KL25Z%2Fta-p%2F1104533%23toc-hId--508165307%22%20target%3D%22_blank%22%3EFRDM-TFC_DEMO%202%20%E3%81%8A%E3%82%88%E3%81%B3%203%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1426845423%22%20id%3D%22toc-hId--503266640%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1060667410%22%20id%3D%22toc-hId-1984246193%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM-TFC%E3%81%AF%E3%80%81%E6%9C%80%E5%A4%A72%E3%81%A4%E3%81%AEDC%E3%83%A2%E3%83%BC%E3%82%BF(%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%82%E3%81%9F%E3%82%8A5A)%E3%80%812%E3%81%A4%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9C%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%AB%E3%83%83%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A8%E3%83%9B%E3%83%BC%E3%83%AB%E5%8A%B9%E6%9E%9C%E3%82%BB%E3%83%B3%E3%82%B5%E7%94%A8%E3%81%AEI%2FO%E3%82%92%E9%A7%86%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E4%BE%BF%E5%88%A9%E3%81%AA%E3%80%8C%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2FFRDM-KL25Z%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKL25Z%3C%2FA%3E%20Freedom%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%AB%E3%83%BC%E3%81%A7%E4%B8%BB%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-TFC.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40270iD0A099A2D21084FC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-TFC.png%22%20alt%3D%22FRDM-TFC.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture%20004.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84347i98F4482AEB143621%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture%20004.jpg%22%20alt%3D%22Picture%20004.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751228884%22%20id%3D%22toc-hId--1620159629%22%3E%E7%89%B9%E9%95%B7%EF%BC%9A%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90IC(MC33887APVW)%3C%2FLI%3E%3CLI%3E2%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%9C%E5%87%BA%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1058%22%20target%3D%22_blank%22%3E%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%AB%E3%83%A1%E3%83%A9%20%3C%2FA%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FLI%3E%3CLI%3E%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E7%94%A8%E3%81%AE2%E3%81%A4%E3%81%AE%E5%85%A5%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%86%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%A1%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3%3C%2FLI%3E%3CLI%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AE4%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%B3DIP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AE4%E3%81%A4%E3%81%AELED(%E7%B7%91)%3C%2FLI%3E%3C%2FUL%3E%3CH1%20id%3D%22toc-hId-1740725780%22%20id%3D%22toc-hId--1630662733%22%3E%3C%2FH1%3E%3CH2%20id%3D%22toc-hId--1863680042%22%20id%3D%22toc-hId--940101259%22%3E%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-254727%2FFRDM-TFC-REVA-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AFRev%20A%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-257650%2FFRDM-TFC-REVB-BUILD_PACKAGE.zip%22%20target%3D%22_blank%22%3ERev%20B%E3%81%AF%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-623832791%22%20id%3D%22toc-hId-1547411574%22%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3ECodewarrior%20%22Bare%20Metal%22%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFRDM-TFC%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20Codewarrior%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E4%BE%8B%E3%81%AF%E3%80%81Google%20Code%20%E3%81%AE%20Subversion%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A7%E3%83%9B%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Ffrdm-tfc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Efrdm-tfc%20-%20FRDM-TFC%20%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%20-%20Google%20Project%20Hosting%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E6%B0%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%AESVN%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F93914-24-264428%2FFRDM-TFC_R1.0.zip%22%20target%3D%22_blank%22%3E%E9%9D%99%E7%9A%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%26nbsp%3B%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%8CR1.0%E3%80%8D%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Embed.org%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1183621672%22%20id%3D%22toc-hId--260042889%22%3EVideos%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--493060198%22%20id%3D%22toc-hId-430518585%22%3EFRDM%20TFC%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E5%85%A5%E9%96%80%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FplL3U2MYLxk%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1994452635%22%20id%3D%22toc-hId--1376935878%22%3EFRDM-TFC_DEMO%200%20%E3%81%8A%E3%82%88%E3%81%B3%201%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FxypYb2jfLPQ%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--508165307%22%20id%3D%22toc-hId-415413476%22%3EFRDM-TFC_DEMO%202%20%E3%81%8A%E3%82%88%E3%81%B3%203%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIFRAME%20frameborder%3D%220%22%20width%3D%22425%22%20height%3D%22350%22%20src%3D%22https%3A%2F%2Fwww.youtube.com%2Fembed%2FjE_5q8pqy9w%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E3%80%81%E8%BB%8A%E3%81%ABRx%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%80%81UART%E3%82%92%E5%90%AB%E3%82%80Tx%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Rx%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%861%E3%81%A4%E8%A8%80%E3%81%84%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E8%BB%8A%E3%81%8B%E3%82%89%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%BB%8A%E3%81%AB%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81UART%E3%81%AE%E3%83%95%E3%82%A3%E3%83%AB%E3%82%B9%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%9B%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99...%E8%AA%B0%E3%81%8B%E3%81%8B%E3%82%89%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E3%81%AB%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9C%B2%E5%85%89%E6%99%82%E9%96%93%E3%82%9250%E3%83%9F%E3%83%AA%E7%A7%92%E6%9C%AA%E6%BA%80%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Lab%20View%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%A5%87%E5%A6%99%E3%81%AA%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BF%A1%E5%8F%B7%E3%81%AB%E3%81%AF%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E3%83%91%E3%82%A4%E3%82%AF%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%80%A5%E9%80%9F%E3%81%AB%E7%8F%BE%E3%82%8C%E3%81%A6%E6%B6%88%E3%81%88%E3%81%9F%E3%82%8A%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%8A%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%80%9F%E3%81%8F%E4%B8%8A%E4%B8%8B%E3%81%AB%E5%8B%95%E3%81%84%E3%81%9F%E3%82%8A%E3%80%81%E3%80%8C%E9%9C%87%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%80%8D%E3%82%88%E3%81%86%E3%81%AB%E5%8B%95%E3%81%8D%E5%9B%9E%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8150%E3%80%9C45%E3%83%9F%E3%83%AA%E7%A7%92%E6%9C%AA%E6%BA%80%E3%81%AE%E4%BD%8E%E9%9C%B2%E5%85%89%E6%99%82%E9%96%93%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EK64F%E3%81%A8TFC%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81K64F%E3%81%AE%E3%83%94%E3%83%B3%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81K64F%E3%81%A7PTA10%E3%80%81PTA11%E3%80%81PTB12%E3%80%81PTB13%E3%80%81PTD5%E3%80%81PTD6%E3%80%81PTD7%E3%80%81PTE1%E4%BF%A1%E5%8F%B7%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%A7%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81TFC%20Pin%20Jx9%20%E3%81%AE%20V_Batterie%20Signal%20%E3%81%8C%E4%BD%95%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%93%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%20K64F%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.)%E3%81%AF%E3%82%93%E3%81%A0%E3%81%AF%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E7%AB%AF%E5%AD%90%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%A8%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E9%A0%98%E5%9F%9F%E3%82%92%E5%82%99%E3%81%88%E3%81%9Farduino%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92Web%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92FRDM-KL25Z%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEI%20%2F%20O%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EKL25Z%E3%81%A8FRDM_TFC%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81SDA%E3%81%ABUART%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E9%80%9F%E5%BA%A6%E6%84%9F%E7%9F%A5%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82UART%E6%A9%9F%E8%83%BD(%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E7%B7%9A)%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81UART2%E3%82%92SDA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E3%83%BB%E3%83%8F%E3%83%80%E3%83%83%E3%83%89%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E3%82%84%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AF%E5%91%A8%E3%82%8A%E3%82%92%E8%A6%8B%E5%9B%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ESDA%E3%80%81UART0%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92TFC%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AA%E5%90%8C%E3%81%98%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AEc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AEISR%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AFmod%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BE%A1%E5%80%A4%E3%80%82SDA%E3%81%BE%E3%81%9F%E3%81%AFUART0%E3%81%A8%E7%AB%B6%E5%90%88%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMB%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E7%9C%81%E7%95%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AF%E3%80%81%E6%BC%94%E7%BF%92%E3%81%A8%E3%81%97%E3%81%A6%E5%AD%A6%E7%94%9F%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%87%AA%E5%88%86%E3%81%A7%E8%A8%AD%E8%A8%88%E3%81%97%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E3%80%8C%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E8%A8%AD%E8%A8%88%20II%20%26amp%3B%20II%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3EThe%20Book%20of%20Eli%20-%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E3%83%AD%E3%83%9C%E3%83%86%E3%82%A3%E3%82%AF%E3%82%B9%E3%80%81%E3%83%AF%E3%83%BC%E3%83%97%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E7%9C%81%E7%95%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AF%E3%80%81%E6%BC%94%E7%BF%92%E3%81%A8%E3%81%97%E3%81%A6%E5%AD%A6%E7%94%9F%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%87%AA%E5%88%86%E3%81%A7%E8%A8%AD%E8%A8%88%E3%81%97%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E3%80%8C%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E8%A8%AD%E8%A8%88%20II%20%26amp%3B%20II%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3EThe%20Book%20of%20Eli%20-%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E3%83%AD%E3%83%9C%E3%83%86%E3%82%A3%E3%82%AF%E3%82%B9%E3%80%81%E3%83%AF%E3%83%BC%E3%83%97%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFKinetis%20FRDM-KL25Z%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82FRDM-TFC%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E7%94%A8%E3%81%AE3%E3%81%A4%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%20%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%A7%81%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%20%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E7%A7%81%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E3%80%81%E4%BD%95%E3%82%82%20%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22hps%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E3%82%92%20%E6%82%AA%E7%94%A8%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22alt-edited%20hps%22%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A3%E3%83%AF%E3%83%8F%E3%83%AB%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E9%9B%BB%E6%B0%97%E5%BA%97%E3%81%A7%E3%83%9B%E3%83%BC%E3%83%AB%E5%8A%B9%E6%9E%9C%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E7%8F%BE%E5%9C%B0%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%81%A7%E7%A0%94%E7%A9%B6%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E8%BB%8A%E3%81%AE%E3%83%9B%E3%82%A4%E3%83%BC%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BB%8A%E3%81%AB%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%A4%E3%83%B3%E3%83%89%E3%81%AB%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%83%89%E3%81%A7%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E5%BA%97%E8%88%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E9%A3%9B%E3%82%93%E3%81%A0%E6%99%82%E9%96%93%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%8C%E7%87%83%E3%81%88%E3%82%8B...%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF3%E9%80%B1%E9%96%93%E5%BE%8C%E3%81%ABEMEA%E3%81%AEFreeacale%E3%82%AB%E3%83%83%E3%83%97%E3%81%AB%E5%8F%82%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E6%88%A6%E5%A3%AB%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%80%81%E8%BB%8A%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%AA%81%E7%84%B6%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%86%B1%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81FRDM-TFC%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%8C%E5%B0%91%E3%81%97%E7%87%83%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F!!%E3%83%94%E3%83%B316(J9)%E3%81%A8VBAT%E3%81%AE%E9%96%93...%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E5%88%A5%E3%81%AE%E3%82%B7%E3%83%BC%E3%83%AB%E3%81%A7%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81R8%E3%81%AE%E6%8A%B5%E6%8A%97%E3%81%8C%E7%87%83%E3%81%88%E5%B0%BD%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%B7%E3%83%BC%E3%83%AB(%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE)%E3%82%92%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%B0%91%E3%81%97%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99!%E3%80%8CChemillards%E3%80%8D%E3%81%A8%E3%82%B8%E3%83%A3%E3%82%B9%E3%83%88%E3%80%82Heli%20Huges%E3%81%AEMain.C%E3%81%A7%E3%83%AA%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%83%90%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E5%BA%8F%E7%9B%A4%E3%81%AE%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E5%85%A8%E3%81%A6%E3%81%8C%E8%89%AF%E3%81%8B%E3%81%A3%E3%81%9F...%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%B4%844%E5%88%86%E5%BE%8C%E3%81%AB%E3%81%AF%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%82%E7%87%83%E3%81%88%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%9A%E3%80%81%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E6%9C%AC%E5%BD%93%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E3%81%8C%E3%81%A3%E3%81%8B%E3%82%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%89%8D%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.)%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMC33887APVW%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%26nbsp%3B%26nbsp%3B%20%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%88%E3%83%AB%E3%82%AF%E5%88%B6%E5%BE%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E9%9B%BB%E6%B5%81%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E3%81%AF%E3%81%84%E3%80%82%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%A6%8B%E3%82%8C%E3%81%B0%E3%80%81%E7%AD%94%E3%81%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETFC%E3%81%AE%E7%89%B9%E5%BE%B4%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%8CH%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8IFA%5CIFB%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E1.%E5%BD%BC%E3%82%89%E3%81%AF%E4%BD%95%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20PWM%E5%87%BA%E5%8A%9B%E3%81%AEH%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E8%BB%8A%E3%81%AE%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20KL25Z%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95(%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E9%9B%BB%E5%9C%A7)%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!!%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E7%A7%81%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%97%E3%81%9F...%E7%A7%81%E3%81%AF%E7%84%A1%E6%96%99%E3%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F...%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E6%97%A5%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%AA%E3%81%93%E3%81%A8%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%99...FRDM%20KL25Z%E3%82%92%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%BB%8A%E3%81%AF%E7%A7%81%E3%81%8C%E6%9C%9B%E3%82%80%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%BE%E3%81%99!%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E5%BD%BC%E3%81%AEUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%8A%9C%E3%81%8F%E3%81%A8%E3%81%8D%E3%80%81%E8%BB%8A%E3%81%AF%E4%BD%95%E3%82%82%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93...%E6%9C%80%E5%88%9D%E3%81%AF%E3%83%90%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%A3%E3%81%B1%E3%81%84%E3%81%A7%E3%81%99...%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%BA%95%E3%81%8C%E3%81%A8%E3%81%A6%E3%82%82%E3%81%A8%E3%81%A6%E3%82%82%E3%81%A8%E3%81%A6%E3%82%82%E7%86%B1%E3%81%84%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F!!%E7%89%87%E5%81%B4%E3%81%AB3%E3%83%94%E3%83%B3%E3%80%81%E5%8F%8D%E5%AF%BE%E5%81%B4%E3%81%AB1%E3%81%A4%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E8%BF%91%E3%81%8F...%E4%BB%8A%E6%97%A5%E3%80%81%E5%88%9D%E3%82%81%E3%81%A6%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F!!%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3ELe%2018%20d%C3%A9c.%202014%20%C3%A0%2013%3A56%2C%20Eli%20Hughes%20%3CADMIN%3E%20a%20%C3%A9crit%20%3A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%20KL25Z%E7%94%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3EEli%20Hughes%20%26lt%3B%26gt%3B%E3%81%AB%E3%82%88%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%AB%E3%83%BC%E3%82%AB%E3%82%B9%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86...%20%20LED%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%9C%A7%E7%B8%AE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%2F%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%80%81Eli%20Hughes%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%A7%26lt%3B%26gt%3B%3A%E5%8F%97%E4%BF%A1%E7%AE%B1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%AB%E3%83%BC%E3%82%AB%E3%82%B9%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%82%87%E3%81%86...%26nbsp%3B%20LED%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%9C%A7%E7%B8%AE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%2F%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222003%22%20data-containertype%3D%2214%22%20data-objectid%3D%2293914%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93914%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AD%E3%81%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emi%20FRDM%20KL25Z%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E8%89%AF%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A7%E3%81%99!%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A9%E3%83%AA%E3%82%A2%E3%83%BC%E3%81%AE%E5%8F%8B%E9%81%94%E3%81%A7%E3%81%99!%20%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E3%80%81%E8%BB%8A%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81CUP%E3%81%AB%E8%87%AA%E5%88%86%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B7%E3%83%BC%E3%83%AB%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%E3%81%9D%E3%81%97%E3%81%A6%E3%83%A2%E3%83%88%E3%81%AF%E3%83%95%E3%83%AB%E3%83%91%E3%83%AF%E3%83%BC%E3%81%A7%E3%81%99!!%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81LED%E3%82%92%E7%82%B9%E6%BB%85%E3%81%95%E3%81%9B%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%A7%92%E6%95%B0%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E8%89%AF%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%86%8D%E3%81%B3%E3%83%95%E3%83%AB%E3%83%91%E3%83%AF%E3%83%BC%E3%81%A7%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%A8Froze%E3%81%AE%E9%96%93%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%8E%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E6%99%82%E9%96%93%E3%82%92%E3%81%8B%E3%81%91%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A7%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%95%B0%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99...50%E5%9B%9E%E3%82%82%E5%87%8D%E3%82%8A%E4%BB%98%E3%81%8F!!%20%3C%2FP%3E%3CP%3E%E8%AA%AC%E6%98%8E%3A%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3Emain()%7B%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9(1)%20%7B%3C%2FP%3E%3CP%3Eif(%E3%83%86%E3%82%A3%E3%83%83%E3%82%AB%E3%83%BC%5B0%5D%20%26gt%3B%20T)%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AB%E3%83%BC%20%3D%200%3C%2FP%3E%3CP%3E%E5%91%BD%E4%BB%A4%3B%20%3C%2FP%3E%3CP%3E%E5%91%BD%E4%BB%A4%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C50%E5%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%83%86%E3%82%A3%E3%83%83%E3%82%AB%E3%83%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%81%8D%E3%81%AB%E8%BB%8A%E3%81%8C%E3%83%95%E3%83%AB%E3%83%91%E3%83%AF%E3%83%BC%E3%81%A7%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%99.....%22%20.%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%81%9D%E3%82%8C%E3%81%AF50%20*%20T%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99...%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%9B%BB%E5%8A%9B%E3%81%AF%E6%9C%80%E5%A4%A7...%20%3C%2FP%3E%3CP%3EA%E3%81%8C%E3%81%AA%E3%81%9C%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3F%3F%3F!!!%E7%A7%81%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E5%8A%A9%E3%81%91%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%811%E3%81%A4%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E6%9C%88%E3%81%AB%E8%B3%87%E6%A0%BCEMEAa%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%AE%E3%82%A2%E3%81%8C%E5%A3%8A%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%95%E3%83%AB%E3%83%91%E3%83%AF%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8C%E5%87%8D%E7%B5%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F..%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%8C%E6%96%B0%E3%81%97%E3%81%84%E3%81%A7%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBEST%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%82%AB%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%92%E3%82%A8%E3%82%A6%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS%3A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%83%95%E3%83%A9%E3%83%B3%E3%82%B9%E4%BA%BA%E3%81%A7%E3%80%81%E8%8B%B1%E8%AA%9E%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E4%B8%8A%E6%89%8B%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B5%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3ENI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%81%A9%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAzaj%20Vahora%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDavid%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%ABKL25Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%8B%95%E4%BD%9C%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%90%AB%E3%82%80%E6%97%A2%E7%9F%A5%E3%81%AE%E5%8B%95%E4%BD%9C%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%99%82%E9%96%93%E3%82%92%E5%A4%A7%E5%B9%85%E3%81%AB%E7%AF%80%E7%B4%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AB%E9%80%B2%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E5%B0%82%E9%96%80%E5%AE%B6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%92%E6%9C%80%E5%88%9D%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%9C%80%E5%88%9D%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%E8%BB%8A%E3%81%ABKwikstik%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%82%82%E3%81%84%E3%81%BE%E3%81%99%E3%80%82K64%E3%81%A8%E5%90%8C%E3%81%98FTM%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%92%E6%8C%81%E3%81%A4K40%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1057%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1057%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%A7%E8%A1%8C%E3%81%8A%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AF%E5%9B%9E%E8%BB%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EKDS%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E9%85%8D%E7%B7%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AE%E4%BE%8B%E3%81%A7%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%95%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E9%85%8D%E7%B7%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E6%82%AA%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%B3%A8%E6%84%8F%E7%82%B9%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%20FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20I%2FO%20%E3%81%AE%E9%81%B8%E6%8A%9E%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20TPM%20(Timer%20Pulse%20Width%20Modulators)%20%E3%81%AE%E5%8F%AF%E7%94%A8%E6%80%A7%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%96%91%E4%BC%BC%E6%A8%99%E6%BA%96%E3%81%AE%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%81%8CFRDM%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81Arduino%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82Arduino%E3%81%A8%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E9%9B%BB%E6%BA%90%E3%81%A8%E4%B8%80%E9%83%A8%E3%81%AEI%20%2F%20O%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E6%A9%9F%E6%A2%B0%E7%9A%84%E3%81%AA%E3%83%95%E3%83%83%E3%83%88%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%93%E3%81%A8%E3%81%AE%E3%81%BF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)TPM0(%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AFFTM0%E3%81%A8%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%81%AF%E3%80%81DC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%B8%E3%81%AEPWM%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E7%84%A1%E6%96%99%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E5%90%8C%E3%81%98%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB2%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AETPM%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99(%40%205-10Khz%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.)%20TPM1%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB0%E3%81%A81%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%9C%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%82%88%E3%82%8A%E3%82%82*%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB*%E9%81%85%E3%81%84%E6%9C%9F%E9%96%93%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E6%99%82%E9%96%93%E3%83%99%E3%83%BC%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.)%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%BC%E3%82%B9(TPM2)%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5.)%20K64%20CPU%E3%81%AB%E3%81%AFFTM%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81KL25Z%E3%81%AE%E3%82%88%E3%81%86%E3%81%AATPM%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82FTM%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AF%E3%82%88%E3%82%8A%E8%A4%87%E9%9B%91%E3%81%A7%E3%80%81%E6%A9%9F%E8%83%BD%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%A7%8B%E3%82%81%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC(%4010KHz%E7%9B%B8%E8%A3%9CPWM)%E3%81%A8%E3%82%B5%E3%83%BC%E3%83%9C(0.5mS%E3%80%9C2mSec%E3%83%91%E3%83%AB%E3%82%B9%40%2020mS%E5%91%A8%E6%9C%9F)%E3%82%92%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92K64%E3%81%AE%E3%83%95%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BF%A1%E5%8F%B7%E3%81%AB%E3%81%AF%E3%80%81%E6%95%B4%E5%88%97%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E6%95%B4%E5%88%97%E3%81%97%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81%E6%95%B0%E6%9C%AC%E3%81%AE%E3%82%A8%E3%82%A2%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A0%E3%81%91%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%AA%E4%BB%95%E4%BA%8B%E3%81%AF%E3%80%81TPM%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FFTM%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%84%AA%E3%82%8C%E3%81%9F%E5%AD%A6%E8%A1%93%E6%BC%94%E7%BF%92%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E5%88%9D%E3%81%ABFRDM-TFC%E3%81%AEIO%E3%82%92%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82IO%E3%81%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92*%E4%BB%BB%E6%84%8F%E3%81%AE*%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3ETFC-Shield%E3%81%A8K64F%E3%81%AF%E8%AB%96%E7%90%86%E7%9A%84%E3%81%AA%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E9%85%8D%E7%B7%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%90%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%93%E3%81%AB%E6%AF%94%E8%BC%83%E8%A1%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99(%E3%83%97%E3%83%AD%E3%83%87%E3%83%A5%E3%83%BC%E3%82%B5%E3%83%BC%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92Arduino%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E5%AE%A3%E8%A8%80%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81Arduino%20Uno%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%20%3CA%20href%3D%22http%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Frobotika.sk%2Ftfc%2FPinoutComparison.xls%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%A6%A7%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh_ng%22%20target%3D%22_blank%22%3ERichardBalogh_ng%3C%2FA%3E%20%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%82%E8%A9%A6%E7%9D%80%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmassimoviolante%22%20target%3D%22_blank%22%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8Cmassimoviolante%3C%2FA%3E%E3%81%A8%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FRichardBalogh%22%20target%3D%22_blank%22%3ERichardBalogh%3C%2FA%3E%E3%81%A8%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E3%82%A4%E3%83%8E%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AB%E3%83%83%E3%83%97%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AETFC-Shield%E3%82%92FRDM%20K64F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BE%8B%E3%80%81K64F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7TFC-Shield%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%B9%E3%83%9A%E3%83%83%E3%82%AF%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%827.2%E3%81%AF%E5%85%AC%E7%A7%B0%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E9%81%8E%E5%85%85%E9%9B%BB%E3%81%AF%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E7%81%AB%E4%BA%8B%E3%81%A0!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF12v%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%86%99%E7%9C%9F%E3%81%AF%E6%92%AE%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E7.2V%202000mAh%20Ni-Cd%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%83%E3%83%88%E3%80%8112V%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%AF%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E5%85%85%E9%9B%BB%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AENi-Cd%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E6%9C%80%E5%A4%A7%E9%9B%BB%E5%9C%A7%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E4%B8%80%E5%BA%A6%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E3%81%A88.5V%E3%81%BE%E3%81%A7%E9%81%94%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E7%A0%B4%E6%90%8D%E3%81%99%E3%82%8B%E6%81%90%E3%82%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%A7%E5%85%85%E9%9B%BB%E3%81%97%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%9C%80%E5%A4%A79V%E3%81%BE%E3%81%A7%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8A%E3%81%AF%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%8B%E3%81%AA%E3%82%8A%E5%BF%99%E3%81%97%E3%81%8F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%AF%E3%80%81%E7%92%B0%E5%A2%83%E3%81%AFProcessorExpert%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B4%E3%83%9F%E7%AE%B1%E3%81%AB%E6%8D%A8%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E6%9C%80%E5%96%84%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E6%A4%9C%E6%9F%BB%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81PE%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%8F%96%E3%82%8A%E6%8E%9B%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Femh203%22%20target%3D%22_blank%22%3EEMH203%3C%2FA%3E%20%E3%81%93%E3%82%8C%E3%82%92%E8%A6%8B%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%82%82%E3%81%97%E3%81%8B%E3%81%97%E3%81%9F%E3%82%89%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFProcessor%20expert%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BPTD6%E3%81%BE%E3%81%9F%E3%81%AFPTD5%E3%83%94%E3%83%B3%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E6%A7%8B%E6%88%90%E3%81%A7%E3%80%81%E4%BB%96%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6ADC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AEADC%E3%83%94%E3%83%B3%E3%81%A7%E3%81%AE%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93914%22%20target%3D%22_blank%22%3EFreedom%20KL25Z%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89Freescale%20Cup%20Shield%3C%2FA%3E%E3%81%AE%E4%B8%8B%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%3C%2FP%3E%3CP%3E1%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99....%3C%2FP%3E%3CP%3E%E3%80%8C%E3%83%93%E3%83%AB%E3%83%89%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8D%E3%82%92%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A9%E3%83%AA%E3%82%A2%E3%83%BC%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B9%E3%82%A6%E3%82%A7%E3%83%BC%E3%83%87%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9F%E3%81%A0%E6%B3%A8%E6%96%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%9C%A8%E5%BA%AB%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%95%B7%E3%81%84%E9%85%8D%E9%81%94%E6%99%82%E9%96%93%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%9A%E3%81%84%E3%81%A8%E8%BF%B0%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%A9%E3%81%AE%E5%9B%BD%E3%81%AB%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E3%81%AD%E3%81%88%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E9%80%81%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E5%A3%B2%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20FRDM-TFC%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89rev1.0(%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E1%20x%20TFC-CAMERA-ASY%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E3%81%AF%E9%85%8D%E9%81%94%E6%99%82%E6%9C%9F%E3%81%8C8%E6%9C%88%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E6%9C%9F%E3%81%8C%E5%BE%85%E3%81%A1%E9%81%A0%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%93%E3%82%AA%E3%83%BB%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%83%95%E3%82%A1%E3%83%B3%3CSPAN%20style%3D%22color%3A%20%23a9a9a9%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E7%A7%81%E3%81%AB%E8%A8%80%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95170%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95170%3C%2FA%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%99%E3%81%90%E3%81%AB%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%BB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E5%9C%B0%E5%9F%9F%E3%81%AB%E8%B3%AA%E5%95%8F%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%80%81%E4%BB%96%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%83%81%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%A1%E3%83%B3%E3%83%90%E3%83%BC%E3%81%8C%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%A4%E3%83%B3%E3%83%86%E3%83%AA%E3%82%B8%E3%82%A7%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AB%E3%83%BC%E9%96%8B%E7%99%BA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTFC-KIT%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETFC-KIT%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%83%BB%E3%82%A4%E3%83%B3%E3%83%86%E3%83%AA%E3%82%B8%E3%82%A7%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AB%E3%83%BC%E9%96%8B%E7%99%BA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A8%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%82%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E(%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEFreescale%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3C%2FSPAN%3E%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%8C%E3%80%81%E8%BF%94%E4%BF%A1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%B1%8A%E3%81%84%E3%81%9F%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A4%E3%83%BC%E3%83%A9%E3%82%A4%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AA%E3%82%93%E3%81%A8%E3%81%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ENABLE%E3%82%92High%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81A-IN1%E3%80%81A-IN2%E3%81%AB%E7%9B%B8%E8%A3%9CPWM%E4%BF%A1%E5%8F%B7%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BCA%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%A8%E6%96%B9%E5%90%91%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%80%81B-IN1%E3%80%81B-IN2%E3%81%AB%E7%9B%B8%E8%A3%9CPWM%E4%BF%A1%E5%8F%B7%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BCB%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%A8%E6%96%B9%E5%90%91%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%82%88%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E7%A7%81%E3%81%AF%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AF%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%812%20%E3%81%A4%E3%81%AE%20H%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%A8%E4%BF%A1%E5%8F%B7%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E5%90%AB%E3%82%80%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%90%84H%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AB%E3%81%AF2%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AE%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%A8%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%20mbed.org%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%83%AA%E3%83%B3%E3%82%AF(%3CA%20href%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20title%3D%22https%3A%2F%2Fmbed.org%2Fcomponents%2FFreescale-Cup-with-FRDM-KL25Z%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreescale%20Cup%20with%20FRDM-KL25Z%20%7C%20mbed%3C%2FA%3E)%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1284%22%20target%3D%22_blank%22%3EThe%20Freescale%20Cup%20Knowledge%20Center%3C%2FA%3E)%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93309%22%20target%3D%22_blank%22%3E%E6%AC%A1%E3%81%ABFreescale%20Cup%20DC%E3%83%A2%E3%83%BC%E3%82%BF%E4%BB%95%E6%A7%98%3C%2FA%3E%20%E3%80%81%E6%AC%A1%E3%81%ABH-Bridge%E4%BB%95%E6%A7%98%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20title%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dtax%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMC33931%26amp%3BwebpageId%3DM98446%26amp%3BnodeId%3D01435979968446%26amp%3BfromPage%3Dt...%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%A8%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%9B%E3%82%88%E3%80%81%E3%81%BE%E3%81%A0%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%94%E3%83%B3(IN1%E3%80%81IN2%E3%80%81D1%E3%80%81D2%E3%80%81EN)%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%8F%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AE%E3%83%94%E3%83%B3%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E(A-IN1%E3%80%81A-IN2%E3%80%81A-IFB%E3%80%81ENABLE%E3%80%81FAULT%E3%80%81B-IN1%E3%80%81B-IN2%E3%80%81B-IFB)%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E3%83%94%E3%83%B3%3C%2FSPAN%3E%E3%81%A8%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%B4%9E%E5%AF%9F%E3%81%8C%E6%9C%80%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3(%E4%B8%8A%E8%A8%98%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%8F%AF%E8%83%BD)%E3%81%AB%E3%81%AF%E3%80%81%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%8CMC33887%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%91%E3%83%BC%E3%83%84%E7%95%AA%E5%8F%B7%E3%81%8C%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Eli%2C%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88(%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fanalog%2Fdoc%2Fdata_sheet%2FMC33931.pdf%3C%2FA%3E)%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AE%E3%83%94%E3%83%B3(IN1%E3%80%81IN2%E3%80%81D1%E3%80%81D2)%E3%82%88%E3%82%8A%E3%82%82%E5%B0%91%E3%81%AA%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8CTFC%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E3%83%94%E3%83%B3%E3%80%81%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6KL25Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%A8%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%82%82%E3%81%97%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E7%A7%81%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%88%B6%E5%BE%A1%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%A2%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E7%A0%94%E7%A9%B6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E3%81%AE%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81PE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%A7%E3%80%82%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E8%B3%AA%E5%95%8F1)%E3%81%AE%E7%AD%94%E3%81%88%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EValentin%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.)%20%E3%81%9D%E3%81%AE%E9%83%A8%E5%93%81%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E5%86%85%E9%83%A8%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99!%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%A7%E3%81%95%E3%81%88%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8F%E5%89%8D%E3%81%AB%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%8B%89%E5%BC%B7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.)%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E5%90%84%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AB%E7%9B%B8%E8%A3%9C%E7%9A%84%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%82%92%E9%80%81%E3%82%8A%E8%BE%BC%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EH-Bridge%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%8B%E3%82%89%E3%80%818%E3%81%A4%E3%81%AE%E5%85%A5%E5%8A%9B(A-IN1%E3%80%81A-IN2%E3%80%81A-IFB%E3%80%81ENABLE%E3%80%81FAULT%E3%80%81B-IN1%E3%80%81B-IN2%E3%80%81B-IFB)%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%80%81Processor%20Expert%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7%E3%82%B9%E3%83%9A%E3%83%83%E3%82%AF%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%82%E3%80%82%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%A7%E3%82%82%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E7%A7%81%E3%81%AB%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%8A%E9%83%A8%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8CCreate-%26gt%3BMessage%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJohn%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%EF%BC%81%EF%BC%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%82%E9%80%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BF%85%E8%A6%81%E3%81%AA%E6%95%B0%E3%82%92%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%E9%80%81%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3EFRDM-TFC%E3%83%9C%E3%83%BC%E3%83%89%E5%8D%98%E4%BD%93(TFC%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%81%AF%E3%81%BE%E3%81%A0%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81FRDM-KL46Z%E3%81%A7%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9B%B4%E6%96%B0%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Embed%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.-%20%E3%81%BE%E3%81%9A%E3%80%81LabVIEW%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2-%20%E6%AC%A1%E3%81%AB%E3%80%81NI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F3802%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI%20Device%20Drivers%202013.02%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.-%20%E6%9C%80%E5%BE%8C%E3%81%ABNI%20VISA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Juan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Juan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Labview%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%89%8D%E3%81%BE%E3%81%9F%E3%81%AF%E5%BE%8C%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Andres%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENational%20Instrument%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89NI%20VISA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20title%3D%22http%3A%2F%2Fjoule.ni.com%2Fnidu%2Fcds%2Fview%2Fp%2Fid%2F4230%2Flang%2Fen%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENI-VISA%205.4%20-%20National%20Instruments%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%A8%E3%81%AElabview%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error_Labview.PNG.png%22%20style%3D%22width%3A%20351px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40618i265604713BE33895%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Error_Labview.PNG.png%22%20alt%3D%22Error_Labview.PNG.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM%E3%81%A8%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FRCA%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EEli%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E9%9B%BB%E5%9C%A7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%87%E3%83%93%E3%83%83%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E5%95%8F%E9%A1%8C(openSDA%E3%81%8C%E7%AB%B6%E5%90%88%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E5%A0%B4%E6%89%80)%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81Hbridge%E3%81%B8%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%82%92%E3%81%99%E3%81%90%E3%81%AB%E6%B8%AC%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDan%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81KL25Z%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AETFC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%81%AE%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%A8USB%E3%81%AE%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%AF%E3%80%81%E5%9F%BA%E6%BA%96%E9%9B%BB%E4%BD%8D%E3%81%8C%E5%90%8C%E3%81%98%E5%80%A4%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%B5%90%E3%81%B3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%AF%E8%A8%80%E3%81%A3%E3%81%A6%E3%82%82...%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E5%94%AF%E4%B8%80%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%E7%B5%B6%E5%AF%BE%E3%81%AB%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84tag%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AB%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%B0%E3%83%A9%E3%83%B3%E3%83%89%E3%82%92%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E5%81%B4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%A7%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E6%A8%AA%E5%88%87%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%91%E3%82%B9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82H%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%A7%E3%81%AF%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AF1%2F2VCC%E3%81%B8%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%8C%E3%83%95%E3%83%AD%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82PCB%E4%B8%8A%E3%81%AEGND%E3%82%92%E5%9F%BA%E6%BA%96%E3%81%AB%E3%81%97%E3%81%A6%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC(H-BRIDGE)%E3%81%AE%E4%B8%A1%E5%81%B4%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E6%B8%AC%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Eli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%88%E3%82%8A%E5%BA%83%E3%81%8F%E8%A6%8B%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AA%E4%BA%88%E9%98%B2%E7%9A%84%E6%B3%A8%E6%84%8F%E3%81%A7%E3%81%99%E3%80%82%E6%80%9D%E3%81%84%E8%BE%BC%E3%81%BE%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%AA%AD%E3%81%BF%E3%80%81%E5%9F%BA%E7%A4%8E%E3%81%A8%E3%81%AA%E3%82%8B%E5%9B%9E%E8%B7%AF%E3%81%8C%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AEPUB%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E6%96%B9%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%3A%E3%80%8C%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E9%9B%BB%E6%BA%90%E3%81%8B%E3%82%89%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!MCU%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92PC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%8D%20%E3%81%93%E3%81%A1%E3%82%89%E3%82%82%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1020%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-1020%3C%2FA%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20red%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E6%89%8B%E8%A8%98%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E9%9B%BB%E6%BA%90%E3%81%8B%E3%82%89%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A0%B9%E6%8B%A0%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%90%8D%E5%82%B7%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E7%81%B0%E8%89%B2%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E3%83%AA%E3%83%9C%E3%83%B3%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF%E4%BF%A1%E5%8F%B7%E5%B0%82%E7%94%A8%E3%81%A7%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EGND%E6%8E%A5%E7%B6%9A!%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFQorriva%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99-%E4%BD%95%E3%81%8B%E3%82%92%E6%8F%9A%E3%81%92%E3%82%8B%E5%89%8D%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaniel%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A8USB%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%A0%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81KL25Z%E3%81%AFTFC%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AE%E3%83%91%E3%83%AF%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%E3%81%8B%E3%82%89%E9%9B%BB%E5%8A%9B%E3%82%92%E5%BE%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%B8%A1%E6%96%B9%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%9C%B0%E4%B8%8A%E8%AD%A6%E5%91%8A%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F(TFC%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E3%80%81KL25Z%E3%81%AFUSB%E3%81%8B%E3%82%89)%E3%81%AE%E3%81%A7%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99(%E3%83%90%E3%83%83%E3%83%88%E3%81%AA%E3%81%97)-%E6%AC%A1%E3%81%ABUSB%E3%82%92%E6%8A%9C%E3%81%84%E3%81%A6%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC(%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE7.2V%E3%80%810.1A%E3%82%BD%E3%83%BC%E3%82%B9)%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%82%8F%E3%81%B0%E3%80%8C%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%8D%E3%81%A7%E8%BB%8A%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84TFC-KIT%E3%81%AB%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E5%80%8B%E5%88%A5%E3%81%AB%E8%B2%A9%E5%A3%B2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%B0%86%E6%9D%A5%E3%81%AB%E5%90%91%E3%81%91%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%B0%E5%9F%9F%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%AF%E3%81%84%E3%80%812014%E5%B9%B4%E3%81%8B%E3%82%89%E3%81%AF%E8%87%AA%E7%94%B1%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E4%BB%8A%E6%97%A5%E3%81%9D%E3%82%8C%E3%82%92%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BD%9C%E6%A5%AD%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE32%E3%83%93%E3%83%83%E3%83%88%E3%83%BB%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E7%82%B9%E3%81%AF%E5%A4%89%E3%82%8F%E3%82%89%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0KL25Z%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%81%AE%E5%A4%A7%E4%BC%9A%E3%81%A7%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%BB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-06-2013 05:28 PM
更新者:
