License for CodeWarrior TAP
2,808 次查看
alcodextech
how and where do i buy license for CodeWarrior TAP for debugging and flashing purposes only?
4 回复数
2,436 次查看
TomasPaez
Alcodex,
Let us know which device are you using the CW TAP so we can point you to the right version to use and their license models.
Thank you
2,436 次查看
alcodextech
MPC8308
2,436 次查看
TICS_Fiona
For MPC8308, the supported CodeWarrior tool is:
CodeWarrior Development Tools for PowerQUICC|Freescale
You need Developer Suite Level or higher to debugger MPC8308, for details, please refer to:
http://cache.freescale.com/files/soft_dev_tools/doc/fact_sheet/CWDEVSNETAPPFS.pdf
Fiona Kuang
Technical Information & Commercial Support
2,436 次查看
Carlos_Mendoza
Hi Alcodex,
In order to use the CodeWarrior TAP for debugging and flashing you first you need to acquire a CodeWarrior Development suite. On the following link you will find the CodeWarrior Development Suites information:
CodeWarrior Suites (Bas, Stand, Pro)|Freescale
Here is a video that explains how to register your new software suite and where to find the license and product installers:
How to register & activate my software|Freescale
Hope it helps!
Carlos Mendoza
Technical Support Engineer
