Hello, when I analyse the external circuit of VR5510 and calculate the FMEDA of the system,how can I integrate the FMEDA of VR5510 into my system FMEDA?
for example the function block:High voltage buck,Vpre, the MOS Q1 and Q2 has the failure mode and fit
PRE-Regulator has the failure mode and fit.
Accourding to failure mode (regulaterd output in OV UV drift ...)descripted in sheet<FMEDA_PM>,it seems the sub block <PRE-REGULATOR> includes the external MOSFET of Q1 and Q2.
已解决! 转到解答。
