Hi NXP
1.where can I get FMEDA files of S32K344、MC33664ATL1RG、TJA1042T/3、MC33879APEK、MC33775AT.
2.I have got the FMEDA SEooC Static - S32K344 file, but how can we calculate our FIT value according our bms application. thanks.
解決済! 解決策の投稿を見る。
unfortunately the FIT rate were not evaluated on those devices. Do you have a way to evaluate on your side if we provide to you the range of transistor count of those devices ?
let us know,
best regards,
ok,please provide the transistor count range for these devices.thanks
MC33664 transitor count is in the range 50k-500k referring to table 5 of SN29500
TJA1042 in the category >3k referring to table 4 of SN29500
MC33879 in the category 50k-500k referring to table 5 of SN29500
thank you
best regards
hello,
thank you very much
you can find for MC33775A in NXP DocStore website the Safety analysis report with FMEDA HW architectural metrics results "Rp698910 - Safety Analysis Report MC33775A (1.0)"
However, the MC33664, MC33879, TJA1042 are QM (Quality Managed) Auto AECQ100 products for which we don't produce a FMEDA as they are not developed according to ISO26262.
Hoping it helps you,
thank you
Valerie Bernon
Answer to Q2:
A2: The FIT is calculated as illustrated in ISO 26262 documentation, chapter 11 (ISO 26262-11:2018(E)) Section "4.6.2 Permanent base failure rate calculation methods"
Hope it helps.
NaveenM
