S32M2xx - Motor control use cases
Designed for 12V motor control applications, the S32M2 family, based on system-in-package (SiP) design, integrates high-voltage analog functionalities (MOSFET gate pre-drivers, physical communication interfaces - LIN/CAN FD, and voltage regulators) with a robust embedded MCU Core (S32K Arm® Cortex®-M4/M7 series core).
S32M2 integrates voltage regulators, pulse-width modulators, analog to digital converters, timers and non-volatile memory to reduce overall component count and reduce board space in a 64-pin LQFP-EP package.
The comprehensive motor control ecosystem based on Automotive Math and Motor Control Library(AMMCLib) set, FreeMASTER with Motor Control ApplicationTuning (MCAT) tool and Model-Based Design Toolbox (MBDT) helps to enable S32M2 MCU in wide range of motor control use cases.
The table below points to the articles with more detailed description each of S32M2 motor control use cases, hardware description, links to appropriate application notes articles, and software repositories.
Device
HW
Article
S32M244CC
S32M244LC
FOC with single shunt current measurement
The article focuses on solution-based Field Oriented Control (FOC) technique (typically used for 3-phase PMSM motors) with single shunt current measurement and without any position sensor (sensorless). The Encoder sensor is supported by SW option, but missing on BLDC PMSM  low voltage motor control accessory kit. The single shunt current measurement is an advanced technique that allows decrease the cost of Bill of Material (BOM). The example codes uses RTD drivers with low-level non-Autosar API.
Hall sensor based Six-step commutation control.
The article focuses on solution-based Six-step commutation (6-step) technique (typically used for 3-phase BLDC motors) with Hall position sensor. The example code uses RTD drivers with low-level non-Autosar API..
Sensorless Six-step commutation control.
The article focuses on solution-based Six-step commutation (6-step) technique (typically used for 3-phase BLDC motors) without position sensor (sensorless). The example code uses RTD drivers with low-level non-Autosar API.
S32M276CH
S32M276LH
Note: the list of use cases cannot cover all combinations of MCU, current measurement scenario, control technique and sensor inputs, but should work as a base reference for most common configurations.
%3CLINGO-SUB%20id%3D%22lingo-sub-2039790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M2xx%20-%20%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%81%AE%E4%BD%BF%E7%94%A8%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E12V%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%90%91%E3%81%91%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2FS32M2%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32M2%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3C%2FA%3E%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8(SiP)%E8%A8%AD%E8%A8%88%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%AB%98%E9%9B%BB%E5%9C%A7%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E6%A9%9F%E8%83%BD(MOSFET%E3%82%B2%E3%83%BC%E3%83%88%E3%83%BB%E3%83%97%E3%83%AA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E7%89%A9%E7%90%86%E9%80%9A%E4%BF%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9(LIN%2FCAN%20FD)%E3%80%81%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF)%E3%81%A8%E5%A0%85%E7%89%A2%E3%81%AA%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFMCU%E3%82%B3%E3%82%A2(%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%3AS32K-MCUS%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32K%20Arm%3CSUP%3E%C2%AE%3C%2FSUP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ECortex-M4%3CSUP%3E%C2%AE%3C%2FSUP%3E%2FM7%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%82%B3%E3%82%A2%3C%2FA%3E)%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ES32M2%E3%81%AF%E3%80%81%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%80%81%E3%83%91%E3%83%AB%E3%82%B9%E5%B9%85%E5%A4%89%E8%AA%BF%E5%99%A8%E3%80%81%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0-%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%80%81%E4%B8%8D%E6%8F%AE%E7%99%BA%E6%80%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%80%81%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E9%83%A8%E5%93%81%E7%82%B9%E6%95%B0%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%97%E3%80%81%E5%9F%BA%E6%9D%BF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CA%20title%3D%22%E8%BB%8A%E8%BC%89%E7%94%A8%E6%BC%94%E7%AE%97%2F%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20(AMMCLib)%20%E3%82%BB%E3%83%83%E3%83%88%22%20href%3D%22https%3A%2F%2Fnxp.com%2FAMMCLib%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAutomotive%20Math%20and%20Motor%20Control%20Library(AMMCLib)%E3%82%BB%E3%83%83%E3%83%88%3C%2FA%3E%20%E3%80%81%3CA%20title%3D%22FreeMASTER%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%22%20href%3D%22https%3A%2F%2Fnxp.com%2FFreeMASTER%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20FreeMASTER%3C%2FA%3E%20%3CSPAN%3E%3C%2FSPAN%3E%E3%81%A8%3CSPAN%3E%3C%2FSPAN%3E%3CA%20title%3D%22%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%EF%BC%88MCAT%EF%BC%89%E3%83%84%E3%83%BC%E3%83%AB%22%20href%3D%22https%3A%2F%2Fnxp.com%2FMCAT%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20Motor%20Control%20ApplicationTuning(MCAT)%E3%83%84%E3%83%BC%E3%83%AB%3C%2FA%3E%3CA%20title%3D%22%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E8%A8%AD%E8%A8%88%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%EF%BC%88MBDT%EF%BC%89%22%20href%3D%22htttps%3A%2F%2Fnxp.com%2FMBDT%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E3%81%8A%E3%82%88%E3%81%B3Model-Based%20Design%20Toolbox(MBDT)%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E5%8C%85%E6%8B%AC%E7%9A%84%E3%81%AA%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%A8%E3%82%B3%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81S32M2%20MCU%E3%82%92%E5%B9%85%E5%BA%83%E3%81%84%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CFONT%20size%3D%223%22%3E%E6%AC%A1%E3%81%AE%E8%A1%A8%E3%81%AF%E3%80%81S32M2%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AC%E6%98%8E%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E8%A8%98%E4%BA%8B%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%98%E4%BA%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%26nbsp%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CTABLE%20width%3D%22692px%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22174px%22%20height%3D%2240px%22%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22141px%22%20height%3D%2240px%22%3E%0A%3CP%3E%3CSTRONG%3EHW%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%2240px%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%A8%98%E4%BA%8B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20rowspan%3D%223%22%20width%3D%22174px%22%20height%3D%22685px%22%20class%3D%22lia-align-center%22%20style%3D%22width%3A%2079.8594px%3B%20height%3A%20130px%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CA%20title%3D%22S32M244CC%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS32M244CCABWKHST%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noreferrer%20noopener%22%3ES32M244CC%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS32M244LCABWKHST%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32M244LC%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20rowspan%3D%223%22%20width%3D%22141px%22%20height%3D%22685px%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32M24XEVB%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32M24%20PMSM%2FBLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FBLDC_KIT%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EBLDC%2FPMSM%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22286px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M244-FOC-with-single-shunt-current-measurement%2Fta-p%2F2039802%22%20target%3D%22_self%22%3E%E5%8D%98%E4%B8%80%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FFOC%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%81%A7%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%3C%2FSPAN%3E%EF%BC%88%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%EF%BC%89%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%AA%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%86%E3%83%83%E3%83%89%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%EF%BC%88FOC%EF%BC%89%E6%8A%80%E8%A1%93%EF%BC%88%E9%80%9A%E5%B8%B8%E3%81%AF%E4%B8%89%E7%9B%B8PMSM%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8%EF%BC%89%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AFSW%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81BLDC%20PMSM%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%81%AF%E3%80%81%E9%83%A8%E5%93%81%E8%A1%A8%EF%BC%88BOM%EF%BC%89%E3%81%AE%E3%82%B3%E3%82%B9%E3%83%88%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%A7%E3%81%8D%E3%82%8B%E9%AB%98%E5%BA%A6%E3%81%AA%E6%8A%80%E8%A1%93%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9EAUTOSARAPI%E3%82%92%E5%82%99%E3%81%88%E3%81%9FRTD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22192px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M244-Hall-sensor-based-6-step-BLDC-motor-control%2Fta-p%2F2013453%22%20target%3D%22_self%22%3E%E3%83%9B%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E6%AE%B5%E9%9A%8E%E6%95%B4%E6%B5%81%E5%88%B6%E5%BE%A1%E3%80%82%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E3%83%9B%E3%83%BC%E3%83%AB%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FSPAN%3E%20%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%95%B4%E6%B5%81(6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%E6%8A%80%E8%A1%93(%E9%80%9A%E5%B8%B8%E3%81%AF3%E7%9B%B8BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8)%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9E%20AUTOSAR%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22207px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M244-Sensorless-6-step-BLDC-motor-control%2Fta-p%2F2009074%22%20target%3D%22_self%22%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%206%E6%AE%B5%E9%9A%8E%E3%81%AE%E6%95%B4%E6%B5%81%E5%88%B6%E5%BE%A1%E3%80%82%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5(%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9)%3C%2FSPAN%3E%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%95%B4%E6%B5%81(6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%E6%8A%80%E8%A1%93(%E9%80%9A%E5%B8%B8%E3%81%AF3%E7%9B%B8BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%81%AB%E4%BD%BF%E7%94%A8)%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9E%20AUTOSAR%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20rowspan%3D%223%22%20width%3D%22174px%22%20height%3D%22450px%22%20class%3D%22lia-align-center%22%20style%3D%22width%3A%2079.8594px%3B%20height%3A%20180px%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS32M276CHABMKHST%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32M276CH%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS32M276LHABMKHST%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32M276LH%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FTD%3E%0A%3CTD%20rowspan%3D%223%22%20width%3D%22141px%22%20height%3D%22450px%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32M27XEVB%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32M27x%20PMSM%2FBLDC%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32M276SFFRD%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32M276SFFRD%20%E8%BB%8A%E8%BC%89%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E7%94%A8%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FBLDC_KIT%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EBLDC%2FPMSM%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22286px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M276-FOC-with-single-shunt-current-measurement%2Fta-p%2F2039818%22%20target%3D%22_self%22%3E%E5%8D%98%E4%B8%80%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FFOC%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%81%A7%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%3C%2FSPAN%3E%EF%BC%88%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%EF%BC%89%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%AA%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%86%E3%83%83%E3%83%89%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%EF%BC%88FOC%EF%BC%89%E6%8A%80%E8%A1%93%EF%BC%88%E9%80%9A%E5%B8%B8%E3%81%AF%E4%B8%89%E7%9B%B8PMSM%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8%EF%BC%89%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AFSW%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81BLDC%20PMSM%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%81%AF%E3%80%81%E9%83%A8%E5%93%81%E8%A1%A8%EF%BC%88BOM%EF%BC%89%E3%81%AE%E3%82%B3%E3%82%B9%E3%83%88%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%A7%E3%81%8D%E3%82%8B%E9%AB%98%E5%BA%A6%E3%81%AA%E6%8A%80%E8%A1%93%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9EAUTOSARAPI%E3%82%92%E5%82%99%E3%81%88%E3%81%9FRTD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22192px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M276-Hall-sensor-based-6-step-BLDC-motor-control%2Fta-p%2F2035021%22%20target%3D%22_self%22%3E%E3%83%9B%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E6%AE%B5%E9%9A%8E%E6%95%B4%E6%B5%81%E5%88%B6%E5%BE%A1%E3%80%82%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E3%83%9B%E3%83%BC%E3%83%AB%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FSPAN%3E%20%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%95%B4%E6%B5%81(6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%E6%8A%80%E8%A1%93(%E9%80%9A%E5%B8%B8%E3%81%AF3%E7%9B%B8BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8)%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9E%20AUTOSAR%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22377px%22%20height%3D%22207px%22%3E%0A%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32M-Knowledge-Base%2FS32M276-sensorless-6-step-BLDC-motor-control%2Fta-p%2F2035476%22%20target%3D%22_self%22%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%AC%E3%82%B9%206%E6%AE%B5%E9%9A%8E%E3%81%AE%E6%95%B4%E6%B5%81%E5%88%B6%E5%BE%A1%E3%80%82%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5(%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9)%3C%2FSPAN%3E%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%95%B4%E6%B5%81(6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%E6%8A%80%E8%A1%93(%E9%80%9A%E5%B8%B8%E3%81%AF3%E7%9B%B8BLDC%E3%83%A2%E3%83%BC%E3%82%BF%E3%81%AB%E4%BD%BF%E7%94%A8)%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%9D%9E%20AUTOSAR%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%B3%A8%3A%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81MCU%E3%80%81%E9%9B%BB%E6%B5%81%E6%B8%AC%E5%AE%9A%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%80%81%E5%88%B6%E5%BE%A1%E6%8A%80%E8%A1%93%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E5%85%A5%E5%8A%9B%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E7%B6%B2%E7%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-07-2025 02:52 AM
更新者:
