S32K312 PWM interrupt configuration
2,925件の閲覧回数
NITHYANANTHVS
Hi team  I'm configuring PWM input and output in interrupt configuration. Can you check the below details are correct for PWM input and output.
EMIOS 0INTERRUPT
CH0EMIOS0_5_IRQn = 66
CH1EMIOS0_5_IRQn = 66
CH2EMIOS0_5_IRQn = 66
CH3EMIOS0_5_IRQn = 66
CH4EMIOS0_4_IRQn = 65
CH5EMIOS0_4_IRQn = 65
CH6EMIOS0_4_IRQn = 65
EMIOS 1INTERRUPT
CH7EMIOS1_4_IRQn = 73
CH14EMIOS1_2_IRQn = 71
CH15EMIOS1_2_IRQn = 71
CH19EMIOS1_1_IRQn = 70
2,898件の閲覧回数
Senlent
Hi@NITHYANANTHVS
Actually you can find emios-pwm related demos in S32 DS with RTD 3.0.0
3 返答(返信)
2,910件の閲覧回数
Senlent
Hi@NITHYANANTHVS
Yes, the interrupt IRQ number corresponds correctly to the emios channel.
2,907件の閲覧回数
NITHYANANTHVS
Will it work in 3.0 version.?
I installed 3.0 version it is not working fine. If i configure one channel, it will work. but i configure more than one channel last channel only working correct, apart from last channel nothing was working correctly. Can you share any code for pwm output with version 3.0.
2,899件の閲覧回数
Senlent
Hi@NITHYANANTHVS
