Pwm_example_S32K148 build failed.
2,093件の閲覧回数
iysheng
I installed DS32 version 3.4 and some needed package.
And I create a project based on Pwm_example_S32K148.When I try to build the project I get some errors like this:
タグ(1)
3 返答(返信)
258件の閲覧回数
shangguanyu
I encountered a situation similar to yours. Have you resolved it?
../src/main.c:94:24: error: 'NUM_OF_CONFIGURED_PINS0' undeclared (first use in this function); did you mean 'NUM_OF_CONFIGURED_PINS'? 94 | Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS0, g_pin_mux_InitConfigArr0); | ^~~~~~~~~~~~~~~~~~~~~~~ | NUM_OF_CONFIGURED_PINS ../src/main.c:94:24: note: each undeclared identifier is reported only once for each function it appears in
2,064件の閲覧回数
Senlent
Hi@iysheng
please click "update code" and then try it again.
2,045件の閲覧回数
iysheng
After I do this ,when I build I get error messages as below:
make -j12 all
Building file: ../board/Port_Ci_Port_Ip_Cfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@board/Clock_Ip_Cfg.args" -MMD -MP -MF"board/Port_Ci_Port_Ip_Cfg.d" -MT"board/Port_Ci_Port_Ip_Cfg.o" -o "board/Port_Ci_Port_Ip_Cfg.o" "../board/Port_Ci_Port_Ip_Cfg.c"
../board/Port_Ci_Port_Ip_Cfg.c:29:60: error: 'NUM_OF_CONFIGURED_PINS0' undeclared here (not in a function); did you mean 'NUM_OF_CONFIGURED_PINS'?
29 | Port_Ci_Port_Ip_PinSettingsConfig g_pin_mux_InitConfigArr0[NUM_OF_CONFIGURED_PINS0] = {
../board/Port_Ci_Port_Ip_Cfg.c:31:9: error: field name not in record or union initializer
31 | .portBase = IP_PORTC,
../board/Port_Ci_Port_Ip_Cfg.c:31:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:32:9: error: field name not in record or union initializer
32 | .gpioBase = NULL_PTR,
../board/Port_Ci_Port_Ip_Cfg.c:32:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:33:9: error: field name not in record or union initializer
33 | .pinPortIdx = 19U,
../board/Port_Ci_Port_Ip_Cfg.c:33:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:34:9: error: field name not in record or union initializer
34 | .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED,
../board/Port_Ci_Port_Ip_Cfg.c:34:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:35:9: error: field name not in record or union initializer
35 | .driveStrength = PORT_DRIVE_STRENGTH_LOW,
../board/Port_Ci_Port_Ip_Cfg.c:35:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:36:9: error: field name not in record or union initializer
36 | .passiveFilter = (boolean)FALSE,
../board/Port_Ci_Port_Ip_Cfg.c:36:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:37:9: error: field name not in record or union initializer
37 | .mux = PORT_MUX_ALT2,
../board/Port_Ci_Port_Ip_Cfg.c:37:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:38:9: error: field name not in record or union initializer
38 | .lockRegister = PORT_LOCK_REGISTER_DISABLED,
../board/Port_Ci_Port_Ip_Cfg.c:38:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:39:9: error: field name not in record or union initializer
39 | .digitalFilter = (boolean)FALSE,
../board/Port_Ci_Port_Ip_Cfg.c:39:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
make: *** [board/subdir.mk:26: board/Port_Ci_Port_Ip_Cfg.o] Error 1
"make -j12 all" terminated with exit code 2. Build might be incomplete.
 and the generated code releate is:
.pinPortIdx = 19U,
I found macro NUM_OF_CONFIGURED_PINS define as
%3CLINGO-SUB%20id%3D%22lingo-sub-1888240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_example_S32K148%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDS32%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.4%20%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_0-1718541776746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_0-1718541776746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284333iF16ABE900FBC097B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_0-1718541776746.png%22%20alt%3D%22iysheng_0-1718541776746.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_2-1718541822764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_2-1718541822764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284335i66BA1A40DD5D0BF4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_2-1718541822764.png%22%20alt%3D%22iysheng_2-1718541822764.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_3-1718541836574.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_3-1718541836574.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284336iE99517E5F6390A5E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_3-1718541836574.png%22%20alt%3D%22iysheng_3-1718541836574.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81Pwm_example_S32K148%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_4-1718541896443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_4-1718541896443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284337i9AFD4D10F31F602C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_4-1718541896443.png%22%20alt%3D%22iysheng_4-1718541896443.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E4%BC%BC%E3%81%9F%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E..%3CSPAN%20class%3D%22%22%3E%20%2F%3C%2FSPAN%3E%20src%3CSPAN%20class%3D%22%22%3E%20%2F%3C%2FSPAN%3E%20main.c%3A%3CSPAN%20class%3D%22%22%3E%2094%3C%2FSPAN%3E%20%3A%3CSPAN%20class%3D%22%22%3E%2024%3C%2FSPAN%3E%20%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%3CSPAN%20class%3D%22%22%3E%20'NUM_OF_CONFIGURED_PINS0'%3C%2FSPAN%3E%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%3CSPAN%20class%3D%22%22%3E%20%E9%96%A2%E6%95%B0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%A7%20%E5%88%9D%E3%82%81%E3%81%A6%3C%2FSPAN%3E%20%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%3B%3CSPAN%20class%3D%22%22%3E%20'NUM_OF_CONFIGURED_PINS'%3C%2FSPAN%3E%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3CSPAN%20class%3D%22%22%3E%2094%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%7C%3C%2FSPAN%3E%20Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS0%2C%20g_pin_mux_InitConfigArr0)%3B%3CSPAN%20class%3D%22%22%3E%20%7C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%5E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%20~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%7C%3C%2FSPAN%3E%20NUM_OF_CONFIGURED_PINS..%3CSPAN%20class%3D%22%22%3E%20%2F%3C%2FSPAN%3E%20src%3CSPAN%20class%3D%22%22%3E%20%2F%3C%2FSPAN%3E%20main.c%3A%3CSPAN%20class%3D%22%22%3E%2094%3C%2FSPAN%3E%20%3A%3CSPAN%20class%3D%22%22%3E%2024%3C%2FSPAN%3E%20%3A%20%E6%B3%A8%3A%20%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3CSPAN%20class%3D%22%22%3E%20%E5%90%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%3C%2FSPAN%3E%20%E5%87%BA%E7%8F%BE%20%E3%81%99%E3%82%8B%3CSPAN%20class%3D%22%22%3E%20%E5%90%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E9%96%A2%E6%95%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%201%20%E5%9B%9E%3C%2FSPAN%3E%20%E3%81%A0%E3%81%91%20%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%20%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E3%80%8D%3C%2FP%3E%3CP%3Emake%20-j12%20all%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20%E6%A8%99%E6%BA%96%20S32DS%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3EArm-none-eabi-gcc%20%22%40board%2FClock_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22board%2FPort_Ci_Port_Ip_Cfg.d%22-MT%22%E3%83%9C%E3%83%BC%E3%83%89%2FPort_Ci_Port_Ip_Cfg.o%22-o%20%22%E3%83%9C%E3%83%BC%E3%83%89%2FPort_Ci_Port_Ip_Cfg.o%22%E3%80%8C..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%E3%80%8D%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A29%3A60%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'NUM_OF_CONFIGURED_PINS0'%20%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E9%96%A2%E6%95%B0%E5%86%85%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3B%20'NUM_OF_CONFIGURED_PINS'%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3CBR%20%2F%3E%2029%20%7C%20Port_Ci_Port_Ip_PinSettingsConfig%20g_pin_mux_InitConfigArr0%5BNUM_OF_CONFIGURED_PINS0%5D%20%3D%20%7B%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%20%7C%20%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%94%E3%83%B3%E3%81%AE%E6%95%B0%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A31%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E31%20%7C%20.portBase%3D%20IP_PORTC%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A31%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A32%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E32%20%7C%20.gpioBase%3D%20NULL_PTR%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A32%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A33%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E33%20%7C%20.pinPortIdx%3D%2019U%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A33%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A34%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E34%20%7C%20.pullConfig%3D%20PORT_INTERNAL_PULL_NOT_ENABLED%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A34%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A35%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E35%20%7C%20.driveStrength%3D%20%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E5%BC%B7%E5%BA%A6%E3%81%8C%E4%BD%8E%E3%81%84%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A35%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A36%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E36%20%7C%20.%E3%83%91%E3%83%83%E3%82%B7%E3%83%96%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3D%20(%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4)FALSE%2C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A36%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A37%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E37%20%7C%20.mux%3D%20PORT_MUX_ALT2%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A37%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A38%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E38%20%7C%20.lockRegister%3D%20%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A38%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A39%3A9%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%90%8D%E3%81%8C%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B1%E7%94%A8%E4%BD%93%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AD%90%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E39%20%7C%20.%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3D%20(%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4)FALSE%2C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A39%3A9%3A%20%E6%B3%A8%E8%A8%98%3A%20('g_pin_mux_InitConfigArr0'%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BB%98%E8%BF%91)%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bboard%2Fsubdir.mk%3A26%3A%E3%83%9C%E3%83%BC%E3%83%89%2FPort_Ci_Port_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%202%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E3%80%8D%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E3%80%8D%3C%2FP%3E%3CP%3EPort_Ci_Port_Ip_PinSettingsConfig%20g_pin_mux_InitConfigArr0%5BNUM_OF_CONFIGURED_PINS0%5D%20%3D%20%7B%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20.portBase%3D%20IP_PORTC%E3%80%81%3CBR%20%2F%3E%20.gpio%E3%83%99%E3%83%BC%E3%82%B9%3D%20NULL_PTR%E3%80%81%3CBR%20%2F%3E%20.pinPortIdx%3D%2019U%E3%80%81%3CBR%20%2F%3E%20.pullConfig%3D%20PORT_INTERNAL_PULL_NOT_ENABLED%E3%80%81%3CBR%20%2F%3E%20.driveStrength%3D%20%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E5%BC%B7%E5%BA%A6%E3%81%8C%E4%BD%8E%E3%81%84%E3%80%81%3CBR%20%2F%3E%20.%E3%83%91%E3%83%83%E3%82%B7%E3%83%96%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3D%20(%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4)FALSE%2C%3CBR%20%2F%3E%20.mux%3D%20PORT_MUX_ALT2%E3%80%81%3CBR%20%2F%3E%20.lockRegister%3D%20%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%3CBR%20%2F%3E%20.%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3D%20(%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4)FALSE%2C%3CBR%20%2F%3E%20%7D%2C%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%E3%80%8C%E3%80%8D%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%AF%E3%83%ADNUM_OF_CONFIGURED_PINS%E3%81%8C%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_0-1718629852941.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_0-1718629852941.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284462iA2C1DAEB3FA019F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_0-1718629852941.png%22%20alt%3D%22iysheng_0-1718629852941.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40iysheng%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%40iysheng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1718591141284.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1718591141284.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284354i758011B910B3CB5F%2Fimage-dimensions%2F607x352%3Fv%3Dv2%22%20width%3D%22607%22%20height%3D%22352%22%20role%3D%22button%22%20title%3D%22Senlent_0-1718591141284.png%22%20alt%3D%22Senlent_0-1718591141284.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
