Pwm_example_S32K148 build failed.
iysheng
I installed DS32 version 3.4 and some needed package.
And I create a project based on Pwm_example_S32K148.When I try to build the project I get some errors like this:
shangguanyu
I encountered a situation similar to yours. Have you resolved it?
../src/main.c:94:24: error: 'NUM_OF_CONFIGURED_PINS0' undeclared (first use in this function); did you mean 'NUM_OF_CONFIGURED_PINS'? 94 | Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS0, g_pin_mux_InitConfigArr0); | ^~~~~~~~~~~~~~~~~~~~~~~ | NUM_OF_CONFIGURED_PINS ../src/main.c:94:24: note: each undeclared identifier is reported only once for each function it appears in
Senlent
Hi@iysheng
please click "update code" and then try it again.
iysheng
After I do this ,when I build I get error messages as below:
make -j12 all
Building file: ../board/Port_Ci_Port_Ip_Cfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@board/Clock_Ip_Cfg.args" -MMD -MP -MF"board/Port_Ci_Port_Ip_Cfg.d" -MT"board/Port_Ci_Port_Ip_Cfg.o" -o "board/Port_Ci_Port_Ip_Cfg.o" "../board/Port_Ci_Port_Ip_Cfg.c"
../board/Port_Ci_Port_Ip_Cfg.c:29:60: error: 'NUM_OF_CONFIGURED_PINS0' undeclared here (not in a function); did you mean 'NUM_OF_CONFIGURED_PINS'?
29 | Port_Ci_Port_Ip_PinSettingsConfig g_pin_mux_InitConfigArr0[NUM_OF_CONFIGURED_PINS0] = {
../board/Port_Ci_Port_Ip_Cfg.c:31:9: error: field name not in record or union initializer
31 | .portBase = IP_PORTC,
../board/Port_Ci_Port_Ip_Cfg.c:31:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:32:9: error: field name not in record or union initializer
32 | .gpioBase = NULL_PTR,
../board/Port_Ci_Port_Ip_Cfg.c:32:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:33:9: error: field name not in record or union initializer
33 | .pinPortIdx = 19U,
../board/Port_Ci_Port_Ip_Cfg.c:33:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:34:9: error: field name not in record or union initializer
34 | .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED,
../board/Port_Ci_Port_Ip_Cfg.c:34:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:35:9: error: field name not in record or union initializer
35 | .driveStrength = PORT_DRIVE_STRENGTH_LOW,
../board/Port_Ci_Port_Ip_Cfg.c:35:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:36:9: error: field name not in record or union initializer
36 | .passiveFilter = (boolean)FALSE,
../board/Port_Ci_Port_Ip_Cfg.c:36:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:37:9: error: field name not in record or union initializer
37 | .mux = PORT_MUX_ALT2,
../board/Port_Ci_Port_Ip_Cfg.c:37:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:38:9: error: field name not in record or union initializer
38 | .lockRegister = PORT_LOCK_REGISTER_DISABLED,
../board/Port_Ci_Port_Ip_Cfg.c:38:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
../board/Port_Ci_Port_Ip_Cfg.c:39:9: error: field name not in record or union initializer
39 | .digitalFilter = (boolean)FALSE,
../board/Port_Ci_Port_Ip_Cfg.c:39:9: note: (near initialization for 'g_pin_mux_InitConfigArr0')
make: *** [board/subdir.mk:26: board/Port_Ci_Port_Ip_Cfg.o] Error 1
"make -j12 all" terminated with exit code 2. Build might be incomplete.
 and the generated code releate is:
.pinPortIdx = 19U,
I found macro NUM_OF_CONFIGURED_PINS define as
%3CLINGO-SUB%20id%3D%22lingo-sub-1888240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20installed%20DS32%20version%203.4%20and%20some%20needed%20package.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_0-1718541776746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_0-1718541776746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284333iF16ABE900FBC097B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_0-1718541776746.png%22%20alt%3D%22iysheng_0-1718541776746.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_2-1718541822764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_2-1718541822764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284335i66BA1A40DD5D0BF4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_2-1718541822764.png%22%20alt%3D%22iysheng_2-1718541822764.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_3-1718541836574.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_3-1718541836574.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284336iE99517E5F6390A5E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_3-1718541836574.png%22%20alt%3D%22iysheng_3-1718541836574.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAnd%20I%20create%20a%20project%20based%20on%20Pwm_example_S32K148.When%20I%20try%20to%20build%20the%20project%20I%20get%20some%20errors%20like%20this%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_4-1718541896443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_4-1718541896443.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284337i9AFD4D10F31F602C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_4-1718541896443.png%22%20alt%3D%22iysheng_4-1718541896443.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3EI%20encountered%20a%20situation%20similar%20to%20yours.%20Have%20you%20resolved%20it%3F%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E..%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Esrc%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Emain.c%3A%3CSPAN%20class%3D%22%22%3E94%3C%2FSPAN%3E%3A%3CSPAN%20class%3D%22%22%3E24%3C%2FSPAN%3E%3A%20error%3A%20%3CSPAN%20class%3D%22%22%3E'NUM_OF_CONFIGURED_PINS0'%3C%2FSPAN%3E%20undeclared%20(%3CSPAN%20class%3D%22%22%3Efirst%3C%2FSPAN%3E%20use%20%3CSPAN%20class%3D%22%22%3Ein%3C%2FSPAN%3E%20this%20%3CSPAN%20class%3D%22%22%3Efunction%3C%2FSPAN%3E)%3B%20did%20you%20mean%20%3CSPAN%20class%3D%22%22%3E'NUM_OF_CONFIGURED_PINS'%3C%2FSPAN%3E%3F%20%3CSPAN%20class%3D%22%22%3E94%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7C%3C%2FSPAN%3E%20Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS0%2C%20g_pin_mux_InitConfigArr0)%3B%20%3CSPAN%20class%3D%22%22%3E%7C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%5E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E~%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7C%3C%2FSPAN%3E%20NUM_OF_CONFIGURED_PINS%20..%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Esrc%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Emain.c%3A%3CSPAN%20class%3D%22%22%3E94%3C%2FSPAN%3E%3A%3CSPAN%20class%3D%22%22%3E24%3C%2FSPAN%3E%3A%20note%3A%20%3CSPAN%20class%3D%22%22%3Eeach%3C%2FSPAN%3E%20undeclared%20identifier%20%3CSPAN%20class%3D%22%22%3Eis%3C%2FSPAN%3E%20reported%20%3CSPAN%20class%3D%22%22%3Eonly%3C%2FSPAN%3E%20once%20%3CSPAN%20class%3D%22%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eeach%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Efunction%3C%2FSPAN%3E%20it%20appears%20%3CSPAN%20class%3D%22%22%3Ein%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20I%20do%20this%20%2Cwhen%20I%20build%20I%20get%20error%20messages%20as%20below%3A%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3Emake%20-j12%20all%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40board%2FClock_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22board%2FPort_Ci_Port_Ip_Cfg.d%22%20-MT%22board%2FPort_Ci_Port_Ip_Cfg.o%22%20-o%20%22board%2FPort_Ci_Port_Ip_Cfg.o%22%20%22..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%22%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A29%3A60%3A%20error%3A%20'NUM_OF_CONFIGURED_PINS0'%20undeclared%20here%20(not%20in%20a%20function)%3B%20did%20you%20mean%20'NUM_OF_CONFIGURED_PINS'%3F%3CBR%20%2F%3E29%20%7C%20Port_Ci_Port_Ip_PinSettingsConfig%20g_pin_mux_InitConfigArr0%5BNUM_OF_CONFIGURED_PINS0%5D%20%3D%20%7B%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%7C%20NUM_OF_CONFIGURED_PINS%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A31%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E31%20%7C%20.portBase%20%3D%20IP_PORTC%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A31%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A32%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E32%20%7C%20.gpioBase%20%3D%20NULL_PTR%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A32%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A33%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E33%20%7C%20.pinPortIdx%20%3D%2019U%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A33%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A34%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E34%20%7C%20.pullConfig%20%3D%20PORT_INTERNAL_PULL_NOT_ENABLED%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A34%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A35%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E35%20%7C%20.driveStrength%20%3D%20PORT_DRIVE_STRENGTH_LOW%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A35%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A36%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E36%20%7C%20.passiveFilter%20%3D%20(boolean)FALSE%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A36%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A37%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E37%20%7C%20.mux%20%3D%20PORT_MUX_ALT2%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A37%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A38%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E38%20%7C%20.lockRegister%20%3D%20PORT_LOCK_REGISTER_DISABLED%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A38%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A39%3A9%3A%20error%3A%20field%20name%20not%20in%20record%20or%20union%20initializer%3CBR%20%2F%3E39%20%7C%20.digitalFilter%20%3D%20(boolean)FALSE%2C%3CBR%20%2F%3E%7C%20%5E%3CBR%20%2F%3E..%2Fboard%2FPort_Ci_Port_Ip_Cfg.c%3A39%3A9%3A%20note%3A%20(near%20initialization%20for%20'g_pin_mux_InitConfigArr0')%3CBR%20%2F%3Emake%3A%20***%20%5Bboard%2Fsubdir.mk%3A26%3A%20board%2FPort_Ci_Port_Ip_Cfg.o%5D%20Error%201%3CBR%20%2F%3E%22make%20-j12%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%26nbsp%3Band%20the%20generated%20code%20releate%20is%3A%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3EPort_Ci_Port_Ip_PinSettingsConfig%20g_pin_mux_InitConfigArr0%5BNUM_OF_CONFIGURED_PINS0%5D%20%3D%20%7B%3CBR%20%2F%3E%7B%3CBR%20%2F%3E.portBase%20%3D%20IP_PORTC%2C%3CBR%20%2F%3E.gpioBase%20%3D%20NULL_PTR%2C%3CBR%20%2F%3E.pinPortIdx%20%3D%2019U%2C%3CBR%20%2F%3E.pullConfig%20%3D%20PORT_INTERNAL_PULL_NOT_ENABLED%2C%3CBR%20%2F%3E.driveStrength%20%3D%20PORT_DRIVE_STRENGTH_LOW%2C%3CBR%20%2F%3E.passiveFilter%20%3D%20(boolean)FALSE%2C%3CBR%20%2F%3E.mux%20%3D%20PORT_MUX_ALT2%2C%3CBR%20%2F%3E.lockRegister%20%3D%20PORT_LOCK_REGISTER_DISABLED%2C%3CBR%20%2F%3E.digitalFilter%20%3D%20(boolean)FALSE%2C%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3EI%20found%20macro%20NUM_OF_CONFIGURED_PINS%20define%20as%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iysheng_0-1718629852941.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iysheng_0-1718629852941.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284462iA2C1DAEB3FA019F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iysheng_0-1718629852941.png%22%20alt%3D%22iysheng_0-1718629852941.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pwm_example_S32K148%20build%20failed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40iysheng%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40iysheng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Eplease%20click%20%22update%20code%22%20and%20then%20try%20it%20again.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1718591141284.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1718591141284.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284354i758011B910B3CB5F%2Fimage-dimensions%2F607x352%3Fv%3Dv2%22%20width%3D%22607%22%20height%3D%22352%22%20role%3D%22button%22%20title%3D%22Senlent_0-1718591141284.png%22%20alt%3D%22Senlent_0-1718591141284.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
