CAN1 issue using S32K344 - Error Frame (stuff error)
MVR
Contributor V
Hello everyone,
I have two codes using CAN0 and CAN1, the first code using RTD (S32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707) both channels are working properly with this configuration on S32DS:
When I configure the same baudrate on EB Tresos 29.0, only the CAN0 is working, the CAN1 is returning error on BUSMASTER tool:
This is the configuration on Tresos for CAN0 and CAN1:
MVR_3-1729191021584.pngMVR_3-1729191021584.pngMVR_4-1729191054213.pngMVR_4-1729191054213.pngMVR_5-1729191084801.pngMVR_5-1729191084801.png
This is the code that I`m using for test:
When I select the instance 0, I can see the message reaching the BUSMASTER correctly:
Note: The transceiver is being configured correctly and as I said, using the RTD code it is working properly, so the hardware is validated.
Anyone can help me with this issue?
MVR
Tags (5)
MVR
Contributor V
Hello @PetrS,
I found the issue. We have a mosfet in the hardware to control the terminator resistor. If the mosfet is activated, the terminator circuit will be working.
The CAN0 doesn't have this mosfet. I didn't know about it... Also the registers are different, so these two things fooled me.
Thank you.
MVR
Contributor V
Anyone can help me?
PetrS
try to use same bit timing setting, even that the one you use in EB would be correct too.
Compare values actually written to bit timing registers.
Finally, do not use FIRC as PE clock source, select FXOSC, or PLL running from FXOSC.
BR, Petr
MVR
Contributor V
I checked the registers and they are the same for bit timing setting, even with different values set in EB... I will test with the another clock that you recommended.
MVR
Contributor V
Hello @PetrS ,
I changed the clock but still the channel 1 is not working... Do you have another idea?
PetrS
try to share simplified project so can be tested on EVB.
Maybe other try could be testing behavior on latest RTD.
BR, Petr
MVR
Contributor V
Hello @PetrS ,
The generated code are the same, using the RTD 2.0.1 and the last version of AUTOSAR HF02 (S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725), but looking the registers, they are different:
Into the "FlexCAN_Ip_Vs_0_PBcfg.c" in both generated code we can see these values (this is one example about bitrate, but the other configuration are the same):
But the registers we can see different values:
How is it possible since the generated code is the same? Again, the CAN0 is working with the new version, but CAN1 is not working.
Note: Left side is the RTD 2.0.1 for S32DS - SW32K3_RTD_4.4_2.0.1 (S32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707) and in the right side is the new library version for Tresos - SW32K3_RTD_R21-11_4.0.0_HF_02 (S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725).
Thank you,
MVR
MVR
Contributor V
Ops, I made a mistake. CBT registers are not different, they are the same:
Sorry, I took a screenshot when I was changing the bitrate. But with the bitrate the same, CBT are the same.
MVR
Contributor V
Note: I set manually the bitrate only to see if this is the problem, but the generated code for bitrate are different...
MVR
Contributor V
Hello @PetrS,
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1976415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20everyone%2C%3C%2FP%3E%3CP%3EI%20have%20two%20codes%20using%20CAN0%20and%20CAN1%2C%20the%20first%20code%20using%20RTD%20(%3CSPAN%3ES32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707)%20both%20channels%20are%20working%20properly%20with%20this%20configuration%20on%20S32DS%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729190610129.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729190610129.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305316i6EBCEAE53072285B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729190610129.png%22%20alt%3D%22MVR_0-1729190610129.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_0-1729190610129.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_1-1729190718903.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_1-1729190718903.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305317i2EA64D6A79A0B794%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_1-1729190718903.png%22%20alt%3D%22MVR_1-1729190718903.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_1-1729190718903.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWhen%20I%20configure%20the%20same%20baudrate%20on%20EB%20Tresos%2029.0%2C%20only%20the%20CAN0%20is%20working%2C%20the%20CAN1%20is%20returning%20error%20on%20BUSMASTER%20tool%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_2-1729190948305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_2-1729190948305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305319i3E24F789F35CFED9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_2-1729190948305.png%22%20alt%3D%22MVR_2-1729190948305.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_2-1729190948305.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20the%20configuration%20on%20Tresos%20for%20CAN0%20and%20CAN1%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_3-1729191021584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_3-1729191021584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305320i423F0E23BB5BFEA2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_3-1729191021584.png%22%20alt%3D%22MVR_3-1729191021584.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_3-1729191021584.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_4-1729191054213.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_4-1729191054213.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305321i9577E01ECE026BD0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_4-1729191054213.png%22%20alt%3D%22MVR_4-1729191054213.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_4-1729191054213.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_5-1729191084801.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_5-1729191084801.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305322iEADC223DFA3EF82C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_5-1729191084801.png%22%20alt%3D%22MVR_5-1729191084801.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_5-1729191084801.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_14-1729199943852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_14-1729199943852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305343iFA41760068C2542E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_14-1729199943852.png%22%20alt%3D%22MVR_14-1729199943852.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_14-1729199943852.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_13-1729199889766.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_13-1729199889766.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305342i1DBEDF49E9307904%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_13-1729199889766.png%22%20alt%3D%22MVR_13-1729199889766.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_13-1729199889766.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_8-1729191175262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_8-1729191175262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305325iE84E98C992E21D81%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_8-1729191175262.png%22%20alt%3D%22MVR_8-1729191175262.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_8-1729191175262.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_11-1729199731391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_11-1729199731391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305340i3B73778A4F6634BB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_11-1729199731391.png%22%20alt%3D%22MVR_11-1729199731391.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_11-1729199731391.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThis%20is%20the%20code%20that%20I%60m%20using%20for%20test%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_9-1729191308590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_9-1729191308590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305326iB7079072F1E1AFFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_9-1729191308590.png%22%20alt%3D%22MVR_9-1729191308590.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_9-1729191308590.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWhen%20I%20select%20the%20instance%200%2C%20I%20can%20see%20the%20message%20reaching%20the%20BUSMASTER%20correctly%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_10-1729191541450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_10-1729191541450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305327i39858AEE821B498C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_10-1729191541450.png%22%20alt%3D%22MVR_10-1729191541450.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_10-1729191541450.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ENote%3A%20The%20transceiver%20is%20being%20configured%20correctly%20and%20as%20I%20said%2C%20using%20the%20RTD%20code%20it%20is%20working%20properly%2C%20so%20the%20hardware%20is%20validated.%3C%2FP%3E%3CP%3EAnyone%20can%20help%20me%20with%20this%20issue%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EMVR%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI%20found%20the%20issue.%20We%20have%20a%20mosfet%20in%20the%20hardware%20to%20control%20the%20terminator%20resistor.%20If%20the%20mosfet%20is%20activated%2C%20the%20terminator%20circuit%20will%20be%20working.%3C%2FP%3E%3CP%3EThe%20CAN0%20doesn't%20have%20this%20mosfet.%20I%20didn't%20know%20about%20it...%20Also%20the%20registers%20are%20different%2C%20so%20these%20two%20things%20fooled%20me.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENote%3A%26nbsp%3BI%20set%20manually%20the%20bitrate%20only%20to%20see%20if%20this%20is%20the%20problem%2C%20but%20the%20generated%20code%20for%20bitrate%20are%20different...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOps%2C%20I%20made%20a%20mistake.%20CBT%20registers%20are%20not%20different%2C%20they%20are%20the%20same%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729747003273.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729747003273.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306636iC3266A458051A641%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729747003273.png%22%20alt%3D%22MVR_0-1729747003273.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_0-1729747003273.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESorry%2C%20I%20took%20a%20screenshot%20when%20I%20was%20changing%20the%20bitrate.%20But%20with%20the%20bitrate%20the%20same%2C%20CBT%20are%20the%20same.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThe%20generated%20code%20are%20the%20same%2C%20using%20the%20RTD%202.0.1%20and%20the%20last%20version%20of%20AUTOSAR%20HF02%20(%3CSPAN%3ES32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725)%2C%20but%20looking%20the%20registers%2C%20they%20are%20different%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInto%20the%20%22FlexCAN_Ip_Vs_0_PBcfg.c%22%20in%20both%20generated%20code%20we%20can%20see%20these%20values%20(this%20is%20one%20example%20about%20bitrate%2C%20but%20the%20other%20configuration%20are%20the%20same)%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729744910477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729744910477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306621i689869C57274DC10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729744910477.png%22%20alt%3D%22MVR_0-1729744910477.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_0-1729744910477.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBut%20the%20registers%20we%20can%20see%20different%20values%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_5-1729745181047.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_5-1729745181047.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306626i706DF22CC90E47BF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_5-1729745181047.png%22%20alt%3D%22MVR_5-1729745181047.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_5-1729745181047.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_6-1729745194254.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_6-1729745194254.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306627iB6F7E089BA43628A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_6-1729745194254.png%22%20alt%3D%22MVR_6-1729745194254.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_6-1729745194254.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_7-1729745202668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_7-1729745202668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306628i36E3F29343FCF941%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_7-1729745202668.png%22%20alt%3D%22MVR_7-1729745202668.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_7-1729745202668.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_8-1729745213193.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_8-1729745213193.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306629i1C2B2146470F60F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_8-1729745213193.png%22%20alt%3D%22MVR_8-1729745213193.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_8-1729745213193.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_1-1729745107341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_1-1729745107341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306622i7396BD66E3AB5D02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_1-1729745107341.png%22%20alt%3D%22MVR_1-1729745107341.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_1-1729745107341.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_3-1729745122469.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_3-1729745122469.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306624i0DD2940AC67FD6FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_3-1729745122469.png%22%20alt%3D%22MVR_3-1729745122469.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_3-1729745122469.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_4-1729745129613.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_4-1729745129613.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306625iF720ECC421773D34%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_4-1729745129613.png%22%20alt%3D%22MVR_4-1729745129613.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMVR_4-1729745129613.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHow%20is%20it%20possible%20since%20the%20generated%20code%20is%20the%20same%3F%20Again%2C%20the%20CAN0%20is%20working%20with%20the%20new%20version%2C%20but%20CAN1%20is%20not%20working.%3C%2FP%3E%3CP%3ENote%3A%20Left%20side%20is%20the%20RTD%202.0.1%20for%20S32DS%20-%26nbsp%3BSW32K3_RTD_4.4_2.0.1%20(%3CSPAN%3ES32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707)%20and%20in%20the%20right%20side%20is%20the%20new%20library%20version%20for%20Tresos%20-%20SW32K3_RTD_R21-11_4.0.0_HF_02%20(S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3EMVR%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Etry%20to%20share%20simplified%20project%20so%20can%20be%20tested%20on%20EVB.%3CBR%20%2F%3EMaybe%20other%20try%20could%20be%20testing%20behavior%20on%20latest%20RTD.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAnyone%20can%20help%20me%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20changed%20the%20clock%20but%20still%20the%20channel%201%20is%20not%20working...%20Do%20you%20have%20another%20idea%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20checked%20the%20registers%20and%20they%20are%20the%20same%20for%20bit%20timing%20setting%2C%20even%20with%20different%20values%20set%20in%20EB...%20I%20will%20test%20with%20the%20another%20clock%20that%20you%20recommended.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1976805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN1%20issue%20using%20S32K344%20-%20Error%20Frame%20(stuff%20error)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Etry%20to%20use%20same%20bit%20timing%20setting%2C%20even%20that%20the%20one%20you%20use%20in%20EB%20would%20be%20correct%20too.%3CBR%20%2F%3ECompare%20values%20actually%20written%20to%20bit%20timing%20registers.%3CBR%20%2F%3EFinally%2C%20do%20not%20use%20FIRC%20as%20PE%20clock%20source%2C%20select%20FXOSC%2C%20or%20PLL%20running%20from%20FXOSC.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
