CAN1 issue using S32K344 - Error Frame (stuff error)
6,067 次查看
MVR
Contributor V
Hello everyone,
I have two codes using CAN0 and CAN1, the first code using RTD (S32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707) both channels are working properly with this configuration on S32DS:
When I configure the same baudrate on EB Tresos 29.0, only the CAN0 is working, the CAN1 is returning error on BUSMASTER tool:
This is the configuration on Tresos for CAN0 and CAN1:
This is the code that I`m using for test:
When I select the instance 0, I can see the message reaching the BUSMASTER correctly:
Note: The transceiver is being configured correctly and as I said, using the RTD code it is working properly, so the hardware is validated.
Anyone can help me with this issue?
MVR
标记 (5)
5,839 次查看
MVR
Contributor V
Hello @PetrS,
I found the issue. We have a mosfet in the hardware to control the terminator resistor. If the mosfet is activated, the terminator circuit will be working.
The CAN0 doesn't have this mosfet. I didn't know about it... Also the registers are different, so these two things fooled me.
Thank you.
9 回复数
5,937 次查看
MVR
Contributor V
Anyone can help me?
6,031 次查看
PetrS
try to use same bit timing setting, even that the one you use in EB would be correct too.
Compare values actually written to bit timing registers.
Finally, do not use FIRC as PE clock source, select FXOSC, or PLL running from FXOSC.
BR, Petr
6,022 次查看
MVR
Contributor V
I checked the registers and they are the same for bit timing setting, even with different values set in EB... I will test with the another clock that you recommended.
6,013 次查看
MVR
Contributor V
Hello @PetrS ,
I changed the clock but still the channel 1 is not working... Do you have another idea?
5,928 次查看
PetrS
try to share simplified project so can be tested on EVB.
Maybe other try could be testing behavior on latest RTD.
BR, Petr
5,903 次查看
MVR
Contributor V
Hello @PetrS ,
The generated code are the same, using the RTD 2.0.1 and the last version of AUTOSAR HF02 (S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725), but looking the registers, they are different:
Into the "FlexCAN_Ip_Vs_0_PBcfg.c" in both generated code we can see these values (this is one example about bitrate, but the other configuration are the same):
But the registers we can see different values:
How is it possible since the generated code is the same? Again, the CAN0 is working with the new version, but CAN1 is not working.
Note: Left side is the RTD 2.0.1 for S32DS - SW32K3_RTD_4.4_2.0.1 (S32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707) and in the right side is the new library version for Tresos - SW32K3_RTD_R21-11_4.0.0_HF_02 (S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725).
Thank you,
MVR
5,888 次查看
MVR
Contributor V
Ops, I made a mistake. CBT registers are not different, they are the same:
Sorry, I took a screenshot when I was changing the bitrate. But with the bitrate the same, CBT are the same.
5,879 次查看
MVR
Contributor V
Note: I set manually the bitrate only to see if this is the problem, but the generated code for bitrate are different...
5,840 次查看
MVR
Contributor V
Hello @PetrS,
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1976415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%A4%E4%B8%AA%E4%BD%BF%E7%94%A8%20CAN0%20%E5%92%8C%20CAN1%20%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%AC%AC%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%20RTD%20%EF%BC%88%20%3CSPAN%3ES32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707%EF%BC%89%E4%B8%A4%E4%B8%AA%E9%80%9A%E9%81%93%E5%9C%A8%20S32DS%20%E4%B8%8A%E9%83%BD%E4%BD%BF%E7%94%A8%E6%AD%A4%E9%85%8D%E7%BD%AE%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729190610129.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729190610129.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305316i6EBCEAE53072285B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729190610129.png%22%20alt%3D%22MVR_0-1729190610129.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_1-1729190718903.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_1-1729190718903.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305317i2EA64D6A79A0B794%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_1-1729190718903.png%22%20alt%3D%22MVR_1-1729190718903.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%9C%A8%20EB%20Tresos%2029.0%20%E4%B8%8A%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%90%8C%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E6%97%B6%EF%BC%8C%E4%BB%85%20CAN0%20%E5%B7%A5%E4%BD%9C%EF%BC%8CCAN1%20%E5%9C%A8%20BUSMASTER%20%E5%B7%A5%E5%85%B7%E4%B8%8A%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_2-1729190948305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_2-1729190948305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305319i3E24F789F35CFED9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_2-1729190948305.png%22%20alt%3D%22MVR_2-1729190948305.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20Tresos%20%E4%B8%8A%20CAN0%20%E5%92%8C%20CAN1%20%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_3-1729191021584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_3-1729191021584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305320i423F0E23BB5BFEA2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_3-1729191021584.png%22%20alt%3D%22MVR_3-1729191021584.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_4-1729191054213.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_4-1729191054213.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305321i9577E01ECE026BD0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_4-1729191054213.png%22%20alt%3D%22MVR_4-1729191054213.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_5-1729191084801.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_5-1729191084801.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305322iEADC223DFA3EF82C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_5-1729191084801.png%22%20alt%3D%22MVR_5-1729191084801.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_14-1729199943852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_14-1729199943852.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305343iFA41760068C2542E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_14-1729199943852.png%22%20alt%3D%22MVR_14-1729199943852.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_13-1729199889766.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_13-1729199889766.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305342i1DBEDF49E9307904%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_13-1729199889766.png%22%20alt%3D%22MVR_13-1729199889766.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_8-1729191175262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_8-1729191175262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305325iE84E98C992E21D81%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_8-1729191175262.png%22%20alt%3D%22MVR_8-1729191175262.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_11-1729199731391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_11-1729199731391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305340i3B73778A4F6634BB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_11-1729199731391.png%22%20alt%3D%22MVR_11-1729199731391.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_9-1729191308590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_9-1729191308590.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305326iB7079072F1E1AFFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_9-1729191308590.png%22%20alt%3D%22MVR_9-1729191308590.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E9%80%89%E6%8B%A9%E5%AE%9E%E4%BE%8B%200%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%B6%88%E6%81%AF%E6%AD%A3%E7%A1%AE%E5%88%B0%E8%BE%BE%20BUSMASTER%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_10-1729191541450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_10-1729191541450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305327i39858AEE821B498C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_10-1729191541450.png%22%20alt%3D%22MVR_10-1729191541450.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%94%B6%E5%8F%91%E5%99%A8%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%88%91%E6%89%80%E8%AF%B4%EF%BC%8C%E4%BD%BF%E7%94%A8%20RTD%20%E4%BB%A3%E7%A0%81%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%A1%AC%E4%BB%B6%E5%B7%B2%E7%BB%8F%E8%BF%87%E9%AA%8C%E8%AF%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A7%BB%E5%8A%A8%E6%80%A7%E9%A3%8E%E9%99%A9%E8%AF%84%E4%BC%B0%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E5%9C%A8%E7%A1%AC%E4%BB%B6%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%20mosfet%20%E6%9D%A5%E6%8E%A7%E5%88%B6%E7%BB%88%E7%AB%AF%E7%94%B5%E9%98%BB%E3%80%82%E5%A6%82%E6%9E%9C%20mosfet%20%E8%A2%AB%E6%BF%80%E6%B4%BB%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%94%B5%E8%B7%AF%E5%B0%B1%E4%BC%9A%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3ECAN0%20%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%20mosfet%E3%80%82%E6%88%91%E5%AF%B9%E6%AD%A4%E4%B8%80%E6%97%A0%E6%89%80%E7%9F%A5...%E8%80%8C%E4%B8%94%E5%AF%84%E5%AD%98%E5%99%A8%E4%B9%9F%E4%B8%8D%E5%90%8C%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E4%B8%A4%E4%BB%B6%E4%BA%8B%E6%84%9A%E5%BC%84%E4%BA%86%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%88%91%E6%89%8B%E5%8A%A8%E8%AE%BE%E7%BD%AE%E6%AF%94%E7%89%B9%E7%8E%87%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E7%9C%8B%E7%9C%8B%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%8C%E4%BD%86%E7%94%9F%E6%88%90%E7%9A%84%E6%AF%94%E7%89%B9%E7%8E%87%E4%BB%A3%E7%A0%81%E4%B8%8D%E5%90%8C......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%93%8E%E5%91%80%EF%BC%8C%E6%88%91%E7%8A%AF%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82CBT%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E4%B8%8D%E5%90%8C%EF%BC%8C%E5%AE%83%E4%BB%AC%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729747003273.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729747003273.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306636iC3266A458051A641%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729747003273.png%22%20alt%3D%22MVR_0-1729747003273.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E5%9C%A8%E6%9B%B4%E6%94%B9%E6%AF%94%E7%89%B9%E7%8E%87%E6%97%B6%E6%88%AA%E5%8F%96%E4%BA%86%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E3%80%82%E4%BD%86%E5%A6%82%E6%9E%9C%E6%AF%94%E7%89%B9%E7%8E%87%E7%9B%B8%E5%90%8C%EF%BC%8CCBT%20%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%8C%E4%BD%BF%E7%94%A8%20RTD%202.0.1%20%E5%92%8C%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20AUTOSAR%20HF02%EF%BC%88%20%3CSPAN%3ES32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725%EF%BC%89%EF%BC%8C%E4%BD%86%E6%9F%A5%E7%9C%8B%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%AE%83%E4%BB%AC%E6%98%AF%E4%B8%8D%E5%90%8C%E7%9A%84%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E4%B8%A4%E4%B8%AA%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E2%80%9CFlexCAN_Ip_Vs_0_PBcfg.c%E2%80%9D%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E8%BF%99%E4%BA%9B%E5%80%BC%EF%BC%88%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8E%E6%AF%94%E7%89%B9%E7%8E%87%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%90%8C%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_0-1729744910477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_0-1729744910477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306621i689869C57274DC10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_0-1729744910477.png%22%20alt%3D%22MVR_0-1729744910477.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_5-1729745181047.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_5-1729745181047.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306626i706DF22CC90E47BF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_5-1729745181047.png%22%20alt%3D%22MVR_5-1729745181047.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_6-1729745194254.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_6-1729745194254.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306627iB6F7E089BA43628A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_6-1729745194254.png%22%20alt%3D%22MVR_6-1729745194254.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_7-1729745202668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_7-1729745202668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306628i36E3F29343FCF941%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_7-1729745202668.png%22%20alt%3D%22MVR_7-1729745202668.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_8-1729745213193.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_8-1729745213193.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306629i1C2B2146470F60F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_8-1729745213193.png%22%20alt%3D%22MVR_8-1729745213193.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_1-1729745107341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_1-1729745107341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306622i7396BD66E3AB5D02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_1-1729745107341.png%22%20alt%3D%22MVR_1-1729745107341.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_3-1729745122469.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_3-1729745122469.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306624i0DD2940AC67FD6FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_3-1729745122469.png%22%20alt%3D%22MVR_3-1729745122469.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MVR_4-1729745129613.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MVR_4-1729745129613.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306625iF720ECC421773D34%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MVR_4-1729745129613.png%22%20alt%3D%22MVR_4-1729745129613.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E9%83%BD%E4%B8%80%E6%A0%B7%EF%BC%8C%E6%80%8E%E4%B9%88%E5%8F%AF%E8%83%BD%E5%91%A2%EF%BC%9F%E5%86%8D%E6%AC%A1%EF%BC%8CCAN0%20%E5%9C%A8%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%20CAN1%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%B7%A6%E4%BE%A7%E6%98%AF%20S32DS%20%E7%9A%84%20RTD%202.0.1%20-%20SW32K3_RTD_4.4_2.0.1%EF%BC%88%20%3CSPAN%3ES32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707%EF%BC%89%EF%BC%8C%E5%8F%B3%E4%BE%A7%E6%98%AF%20Tresos%20%E7%9A%84%E6%96%B0%E5%BA%93%E7%89%88%E6%9C%AC%20-%20SW32K3_RTD_R21-11_4.0.0_HF_02%EF%BC%88S32K3_RTD_4_0_0_HF02_D2407_ASR_REL_4_7_REV_0000_20240725%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A7%BB%E5%8A%A8%E6%80%A7%E9%A3%8E%E9%99%A9%E8%AF%84%E4%BC%B0%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E5%85%B1%E4%BA%AB%E7%AE%80%E5%8C%96%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%8F%AF%E4%BB%A5%E5%9C%A8%20EVB%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E5%85%B6%E4%BB%96%E5%B0%9D%E8%AF%95%E5%8F%AF%E4%BB%A5%E6%B5%8B%E8%AF%95%E6%9C%80%E6%96%B0%20RTD%20%E4%B8%8A%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B9%AB%E5%8A%A9%E6%88%91%E5%97%8E%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52961%22%20target%3D%22_blank%22%3E%40PetrS%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9B%B4%E6%94%B9%E4%BA%86%E6%97%B6%E9%92%9F%EF%BC%8C%E4%BD%86%E9%A2%91%E9%81%93%201%20%E4%BB%8D%E7%84%B6%E4%B8%8D%E5%B7%A5%E4%BD%9C...%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%AE%83%E4%BB%AC%E7%9A%84%E4%BD%8D%E6%97%B6%E5%BA%8F%E8%AE%BE%E7%BD%AE%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%20EB%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC......%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%E6%82%A8%E6%8E%A8%E8%8D%90%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%97%B6%E9%92%9F%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1976805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20S32K344%20%E7%9A%84%20CAN1%20%E9%97%AE%E9%A2%98%20-%20%E9%94%99%E8%AF%AF%E5%B8%A7%EF%BC%88%E5%A1%AB%E5%85%85%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E4%BD%8D%E6%97%B6%E5%BA%8F%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%82%A8%E5%9C%A8%20EB%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E4%B9%9F%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E4%B8%8E%E5%AE%9E%E9%99%85%E5%86%99%E5%85%A5%E4%BD%8D%E6%97%B6%E5%BA%8F%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%20FIRC%20%E4%BD%9C%E4%B8%BA%20PE%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%8C%E9%80%89%E6%8B%A9%20FXOSC%EF%BC%8C%E6%88%96%E8%80%85%E4%BB%8E%20FXOSC%20%E8%BF%90%E8%A1%8C%E7%9A%84%20PLL%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
