Example S32K144 RAM selftest simple S32DS 2018.R1
* Detailed Description:
* RAM self-test is performed after reset in startup_S32K144.s file.
* The RAM self-test should be executed right after reset, so it does not destroy
* data loaded to RAM by init functions. The code is inserted after
* initialization of core registers. RAM initialization is commented out because
* the same operation is done by the self-test.
* The test flow is:
* 1. Write pattern 0x55AA55AA to first word in RAM
* 2. Read the data back
* 3. Compare the data and increment error counter if not equal
* 4. Write inverse pattern 0xAA55AA55 to first word in RAM
* 5. Read the data back
* 6. Compare the data and increment error counter if not equal
* 7. Clear the first word in RAM to leave whole RAM erased to ‘0’ at the end of test
* This procedure is repeated for whole RAM.
* If the error counter is different from zero at the end, the program stays in
* endless loop until watchdog reset.
* Test HW:         S32K144EVB-Q100
* MCU:             FS32K144UAVLL 0N57U
* Fsys:            Default
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH
Comments
Dear Lukas, if I want to run this sample in
"S32 Design Studio for ARM
Version: 2.0
Build id: 170810",
what should I modify to correspond to the environment?
Hi sir,
Is this test contain SRAM-U, SRAM-L and Flex RAM test also?
Please give me the information about this ,
Thankyou
Veeraju V Hallikeri
%3CLINGO-SUB%20id%3D%22lingo-sub-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BS32K144%20RAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%80%81%E5%8D%98%E7%B4%94%E3%81%AAS32DS%202018.R1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%20RAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20startup_S32K144.s%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%20%3CBR%20%2F%3E*%20RAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81%E7%A0%B4%E5%A3%8A%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%9B%B4%E5%BE%8C%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E*%20init%E9%96%A2%E6%95%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6RAM%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%20%3CBR%20%2F%3E*%20%E3%82%B3%E3%82%A2%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%80%82RAM%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20%E3%82%A2%E3%82%A6%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E*%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AF%E3%80%81%3CBR%20%2F%3E*%201.RAM%E5%86%85%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AB%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B30x55AA55AA%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E*%202.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%99%3CBR%20%2F%3E*%203.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81%E7%AD%89%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%204.RAM%E5%86%85%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AB%E9%80%86%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B30xAA55AA55%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%205.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%99%3CBR%20%2F%3E*%206.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81%E7%AD%89%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%207.RAM%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E5%8D%98%E8%AA%9E%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E7%B5%82%E4%BA%86%E6%99%82%E3%81%ABRAM%E5%85%A8%E4%BD%93%E3%82%92%E3%80%8C0%E3%80%8D%E3%81%AB%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81RAM%20%E5%85%A8%E4%BD%93%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%E2%80%BB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%AB%E5%B0%BE%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%20%3CBR%20%2F%3E*%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E7%84%A1%E9%99%90%E3%83%AB%E3%83%BC%E3%83%97%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AS32K144EVB-Q100%3CBR%20%2F%3E%E2%80%BBMCU%3AFS32K144UAVLL%200N57U%3CBR%20%2F%3E*%20fsys%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%3CBR%20%2F%3E*%20%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%20RAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20startup_S32K144.s%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%20%3CBR%20%2F%3E*%20RAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81%E7%A0%B4%E5%A3%8A%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%9B%B4%E5%BE%8C%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E*%20init%E9%96%A2%E6%95%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6RAM%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%20%3CBR%20%2F%3E*%20%E3%82%B3%E3%82%A2%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%80%82RAM%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20%E3%82%A2%E3%82%A6%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E*%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AF%E3%80%81%3CBR%20%2F%3E*%201.RAM%E5%86%85%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AB%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B30x55AA55AA%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E*%202.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%99%3CBR%20%2F%3E*%203.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81%E7%AD%89%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%204.RAM%E5%86%85%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AB%E9%80%86%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B30xAA55AA55%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%205.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%99%3CBR%20%2F%3E*%206.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81%E7%AD%89%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%207.RAM%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E5%8D%98%E8%AA%9E%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E7%B5%82%E4%BA%86%E6%99%82%E3%81%ABRAM%E5%85%A8%E4%BD%93%E3%82%92%E3%80%8C0%E3%80%8D%E3%81%AB%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81RAM%20%E5%85%A8%E4%BD%93%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%E2%80%BB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%AB%E5%B0%BE%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%20%3CBR%20%2F%3E*%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E7%84%A1%E9%99%90%E3%83%AB%E3%83%BC%E3%83%97%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AS32K144EVB-Q100%3CBR%20%2F%3E%E2%80%BBMCU%3AFS32K144UAVLL%200N57U%3CBR%20%2F%3E*%20fsys%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%3CBR%20%2F%3E*%20%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ARAM%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88S32K144%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AAS32DS%202018.R1%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%AB%E3%83%BC%E3%82%AB%E3%82%B9%E3%80%81%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%3C%2FP%3E%3CP%3E%E3%80%8CARM%E7%94%A8S32%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%E3%80%8D%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202.0%20%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89ID%3A170810%20%22%E3%80%81%3C%2FP%3E%3CP%3E%E7%92%B0%E5%A2%83%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E4%BD%95%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎06-06-2019 02:28 AM
Updated by:
