Example S32K144 RAM selftest simple S32DS 2018.R1
* Detailed Description:
* RAM self-test is performed after reset in startup_S32K144.s file.
* The RAM self-test should be executed right after reset, so it does not destroy
* data loaded to RAM by init functions. The code is inserted after
* initialization of core registers. RAM initialization is commented out because
* the same operation is done by the self-test.
* The test flow is:
* 1. Write pattern 0x55AA55AA to first word in RAM
* 2. Read the data back
* 3. Compare the data and increment error counter if not equal
* 4. Write inverse pattern 0xAA55AA55 to first word in RAM
* 5. Read the data back
* 6. Compare the data and increment error counter if not equal
* 7. Clear the first word in RAM to leave whole RAM erased to ‘0’ at the end of test
* This procedure is repeated for whole RAM.
* If the error counter is different from zero at the end, the program stays in
* endless loop until watchdog reset.
* Test HW:         S32K144EVB-Q100
* MCU:             FS32K144UAVLL 0N57U
* Fsys:            Default
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH
附件
评论
Dear Lukas, if I want to run this sample in
"S32 Design Studio for ARM
Version: 2.0
Build id: 170810",
what should I modify to correspond to the environment?
Hi sir,
Is this test contain SRAM-U, SRAM-L and Flex RAM test also?
Please give me the information about this ,
Thankyou
Veeraju V Hallikeri
%3CLINGO-SUB%20id%3D%22lingo-sub-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20S32K144%20RAM%20%E8%87%AA%E6%A3%80%E7%AE%80%E5%8D%95%20S32DS%202018.R1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%E5%9C%A8%E5%90%AF%E5%8A%A8_S32K144.s%E4%B8%AD%E9%87%8D%E7%BD%AE%E5%90%8E%E6%89%A7%E8%A1%8CRAM%E8%87%AA%E6%A3%80%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E*%20RAM%20%E8%87%AA%E6%A3%80%E5%BA%94%E5%9C%A8%E9%87%8D%E7%BD%AE%E5%90%8E%E7%AB%8B%E5%8D%B3%E6%89%A7%E8%A1%8C%EF%BC%8C%E4%BB%A5%E5%85%8D%E7%A0%B4%E5%9D%8F%3CBR%20%2F%3E*%20%E6%95%B0%E6%8D%AE%E7%94%B1%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%E5%8A%A0%E8%BD%BD%E5%88%B0%20RAM%E3%80%82%E4%BB%A3%E7%A0%81%E6%8F%92%E5%85%A5%E5%90%8E%3CBR%20%2F%3E*%20%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82RAM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E8%A2%AB%E6%B3%A8%E9%87%8A%E6%8E%89%EF%BC%8C%E5%9B%A0%E4%B8%BA%3CBR%20%2F%3E*%20%E8%87%AA%E6%A3%80%E4%B9%9F%E8%BF%9B%E8%A1%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E*%20%E6%B5%8B%E8%AF%95%E6%B5%81%E7%A8%8B%E4%B8%BA%EF%BC%9A%3CBR%20%2F%3E%20*%201.%20%E5%B0%86%E6%A8%A1%E5%BC%8F%200x55AA55AA%20%E5%86%99%E5%85%A5%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%3CBR%20%2F%3E*%202.%E8%AF%BB%E5%9B%9E%E6%95%B0%E6%8D%AE%3CBR%20%2F%3E*%203.%20%E6%AF%94%E8%BE%83%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E7%9B%B8%E7%AD%89%EF%BC%8C%E5%88%99%E5%A2%9E%E5%8A%A0%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3E*%204.%20%E5%B0%86%E5%8F%8D%E8%BD%AC%E6%A8%A1%E5%BC%8F%200xAA55AA55%20%E5%86%99%E5%85%A5%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%3CBR%20%2F%3E*%205.%E8%AF%BB%E5%9B%9E%E6%95%B0%E6%8D%AE%3CBR%20%2F%3E*%206.%20%E6%AF%94%E8%BE%83%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E7%9B%B8%E7%AD%89%EF%BC%8C%E5%88%99%E5%A2%9E%E5%8A%A0%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3E*%207.%20%E6%B8%85%E9%99%A4%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9D%9F%E6%97%B6%E5%B0%86%E6%95%B4%E4%B8%AA%20RAM%20%E6%93%A6%E9%99%A4%E4%B8%BA%E2%80%9C0%E2%80%9D%3CBR%20%2F%3E%20*%20%E5%AF%B9%E6%95%B4%E4%B8%AA%20RAM%20%E9%87%8D%E5%A4%8D%E6%AD%A4%E8%BF%87%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%20*%20%E5%A6%82%E6%9E%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%E6%9C%80%E5%90%8E%E4%B8%8D%E4%B8%BA%E9%9B%B6%EF%BC%8C%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%81%9C%E7%95%99%E5%9C%A8%3CBR%20%2F%3E*%20%E6%97%A0%E9%99%90%E5%BE%AA%E7%8E%AF%E7%9B%B4%E5%88%B0%E7%9C%8B%E9%97%A8%E7%8B%97%E5%A4%8D%E4%BD%8D%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AS32K144EVB-Q100%3CBR%20%2F%3E%20*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9AFS32K144UAVLL%200N57U%3CBR%20%2F%3E%20*%20%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%EF%BC%9A%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1106118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%E5%9C%A8%E5%90%AF%E5%8A%A8_S32K144.s%E4%B8%AD%E9%87%8D%E7%BD%AE%E5%90%8E%E6%89%A7%E8%A1%8CRAM%E8%87%AA%E6%A3%80%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E*%20RAM%20%E8%87%AA%E6%A3%80%E5%BA%94%E5%9C%A8%E9%87%8D%E7%BD%AE%E5%90%8E%E7%AB%8B%E5%8D%B3%E6%89%A7%E8%A1%8C%EF%BC%8C%E4%BB%A5%E5%85%8D%E7%A0%B4%E5%9D%8F%3CBR%20%2F%3E*%20%E6%95%B0%E6%8D%AE%E7%94%B1%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%E5%8A%A0%E8%BD%BD%E5%88%B0%20RAM%E3%80%82%E4%BB%A3%E7%A0%81%E6%8F%92%E5%85%A5%E5%90%8E%3CBR%20%2F%3E*%20%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82RAM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E8%A2%AB%E6%B3%A8%E9%87%8A%E6%8E%89%EF%BC%8C%E5%9B%A0%E4%B8%BA%3CBR%20%2F%3E*%20%E8%87%AA%E6%A3%80%E4%B9%9F%E8%BF%9B%E8%A1%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E*%20%E6%B5%8B%E8%AF%95%E6%B5%81%E7%A8%8B%E4%B8%BA%EF%BC%9A%3CBR%20%2F%3E%20*%201.%20%E5%B0%86%E6%A8%A1%E5%BC%8F%200x55AA55AA%20%E5%86%99%E5%85%A5%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%3CBR%20%2F%3E*%202.%E8%AF%BB%E5%9B%9E%E6%95%B0%E6%8D%AE%3CBR%20%2F%3E*%203.%20%E6%AF%94%E8%BE%83%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E7%9B%B8%E7%AD%89%EF%BC%8C%E5%88%99%E5%A2%9E%E5%8A%A0%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3E*%204.%20%E5%B0%86%E5%8F%8D%E8%BD%AC%E6%A8%A1%E5%BC%8F%200xAA55AA55%20%E5%86%99%E5%85%A5%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%3CBR%20%2F%3E*%205.%E8%AF%BB%E5%9B%9E%E6%95%B0%E6%8D%AE%3CBR%20%2F%3E*%206.%20%E6%AF%94%E8%BE%83%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E7%9B%B8%E7%AD%89%EF%BC%8C%E5%88%99%E5%A2%9E%E5%8A%A0%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3E*%207.%20%E6%B8%85%E9%99%A4%20RAM%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%AD%97%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9D%9F%E6%97%B6%E5%B0%86%E6%95%B4%E4%B8%AA%20RAM%20%E6%93%A6%E9%99%A4%E4%B8%BA%E2%80%9C0%E2%80%9D%3CBR%20%2F%3E%20*%20%E5%AF%B9%E6%95%B4%E4%B8%AA%20RAM%20%E9%87%8D%E5%A4%8D%E6%AD%A4%E8%BF%87%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%20*%20%E5%A6%82%E6%9E%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%E6%9C%80%E5%90%8E%E4%B8%8D%E4%B8%BA%E9%9B%B6%EF%BC%8C%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%81%9C%E7%95%99%E5%9C%A8%3CBR%20%2F%3E*%20%E6%97%A0%E9%99%90%E5%BE%AA%E7%8E%AF%E7%9B%B4%E5%88%B0%E7%9C%8B%E9%97%A8%E7%8B%97%E5%A4%8D%E4%BD%8D%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AS32K144EVB-Q100%3CBR%20%2F%3E%20*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9AFS32K144UAVLL%200N57U%3CBR%20%2F%3E%20*%20%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%EF%BC%9A%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20RAM%20%E8%87%AA%E6%A3%80%E7%AE%80%E5%8D%95%20S32DS%202018.R1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Lukas%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E6%83%B3%E8%BF%90%E8%A1%8C%E8%BF%99%E4%B8%AA%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3EARM%20%E7%9A%84%20S32%20%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%EF%BC%9A2.0%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%E5%8F%B7%EF%BC%9A170810%E2%80%9D%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E4%BF%AE%E6%94%B9%E4%BB%80%E4%B9%88%E6%9D%A5%E9%80%82%E5%BA%94%E7%8E%AF%E5%A2%83%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎06-06-2019 02:28 AM
更新人:
