S32DS for vision v2.0 build error(import sdk from vsdk)
huangtianxiang
      It's my first-time use S32DS for vision, I refer the Release note:
I have copied the SDK folder to S32ds install folder.
However, when I import the sample project(e.g. isp_sonyimx224_csi_dcu) and build it, there are 2 problems I can't fix.
The first problem is the OSDIR is not defined.
After I modified the OSDIR to "linux" there is a new problem.
Is there anyone has the same problem, Thanks.
My PC environment is:
Win10_64bit
S32DS for vision newest one.
Labels (2)
Tags (2)
