LIN Example Code?
LIN Example Code?
4,698件の閲覧回数
hjinha
I want to configure LIN communication over S32K144EVB-Q100
Where can i get LIN Example Code?
3 返答(返信)
4,184件の閲覧回数
stanish
I'd recommend you to install the latest S32DS for ARM:
S32 Design Studio for ARM 2018.R1 (Windows/Linux) released!
 and the latest update:
S32 Design Studio for ARM 2018.R1 - Update 8 available
And create a new S32DS project from example (use the latest SDK examples v2.9.2):
Hope it helps.
Stan
4,184件の閲覧回数
hjinha
Thanks You! Sliva.
Does NXP support such tools as LIN Cluster Design tool that generates LDF(LIN Description file)?
4,184件の閲覧回数
stanish
I recall  a tool named  "Node Configuration tool" which is part of FSL LIN stack. The only ARM supported is KEA.
Please check this package:
https://cache.nxp.com/secured/assets/downloads/en/device-drivers/FSL_LIN_2.X_STACK.zip?__gda__=15511...
