what is your use case? If you like store for example some static data in two sections - you can use __attribute__ keyword in your code like this:
__attribute__ ((section(".my_primary_data"))) int primary_data[] = {10,20,30,40,50};
__attribute__ ((section(".my_backup_data"))) int backup_data[] = {10,20,30,40,50};
In linker file you need to define my_backup_data and my_primary_data and sections and if you need them on particular address define - MEMORY region for these sections as well.
If you just need to copy part of flash in run-time - there are some examples in SDK for writing to flash.
Hope it helps.
Jiri
