S32 Design Studio Offline activation issue hot fix
Problem description
When installing S32 Design Studio using the offline activation method (Offline activation on S32 ) the installer may pop up an error dialog: " Error: "Invalid offline response, ResponseType"." This typically occurs on the computers that have no previous installation of S32 Design Studio.
Affected versions
S32DS for ARM v1.1, v1.2, v1.3
S32DS for Power v1.1
S32DS for Vision v1.0
Newer versions should include the fix already.
Solution
Option A) Easiest solution is to use online method instead of offline. But in some cases it may not be possible (LAN restrictions, computer is not connected to the Internet or there is some other network obstacle etc.)
Option B) Apply the hot fix attached. See the instructions below how to proceed for Windows and Linux (Ubuntu) users
Windows users
  • Download and extract the attached archive file "licfix.zip" to your local machine (same package for Windows and Linux)
  • Run "clean.bat" to reset trusted storage
  • Run "setts.bat" to run the activation fix and enter your activation ID for the product you need to activate
  • Select offline activation type and save generated "request.xml" file
  • Submit generated "request.xml" to your nxp.com account offline activation section and generate activation response "activation.xml"
  • Save the created activation response, refresh the Activation response dialog and select the saved file
  • The script is then successfully terminated and now you should be able to install S32 Design Studio
  • Add the executable right to configure.sh script
chmod 777 configure.sh
  • Run the script as admin with parameter "install" to install appropriate libraries
sudo ./configure.sh install
  • Run the script as admin with parameter "reset" to reset trusted storage into its initial state
    sudo ./configure.sh reset
  • Run the script as admin with parameter "activate" to proceed to activation process
    sudo ./configure.sh activate
  • Enter your activation ID for the product you need to activate
  • After this step the script should be terminated without any error message.
Now you should be able to install S32 Design Studio on your computer.
Special thanks to denisrobert and zhongzhengliu for your help with fix testing and to all of you who reported this nasty issue. Thank you!!!
Stan
附件
评论
Hello Stan
I've tried this method,but it didn't work. It seems that the license can not be detected,and I still need to enter an activation code, but I got "Activation ID is already used on this station", could you help me?
Michael Von
Finally I solved this problem!
The ID I used before is unavailable,I ran licfix with ID:C699-XXXX-XXXX-E800 , after this process ,the installtion succeeded.
This is not working for me, tried both in Windows 10 and Ubuntu Linux. I get the same error as before for both online and offline activation. Tried with several activation codes given to me by NXP-staff.
this way is very very good , perfect solve my solution,thanks author!
Here I have a problem,
S32 Design Studio V1.2 starts failed after Offline activation installation, although there is information says the installation is successful. After the installation, I double click the icon to start the S32DS V1.2 IDE on my 64bit computer, which runs on a windows 7 OS, then it appears the information"An error has occurred.See the log file D:\software\s32_power_win32_v1.2\eclipse\configuration\1587541348989.log.", when I install it on a x86 computer, it starts normally after my double click the icon.
here are the contents of log files:
 1.  request.xml
<?xml version="1.0" encoding="UTF-8" ?><Request xmlns="http://www.macrovision.com/fnp/2004/11/activation"><RequestHeader><VersionNumber>3</VersionNumber><RequestType>ACTIVATION</RequestType></RequestHeader><RequestData><EntitlementData>
<EntitlementId>F5C1-454F-0B3F-D638</EntitlementId>
<ActivationReason>0</ActivationReason>
<ProductId>Not Applicable</ProductId><PublisherId>10295808</PublisherId>
</EntitlementData><OriginData><ClientVersion>11.13.0</ClientVersion><ConfigData><IsServer>0</IsServer><TrustedHostInformation><TrustedId>3</TrustedId><Revision>1</Revision><RevisionType>SRV</RevisionType><MachineIdentifier>C10B71177DE41388FFF8D8F63272A257460555DE</MachineIdentifier><Status>OK</Status></TrustedHostInformation></ConfigData>
<Platform>
<PlatformTypeName>i86_n3</PlatformTypeName>
<OperatingSystem><Info>none</Info></OperatingSystem>
</Platform>
<UniqueMachineNumbers>
<UniqueMachineNumber><Type>1</Type><Value>DD27C1ECE3C53BD3AF0066FECCEDDE48B08EBBB8</Value></UniqueMachineNumber>
<UniqueMachineNumber><Type>2</Type><Value>8DA5DC9D43A2734F9CFB439C9AAF6E918F126C23</Value></UniqueMachineNumber>
</UniqueMachineNumbers>
<SequenceNumber>1</SequenceNumber></OriginData><PublisherDictionary>
<Entries>
<Entry>
<Key>flexFulfillmentVersion</Key>
<Value>1</Value>
</Entry>
</Entries>
</PublisherDictionary></RequestData><Hash>36D5F97454FB2C75A57499FC6A34B353E6F1553C</Hash><HashVersion>1</HashVersion></Request>
2.  activation.xml
<?xml version="1.0" encoding="UTF-8" ?><Response xmlns="http://www.macrovision.com/fnp/2004/11/activation"><ResponseHeader><VersionNumber>2</VersionNumber><ResponseType>ACTIVATION</ResponseType><RequestSequenceNumber>1</RequestSequenceNumber><RequestHash>36D5F97454FB2C75A57499FC6A34B353E6F1553C</RequestHash></ResponseHeader><ResponseData><EntitlementData><EntitlementId>F5C1-454F-0B3F-D638</EntitlementId><ProductId>Not Applicable</ProductId></EntitlementData><TrustedHostInformation><TrustedId>3</TrustedId><Revision>1</Revision><RevisionType>SRV</RevisionType><MachineIdentifier>C10B71177DE41388FFF8D8F63272A257460555DE</MachineIdentifier><Status>OK</Status></TrustedHostInformation><FulfillmentRecord><FulfillmentRecordHeader><VersionNumber>1</VersionNumber></FulfillmentRecordHeader><FulfillmentRecordData><FulfillmentId>172921657</FulfillmentId><FulfillmentDictionary><Entries><Entry><Key>serverHostId</Key><Value>INTERNET=0.0.0.0</Value></Entry><Entry><Key>fulfillmentIdChain</Key><Value>172921657</Value></Entry><Entry><Key>servOrLocal</Key><Value>2</Value></Entry><Entry><Key>availAct</Key><Value>1</Value></Entry><Entry><Key>fulfillmentType</Key><Value>6</Value></Entry><Entry><Key>actServerChain</Key><Value>https://nxp.flexnetoperations.com/control/frse/ActivationService</Value></Entry><Entry><Key>features</Key><Value>INCREMENT Activated freescale 1.2 16-jun-2023 1 \
VENDOR_STRING=S32-DS-E200_v1.2|F5C1-454F-0B3F-D638|NO_TRIAL \
DUP_GROUP=UHDV ISSUER="Freescale Semiconductor" \
ISSUED=22-apr-2020 ck=129 SN="FSL - 30328777" TS_OK SIGN="0296 \
8025 ACEC 5534 B687 E3DE D973 B0A1 8D15 1B55 1777 7F25 3555 \
602C 396C 11F6 D87B DC00 5A6C 1218 7276 19E0 D2B2 C66F 5780 \
6286 CC44 D71D 387D 5216"
</Value></Entry><Entry><Key>expiry</Key><Value>16-Jun-2023</Value></Entry><Entry><Key>productId</Key><Value>S32-DS-E200_v1.2</Value></Entry><Entry><Key>entitlementId</Key><Value>F5C1-454F-0B3F-D638</Value></Entry></Entries></FulfillmentDictionary></FulfillmentRecordData></FulfillmentRecord></ResponseData><Signature>0FA674232B263BB9B97E4DD99150D291CF78673E5245FA5012A37E72F55E13CA62F1D7ADF8AAA524505FD31C6C11FEC770C64C9333F88A29EE090292</Signature><SignatureVersion>1</SignatureVersion></Response>
3.  1587541348989.log
!SESSION 2020-04-22 15:42:28.833 -----------------------------------------------
eclipse.buildId=4.4.2.M20150204-1700
java.version=1.8.0_51
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.freescale.s32ds.e200.ide
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.freescale.s32ds.e200.ide
!ENTRY org.eclipse.osgi 4 0 2020-04-22 15:42:38.661
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.cdt.codan.core.application, org.eclipse.cdt.core.GeneratePDOM, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
How to solve this problem under an Offline activation installation method?
Thank you.
        yours Jakie.
Where is the "HOT FIX" attached? ........ as described above?
Please check the bottom of the original message.
This problem does not seems to be related to the activation since the generated XML response is ok.
It rather seems like an eclipse is missing some plugins. Can you try to download the installer again and try to reinstall S32DS.
I'd suggest you to install the lateset greatest version:
https://community.nxp.com/docs/DOC-343864
S.
Sorry to bother you.
I also tried the relevant solutions in the community, but I couldn't solve the problem.
Thanks in advance for your help.
Hello I'm trying to dlownload for a previous version v2.0 and v2.2 is already installed on my local pc. so when I'm trying to get the activation xml file it is giving me this error message again and again. Can anyone please help me on this?
%3CLINGO-SUB%20id%3D%22lingo-sub-1119120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-381677638%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId-381677638%22%20id%3D%22toc-hId-1303113460%22%3E%E9%97%AE%E9%A2%98%E6%8F%8F%E8%BF%B0%3C%2FH1%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E6%96%B9%E5%BC%8F%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%20%E6%97%B6%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-332281%22%20target%3D%22_blank%22%3ES32%20%E4%B8%8A%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%3C%2FA%3E%EF%BC%89%EF%BC%8C%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BC%B9%E5%87%BA%E9%94%99%E8%AF%AF%E5%AF%B9%E8%AF%9D%E6%A1%86%EF%BC%9A%E2%80%9C%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98Invalid%20offline%20response%2C%20ResponseType%E2%80%99%E3%80%82%E2%80%9D%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E9%80%9A%E5%B8%B8%E5%8F%91%E7%94%9F%E5%9C%A8%E4%B9%8B%E5%89%8D%E6%9C%AA%E5%AE%89%E8%A3%85%E8%BF%87%20S32%20Design%20Studio%20%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline.png%22%20style%3D%22width%3A%20574px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19440i8B5063C60B371224%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline.png%22%20alt%3D%22S32DS_invalid_offline.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425776825%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--1425776825%22%20id%3D%22toc-hId--504341003%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1061736008%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId-1061736008%22%20id%3D%22toc-hId-1983171830%22%3E%E5%8F%97%E5%BD%B1%E5%93%8D%E7%9A%84%E7%89%88%E6%9C%AC%3C%2FH1%3E%3CP%3ES32DS%20for%20ARM%20v1.1%2C%20v1.2%2C%20v1.3%3C%2FP%3E%3CP%3ES32DS%20for%20Power%20v1.1%3C%2FP%3E%3CP%3ES32DS%20for%20Vision%20v1.0%3C%2FP%3E%3CP%3E%E8%BE%83%E6%96%B0%E7%9A%84%E7%89%88%E6%9C%AC%E5%BA%94%E8%AF%A5%E5%B7%B2%E7%BB%8F%E5%8C%85%E5%90%AB%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745718455%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--745718455%22%20id%3D%22toc-hId-175717367%22%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FH1%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E9%A1%B9%20A)%EF%BC%9A%E6%9C%80%E7%AE%80%E5%8D%95%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%BD%BF%E7%94%A8%E5%9C%A8%E7%BA%BF%E6%BF%80%E6%B4%BB%E6%96%B9%E5%BC%8F%E6%9B%BF%E4%BB%A3%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E3%80%82%E4%BD%86%E5%9C%A8%E6%9F%90%E4%BA%9B%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%A6%82%E5%B1%80%E5%9F%9F%E7%BD%91%E9%99%90%E5%88%B6%E3%80%81%E8%AE%A1%E7%AE%97%E6%9C%BA%E6%9C%AA%E8%81%94%E7%BD%91%E6%88%96%E5%AD%98%E5%9C%A8%E5%85%B6%E4%BB%96%E7%BD%91%E7%BB%9C%E9%9A%9C%E7%A2%8D%E7%AD%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E9%A1%B9%20B)%3CSTRONG%3E%20%3C%2FSTRONG%3E%E5%BA%94%E7%94%A8%E9%99%84%E5%B8%A6%E7%9A%84%E7%83%AD%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%EF%BC%8C%E4%BA%86%E8%A7%A3%20Windows%20%E5%92%8C%20Linux%EF%BC%88Ubuntu%EF%BC%89%E7%94%A8%E6%88%B7%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20id%3D%22toc-hId--55156981%22%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%20id%3D%22toc-hId--55156981%22%20id%3D%22toc-hId-866278841%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3EWindows%20%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%B8%8B%E8%BD%BD%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Elicfix.zip%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8E%8B%E7%BC%A9%E5%8C%85%E5%B9%B6%E8%A7%A3%E5%8E%8B%E5%88%B0%E6%9C%AC%E5%9C%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%EF%BC%88Windows%20%E5%92%8C%20Linux%20%E9%80%9A%E7%94%A8%E5%8C%85%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%BF%90%E8%A1%8C%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eclean.bat%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E4%BB%A5%E9%87%8D%E7%BD%AE%E5%8F%AF%E4%BF%A1%E5%AD%98%E5%82%A8%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20left%3B%20padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_2.png%22%20style%3D%22width%3A%20404px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19485i7F9DD068E9E97D5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_2.png%22%20alt%3D%22S32DS_invalid_offline_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%BF%90%E8%A1%8C%20%E2%80%9C%3CEM%3E%3CSTRONG%3Esetts.bat%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E4%BB%A5%E6%89%A7%E8%A1%8C%E6%BF%80%E6%B4%BB%E4%BF%AE%E5%A4%8D%EF%BC%8C%E5%B9%B6%E8%BE%93%E5%85%A5%E9%9C%80%E8%A6%81%E6%BF%80%E6%B4%BB%E7%9A%84%E4%BA%A7%E5%93%81%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_3.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19519i6157677CE40266E3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_3.png%22%20alt%3D%22S32DS_invalid_offline_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E6%8B%A9%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E7%B1%BB%E5%9E%8B%EF%BC%8C%E5%B9%B6%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%96%87%E4%BB%B6%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_4.png%22%20style%3D%22width%3A%20320px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19551iC4A6252B8A350ED2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_4.png%22%20alt%3D%22S32DS_invalid_offline_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_5.png%22%20style%3D%22width%3A%20512px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19648i12A76B5AD511CD42%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_5.png%22%20alt%3D%22S32DS_invalid_offline_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%8F%90%E4%BA%A4%E5%88%B0%E6%82%A8%E7%9A%84%20nxp.com%20%E8%B4%A6%E6%88%B7%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%83%A8%E5%88%86%EF%BC%8C%E5%B9%B6%E7%94%9F%E6%88%90%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivation.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_6.png%22%20style%3D%22width%3A%20818px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19603i02BFE617B5168456%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_6.png%22%20alt%3D%22S32DS_invalid_offline_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%EF%BC%8C%E5%88%B7%E6%96%B0%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E5%AF%B9%E8%AF%9D%E6%A1%86%E5%B9%B6%E9%80%89%E6%8B%A9%E4%BF%9D%E5%AD%98%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_7.png%22%20style%3D%22width%3A%20852px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19677i15D701226314092D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_7.png%22%20alt%3D%22S32DS_invalid_offline_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_8.png%22%20style%3D%22width%3A%20512px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19727i56242C4FBCBC7F82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_8.png%22%20alt%3D%22S32DS_invalid_offline_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%84%9A%E6%9C%AC%E5%B0%86%E6%88%90%E5%8A%9F%E7%BB%88%E6%AD%A2%EF%BC%8C%E6%AD%A4%E6%97%B6%E6%82%A8%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%20%E4%BA%86%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_9.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19728iECD15EF19E0605D4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_9.png%22%20alt%3D%22S32DS_invalid_offline_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1862611444%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--1862611444%22%20id%3D%22toc-hId--941175622%22%3ELinux%20(Ubuntu)%20users%3C%2FH2%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%B8%8B%E8%BD%BD%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Elicfix.zip%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8E%8B%E7%BC%A9%E5%8C%85%E5%B9%B6%E8%A7%A3%E5%8E%8B%E5%88%B0%E6%9C%AC%E5%9C%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%EF%BC%88Windows%20%E5%92%8C%20Linux%20%E9%80%9A%E7%94%A8%E5%8C%85%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E4%B8%BA%20configure.sh%20%E8%84%9A%E6%9C%AC%E6%B7%BB%E5%8A%A0%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%9D%83%E9%99%90%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20style%3D%22padding-left%3A%2030px%3B%22%3Echmod%20777%20configure.sh%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux1.png%22%20style%3D%22width%3A%20720px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19777i0A443ADEC9AE3658%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux1.png%22%20alt%3D%22S32DS_invalid_offline_linux1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Einstall%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BB%A5%E5%AE%89%E8%A3%85%E7%9B%B8%E5%BA%94%E7%9A%84%E5%BA%93%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20style%3D%22padding-left%3A%2030px%3B%22%3Esudo%20.%2Fconfigure.sh%20install%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux2.png%22%20style%3D%22width%3A%20720px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19817i87813DC4A5A4E7CB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux2.png%22%20alt%3D%22S32DS_invalid_offline_linux2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Ereset%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E5%B0%86%E5%8F%AF%E4%BF%A1%E5%AD%98%E5%82%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%88%9D%E5%A7%8B%E7%8A%B6%E6%80%81%3CBLOCKQUOTE%20class%3D%22jive-quote%22%20style%3D%22margin%3A%200%200%200%2040px%3B%20border%3A%20none%3B%20padding%3A%200px%3B%22%3E%3C%2FBLOCKQUOTE%3E%3CPRE%20translate%3D%22no%22%3Esudo%20.%2Fconfigure.sh%20reset%3C%2FPRE%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux3.png%22%20style%3D%22width%3A%20704px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19604i35319B0E8510D52B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux3.png%22%20alt%3D%22S32DS_invalid_offline_linux3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivate%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E8%BF%9B%E5%85%A5%E6%BF%80%E6%B4%BB%E6%B5%81%E7%A8%8B%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3Esudo%20.%2Fconfigure.sh%20activate%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E8%BE%93%E5%85%A5%E9%9C%80%E8%A6%81%E6%BF%80%E6%B4%BB%E7%9A%84%E4%BA%A7%E5%93%81%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux4.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19441i7510A9AF13AA22F8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux4.png%22%20alt%3D%22S32DS_invalid_offline_linux4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%80%89%E6%8B%A9%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E7%B1%BB%E5%9E%8B%EF%BC%8C%E5%B9%B6%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%96%87%E4%BB%B6%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux5.png%22%20style%3D%22width%3A%20262px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19851i80B285B640BA43C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux5.png%22%20alt%3D%22S32DS_invalid_offline_linux5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux6.png%22%20style%3D%22width%3A%20518px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19914iE876CDBD5FF385DF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux6.png%22%20alt%3D%22S32DS_invalid_offline_linux6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CSTRONG%3E%3CEM%3Erequest.xml%3C%2FEM%3E%3C%2FSTRONG%3E%E2%80%9D%20%E6%8F%90%E4%BA%A4%E5%88%B0%E6%82%A8%E7%9A%84%20nxp.com%20%E8%B4%A6%E6%88%B7%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%83%A8%E5%88%86%EF%BC%8C%E5%B9%B6%E7%94%9F%E6%88%90%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivation.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux7.png%22%20style%3D%22width%3A%20896px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19955i6C66FE1CA3868710%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux7.png%22%20alt%3D%22S32DS_invalid_offline_linux7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_invalid_offline_linux8.png%22%20style%3D%22width%3A%20516px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F20010i954DD406C288BB36%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_invalid_offline_linux8.png%22%20alt%3D%22S32DS_invalid_offline_linux8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_invalid_offline_linux8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%AD%A4%E6%AD%A5%E9%AA%A4%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E8%84%9A%E6%9C%AC%E5%BA%94%E6%97%A0%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%9C%B0%E7%BB%88%E6%AD%A2%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%9C%A8%E6%82%A8%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%B9%E5%88%AB%E6%84%9F%E8%B0%A2%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdenisrobert%22%20target%3D%22_blank%22%3Edenisrobert%3C%2FA%3E%20%E5%92%8C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fzhongzhengliu%22%20target%3D%22_blank%22%3Ezhongzheng%20liu%3C%2FA%3E%20%E5%9C%A8%E4%BF%AE%E5%A4%8D%E6%B5%8B%E8%AF%95%E4%B8%AD%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%89%80%E6%9C%89%E6%8A%A5%E5%91%8A%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E7%94%A8%E6%88%B7%EF%BC%81%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1119120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--951678726%22%3E%E9%97%AE%E9%A2%98%E6%8F%8F%E8%BF%B0%3C%2FH1%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E6%96%B9%E5%BC%8F%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%20%E6%97%B6%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-332281%22%20target%3D%22_blank%22%3ES32%20%E4%B8%8A%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%3C%2FA%3E%EF%BC%89%EF%BC%8C%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BC%B9%E5%87%BA%E9%94%99%E8%AF%AF%E5%AF%B9%E8%AF%9D%E6%A1%86%EF%BC%9A%E2%80%9C%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98Invalid%20offline%20response%2C%20ResponseType%E2%80%99%E3%80%82%E2%80%9D%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E9%80%9A%E5%B8%B8%E5%8F%91%E7%94%9F%E5%9C%A8%E4%B9%8B%E5%89%8D%E6%9C%AA%E5%AE%89%E8%A3%85%E8%BF%87%20S32%20Design%20Studio%20%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CP%3E%3C%2FP%3E%3CH1%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId-1535834107%22%3E%3C%2FH1%3E%3CH1%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--271620356%22%3E%E5%8F%97%E5%BD%B1%E5%93%8D%E7%9A%84%E7%89%88%E6%9C%AC%3C%2FH1%3E%3CP%3ES32DS%20for%20ARM%20v1.1%2C%20v1.2%2C%20v1.3%3C%2FP%3E%3CP%3ES32DS%20for%20Power%20v1.1%3C%2FP%3E%3CP%3ES32DS%20for%20Vision%20v1.0%3C%2FP%3E%3CP%3E%E8%BE%83%E6%96%B0%E7%9A%84%E7%89%88%E6%9C%AC%E5%BA%94%E8%AF%A5%E5%B7%B2%E7%BB%8F%E5%8C%85%E5%90%AB%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--2079074819%22%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FH1%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E9%A1%B9%20A)%EF%BC%9A%E6%9C%80%E7%AE%80%E5%8D%95%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%BD%BF%E7%94%A8%E5%9C%A8%E7%BA%BF%E6%BF%80%E6%B4%BB%E6%96%B9%E5%BC%8F%E6%9B%BF%E4%BB%A3%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E3%80%82%E4%BD%86%E5%9C%A8%E6%9F%90%E4%BA%9B%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%A6%82%E5%B1%80%E5%9F%9F%E7%BD%91%E9%99%90%E5%88%B6%E3%80%81%E8%AE%A1%E7%AE%97%E6%9C%BA%E6%9C%AA%E8%81%94%E7%BD%91%E6%88%96%E5%AD%98%E5%9C%A8%E5%85%B6%E4%BB%96%E7%BD%91%E7%BB%9C%E9%9A%9C%E7%A2%8D%E7%AD%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E9%A1%B9%20B)%3CSTRONG%3E%20%3C%2FSTRONG%3E%E5%BA%94%E7%94%A8%E9%99%84%E5%B8%A6%E7%9A%84%E7%83%AD%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%EF%BC%8C%E4%BA%86%E8%A7%A3%20Windows%20%E5%92%8C%20Linux%EF%BC%88Ubuntu%EF%BC%89%E7%94%A8%E6%88%B7%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%20id%3D%22toc-hId-285256394%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3EWindows%20%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%B8%8B%E8%BD%BD%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Elicfix.zip%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8E%8B%E7%BC%A9%E5%8C%85%E5%B9%B6%E8%A7%A3%E5%8E%8B%E5%88%B0%E6%9C%AC%E5%9C%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%EF%BC%88Windows%20%E5%92%8C%20Linux%20%E9%80%9A%E7%94%A8%E5%8C%85%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%BF%90%E8%A1%8C%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eclean.bat%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E4%BB%A5%E9%87%8D%E7%BD%AE%E5%8F%AF%E4%BF%A1%E5%AD%98%E5%82%A8%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20left%3B%20padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%BF%90%E8%A1%8C%20%E2%80%9C%3CEM%3E%3CSTRONG%3Esetts.bat%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E4%BB%A5%E6%89%A7%E8%A1%8C%E6%BF%80%E6%B4%BB%E4%BF%AE%E5%A4%8D%EF%BC%8C%E5%B9%B6%E8%BE%93%E5%85%A5%E9%9C%80%E8%A6%81%E6%BF%80%E6%B4%BB%E7%9A%84%E4%BA%A7%E5%93%81%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E9%80%89%E6%8B%A9%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E7%B1%BB%E5%9E%8B%EF%BC%8C%E5%B9%B6%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%96%87%E4%BB%B6%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%8F%90%E4%BA%A4%E5%88%B0%E6%82%A8%E7%9A%84%20nxp.com%20%E8%B4%A6%E6%88%B7%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%83%A8%E5%88%86%EF%BC%8C%E5%B9%B6%E7%94%9F%E6%88%90%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivation.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%EF%BC%8C%E5%88%B7%E6%96%B0%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E5%AF%B9%E8%AF%9D%E6%A1%86%E5%B9%B6%E9%80%89%E6%8B%A9%E4%BF%9D%E5%AD%98%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%E8%84%9A%E6%9C%AC%E5%B0%86%E6%88%90%E5%8A%9F%E7%BB%88%E6%AD%A2%EF%BC%8C%E6%AD%A4%E6%97%B6%E6%82%A8%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%20%E4%BA%86%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--1522198069%22%3ELinux%20(Ubuntu)%20users%3C%2FH2%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E4%B8%8B%E8%BD%BD%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Elicfix.zip%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8E%8B%E7%BC%A9%E5%8C%85%E5%B9%B6%E8%A7%A3%E5%8E%8B%E5%88%B0%E6%9C%AC%E5%9C%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%EF%BC%88Windows%20%E5%92%8C%20Linux%20%E9%80%9A%E7%94%A8%E5%8C%85%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E4%B8%BA%20configure.sh%20%E8%84%9A%E6%9C%AC%E6%B7%BB%E5%8A%A0%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%9D%83%E9%99%90%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20style%3D%22padding-left%3A%2030px%3B%22%3Echmod%20777%20configure.sh%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Einstall%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BB%A5%E5%AE%89%E8%A3%85%E7%9B%B8%E5%BA%94%E7%9A%84%E5%BA%93%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20style%3D%22padding-left%3A%2030px%3B%22%3Esudo%20.%2Fconfigure.sh%20install%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Ereset%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E5%B0%86%E5%8F%AF%E4%BF%A1%E5%AD%98%E5%82%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%88%9D%E5%A7%8B%E7%8A%B6%E6%80%81%3CBLOCKQUOTE%20class%3D%22jive-quote%22%20style%3D%22margin%3A%200%200%200%2040px%3B%20border%3A%20none%3B%20padding%3A%200px%3B%22%3E%3C%2FBLOCKQUOTE%3E%3CPRE%20translate%3D%22no%22%3Esudo%20.%2Fconfigure.sh%20reset%3C%2FPRE%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E5%B9%B6%E5%B8%A6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivate%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E5%8F%82%E6%95%B0%EF%BC%8C%E8%BF%9B%E5%85%A5%E6%BF%80%E6%B4%BB%E6%B5%81%E7%A8%8B%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3Esudo%20.%2Fconfigure.sh%20activate%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E8%BE%93%E5%85%A5%E9%9C%80%E8%A6%81%E6%BF%80%E6%B4%BB%E7%9A%84%E4%BA%A7%E5%93%81%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%80%89%E6%8B%A9%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E7%B1%BB%E5%9E%8B%EF%BC%8C%E5%B9%B6%E4%BF%9D%E5%AD%98%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CEM%3E%3CSTRONG%3Erequest.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%20%E6%96%87%E4%BB%B6%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%20%E2%80%9C%3CSTRONG%3E%3CEM%3Erequest.xml%3C%2FEM%3E%3C%2FSTRONG%3E%E2%80%9D%20%E6%8F%90%E4%BA%A4%E5%88%B0%E6%82%A8%E7%9A%84%20nxp.com%20%E8%B4%A6%E6%88%B7%E7%9A%84%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%83%A8%E5%88%86%EF%BC%8C%E5%B9%B6%E7%94%9F%E6%88%90%E6%BF%80%E6%B4%BB%E5%93%8D%E5%BA%94%E6%96%87%E4%BB%B6%20%E2%80%9C%3CEM%3E%3CSTRONG%3Eactivation.xml%3C%2FSTRONG%3E%3C%2FEM%3E%E2%80%9D%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2F0255F9CE795E790E84C2F222EC0FBA1E%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%AD%A4%E6%AD%A5%E9%AA%A4%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E8%84%9A%E6%9C%AC%E5%BA%94%E6%97%A0%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%9C%B0%E7%BB%88%E6%AD%A2%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-left%3A%20.375in%3B%20font-size%3A%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%9C%A8%E6%82%A8%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%B9%E5%88%AB%E6%84%9F%E8%B0%A2%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FDenis%20Robert%22%20target%3D%22_blank%22%3Edenisrobert%3C%2FA%3E%20%E5%92%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fzhongzheng%20liu%22%20target%3D%22_blank%22%3Ezhongzheng%20liu%3C%2FA%3E%20%E5%9C%A8%E4%BF%AE%E5%A4%8D%E6%B5%8B%E8%AF%95%E4%B8%AD%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%89%80%E6%9C%89%E6%8A%A5%E5%91%8A%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E7%94%A8%E6%88%B7%EF%BC%81%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1119120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%BF%80%E6%B4%BB%20-%20%E5%AE%89%E8%A3%85%20-%20%E8%AE%B8%E5%8F%AF%20-%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E4%B8%8B%E8%BD%BD%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1732744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1732744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%B0%9D%E8%AF%95%E4%B8%8B%E8%BD%BD%E6%97%A7%E7%89%88%E6%9C%AC%20v2.0%EF%BC%8C%E8%80%8C%E6%88%91%E7%9A%84%E6%9C%AC%E5%9C%B0%E7%94%B5%E8%84%91%E4%B8%8A%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%20v2.2%E3%80%82%E6%89%80%E4%BB%A5%E5%BD%93%E6%88%91%E8%AF%95%E5%9B%BE%E8%8E%B7%E5%8F%96%E6%BF%80%E6%B4%BB%20xml%20%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%AE%83%E5%8F%8D%E5%A4%8D%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%2C%20'Microsoft%20YaHei'%2C%20'%5CFAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C%20'%5CB8B%E4%BD%93'%2C%20'Malgun%20Gothic'%2C%20Meiryo%2C%20sans-serif%3B%20font-size%3A%2014.000000953674316px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%2025.989585876464844px%3B%20orphans%3A%20auto%3B%20text-align%3A%20justify%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%20auto%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f8fa%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%8A%B1%E6%AD%89%E6%89%93%E6%89%B0%E6%82%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%2C%20'Microsoft%20YaHei'%2C%20'%5CFAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C%20'%5CB8B%E4%BD%93'%2C%20'Malgun%20Gothic'%2C%20Meiryo%2C%20sans-serif%3B%20font-size%3A%2014.000000953674316px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%2025.989585876464844px%3B%20orphans%3A%20auto%3B%20text-align%3A%20justify%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%20auto%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f8fa%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%88%91%E5%9C%A8%E5%AE%89%E8%A3%85%EF%BC%88S32DS_PA%20V2.1%EF%BC%89%E6%97%B6%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Error.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108842i5694B9971D98371D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Error.PNG%22%20alt%3D%22Error.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EError.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23001000%3B%20font-family%3A%20Arial%2C'Microsoft%20YaHei'%2C'FAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'B8B%E4%BD%93'%2C'Malgun%20Gothic'%2CMeiryo%2Csans-serif%3B%20background-color%3A%20%23f7f8fa%3B%22%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E4%BA%86%E7%A4%BE%E5%8C%BA%E4%B8%AD%E7%9A%84%E7%9B%B8%E5%85%B3%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E4%BD%86%E6%9C%AA%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E4%B8%8E%E6%BF%80%E6%B4%BB%E6%97%A0%E5%85%B3%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%9F%E6%88%90%E7%9A%84%20XML%20%E5%93%8D%E5%BA%94%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%9B%B4%E5%8F%AF%E8%83%BD%E6%98%AF%20Eclipse%20%E7%BC%BA%E5%B0%91%E6%9F%90%E4%BA%9B%E6%8F%92%E4%BB%B6%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%E9%87%8D%E6%96%B0%E4%B8%8B%E8%BD%BD%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%B9%B6%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20S32DS%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%AE%89%E8%A3%85%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343864%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343864%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ES%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E5%8E%9F%E5%A7%8B%E6%B6%88%E6%81%AF%E7%9A%84%E5%BA%95%E9%83%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20997px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F107420i64CF8C01056F48F1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E2%80%9C%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%E2%80%9D%E9%99%84%E4%BB%B6%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%E5%B0%B1%E5%83%8F%E4%B8%8A%E9%9D%A2%E6%8F%8F%E8%BF%B0%E7%9A%84%E9%82%A3%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E5%AE%89%E8%A3%85%20S32%20Design%20Studio%20V1.2%20%E5%90%8E%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%98%BE%E7%A4%BA%E5%AE%89%E8%A3%85%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%E3%80%82%E5%AE%89%E8%A3%85%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E6%88%91%E5%9C%A8%E8%BF%90%E8%A1%8C%20Windows%207%20%E7%B3%BB%E7%BB%9F%E7%9A%84%2064%20%E4%BD%8D%E7%94%B5%E8%84%91%E4%B8%8A%E5%8F%8C%E5%87%BB%E5%9B%BE%E6%A0%87%E5%90%AF%E5%8A%A8%20S32DS%20V1.2%20IDE%20%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%8F%90%E7%A4%BA%E4%BF%A1%E6%81%AF%20%E2%80%9C%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%20D%3A%5Csoftware%5Cs32_power_win32_v1.2%5Ceclipse%5Cconfiguration%5C1587541348989.log%E2%80%9D%EF%BC%9B%E8%80%8C%E5%BD%93%E6%88%91%E5%9C%A8%20x86%EF%BC%8832%20%E4%BD%8D%EF%BC%89%E7%94%B5%E8%84%91%E4%B8%8A%E5%AE%89%E8%A3%85%E6%97%B6%EF%BC%8C%E5%8F%8C%E5%87%BB%E5%9B%BE%E6%A0%87%E5%90%8E%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B1.%26nbsp%3B%20request.xml%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CREQUEST%20xmlns%3D%22%26lt%3B%2FSPAN%26gt%3B%26lt%3BA%20class%3D%22%20jive-link-external-small%3D%22%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.macrovision.com%2Ffnp%2F2004%2F11%2Factivation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.macrovision.com%2Ffnp%2F2004%2F11%2Factivation%3C%2FA%3E%3CSPAN%3E%22%26gt%3B%3CREQUESTHEADER%3E%3CVERSIONNUMBER%3E3%3C%2FVERSIONNUMBER%3E%3CREQUESTTYPE%3EACTIVATION%3C%2FREQUESTTYPE%3E%3C%2FREQUESTHEADER%3E%3CREQUESTDATA%3E%3CENTITLEMENTDATA%3E%3C%2FENTITLEMENTDATA%3E%3C%2FREQUESTDATA%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CENTITLEMENTID%3EF5C1-454F-0B3F-D638%3C%2FENTITLEMENTID%3E%3CACTIVATIONREASON%3E0%3C%2FACTIVATIONREASON%3E%3CPRODUCTID%3E%E4%B8%8D%E9%80%82%E7%94%A8%3C%2FPRODUCTID%3E%3CPUBLISHERID%3E10295808%3C%2FPUBLISHERID%3E%3C%2FREQUEST%3E%3CORIGINDATA%3E%3CCLIENTVERSION%3E11.13.0%3C%2FCLIENTVERSION%3E%3CCONFIGDATA%3E%3CISSERVER%3E0%3C%2FISSERVER%3E%3CTRUSTEDHOSTINFORMATION%3E%3CTRUSTEDID%3E3%3C%2FTRUSTEDID%3E%3CREVISION%3E1%3C%2FREVISION%3E%3CREVISIONTYPE%3ESRV%3C%2FREVISIONTYPE%3E%3CMACHINEIDENTIFIER%3EC10B71177DE41388FFF8D8F63272A257460555DE%3C%2FMACHINEIDENTIFIER%3E%3CSTATUS%3EOK%3C%2FSTATUS%3E%3C%2FTRUSTEDHOSTINFORMATION%3E%3C%2FCONFIGDATA%3E%3CPLATFORM%3E%3CPLATFORMTYPENAME%3Ei86_n3%3C%2FPLATFORMTYPENAME%3E%3COPERATINGSYSTEM%3E%3CINFO%3Enone%3C%2FINFO%3E%3C%2FOPERATINGSYSTEM%3E%3C%2FPLATFORM%3E%3CUNIQUEMACHINENUMBERS%3E%3CUNIQUEMACHINENUMBER%3E%3CTYPE%3E1%3C%2FTYPE%3E%3CVALUE%3EDD27C1ECE3C53BD3AF0066FECCEDDE48B08EBBB8%3C%2FVALUE%3E%3C%2FUNIQUEMACHINENUMBER%3E%3CUNIQUEMACHINENUMBER%3E%3CTYPE%3E2%3C%2FTYPE%3E%3CVALUE%3E8DA5DC9D43A2734F9CFB439C9AAF6E918F126C23%3C%2FVALUE%3E%3C%2FUNIQUEMACHINENUMBER%3E%3C%2FUNIQUEMACHINENUMBERS%3E%3CSEQUENCENUMBER%3E1%3C%2FSEQUENCENUMBER%3E%3C%2FORIGINDATA%3E%3CPUBLISHERDICTIONARY%3E%3CENTRIES%3E%3CENTRY%3E%3CKEY%3EflexFulfillmentVersion%3C%2FKEY%3E%3CVALUE%3E1%3C%2FVALUE%3E%3C%2FENTRY%3E%3C%2FENTRIES%3E%3C%2FPUBLISHERDICTIONARY%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CHASH%3E36D5F97454FB2C75A57499FC6A34B353E6F1553C%3C%2FHASH%3E%3CHASHVERSION%3E1%3C%2FHASHVERSION%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20activation.xml%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CRESPONSE%20xmlns%3D%22%26lt%3B%2FSPAN%26gt%3B%26lt%3BA%20class%3D%22%20jive-link-external-small%3D%22%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.macrovision.com%2Ffnp%2F2004%2F11%2Factivation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.macrovision.com%2Ffnp%2F2004%2F11%2Factivation%3C%2FA%3E%3CSPAN%3E%22%26gt%3B%3CRESPONSEHEADER%3E%3CVERSIONNUMBER%3E2%3C%2FVERSIONNUMBER%3E%3CRESPONSETYPE%3EACTIVATION%3C%2FRESPONSETYPE%3E%3CREQUESTSEQUENCENUMBER%3E1%3C%2FREQUESTSEQUENCENUMBER%3E%3CREQUESTHASH%3E36D5F97454FB2C75A57499FC6A34B353E6F1553C%3C%2FREQUESTHASH%3E%3C%2FRESPONSEHEADER%3E%3CRESPONSEDATA%3E%3CENTITLEMENTDATA%3E%3CENTITLEMENTID%3EF5C1-454F-0B3F-D638%3C%2FENTITLEMENTID%3E%3CPRODUCTID%3ENot%20Applicable%3C%2FPRODUCTID%3E%3C%2FENTITLEMENTDATA%3E%3CTRUSTEDHOSTINFORMATION%3E%3CTRUSTEDID%3E3%3C%2FTRUSTEDID%3E%3CREVISION%3E1%3C%2FREVISION%3E%3CREVISIONTYPE%3ESRV%3C%2FREVISIONTYPE%3E%3CMACHINEIDENTIFIER%3EC10B71177DE41388FFF8D8F63272A257460555DE%3C%2FMACHINEIDENTIFIER%3E%3CSTATUS%3EOK%3C%2FSTATUS%3E%3C%2FTRUSTEDHOSTINFORMATION%3E%3CFULFILLMENTRECORD%3E%3CFULFILLMENTRECORDHEADER%3E%3CVERSIONNUMBER%3E1%3C%2FVERSIONNUMBER%3E%3C%2FFULFILLMENTRECORDHEADER%3E%3CFULFILLMENTRECORDDATA%3E%3CFULFILLMENTID%3E172921657%3C%2FFULFILLMENTID%3E%3CFULFILLMENTDICTIONARY%3E%3CENTRIES%3E%3CENTRY%3E%3CKEY%3EserverHostId%3C%2FKEY%3E%3CVALUE%3EINTERNET%3D0.0.0.0%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EfulfillmentIdChain%3C%2FKEY%3E%3CVALUE%3E172921657%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EservOrLocal%3C%2FKEY%3E%3CVALUE%3E2%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EavailAct%3C%2FKEY%3E%3CVALUE%3E1%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EfulfillmentType%3C%2FKEY%3E%3CVALUE%3E6%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EactServerChain%3C%2FKEY%3E%3CVALUE%3E%3C%2FVALUE%3E%3C%2FENTRY%3E%3C%2FENTRIES%3E%3C%2FFULFILLMENTDICTIONARY%3E%3C%2FFULFILLMENTRECORDDATA%3E%3C%2FFULFILLMENTRECORD%3E%3C%2FRESPONSEDATA%3E%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fnxp.flexnetoperations.com%252Fcontrol%252Ffrse%252FActivationService%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2FActivationService%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FRESPONSE%3E%3CENTRY%3E%3CKEY%3Efeatures%3C%2FKEY%3E%3CVALUE%3EINCREMENT%20Activated%20freescale%201.2%2016-jun-2023%201%20%5C%3C%2FVALUE%3E%3C%2FENTRY%3E%3C%2FSPAN%3E%3CBR%20%2F%3EVENDOR_STRING%3DS32-DS-E200_v1.2%7CF5C1-454F-0B3F-D638%7CNO_TRIAL%20%5C%3CBR%20%2F%3EDUP_GROUP%3DUHDV%20ISSUER%3D%22Freescale%20Semiconductor%22%20%5C%3CBR%20%2F%3EISSUED%3D22-apr-2020%20ck%3D129%20SN%3D%22FSL%20-%2030328777%22%20TS_OK%20SIGN%3D%220296%20%5C%3CBR%20%2F%3E8025%20ACEC%205534%20B687%20E3DE%20D973%20B0A1%208D15%201B55%201777%207F25%203555%20%5C%3CBR%20%2F%3E602C%20396C%2011F6%20D87B%20DC00%205A6C%201218%207276%2019E0%20D2B2%20C66F%205780%20%5C%3CBR%20%2F%3E6286%20CC44%20D71D%20387D%205216%22%3CBR%20%2F%3E%3CENTRY%3E%3CKEY%3Eexpiry%3C%2FKEY%3E%3CVALUE%3E16-Jun-2023%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EproductId%3C%2FKEY%3E%3CVALUE%3ES32-DS-E200_v1.2%3C%2FVALUE%3E%3C%2FENTRY%3E%3CENTRY%3E%3CKEY%3EentitlementId%3C%2FKEY%3E%3CVALUE%3EF5C1-454F-0B3F-D638%3C%2FVALUE%3E%3C%2FENTRY%3E%3CSIGNATURE%3E0FA674232B263BB9B97E4DD99150D291CF78673E5245FA5012A37E72F55E13CA62F1D7ADF8AAA524505FD31C6C11FEC770C64C9333F88A29EE090292%3C%2FSIGNATURE%3E%3CSIGNATUREVERSION%3E1%3C%2FSIGNATUREVERSION%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%201587541348989.log%3C%2FP%3E%3CP%3E!SESSION%202020-04-22%2015%3A42%3A28.833%20-----------------------------------------------%3CBR%20%2F%3Eeclipse.buildId%3D4.4.2.M20150204-1700%3CBR%20%2F%3Ejava.version%3D1.8.0_51%3CBR%20%2F%3Ejava.vendor%3DOracle%20Corporation%3CBR%20%2F%3EBootLoader%20constants%3A%20OS%3Dwin32%2C%20ARCH%3Dx86%2C%20WS%3Dwin32%2C%20NL%3Dzh_CN%3CBR%20%2F%3EFramework%20arguments%3A%20-product%20com.freescale.s32ds.e200.ide%3CBR%20%2F%3ECommand-line%20arguments%3A%20-os%20win32%20-ws%20win32%20-arch%20x86%20-product%20com.freescale.s32ds.e200.ide%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.......%3C%2FP%3E%3CP%3E.......%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E!ENTRY%20org.eclipse.osgi%204%200%202020-04-22%2015%3A42%3A38.661%3CBR%20%2F%3E!MESSAGE%20Application%20error%3CBR%20%2F%3E!STACK%201%3CBR%20%2F%3Ejava.lang.RuntimeException%3A%20Application%20%22org.eclipse.ui.ide.workbench%22%20could%20not%20be%20found%20in%20the%20registry.%20The%20applications%20available%20are%3A%20org.eclipse.ant.core.antRunner%2C%20org.eclipse.cdt.codan.core.application%2C%20org.eclipse.cdt.core.GeneratePDOM%2C%20org.eclipse.equinox.app.error%2C%20org.eclipse.equinox.p2.director%2C%20org.eclipse.equinox.p2.garbagecollector.application%2C%20org.eclipse.equinox.p2.publisher.InstallPublisher%2C%20org.eclipse.equinox.p2.publisher.EclipseGenerator%2C%20org.eclipse.equinox.p2.publisher.ProductPublisher%2C%20org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher%2C%20org.eclipse.equinox.p2.reconciler.application%2C%20org.eclipse.equinox.p2.repository.repo2runnable%2C%20org.eclipse.equinox.p2.repository.metadataverifier%2C%20org.eclipse.equinox.p2.artifact.repository.mirrorApplication%2C%20org.eclipse.equinox.p2.metadata.repository.mirrorApplication%2C%20org.eclipse.equinox.p2.updatesite.UpdateSitePublisher%2C%20org.eclipse.equinox.p2.publisher.UpdateSitePublisher%2C%20org.eclipse.equinox.p2.publisher.CategoryPublisher%2C%20org.eclipse.help.base.infocenterApplication%2C%20org.eclipse.help.base.helpApplication%2C%20org.eclipse.help.base.indexTool%2C%20org.eclipse.jdt.core.JavaCodeFormatter%2C%20org.eclipse.jdt.core.JavaIndexer.%3CBR%20%2F%3Eat%20org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java%3A248)%3CBR%20%2F%3Eat%20org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java%3A29)%3CBR%20%2F%3Eat%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java%3A134)%3CBR%20%2F%3Eat%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java%3A104)%3CBR%20%2F%3Eat%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A380)%3CBR%20%2F%3Eat%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A235)%3CBR%20%2F%3Eat%20sun.reflect.NativeMethodAccessorImpl.invoke0(Native%20Method)%3CBR%20%2F%3Eat%20sun.reflect.NativeMethodAccessorImpl.invoke(Unknown%20Source)%3CBR%20%2F%3Eat%20sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown%20Source)%3CBR%20%2F%3Eat%20java.lang.reflect.Method.invoke(Unknown%20Source)%3CBR%20%2F%3Eat%20org.eclipse.equinox.launcher.Main.invokeFramework(Main.java%3A648)%3CBR%20%2F%3Eat%20org.eclipse.equinox.launcher.Main.basicRun(Main.java%3A603)%3CBR%20%2F%3Eat%20org.eclipse.equinox.launcher.Main.run(Main.java%3A1465)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%3CSPAN%3E%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%3CSPAN%3E%3C%2FSPAN%3E%E5%AE%89%E8%A3%85%E6%96%B9%E6%B3%95%E4%B8%8B%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20yours%20Jakie.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%AA%E6%96%B9%E6%B3%95%E9%9D%9E%E5%B8%B8%E9%9D%9E%E5%B8%B8%E5%A5%BD%EF%BC%8C%E5%AE%8C%E7%BE%8E%E8%A7%A3%E5%86%B3%E4%BA%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%84%9F%E8%B0%A2%E4%BD%9C%E8%80%85%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%AF%B9%E6%88%91%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E6%88%91%E5%9C%A8%20Windows%2010%20%E5%92%8C%20Ubuntu%20Linux%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%E9%83%BD%E8%AF%95%E4%BA%86%E3%80%82%E6%97%A0%E8%AE%BA%E6%98%AF%E5%9C%A8%E7%BA%BF%E6%BF%80%E6%B4%BB%E8%BF%98%E6%98%AF%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%EF%BC%8C%E6%88%91%E9%83%BD%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%E4%B9%8B%E5%89%8D%E4%B8%80%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E7%94%A8%E4%BA%86%20NXP%20%E5%B7%A5%E4%BD%9C%E4%BA%BA%E5%91%98%E7%BB%99%E6%88%91%E7%9A%84%E5%A5%BD%E5%87%A0%E4%B8%AA%E6%BF%80%E6%B4%BB%E7%A0%81%E6%9D%A5%E8%AF%95%EF%BC%8C%E4%BD%86%E9%83%BD%E4%B8%8D%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%BB%88%E4%BA%8E%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9A%84%20ID%20%E4%B8%8D%E5%8F%AF%E7%94%A8%E4%BA%86%EF%BC%8C%E6%88%91%E7%94%A8%20ID%EF%BC%9A%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23eeeeee%3B%20font-size%3A%2012px%3B%22%3E1C699-XXXX-XXXX-E800%20%E8%BF%90%E8%A1%8C%E4%BA%86%20licfix%EF%BC%8C%E5%AE%8C%E6%88%90%E8%BF%99%E4%B8%AA%E6%B5%81%E7%A8%8B%E5%90%8E%EF%BC%8C%E5%AE%89%E8%A3%85%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20%E7%A6%BB%E7%BA%BF%E6%BF%80%E6%B4%BB%E9%97%AE%E9%A2%98%E7%9A%84%E7%B4%A7%E6%80%A5%E4%BF%AE%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%96%AF%E5%9D%A6%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%95%88%E6%9E%9C%E3%80%82%E4%BC%BC%E4%B9%8E%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%97%A0%E6%B3%95%E8%A2%AB%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E8%BE%93%E5%85%A5%E6%BF%80%E6%B4%BB%E7%A0%81%EF%BC%8C%E5%8D%B4%E6%94%B6%E5%88%B0%E4%BA%86%20%E2%80%9C%E6%AD%A4%E6%BF%80%E6%B4%BB%20ID%20%E5%B7%B2%E5%9C%A8%E6%AD%A4%E5%B7%A5%E4%BD%9C%E7%AB%99%E4%B8%8A%E4%BD%BF%E7%94%A8%E2%80%9D%20%E7%9A%84%E6%8F%90%E7%A4%BA%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EMichael%20Von%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:42 AM
更新人:
