HOWTO: Create An ISP Project From Existing VSDK Graph in S32DS for Vision
There are a number of existing ISP Graph diagrams provided within the VSDK. It is possible to import them into S32DS for Vision and use them in a new C/C++ project. The steps to do this are detailed in this document.
1) Launch S32DS for Vision
2) Select File -> New -> S32DS Application Project or select "S32DS Application Project" from the toolbar.
3) Enter a project name, such as: ISP_ISP_Generic_demo
4) Select 'A53 APEX/ISP Linux'
5) Click Next
6) Unselect the APEX2 options and 'ISP Visual Modeling' option.
7) Click Finish
8) Select File -> New -> S32DS Project from Example or select "S32DS Project from Example" from the toolbar.
9) Select isp_generic.
10) Select Finish
11) Open isp_generic in the project explorer
12) Double-click ISP data flow ; isp_generic. The ISP data flow graph will appear in the editor
13) Define a new configuration for emitting code from the graph
      a) Create a folder in the application project to receive the emitted code. Right-click on the application project and select New -> Folder.
      b) Enter a name for the folder and click Finish
      c) Right-click in the ISP data flow window and select Emit As -> Emit Configurations...
      d) Select ISP Emitter
      e) Select New Launch Configuration
      f) Enter a name
      g) Select the graph, Browse Workspace
      h) Expand each item until you can select the .isp file. Click OK
      i) Select the location of the emitted output to the application project, select Browse Workspace
      j) Select the name of your application project, then OK
      k) Write A53_gen to the Dynamic sequences sources folder box. This is the folder within the target project that generated code will be stored. Check the box for Emit host code.
      l)Now select the location to store the configuration file. Go to the Common tab, select Shared file and click Browse
      m) Select the folder name you created earlier inside ISP_ISP_Generic_demo and click OK
      n) Click Apply and Emit. Dialog box will appear when code generation is successful
      o) Expand the folders within ISP_ISP_Generic_demo, A53_gen, src and inc, to see the newly generated output files
14) Change to C/C++ perspective, click on ‘C/C++ Development’
15) Build the project 'ISP_ISP_Generic_demo' for ISP
16) Open file 'ISP_ISP_Generic_demo/A53_inc/isp_user_define.h' and change '#define __DCU_BPP' to "#undef __DCU_BPP"
17) Using the method detailed in steps 8 - 10, create the example project 'isp_sonyimx224_csi_dcu'. Take from this project the file 'isp_sonyimx224_csi_dcu/A53_src/main.cpp' and use it to replace the file 'ISP_ISP_Generic_demo/A53_src/main.cpp' in the current project. Then make the following modifications:
On line 40, change <#include "mipi_simple_c.h"> to <#include "isp_generic_c.h">.
On line 303, change <gpGraph_mipi_simple> to <gpGraph> AND <gGraphMetadata_mipi_simple> to <gGraphMetadata>
On line 330, change <FDMA_IX_FastDMA_Out_MIPI_SIMPLE> to <FDMA_IX_ISP_OUTPUT>.
Please see C:\NXP\S32DS_Vision_v2.0\S32DS\s32v234_sdk\docs\drivers\SDI_Software_User_Guide.pdf for details on what this code is for.
18) In Project Explorer, right-click on "...\A53_gen\src\isp_process.cpp" and select Build path -> Remove from -> A53
19) Select 'ISP_ISP_Generic_demo:A53' in the Project Explorer panel, then Build for A53
20) Run it remotely on the target using the method fromHOWTO: Create A53 Linux Project in S32DS for Vision. Should get results similar to this:
评论
Hi Expert,
I followed this Document to setup the ISP_Generic Demo on S32V234-EVB2.
However, when I run the ISP_ISP_Generic_demo.elf by command line or remote debug, I can't see the result on S32V234-EVB2's display panel.
I found the main function in this demo does not call any codes / functions I add in Step 24.
Is that right?
Anything I did wrong?
How can I show the camera input on the display panel?
H/W Architecture:
S32V234-EVB2 + Display panel + Sony224 Camera (should be same as NXP demo)
S/W:
1. S32V BSP 15.0
2. S32 Design Studio Vision 2.0
Wayne Kuo
Hello Wayne,
Thank you for identifying this issue. It seems this document was not fully in sync with the latest release of the S32DS for Vision. I have updated it to correct the steps which were wrong and now it should be possible to complete the exercise and see the output on the screen.
Please follow up once you have tried it so we can know if you were successful.
Mike
Hi Expert,
I followed this Document to setup the ISP_Generic Demo on S32V234-EVB28899.
However,when I Select 'ISP_ISP_Generic_demo:A53' in the Project Explorer panel, then Build for A53,the errors showed  as below:pastedImage_1.png
and my VSDK version is RTM-1.1.1. Can you tell me how to get the missing libs such as "seqencer.a"?
S/W:
1. S32V Vision SDK  RTM-1.1.1
Weikang Zhang
%3CLINGO-SUB%20id%3D%22lingo-sub-1112306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BB%8E%20S32DS%20%E4%B8%AD%E7%8E%B0%E6%9C%89%E7%9A%84%20VSDK%20%E5%9B%BE%E5%BD%A2%E5%88%9B%E5%BB%BA%20ISP%20%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EVSDK%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E4%BA%86%E8%AE%B8%E5%A4%9A%E7%8E%B0%E6%9C%89%E7%9A%84%20ISP%20Graph%20%E5%9B%BE%E8%A1%A8%E3%80%82%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AE%83%E4%BB%AC%E5%AF%BC%E5%85%A5%20S32DS%20for%20Vision%20%E5%B9%B6%E5%9C%A8%E6%96%B0%E7%9A%84%20C%2FC%2B%2B%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%E3%80%82%E6%9C%AC%E6%96%87%E6%A1%A3%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E4%BA%86%E6%89%A7%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%EF%BC%89%E5%90%AF%E5%8A%A8S32DS%20for%20Vision%3C%2FP%3E%3CP%3E2%EF%BC%89%E9%80%89%E6%8B%A9%E6%96%87%E4%BB%B6-%26gt%3B%E6%96%B0%E5%BB%BA-%26gt%3BS32DS%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E6%88%96%E4%BB%8E%E5%B7%A5%E5%85%B7%E6%A0%8F%E4%B8%AD%E9%80%89%E6%8B%A9%E2%80%9CS32DS%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20611px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78754i308BDB28824EF9CE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3%EF%BC%89%E8%BE%93%E5%85%A5%E9%A1%B9%E7%9B%AE%E5%90%8D%E7%A7%B0%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9AISP_ISP_Generic_demo%3C%2FP%3E%3CP%3E4%EF%BC%89%E9%80%89%E6%8B%A9%E2%80%9CA53%20APEX%2FISP%20Linux%E2%80%9D%3C%2FP%3E%3CP%3E5%EF%BC%89%E7%82%B9%E5%87%BB%3CSTRONG%3E%E4%B8%8B%E4%B8%80%E6%AD%A5%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20861px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74591i95BD4090267FE388%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6%EF%BC%89%E5%8F%96%E6%B6%88%E9%80%89%E6%8B%A9APEX2%E9%80%89%E9%A1%B9%E5%92%8C%E2%80%98ISP%20Visual%20Modeling%E2%80%99%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E7%EF%BC%89%E7%82%B9%E5%87%BB%3CSTRONG%3E%E2%80%9C%E5%AE%8C%E6%88%90%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20861px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74631iDE924F3078928D78%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E8%EF%BC%89%E9%80%89%E6%8B%A9%E6%96%87%E4%BB%B6-%26gt%3B%E6%96%B0%E5%BB%BA-%26gt%3B%E6%9D%A5%E8%87%AA%E7%A4%BA%E4%BE%8B%E7%9A%84S32DS%E9%A1%B9%E7%9B%AE%E6%88%96%E4%BB%8E%E5%B7%A5%E5%85%B7%E6%A0%8F%E4%B8%AD%E9%80%89%E6%8B%A9%E2%80%9C%E6%9D%A5%E8%87%AA%E7%A4%BA%E4%BE%8B%E7%9A%84S32DS%E9%A1%B9%E7%9B%AE%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20621px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74719i40B7AD78F3B2A7B7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74764i9680F446A29EA8A3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E9%EF%BC%89%E9%80%89%E6%8B%A9%3CSTRONG%3Eisp_generic%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3CP%3E10%EF%BC%89%E9%80%89%E6%8B%A9%3CSTRONG%3E%E5%AE%8C%E6%88%90%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20802px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74805iEC0680F4393E3D60%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E11%EF%BC%89%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E6%89%93%E5%BC%80%3CSTRONG%3Eisp_generic%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E12%EF%BC%89%E5%8F%8C%E5%87%BB%3CSTRONG%3EISP%E6%95%B0%E6%8D%AE%E6%B5%81%EF%BC%9Bisp_generic%3C%2FSTRONG%3E%20%E3%80%82ISP%20%E6%95%B0%E6%8D%AE%E6%B5%81%E5%9B%BE%E5%B0%86%E5%87%BA%E7%8E%B0%E5%9C%A8%E7%BC%96%E8%BE%91%E5%99%A8%E4%B8%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78752i472C817DB85F92A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E13%EF%BC%89%E5%AE%9A%E4%B9%89%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%94%A8%E4%BA%8E%E4%BB%8E%E5%9B%BE%E4%B8%AD%E5%8F%91%E5%87%BA%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CP%3Ea)%20%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%E6%9D%A5%E6%8E%A5%E6%94%B6%E5%8F%91%E5%87%BA%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%3CSTRONG%3E%E6%96%B0%E5%BB%BA-%26gt%3B%E6%96%87%E4%BB%B6%E5%A4%B9%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%20style%3D%22width%3A%20812px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74985iF1125857AD20449C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_32.png%22%20alt%3D%22pastedImage_32.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eb)%20%E8%BE%93%E5%85%A5%E6%96%87%E4%BB%B6%E5%A4%B9%E7%9A%84%E5%90%8D%E7%A7%B0%E5%B9%B6%E5%8D%95%E5%87%BB%3CSTRONG%3E%E2%80%9C%E5%AE%8C%E6%88%90%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_36.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_36.png%22%20style%3D%22width%3A%20511px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75025iF657C70D65A1095B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_36.png%22%20alt%3D%22pastedImage_36.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec)%20%E5%9C%A8%20ISP%20%E6%95%B0%E6%8D%AE%E6%B5%81%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%E9%BC%A0%E6%A0%87%E5%8F%B3%E9%94%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E9%80%89%E6%8B%A9%3CSTRONG%3EEmit%20As%20-%26gt%3B%20Emit%20Configurations...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20865px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74895i441BAECA499A1F65%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ed)%20%E9%80%89%E6%8B%A9%3CSTRONG%3EISP%20%E5%8F%91%E5%B0%84%E5%99%A8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ee%EF%BC%89%E9%80%89%E6%8B%A9%3CSTRONG%3E%E6%96%B0%E7%9A%84%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74580iBB061E6F01155D5C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSTRONG%3E%20%3C%2FSTRONG%3Ef)%20%E8%BE%93%E5%85%A5%E5%90%8D%E7%A7%B0%3C%2FP%3E%3CP%3Eg)%20%E9%80%89%E6%8B%A9%E5%9B%BE%E8%A1%A8%EF%BC%8C%3CSTRONG%3E%E6%B5%8F%E8%A7%88%E5%B7%A5%E4%BD%9C%E5%8C%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74714i5740952F71CF9F62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eh%3C%2FSTRONG%3E%20%EF%BC%89%E5%B1%95%E5%BC%80%E6%AF%8F%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9.isp%E6%96%87%E4%BB%B6%E3%80%82%E5%8D%95%E5%87%BB%3CSTRONG%3E%E2%80%9C%E7%A1%AE%E5%AE%9A%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%20style%3D%22width%3A%20405px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74745i0042D992D609147B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_24.png%22%20alt%3D%22pastedImage_24.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei%EF%BC%89%E9%80%89%E6%8B%A9%E8%BE%93%E5%87%BA%E5%88%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%8C%E9%80%89%E6%8B%A9%3CSTRONG%3E%E6%B5%8F%E8%A7%88%E5%B7%A5%E4%BD%9C%E5%8C%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_26.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_26.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74791iBDBA06A2101A3E7E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_26.png%22%20alt%3D%22pastedImage_26.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ej)%20%E9%80%89%E6%8B%A9%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%8C%E7%84%B6%E5%90%8E%3CSTRONG%3E%E7%A1%AE%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_28.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_28.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74833i478482110C6E30B1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_28.png%22%20alt%3D%22pastedImage_28.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ek)%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%B0%86%3CSTRONG%3EA53_gen%3C%2FSTRONG%3E%E5%86%99%E5%85%A5%3CSTRONG%3E%E5%8A%A8%E6%80%81%E5%BA%8F%E5%88%97%E6%BA%90%E6%96%87%E4%BB%B6%E5%A4%B9%3C%2FSTRONG%3E%E6%A1%86%E3%80%82%E8%BF%99%E6%98%AF%E7%9B%AE%E6%A0%87%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%94%A8%E4%BA%8E%E5%AD%98%E5%82%A8%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E5%8B%BE%E9%80%89%3CSTRONG%3E%E2%80%9C%E5%8F%91%E5%87%BA%E4%B8%BB%E6%9C%BA%E4%BB%A3%E7%A0%81%E2%80%9D%E5%A4%8D%E9%80%89%E6%A1%86%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74894i8F9EEEC8C9A795E1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_29.png%22%20alt%3D%22pastedImage_29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3El)%E7%8E%B0%E5%9C%A8%E9%80%89%E6%8B%A9%E5%AD%98%E5%82%A8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BD%AC%E5%88%B0%3CSTRONG%3E%E2%80%9C%E5%B8%B8%E7%94%A8%E2%80%9D%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E5%8D%A1%EF%BC%8C%E9%80%89%E6%8B%A9%3CSTRONG%3E%E2%80%9C%E5%85%B1%E4%BA%AB%E6%96%87%E4%BB%B6%E2%80%9D%3C%2FSTRONG%3E%20%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%3CSTRONG%3E%E2%80%9C%E6%B5%8F%E8%A7%88%E2%80%9D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_31.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_31.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74942iCE54582C403F5911%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_31.png%22%20alt%3D%22pastedImage_31.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3Em)%20%E9%80%89%E6%8B%A9%E6%82%A8%E4%B9%8B%E5%89%8D%E5%9C%A8%3CSTRONG%3EISP_ISP_Generic_demo%3C%2FSTRONG%3E%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8D%E7%A7%B0%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%3CSTRONG%3E%E2%80%9C%E7%A1%AE%E5%AE%9A%E2%80%9D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75049i31F08DD5E8FC6C01%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_45.png%22%20alt%3D%22pastedImage_45.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3En)%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E7%82%B9%E5%87%BB%3CSTRONG%3EApply%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EEmit%3C%2FSTRONG%3E%20%E3%80%82%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E6%88%90%E5%8A%9F%E5%90%8E%EF%BC%8C%E5%B0%86%E5%87%BA%E7%8E%B0%E5%AF%B9%E8%AF%9D%E6%A1%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_46.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_46.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74984i6F8FA2FFF62EAC16%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_46.png%22%20alt%3D%22pastedImage_46.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%20style%3D%22width%3A%20518px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74983i14B730484BE1A611%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_47.png%22%20alt%3D%22pastedImage_47.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eo)%20%E5%B1%95%E5%BC%80%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSTRONG%3EISP_ISP_Generic_demo%3C%2FSTRONG%3E%20%E3%80%81A53_gen%E3%80%81src%20%E5%92%8C%20inc%20%E5%86%85%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E6%9F%A5%E7%9C%8B%E6%96%B0%E7%94%9F%E6%88%90%E7%9A%84%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_49.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_49.png%22%20style%3D%22width%3A%20410px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74892i3F6151BE1CC76ED2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_49.png%22%20alt%3D%22pastedImage_49.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E14%EF%BC%89%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0%20C%2FC%2B%2B%20%E8%A7%86%E8%A7%92%EF%BC%8C%E7%82%B9%E5%87%BB%E2%80%9CC%2FC%2B%2B%20%E5%BC%80%E5%8F%91%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_50.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_50.png%22%20style%3D%22width%3A%20677px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75098iE7B819B06ED0CAD5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_50.png%22%20alt%3D%22pastedImage_50.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E15)%20%E4%B8%BA%20ISP%20%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E2%80%9CISP_ISP_Generic_demo%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%20style%3D%22width%3A%20347px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74632iF51017A7084D6003%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_22.png%22%20alt%3D%22pastedImage_22.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E16)%E6%89%93%E5%BC%80%E6%96%87%E4%BB%B6%E2%80%9CISP_ISP_Generic_demo%2FA53_inc%2Fisp_user_define.h%E2%80%9D%E5%B9%B6%E5%B0%86%E2%80%9C%23define%20__DCU_BPP%E2%80%9D%E6%9B%B4%E6%94%B9%E4%B8%BA%E2%80%9C%23undef%20__DCU_BPP%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_54.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_54.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75164i3A5762F8710DEDE4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_54.png%22%20alt%3D%22pastedImage_54.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E17%EF%BC%89%E4%BD%BF%E7%94%A8%E6%AD%A5%E9%AA%A48-10%E4%B8%AD%E8%AF%A6%E8%BF%B0%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E5%88%9B%E5%BB%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E2%80%9Cisp_sonyimx224_csi_dcu%E2%80%9D%E3%80%82%E4%BB%8E%E8%AF%A5%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%8F%96%E5%87%BA%E6%96%87%E4%BB%B6%E2%80%9Cisp_sonyimx224_csi_dcu%2FA53_src%2Fmain.cpp%E2%80%9D%E5%B9%B6%E7%94%A8%E5%AE%83%E6%9B%BF%E6%8D%A2%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E2%80%9CISP_ISP_Generic_demo%2FA53_src%2Fmain.cpp%E2%80%9D%E3%80%82%E7%84%B6%E5%90%8E%E5%81%9A%E5%A6%82%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%AC%AC%2040%20%E8%A1%8C%EF%BC%8C%E5%B0%86%20%26lt%3B%23include%20%22mipi_simple_c.h%22%26gt%3B%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%26lt%3B%23include%20%22isp_generic_c.h%22%26gt%3B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_55.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_55.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75203iD8BCFDCFE964D339%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_55.png%22%20alt%3D%22pastedImage_55.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%AC%AC%20303%20%E8%A1%8C%EF%BC%8C%E5%B0%86%20%3CGPGRAPH_MIPI_SIMPLE%3E%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CGPGRAPH%3E%EF%BC%8C%E5%B9%B6%E5%B0%86%20%3CGGRAPHMETADATA_MIPI_SIMPLE%3E%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CGGRAPHMETADATA%3E%3C%2FGGRAPHMETADATA%3E%3C%2FGGRAPHMETADATA_MIPI_SIMPLE%3E%3C%2FGPGRAPH%3E%3C%2FGPGRAPH_MIPI_SIMPLE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_56.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_56.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75202i50AB9EAE894C65AB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_56.png%22%20alt%3D%22pastedImage_56.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%AC%AC%20330%20%E8%A1%8C%EF%BC%8C%E5%B0%86%20%3CFDMA_IX_FASTDMA_OUT_MIPI_SIMPLE%3E%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CFDMA_IX_ISP_OUTPUT%3E%E3%80%82%3C%2FFDMA_IX_ISP_OUTPUT%3E%3C%2FFDMA_IX_FASTDMA_OUT_MIPI_SIMPLE%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_57.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_57.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75240i520CA9C978F7F034%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_57.png%22%20alt%3D%22pastedImage_57.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%E6%9C%89%E5%85%B3%E6%AD%A4%E4%BB%A3%E7%A0%81%E7%94%A8%E9%80%94%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20C%3A%5CNXP%5CS32DS_Vision_v2.0%5CS32DS%5Cs32v234_sdk%5Cdocs%5Cdrivers%5CSDI_Software_User_Guide.pdf%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E18)%20%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%EF%BC%8C%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E2%80%9C...%5CA53_gen%5Csrc%5Cisp_process.cpp%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E9%80%89%E6%8B%A9%3CSTRONG%3E%E2%80%9C%E6%9E%84%E5%BB%BA%E8%B7%AF%E5%BE%84%E2%80%9D-%26gt%3B%E2%80%9C%E4%BB%8E%E4%B8%AD%E5%88%A0%E9%99%A4%E2%80%9D-%26gt%3B%E2%80%9CA53%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_59.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_59.png%22%20style%3D%22width%3A%20766px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74537i201BF126D10845B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_59.png%22%20alt%3D%22pastedImage_59.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%203.2pt%202.3pt%20.45pt%3B%22%3E%3C%2FP%3E%3CP%3E19%EF%BC%89%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%9C%A8%20Project%20Explorer%20%E9%9D%A2%E6%9D%BF%E4%B8%AD%E9%80%89%E6%8B%A9%E2%80%9CISP_ISP_Generic_demo%3AA53%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E4%B8%BA%3CSTRONG%3EA53%3C%2FSTRONG%3E%E6%9E%84%E5%BB%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_61.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_61.png%22%20style%3D%22width%3A%20306px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74589i44999352D283FD3B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_61.png%22%20alt%3D%22pastedImage_61.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E20%EF%BC%89%E4%BD%BF%E7%94%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335006%22%20target%3D%22_blank%22%3EHOWTO%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%BF%9C%E7%A8%8B%E8%BF%90%E8%A1%8C%E5%AE%83%EF%BC%9A%E5%9C%A8S32DS%E4%B8%AD%E4%B8%BAVision%E5%88%9B%E5%BB%BAA53%20Linux%E9%A1%B9%E7%9B%AE%3C%2FA%3E%E3%80%82%E5%BA%94%E8%AF%A5%E5%BE%97%E5%88%B0%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F33375iFFF3C3CD961C1F06%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_29.png%22%20alt%3D%22pastedImage_29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BB%8ES32DS%E4%B8%AD%E7%8E%B0%E6%9C%89%E7%9A%84VSDK%E5%9B%BE%E5%BD%A2%E4%B8%BAVision%E5%88%9B%E5%BB%BAISP%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B8%93%E5%AE%B6%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%88%91%E6%8C%89%E7%85%A7%E6%9C%AC%E6%96%87%E6%A1%A3%E5%9C%A8%20S32V234-EVB28899%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E4%BA%86%20ISP_Generic%20%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%E5%9C%A8%20Project%20Explorer%20%E9%9D%A2%E6%9D%BF%E4%B8%AD%E9%80%89%E6%8B%A9%E2%80%9CISP_ISP_Generic_demo%3AA53%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E4%B8%BA%20A53%20%E6%9E%84%E5%BB%BA%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F62968i3CCA04C28D83C39A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%E6%88%91%E7%9A%84VSDK%E7%89%88%E6%9C%AC%E6%98%AFRTM-1.1.1%E3%80%82%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%E7%BC%BA%E5%B0%91%E7%9A%84%E5%BA%93%EF%BC%8C%E4%BE%8B%E5%A6%82%E2%80%9Cseqencer.a%E2%80%9D%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%E8%BD%AF%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%201.%20S32V%20Vision%20SDK%20RTM-1.1.1%3CBR%20%2F%3E2.%20S32%20%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%E6%84%BF%E6%99%AF%202.0%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E5%BC%A0%E4%BC%9F%E5%BA%B7%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BB%8ES32DS%E4%B8%AD%E7%8E%B0%E6%9C%89%E7%9A%84VSDK%E5%9B%BE%E5%BD%A2%E4%B8%BAVision%E5%88%9B%E5%BB%BAISP%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E9%9F%A6%E6%81%A9%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%8F%91%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E7%9C%8B%E6%9D%A5%E8%AF%A5%E6%96%87%E6%A1%A3%E4%B8%8E%20S32DS%20for%20Vision%20%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E5%B9%B6%E4%B8%8D%E5%AE%8C%E5%85%A8%E5%90%8C%E6%AD%A5%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%9B%B4%E6%96%B0%EF%BC%8C%E4%BB%A5%E7%BA%A0%E6%AD%A3%E9%94%99%E8%AF%AF%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E5%AE%8C%E6%88%90%E7%BB%83%E4%B9%A0%E5%B9%B6%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E7%9C%8B%E5%88%B0%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%9D%E8%AF%95%E5%90%8E%E8%AF%B7%E8%B7%9F%E8%BF%9B%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E4%BA%86%E8%A7%A3%E6%82%A8%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BB%8ES32DS%E4%B8%AD%E7%8E%B0%E6%9C%89%E7%9A%84VSDK%E5%9B%BE%E5%BD%A2%E4%B8%BAVision%E5%88%9B%E5%BB%BAISP%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B8%93%E5%AE%B6%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E6%9C%AC%E6%96%87%E6%A1%A3%E5%9C%A8%20S32V234-EVB2%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E4%BA%86%20ISP_Generic%20%E6%BC%94%E7%A4%BA%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E9%80%9A%E8%BF%87%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%88%96%E8%BF%9C%E7%A8%8B%E8%B0%83%E8%AF%95%E8%BF%90%E8%A1%8CISP_ISP_Generic_demo.elf%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8S32V234-EVB2%E7%9A%84%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E4%B8%8A%E7%9C%8B%E5%88%B0%E7%BB%93%E6%9E%9C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%8F%91%E7%8E%B0%E6%AD%A4%E6%BC%94%E7%A4%BA%E4%B8%AD%E7%9A%84%E4%B8%BB%E5%87%BD%E6%95%B0%E6%B2%A1%E6%9C%89%E8%B0%83%E7%94%A8%E6%88%91%E5%9C%A8%E6%AD%A5%E9%AA%A4%2024%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%2F%E5%87%BD%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E6%98%AF%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E4%B8%8A%E6%98%BE%E7%A4%BA%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%85%A5%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E6%9E%B6%E6%9E%84%EF%BC%9A%3CBR%20%2F%3E%20S32V234-EVB2%20%2B%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%20%2B%20Sony224%20%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%88%E5%BA%94%E4%B8%8E%20NXP%20%E6%BC%94%E7%A4%BA%E7%9B%B8%E5%90%8C%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%201.S32V%20BSP%2015.0%3CBR%20%2F%3E%202.%20S32%20%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%E6%84%BF%E6%99%AF%202.0%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E9%83%AD%E4%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-19-2017 08:16 AM
更新人:
