FS6510 Can't set IMPACT register
2,776 次查看
Jamber_H
After Power-On, the SBC is in Init mode, I set INIT_VAUX_OVUV_IMPACT register as 0xA, after 200us, I read back it, but the result is 0x0, which is not equal to the value I set. What's the reason?Can't set IMPACT register.pngCan't set IMPACT register.png
2,771 次查看
TomasVaverka
Please try to close the INIT_FS with at least 1 good WD refresh and then read back the INIT_VAUX_OVUV_IMPACT register.
Tomas
2,758 次查看
Jamber_H
HI, could you help me?
2,772 次查看
TomasVaverka
Tomas
2,769 次查看
Jamber_H
Hi, Tomas,
I tried that, I read this register periodly after I set it in INIT phase. In Normal phase, the value is not 0x0, but it's a default value as 0xE.
Jamber
