We are designing a product using the MC33FS4500 series SBC. These SBC's are available in both ASIL-B and ASIL-D level, most notably the ASIL-B variant does not require the LFSR calculation for WD_ANSWER. We require ASIL-D for our application.
The ASIL-B and ASIL-D parts are pin-compatible and I was wondering: if an ASIL-B part was accidentally populated instead of an ASIL-D part, could software reliably detect this? DEVICE_ID_FS and DEVICE_ID seem unusable for this goal. Maybe DEV_REV is usable, but this field is not documented in detail.
Of course, we can refresh the watchdog with an erroneous WD_ANSWER write and see how the error counter responds, but I'd like to have a more robust solution.
Kind regards,
Joey
Solved! Go to Solution.
Hi Joey,
Yes, DEV_REV bits can be used to distinguish between ASIL-B and ASIL-D parts.
Usually, their actual values are mentioned in the ‘Revision History’ subsection of the datasheet, but we missed to implement it in the ASIL-B datasheet.
Tomas
Hi Joey,
Tomas
Hi Tomas,
Thank you. This is exactly what I was looking for.
Kind regards,
Joey
