1106702_en-US
1106702_en-US
1106702_en-US
High-Voltage 3-Phase Motor Control
Description
3-phase high voltage motor control can drive today demanding BLDC, PMSM, and ACIM motor control designs with optimized MCU performance. The Kinetis V MCUs range from 75MHz to 240MHz to give product flexibility and to maximize reuse. Additionally, NXP provides a Kinetis motor software suite to reduce the motor control learning curve and accelerate time to market.
Block Diagram
Block_Diagram-High_Voltage_3-PH_Motorcontrol-Drive-Pump[1].pngBlock_Diagram-High_Voltage_3-PH_Motorcontrol-VacuumCleaner[1].png
Products
Category Name 1:
MCU
Product URL 1
Arm® Cortex®-M0+|Kinetis® KV1x Motor Control MCUs | NXP
Product Description 1
The Kinetis® KV1x MCU delivers a 27% increase in performance in math-intensive applications versus comparable MCUs, allowing it to target BLDC as well as more computationally demanding PMSM motors.
Category Name 2:
AC/DC
Product URL 1
TEA175x | NXP
The high level of integration of the TEA175x allows the design of a cost-effective power supply with a very low number of external components. The special built-in green functions provide high efficiency at all power levels.
Category Name 3:
Temperature Sensor
Product URL 1
LM75B: Digital Temperature Sensor | NXP
The I²C-bus LM75B contains a number of data to store the device settings, it features an 11-bit ADC that offers a temperature resolution of 0.125 °C with a programmable temperature threshold.
Related Documentation
Document URL
Title
https://www.nxp.com/docs/en/application-note/AN10441.pdf
Level shifting techniques in I2C-bus design
https://www.nxp.com/docs/en/application-note/AN10580.pdf
GreenChip TEA1761 synchronous rectification and feedback controller
https://www.nxp.com/docs/en/application-note/AN11013.pdf
DCM Flyback SMPS controller
https://www.nxp.com/docs/en/application-note/AN4986.pdf
Automated PMSM Parameter Identification
https://www.nxp.com/docs/en/application-note/AN4912.pdf
Tuning 3-Phase PMSM Sensorless control application using MCAT Tool
https://www.nxp.com/docs/en/application-note/AN4862.pdf
Three-phase BLDC sensorless control using the MKV10x
https://www.nxp.com/docs/en/application-note/AN4870.pdf
Tuning 3-Phase BLDC motor sensorless control using MKV10
https://www.nxp.com/docs/en/application-note/AN4560.pdf
PWM synchronization using Kinetis Flextimers
https://www.nxp.com/docs/en/application-note/AN4410.pdf
FlexTimer and ADC synchronization for Field-Oriented-Control
Tools
Training URL
https://store.nxp.com/webapp/ecommerce.add_item.framework?PART_NUMBER=TWR-MC-LV3PH&QUANTITY=1&ITEM_T...
Training
Training URL
NXP Complete Motor Control Solutions
Related Demos from Communities
Related Demos URL
Kinetis KV1x MCU with Tower System TWR-KV10Z32 Demo
Kinetis V Series ATV Enabled by Kinetis V & Motor Control Toolbox
Block DiagramsIndustrial
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-19-2025 10:17 AM
更新者:
