When reviewing the code generated for MPC5643L,I can't find the definition of the "e200zX_Interrupt_Setup()" in "intc_init.c".Can you help me find it?
Thanks a lot.Hj
Solved! Go to Solution.
Hi hjhjhj,
Please check excep_handler.s line 173.
The e200zX_Interrupt_Setup() is implemented in assembly.
Best regards,Daniel
Can you please attach the folder with the generated code to have a look ?
Thank you!
Hi Daniel,
Check the attachment ,please.
Hj
