The definition of the "e200zX_Interrupt_Setup()"
2,688 次查看
hjhjhj
  When reviewing the  code generated for MPC5643L,I can't find the definition of the "e200zX_Interrupt_Setup()" in "intc_init.c".Can you help me find it?
Thanks a lot.
Hj
2,476 次查看
Daniel_Popa
Hi hjhjhj‌,
Please check excep_handler.s line 173.
The e200zX_Interrupt_Setup() is implemented in assembly.
2,476 次查看
Daniel_Popa
Hi hjhjhj‌,
Can you please attach the folder with the generated code to have a look ?
Thank you!
2,476 次查看
hjhjhj
Hi Daniel,
   Check the attachment ,please.
Thank you!
Hj
2,477 次查看
Daniel_Popa
Hi hjhjhj‌,
