Pwm_delay_in_trigger_pulse
13,064件の閲覧回数
Vijay98
Hello NXP team,
Currently we are generating the pwm pulse for two channels.
and with pwm channel 1 pulse, we are triggering the pwm channel 2 pulse with edge triggering.
but with triggering, there is some delay in Pwm channel 2 pulse and that delay is not constant it is getting varying from one pulse to another pulse.
Photo - 1: 820uS delay for pwm 2.
Photo - 2: no delay for pwm 2.
Photo - 3: 520uS delay for pwm 2.
we don't know how to reduce this delay, and it is not constant delay.
We have attached the configuration settings for this pwm pulse below,
Emios_0 - Channel_0 for pwm2 pulse
Emios_1 - Channel_0 for pwm1 pulse
Mcl_configuration for Pwm2 pulse
Kindly help us to resolve this issue related to pwm delay.
Thanks, and regards,
Esakki.P
@Irina_Costachescu @dragostoma
@DrKarthi
11,180件の閲覧回数
stefanvlad
Hi @Vijay98 ,
I'm not sure what do you mean having an issue on PTC10, since on this thread  Re: Pwm_delay_in_trigger_pulse - NXP Community, the solution works well and tested on logic analyzer.
Can you provide pictures of the model that you modified based on the steps i provided in the thread above, instead of reposting my screenshots.
Once again to use another pin to output the signal from PTA3 to PTC10 there are only two options, one is presented above by using PTC10 as emios_0_ch6 and the other solution is to use PTC10 as lcu1_out11:
Then you need to route the signal from PTA3 (lcu0_out2) to PTC10 (lcu1_out11) using TRGMUX:
Then we need to update the LCU configuration for the new input:
And then we update the LCU output config:
Also PTC10 pin needs to be added into the Port peripheral:
and the last step is to update the model with the new LCU output:
After this, clean up the local Matlab folder, delete the .slxc file, and the folders 32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw, and slprj:
Then rebuild and flash the project on the S32K312 board, and check the pins with logic analyzer:
And to summarize the complete application, how all the peripherals are connected, I have created this diagram:
This are all the steps needed, please read them carefully and replicate them on your model,
Stefan V.
21 返答(返信)
12,753件の閲覧回数
dragostoma
Hi, @Vijay98,
First of all, for the results obtained and the displayed delay, were the recommendations from this post also taken into account, namely those related to the level of optimization?
Secondly, I would like to mention the fact that I noticed in the provided screenshots the configuration of a master bus in the MCL component, for the eMIOS 1 instance.
On the other hand, in the configuration of the PWM channel I notice that in the same eMIOS 1 instance it is set to use a internal counter, that is, the reference to the previously mentioned master bus is not taken into account, but the calculation is based on an internal counter.
Is this how the application was designed? Because the results of the calculations are totally different regarding the counter used, if it is internal or external. In the case of an external master bus, when calculating the frequency and period of a PWM signal, the period of the master bus, the clock divider and respectively the master bus prescalers are also included. Conversely, these things do not apply to the use of an internal counter.
The last question would be if this model uses the same configuration as in the other similar thread, because in order to fully understand the behavior and configuration of the application, it can't help to share the configuration project, along with the model.
Let us know about your progress.
Dragos
12,729件の閲覧回数
Vijay98
Hello Dragos,
My first point is that
Yes, we are generating the pwm signal using the internal counter for emios1_ch0 and emios0_ch0 in OPWFMB mode. And in mcl configuration we mentioned only clock divider value.
And yes, we are configuring the same configuration for pwm in this post Re: Reg: Raising edge and Falling edge detection issue_S32k344 - NXP Community.
We can be able to check the pwm edge triggering and able to generate pwm2 pulse within the pwm1 pulse on time.
But currently we are facing an issue of Certain delay in pwm2, and that delay is not constant for pwm2 pulse.
We don't know how to reduce this delay or make it as a constant delay.
Kindly help us resolve this issue.
I have attached the model and configuration with this post.
Thanks & regards,
Esakki.P
タグ(1)
12,601件の閲覧回数
stefanvlad
Hi @Vijay98 ,
I have opened the archived model:
And flashed it on the S32K312EVB-Q172 board, then connected Logic analyzer probes and got this signals:
Unfortunately the PTC10 signal seems to be reversed from your "Photo - 2: no delay for pwm 2."
But nevertheless i understood want you want to achieve, an PWM signal with lower Frequency , usually called a PWM_Modulator and a signal with a higher (11x) frequency, called a PWM_Carrier.
there are two approaches to do this:
  1. Software enable/disable of PWM_Carrier on the triggered PWM_Modulator interrupt, this is the implementation that you have tried. The disadvantage is the delay is not constant as you saw, one way to correct this is to check the peripheral priorities in the Interrupt Controller, another way is to implement the FastUpdate function for PWM, we have an example in the model s32k344_mc_bldc_s32ct:
  2. Hardware generation of the PWM_Carrier, to be generated using the eMIOS with TRGMUX and LCU:
    With this configuration i was able to generate the proper PWM signals:
    This approach is a bit more complex, but it will ensure the delay is minimum and controllable.
Please try the FastUpdatePWM implementation in your model, or you can test the attached model in s32k312_pwm_lcu_s32ct.zip:
Let me know if this helps you and have a great weekend,
Stefan V.
12,509件の閲覧回数
Vijay98
Hello, @stefanvlad
1. For the first approach, Fast update function we tried with fast update function in our model and checked but there is a variable delay in pwm 2 pulse. is there any example model available for the previous mentioned requirement.
and i have attached the file "Test_in_new".
2. And for the second approach,
The program which shared was running in opwmb and has counter bus of bcde. And we seen change in periods not happening, its in fixed frequency with variable dutycycle.
Observation with your shared model(S32k312_pwm_icu_S32ct):
1. High side frequency always at 259.63HZ, refer image.
(our requirement: it need to change from 0.1HZ to 150HZ)
2. Low side Frequency always at 2.8Khz refer image
(Our requirement: its need to change from 0.1Hz to 12Khz based on ON time of High side frequency)
we tried changing the mode and counter bus to 'OPWFMB' & 'internal bus' but the PWM-2 pulse is not getting synchronized with PWM1 pulse.
we want to change one pwm (PWM-1) both period and duty cycle for different frequency (OPWFMB) from Application and PWM-2 has to turned on and off based on PWM-1 ON time.
And i have attached the file below as "Nxp_pwm"
Thanks & regards,
Esakki.P
@DrKarthi @Kavin_raj_mbd
12,347件の閲覧回数
stefanvlad
Hi @Vijay98 , @DrKarthi
1. For the first Software enable/disable I have looked in your attached model and saw:
In the model above, i could not find the missing PWM_FastUpdate blocks, as in the model s32k344_mc_bldc_s32ct, take a closer look at the picture below:
There are 4 blocks needed for one PWM channel, and to be run in that specific order:
  1. Pwm_FastUpdateDisableOU
  2. Pwm_FastUpdateSetUCRegA
  3. Pwm_FastUpdateSetUCRegB
  4. Pwm_FastUpdateEnableOU
Also the Channel Mask value is not "0" in the s32k344_mc_bldc_s32ct model, it is defined as MBD_APP_PWM_MASK = uint32(0xE00);
This steps are a proper implementation that can help you achieve better results.
2. For the Hardware generation of the PWM_Carrier, to be generated using the eMIOS with TRGMUX and LCU, i have updated the model and configuration to use OPWFMB:
The PWM_Mod+ PWM_Carrier Period and Duty cycle values can be modified from FreeMASTER while the code is running on the board:
Now the variable frequency and duty cycle can be changed for both channels:
Please find the attached model in s32k312_pwm_lcu_mod_carrier_s32ct.zip
Stefan V.
11,816件の閲覧回数
MN_TL_24
Hello Nxp team,
We are also working in Pwm_trigmux_lcu to generate the pwm pulse in Lcu pins.
And we have checked the model given by nxp team "s32k312_pwm_lcu_mod_carrier_s32ct.zip" and we have also used 'PTA0' as the High side pin
but we need to configure the 'PTC10' pin as the Low side pin, but we can't be able to see the waveform in Ptc 10 pin.
we have attached the photos by steps of which we configured.
Step-1: Pin configuration
Step-2: Pin config in port driver
Step-3: Pwm driver configuration
Step-4: Trigmux configuration for Ptc10 (Lcu1_out11)
Step-5: Lcu_instance configuration
Step-6: Lcu logic input config
Step-7: Lcu logic output configuration
Kindly check this configuration, we think that we have made some small mistake in this.
We want to generate High side pwm pulse in "PTA0" - this is ok
and Low side PWM pulse in "PTC10" - this we tried but the waveform is not able to view.
Kindly help us to resolve this issue.
Thanks & regards,
MN_TL
@stefanvlad
11,470件の閲覧回数
stefanvlad
Hi @MN_TL_24 , @Vijay98
Thank you for reading the post on: Re: Pwm_delay_in_trigger_pulse - NXP Community
The pinout configuration in that thread is for enabling the Logic Cell 0 with it's corresponding pins.
Unfortunately, the pin PTC10 is tied to another Logic Cell 1, Output 11, namely LC1_Out11, as state in the Pin Manager:
What output pin from LCU0 do you want to generate on the PTC10 pin? From my understanding you want to output PWM_Modulator from PTD2 on the PTC10 pin.
We can check what options we have for that PTC10 in Pin Manager, there is an option for emios_0_ch6:
We can use it as this and add another eMIOS channel in PWM driver, EMIOS_0 and CH_6:
Then we add another PWM channel:
Then we need to enable it in Port peripheral:
After this we need to Update Code and save configuration, and modify the Model to update Duty+Period on the new channel:
Save the model and Build , and program the board, we get the new eMIOS PWMC_Modulator on the PTC10 pin:
Hope this solves your questions,
Stefan V.
11,290件の閲覧回数
Vijay98
Hello @stefanvlad
Thank you for your support.
But in fast update method, when we give our period and duty cycle value to generate pwm signal the output signal is much different from what we expected.
For example,
1. I want to generate pwm pulse for frequency - 25 Hz for that period value is 1176 (Core clock - 120MHz, Clock divider value is 255 and internal prescalar value is 16) and Duty cycle is 16784 (50% duty cycle).  with those period and duty cycle value given to fast update block, the output pulse is with different frequency and different duty cycle.
2. And want to generate pwm pulse for frequency - 1000 Hz for that period value is 29(Core clock - 120MHz, Clock divider value is 255 and internal prescalar value is 16) and Duty cycle is 31129(95% duty cycle).  with those period and duty cycle value given to fast update block, the output pulse is with different frequency and different duty cycle.
But the Pins we are using PTA0 & PTC10, in that pins we can be able to see the output waveform with different frequency & different duty cycle.
and we need to configure the 'PTC10' pin as the Low side pin with lcu configuration.
and Low side PWM pulse in "PTC10" - this we tried but the waveform is not able to view without fast update method.
Kindly help us with this configuration.
Thanks & regards,
Vijay
11,061件の閲覧回数
stefanvlad
Hi @Vijay98 ,
Can you repost the images? since they are very low resolution and cannot be read properly.
Regarding the PTC10 output, I have already given the solution and required steps in this post Re: Pwm_delay_in_trigger_pulse - NXP Community
I am able to generate the PWM_Modulator frequency of 1000Hz (1kHz) using the Period = 7270 :
And for Period = 43500 i was able to get PWM_Modulator frequency to 167Hz:
But for even lower frequency you need to modify the PWM configuration for both PWM channels in order to keep that 11x times frequency in between them.
Stefan V.
10,986件の閲覧回数
Vijay98
Hello @stefanvlad
Thanks for the update and we have checked with that configuration.
1. With fast update method that you provided is that we have an issue in generating low side pulse in PTC10 pin. Kindly check the video uploaded with this post.
2. That we have a low side pulse already generated in PTA3 pin and we have to change that output to PTC10 pin (low side pulse).
For that we need help with configuration to generate the low side pulse in PTC10 pin.
Kindly help us with this,
Thanks & regards,
Vijay
11,181件の閲覧回数
stefanvlad
Hi @Vijay98 ,
Stefan V.
10,833件の閲覧回数
Vijay98
Hello @stefanvlad
Thank you for the reply.
it helped us to understand the configuration very much.
11,144件の閲覧回数
Vijay98
Hello nxp ,
Any update on this Lcu pin configuration
Kindly help us on this issue
Thanks & regards,
Vijay
11,501件の閲覧回数
Vijay98
Hello Nxp Team,
Currently we are working in Pwm pulse generation using Lcu & Trigmux with the help of Re: Pwm_delay_in_trigger_pulse - NXP Community this post.
We want to route the "PTA3" pin which pwm is already generated by Lcu configuration to "PTC10" pin by Lcu configuration.
But we are trying to configure the PTC10 pin (LCU1_out11) in LCU configuration and trying to generate pwm pulse. But we are unable to generate pulse in that pin. Here by, we are attached the file and steps that we are configured.
Step-1: Pin configuration for PTC-10 pin.
Step-2: Port configuration for Ptc10 pin.
Step-3: Pwm peripheral configuration for PTC-10
Step-4: Trigmux configuration for Ptc10 - LCU1_out11
Step-5: Lcu configuration- lcu logic instance config
Step-6: Lcu configuration - Lcu input
Step-7: Lcu configuration - Lcu output
Step-8: In model -> initialize system -> configured Mcl output state - 4
Kindly help to check this configuration for routing the Lcu output of 'PTA3' pwm to 'PTC10' pin with LCU configuration.
Thanks & regards,
Vijay
@stefanvlad @dragostoma @Irina_Costachescu @Adrian_Gherca  @DrKarthi @Kavin_raj_mbd
12,268件の閲覧回数
Vijay98
Hello @stefanvlad
We tried the model attached with this post and we can be able to Change the period and duty cycle with this model and able to see the waveform.
Thank you for your support for this method.
But we have a doubt that the modulator wave inside the carrier wave gets keep on updating (running) -> kindly see the video attached with this post.
It is ok for the modulator wave is running like that or can we stop that?
Thanks & regards
Vijay
12,252件の閲覧回数
stefanvlad
Hi @Vijay98
Glad to hear that this works better,
I saw the issue presented in the Video, maybe there is a problem with the Oscilloscope trigger?
In my case the duty cycle is changed only when i change it in FreeMASTER, otherwise it is kept constant, as in the picture below:
Can you check the same pins with a logic analyzer?
Stefan V.
12,168件の閲覧回数
Vijay98
Hello @stefanvlad
Thank you for your response
We have checked the waveform,
and right now we need to change only the LCU pins for our hardware for that,
1. In MCL component -> LCU configuration what are the configuration need to be changed?  (for pin change)
For ex: I need to change the pin from PTA3 to PTA0 and i configured pins in pin configuration & in peripherals port has been configured and then in Lcu how to configure that pin?
2. which logic analyzer is used to measure the pwm signal from your side?
Thanks & regards,
Esakki.P
12,091件の閲覧回数
stefanvlad
Hi @Vijay98 ,
To change the LCU output pins it is not easy(feasible), since all the Inputs/Outputs are tightly related to the existing LCU0 pins:
Instead, we can use TrgMux to re-route the PTA3 output to PTA0, there are multiple steps required:
1. in the MCL Configuration , Trgmux Logic Instance, add input LCU0_LC0_OUT_I2:
2. LCU Configuration, add an Lcu Logic Input, set to LCU_IP_MUX_SEL_LU_IN_2:
3. LCU Logic Output, add another ouput to LC_1, set to LCU_IP_HW_OUTPUT_0 :
4. In the Simulink model, Initialize Function we need to add another MCL_LCU Output:
I have updated the model with PWM_FastUpdate functions, that can be used(applied) also in your original model that used Software Trigger, to improve the update time, in my model this takes around 7us to update 2 PWM channels:
Visualize the results with the logic analyzer(Saleae Logic 8 or others from ebay/Aliexp) using the Logic2 software:
Also i have update the FreeMASTER model, so now it can change both Duty cycles and same Period:
This is all from my side, you can find the updated model in the archive: s32k312_pwm_lcu_mod_carrier_s32ct.zip
Stefan V.
11,983件の閲覧回数
Vijay98
Hello @stefanvlad
Thanks for the update.
we have checked the model and its output pwm pulse in Saleae Logic 8 (logic analyzer)
we can be able to see the pulses and checked that the delay is reduced but we have an issue is that the pulse inside the Carrier (i.e., the modulator pulse in PTD2 & PTA0) is changing like keep on running.
I have attached the video of the pulses that we captured using logic analyzer and its logic analyzer file with this post.
we have tried giving different duty cycle and period for both the pulses, but we are facing that issue (modulator pulse is running).
Thanks & regards,
Vijay
11,724件の閲覧回数
stefanvlad
Hi @Vijay98 ,
This is normal , since the Logic Analyzer software is plotting the captured samples in a increasing time domain on the X axis.
The effect you are seeing in the video , i think it is due to aliasing in between the captured PWM frequency, the Logic software rendering and the display refresh rate.
The only issue i could find is regarding the PWM frequency:
But this is due to PWM generation based on the PLL jitter, there is information about this jitter in the S32K3xx Data Sheet:
Since the PLL clock is generating the CORE_CLK that goes into EMIOS_CLK that generates the PWM signals, according to this diagram:
Hope this answered your questions,
Stefan V.
%3CLINGO-SUB%20id%3D%22lingo-sub-1955433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1955433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%812%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AEpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81PWM%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB1%E3%83%91%E3%83%AB%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A8%E3%83%83%E3%82%B8%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%A7PWM%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB2%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1726550630893.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1726550630893.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299358i4DD3C0F321532759%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1726550630893.jpeg%22%20alt%3D%22Esakki_0-1726550630893.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Pwm%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB2%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AB%E9%81%85%E5%BB%B6%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E4%B8%80%E5%AE%9A%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%811%E3%81%A4%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9%E3%81%8B%E3%82%89%E5%88%A5%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AB%E5%A4%89%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F-1%3Apwm%202%E3%81%AE820uS%E9%81%85%E5%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_4-1726551336086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_4-1726551336086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299363iFC7DEF99CAF2E802%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_4-1726551336086.png%22%20alt%3D%22Esakki_4-1726551336086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F-2%3Apwm%202%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_5-1726551406656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_5-1726551406656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299364i210F73BAC85C3CD4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_5-1726551406656.png%22%20alt%3D%22Esakki_5-1726551406656.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F-3%3Apwm%202%E3%81%AE520uS%E9%81%85%E5%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_6-1726551459604.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_6-1726551459604.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299365i60BA235E4F4B8283%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_6-1726551459604.png%22%20alt%3D%22Esakki_6-1726551459604.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E9%81%85%E5%BB%B6%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%97%E3%80%81%E4%B8%80%E5%AE%9A%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AEpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AE%E6%A7%8B%E6%88%90%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EEmios_0%20-%20PWM2%E3%83%91%E3%83%AB%E3%82%B9%E7%94%A8Channel_0%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_7-1726551591729.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_7-1726551591729.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299367iF9DE6EC3CA19C733%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_7-1726551591729.png%22%20alt%3D%22Esakki_7-1726551591729.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_9-1726551786268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_9-1726551786268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299369iEF3A59B0468B8652%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_9-1726551786268.png%22%20alt%3D%22Esakki_9-1726551786268.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EEmios_1%20-%20Channel_0%20PWM1%E3%83%91%E3%83%AB%E3%82%B9%E7%94%A8%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_8-1726551759125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_8-1726551759125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299368i767C084A1D337CF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_8-1726551759125.png%22%20alt%3D%22Esakki_8-1726551759125.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_10-1726551802652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_10-1726551802652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299370i885BE0BAD6B2C6EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_10-1726551802652.png%22%20alt%3D%22Esakki_10-1726551802652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPwm2%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AEMcl_configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_11-1726551854311.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_11-1726551854311.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299371i0DE1B1B62703EBBE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_11-1726551854311.png%22%20alt%3D%22Esakki_11-1726551854311.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Epwm%E9%81%85%E5%BB%B6%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%40Irina_Costachescu%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2013291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2013291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A7%8B%E6%88%90%E3%82%92%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2012221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2012221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F2003791%2Fhighlight%2Ftrue%23M9822%22%20target%3D%22_blank%22%3ERe%3APwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81PTC10%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E5%86%8D%E6%8A%95%E7%A8%BF%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%80%81%3CSTRONG%3EPTA3%3C%2FSTRONG%3E%E3%81%8B%E3%82%89%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%88%A5%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%8B%E3%81%AA%E3%81%8F%E3%80%811%E3%81%A4%E3%81%AF%3CSTRONG%3Eemios_0_ch6%3C%2FSTRONG%3E%E3%81%A8%E3%81%97%E3%81%A6%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%B8%8A%E8%A8%98%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%E3%82%92%3CSTRONG%3Elcu1_out11%3C%2FSTRONG%3E%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1733937742783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1733937742783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315421iF5E81811ED866B7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1733937742783.png%22%20alt%3D%22stefanvlad_0-1733937742783.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81TRGMUX%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20%3CSTRONG%3EPTA3%20(lcu0_out2)%3C%2FSTRONG%3E%20%E3%81%8B%E3%82%89%20%3CSTRONG%3EPTC10%20%3C%2FSTRONG%3E%3CSTRONG%3E(lcu1_out11)%20%3C%2FSTRONG%3E%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1733937895546.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1733937895546.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315422iF5A2D2E323BCEE82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1733937895546.png%22%20alt%3D%22stefanvlad_1-1733937895546.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%85%A5%E5%8A%9B%E3%81%AELCU%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1733937955577.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1733937955577.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315423i38AA9DEA13321717%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1733937955577.png%22%20alt%3D%22stefanvlad_2-1733937955577.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81LCU%20%E5%87%BA%E5%8A%9B%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1733938011056.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1733938011056.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315424i631F684F6030B030%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1733938011056.png%22%20alt%3D%22stefanvlad_3-1733938011056.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1733938099707.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1733938099707.png%22%20style%3D%22width%3A%20898px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315425i95BF54EA5AB8F412%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1733938099707.png%22%20alt%3D%22stefanvlad_4-1733938099707.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20LCU%20%E5%87%BA%E5%8A%9B%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1733938321744.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1733938321744.png%22%20style%3D%22width%3A%20929px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315426i431C5AFF7CF27EB2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1733938321744.png%22%20alt%3D%22stefanvlad_5-1733938321744.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%AEMatlab%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%80%81%3CSTRONG%3E.slxc%3C%2FSTRONG%3E%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%3CSTRONG%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%20(32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw)%E3%80%81%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%20slprj%3C%2FSTRONG%3E%20%3CSPAN%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1733939601313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1733939601313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315429iAB36FFB7BD28FD79%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1733939601313.png%22%20alt%3D%22stefanvlad_6-1733939601313.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81S32K312%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E3%83%94%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1733939679624.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1733939679624.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315430iDA7A3769CF6E6ECD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1733939679624.png%22%20alt%3D%22stefanvlad_7-1733939679624.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E8%A6%81%E7%B4%84%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20style%3D%22width%3A%20931px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315623i49FFE3875E0D6DD3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E6%B3%A8%E6%84%8F%E6%B7%B1%E3%81%8F%E8%AA%AD%E3%82%93%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%9D%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1.%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E9%AB%98%E9%80%9F%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%20%3CSTRONG%3E%E3%80%81PTC10%E3%83%94%E3%83%B3%E3%81%A7%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1733827424686.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1733827424686.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315062i835256416F9BF2F8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1733827424686.png%22%20alt%3D%22Vijay98_2-1733827424686.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%3CSTRONG%3EPTA3%E3%83%94%E3%83%B3%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%E3%83%91%E3%83%AB%E3%82%B9%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92PTC10%E3%83%94%E3%83%B3(%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%E3%83%91%E3%83%AB%E3%82%B9)%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1733827048319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1733827048319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315060iD3DC3B3550DF2F5B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1733827048319.png%22%20alt%3D%22Vijay98_1-1733827048319.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81PTC10%20%E3%83%94%E3%83%B3%E3%81%A7%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%20%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%AA%E5%88%87%E3%81%AB%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%94%BB%E5%83%8F%E3%82%92%E5%86%8D%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BD%8E%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E9%81%A9%E5%88%87%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPTC10%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E3%81%99%E3%81%A7%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F2003791%2Fhighlight%2Ftrue%23M9822%22%20target%3D%22_blank%22%3EPwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E5%91%A8%E6%9C%9F%3C%2FSTRONG%3E%3D%20%3CSTRONG%3E7270%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%811000Hz(1kHz)%E3%81%AE%3CSTRONG%3EPWM_Modulator%3C%2FSTRONG%3E%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1733763433340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1733763433340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314885i966A46AF12696787%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1733763433340.png%22%20alt%3D%22stefanvlad_0-1733763433340.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%20%3CSTRONG%3E%E3%80%81Period%3C%2FSTRONG%3E%20%3D%20%3CSTRONG%3E43500%3C%2FSTRONG%3E%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3CSTRONG%3EPWM_Modulator%3C%2FSTRONG%3E%20%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92167Hz%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1733763983268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1733763983268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314887iCB7EA1F0A6629A71%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1733763983268.png%22%20alt%3D%22stefanvlad_1-1733763983268.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E4%BD%8E%E3%81%84%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AEPWM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AEPWM%E6%A7%8B%E6%88%90%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E9%96%93%E3%81%AB%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE11%E5%80%8D%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2009083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2009083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20nxp%20%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%20Lcu%20%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%9B%B4%E6%96%B0%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E9%AB%98%E9%80%9F%E6%9B%B4%E6%96%B0%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%E3%80%81pwm%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%91%A8%E6%9C%9F%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E5%80%A4%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%87%BA%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AF%E4%BA%88%E6%83%B3%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%3C%2FP%3E%3CP%3E1.%E5%91%A8%E6%B3%A2%E6%95%B0%20-%20%3CSTRONG%3E25%20Hz%20%3C%2FSTRONG%3E%E3%81%AE%20pwm%20%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3CSTRONG%3E%E3%81%9D%E3%81%AE%E5%91%A8%E6%9C%9F%E3%81%AE%E5%80%A4%E3%81%AF%201176%20(%E3%82%B3%E3%82%A2%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20-%20120MHz%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8%E5%99%A8%E3%81%AE%E5%80%A4%E3%81%AF%20255%E3%80%81%E5%86%85%E9%83%A8%E3%83%97%E3%83%AA%E3%82%B9%E3%82%AB%E3%83%A9%E5%80%A4%E3%81%AF%2016)%20%3C%2FSTRONG%3E%E3%81%A7%E3%80%81%20%3CSTRONG%3E%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AF%2016784%20(50%25%20%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB)%20%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%26nbsp%3B%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%91%A8%E6%9C%9F%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E5%80%A4%E3%81%8C%20%3CSTRONG%3EFast%20Update%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3C%2FSTRONG%3E%E3%81%AB%E4%B8%8E%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%20%3CSTRONG%3E%E5%87%BA%E5%8A%9B%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3E2.%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AEpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%20-%20%3CSTRONG%3E1000%20Hz%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3E%E3%81%9D%E3%81%AE%E5%91%A8%E6%9C%9F%E5%80%A4%E3%81%AF29(%E3%82%B3%E3%82%A2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20-%20120MHz%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8%E5%99%A8%E5%80%A4%E3%81%AF255%E3%80%81%E5%86%85%E9%83%A8%E3%83%97%E3%83%AA%E3%82%B9%E3%82%AB%E3%83%A9%E5%80%A4%E3%81%AF16)%E3%80%81%3C%2FSTRONG%3E%3CSTRONG%3E%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AF31129(95%25%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB)%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%26nbsp%3B%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%91%A8%E6%9C%9F%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E5%80%A4%E3%81%8C%20%3CSTRONG%3EFast%20Update%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3C%2FSTRONG%3E%E3%81%AB%E4%B8%8E%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%20%3CSTRONG%3E%E5%87%BA%E5%8A%9B%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PTA0%E3%81%A8PTC10%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%94%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%E6%B3%A2%E5%BD%A2%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%3CSPAN%3E%E3%80%81%E3%80%8CPTC10%E3%80%8D%E3%83%94%E3%83%B3%E3%82%92LCU%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%E3%83%94%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%A7%E5%86%99%E7%9C%9F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-1%3A%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_0-1733286929488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_0-1733286929488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313904iC901BE827AFEB967%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_0-1733286929488.png%22%20alt%3D%22Vijay98_0-1733286929488.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-2%3A%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1733286929217.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1733286929217.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313905i811C5E8FF08196AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1733286929217.png%22%20alt%3D%22Vijay98_1-1733286929217.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-3%3APWM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1733286929646.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1733286929646.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313906i66452306BB00772C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1733286929646.png%22%20alt%3D%22Vijay98_2-1733286929646.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_3-1733286929440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_3-1733286929440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313907i7676F65D7D678C45%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_3-1733286929440.png%22%20alt%3D%22Vijay98_3-1733286929440.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-4%3APtc10(Lcu1_out11)%E3%81%AETrigmux%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_4-1733286929278.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_4-1733286929278.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313909i18BF56C64FE47A7B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_4-1733286929278.png%22%20alt%3D%22Vijay98_4-1733286929278.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-5%3ALcu_instance%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_5-1733286929538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_5-1733286929538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313908i8325AD253A2CFD52%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_5-1733286929538.png%22%20alt%3D%22Vijay98_5-1733286929538.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-6%3ALcu%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_6-1733286929696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_6-1733286929696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313910i09A0E56EB6F17D06%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_6-1733286929696.png%22%20alt%3D%22Vijay98_6-1733286929696.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-7%3A%20Lcu%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_7-1733286929685.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_7-1733286929685.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313911iB8F2B2027AF62590%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_7-1733286929685.png%22%20alt%3D%22Vijay98_7-1733286929685.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E4%BD%95%E3%81%8B%E5%B0%8F%E3%81%95%E3%81%AA%E9%96%93%E9%81%95%E3%81%84%E3%82%92%E7%8A%AF%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8CPTA0%E3%80%8D%E3%81%A7%E3%83%8F%E3%82%A4%E3%82%B5%E3%82%A4%E3%83%89%E3%81%AEpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%80%8CPTC10%E3%80%8D%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89PWM%E3%83%91%E3%83%AB%E3%82%B9%20-%20%E3%81%93%E3%82%8C%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3CSTRONG%3E%E9%AB%98%E9%80%9F%E6%9B%B4%E6%96%B0%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%B3%A2%E5%BD%A2%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2003791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2003791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233667%22%20target%3D%22_blank%22%3E%40MN_TL_24%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F1993066%2Fhighlight%2Ftrue%23M9749%22%20target%3D%22_blank%22%3ERe%3APwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%BB%E3%83%AB%20%3CSTRONG%3E0%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%20%E3%81%A8%E3%81%9D%E3%82%8C%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%83%94%E3%83%B3%20PTC10%20%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%BB%E3%83%AB%201%3C%2FSTRONG%3E%E3%80%81%E5%87%BA%E5%8A%9B%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E11%3C%2FSTRONG%3E%20(%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ELC1_Out11%3C%2FSTRONG%3E)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1732802557969.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1732802557969.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313143i7BDB6A2EC2B922CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1732802557969.png%22%20alt%3D%22stefanvlad_0-1732802557969.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%83%94%E3%83%B3%E3%81%A7%3CSTRONG%3E%20LCU0%20%E3%81%8B%E3%82%89%E3%81%A9%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%94%E3%83%B3%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTD2%20%3C%2FSTRONG%3E%E3%81%8B%E3%82%89%20PWM_Modulator%20%E3%82%92%20%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%94%E3%83%B3%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%81%AEPTC10%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AFPin%20Manager%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Eemios_0_ch6%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1732802558139.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1732802558139.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313145iB2AEAB1477CE678E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1732802558139.png%22%20alt%3D%22stefanvlad_1-1732802558139.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81PWM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20EMIOS_0%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20CH_6%3C%2FSTRONG%3E%20%E3%81%AB%E5%88%A5%E3%81%AEeMIOS%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1732802558540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1732802558540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313144i78955F9CE7B33889%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1732802558540.png%22%20alt%3D%22stefanvlad_2-1732802558540.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E5%88%A5%E3%81%AEPWM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1732802558189.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1732802558189.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313147iA8AE36FF75CB0A53%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1732802558189.png%22%20alt%3D%22stefanvlad_3-1732802558189.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1732802558073.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1732802558073.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313146i76E884CD4A630CD3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1732802558073.png%22%20alt%3D%22stefanvlad_4-1732802558073.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%20Duty%2BPeriod%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1732802558185.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1732802558185.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313148i2E5A5A881A48F1FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1732802558185.png%22%20alt%3D%22stefanvlad_5-1732802558185.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20eMIOS%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20PWMC_Modulator%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20pin%20%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1732802557917.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1732802557917.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313149iC6CFFD38DFBE5C7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1732802557917.png%22%20alt%3D%22stefanvlad_6-1732802557917.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%96%91%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2002925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_Icu_pin_config_issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2002925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFNxp%E3%83%81%E3%83%BC%E3%83%A0%E3%80%81%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F1995720%23M9763%22%20target%3D%22_blank%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFRe%3APwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%E3%81%AE%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E5%80%9F%E3%82%8A%E3%81%A6%E3%80%81Lcu%E3%81%A8Trigmux%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Pwm%E3%83%91%E3%83%AB%E3%82%B9%E7%94%9F%E6%88%90%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELcu%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7pwm%E3%81%8C%E6%97%A2%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSTRONG%3E%20PTA3%E3%83%94%E3%83%B3%3C%2FSTRONG%3E%20%E3%82%92%E3%80%81Lcu%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%20%3CSTRONG%3EPTC10%E3%83%94%E3%83%B3%3C%2FSTRONG%3E%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LCU%E6%A7%8B%E6%88%90%E3%81%A7PTC10%E3%83%94%E3%83%B3(LCU1_out11)%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81pwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%94%E3%83%B3%E3%81%A7%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E6%89%8B%E9%A0%86%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-1%3APTC-10%E3%83%94%E3%83%B3%E3%81%AE%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_0-1732715275333.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_0-1732715275333.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312874i0B13797775D1AD12%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_0-1732715275333.png%22%20alt%3D%22Vijay98_0-1732715275333.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-2%3APtc10%E3%83%94%E3%83%B3%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1732715453267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1732715453267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312875iED5778B0142967FF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1732715453267.png%22%20alt%3D%22Vijay98_1-1732715453267.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-3%3APTC-10%E3%81%AEPWM%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1732715510985.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1732715510985.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312878i1E6C68F652147495%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1732715510985.png%22%20alt%3D%22Vijay98_2-1732715510985.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_3-1732715524321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_3-1732715524321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312879i4970309662F1A813%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_3-1732715524321.png%22%20alt%3D%22Vijay98_3-1732715524321.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-4%3APtc10%E3%81%AETrigmux%E6%A7%8B%E6%88%90-LCU1_out11%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_4-1732715577831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_4-1732715577831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312880i12637171241189B6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_4-1732715577831.png%22%20alt%3D%22Vijay98_4-1732715577831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-5%3ALcu%E6%A7%8B%E6%88%90-lcu%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_5-1732715627968.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_5-1732715627968.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312881i20F1BDEC3B2705A9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_5-1732715627968.png%22%20alt%3D%22Vijay98_5-1732715627968.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-6%3ALcu%E6%A7%8B%E6%88%90-Lcu%E5%85%A5%E5%8A%9B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_6-1732715660529.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_6-1732715660529.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312882iF39FFE6097CEA844%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_6-1732715660529.png%22%20alt%3D%22Vijay98_6-1732715660529.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-7%3ALcu%E6%A7%8B%E6%88%90-Lcu%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_7-1732715691206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_7-1732715691206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312883iFD7883BD0B8C1878%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_7-1732715691206.png%22%20alt%3D%22Vijay98_7-1732715691206.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%208%3A%20%E3%83%A2%E3%83%87%E3%83%AB%20-%26gt%3B%20%E3%81%A7%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81%E6%A7%8B%E6%88%90%20Mcl%20%E5%87%BA%E5%8A%9B%E7%8A%B6%E6%85%8B%20-%20%26gt%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_8-1732715733740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_8-1732715733740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312884i6E2D9439D0377BB7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_8-1732715733740.png%22%20alt%3D%22Vijay98_8-1732715733740.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELCU%E6%A7%8B%E6%88%90%E3%81%A7%E3%80%8CPTA3%E3%80%8Dpwm%E3%81%AELcu%E5%87%BA%E5%8A%9B%E3%82%92%E3%80%8CPTC10%E3%80%8D%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%40Irina_Costachescu%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F221383%22%20target%3D%22_blank%22%3E%40Adrian_Gherca%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226537%22%20target%3D%22_blank%22%3E%40Kavin_raj_mbd%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%20X%20%E8%BB%B8%E4%B8%8A%E3%81%AE%E5%A2%97%E5%8A%A0%E6%99%82%E9%96%93%E9%A0%98%E5%9F%9F%E3%81%AB%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E8%A6%8B%E3%81%A6%E3%81%84%E3%82%8B%E5%8A%B9%E6%9E%9C%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%9FPWM%E5%91%A8%E6%B3%A2%E6%95%B0%E3%80%81Logic%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E9%96%93%E3%81%AE%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81PWM%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1732126556146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1732126556146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311495iE7F3E6218AE01C6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1732126556146.png%22%20alt%3D%22stefanvlad_0-1732126556146.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20PLL%20%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%20PWM%20%E7%94%9F%E6%88%90%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K3xx.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3xx%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%3C%2FA%3E%E3%81%AB%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1732126667330.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1732126667330.png%22%20style%3D%22width%3A%20335px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311496i55B7A436CC60A75A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1732126667330.png%22%20alt%3D%22stefanvlad_1-1732126667330.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPLL%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81PWM%20%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%20EMIOS_CLK%20%E3%81%AB%E5%85%A5%E3%82%8B%20CORE_CLK%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1732126722563.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1732126722563.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311497iAC6A11EC1745BE0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1732126722563.png%22%20alt%3D%22stefanvlad_2-1732126722563.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1996919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFNxp%E3%83%81%E3%83%BC%E3%83%A0%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81Lcu%E3%83%94%E3%83%B3%E3%81%A7pwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8BPwm_trigmux_lcu%E3%81%AB%E3%82%82%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81nxp%E3%83%81%E3%83%BC%E3%83%A0%E3%80%8Cs32k312_pwm_lcu_mod_carrier_s32ct.zip%E3%80%8D%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%3CSPAN%3E%E3%80%81%E3%83%8F%E3%82%A4%E3%82%B5%E3%82%A4%E3%83%89%E3%83%94%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8CPTA0%E3%80%8D%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81PTC10%E3%83%94%E3%83%B3%E3%82%92%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89%E3%83%94%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Ptc%2010%E3%83%94%E3%83%B3%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%A7%E5%86%99%E7%9C%9F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-1%3A%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_0-1731999687067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_0-1731999687067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311170iD072515B8013D201%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_0-1731999687067.png%22%20alt%3D%22MN_TL_24_0-1731999687067.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-2%3A%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_1-1731999717746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_1-1731999717746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311171i0EFF1CE76A120130%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_1-1731999717746.png%22%20alt%3D%22MN_TL_24_1-1731999717746.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-3%3APWM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_2-1731999753141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_2-1731999753141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311172i78E426A51630E139%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_2-1731999753141.png%22%20alt%3D%22MN_TL_24_2-1731999753141.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_3-1731999761421.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_3-1731999761421.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311173iD575780E1D5B1741%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_3-1731999761421.png%22%20alt%3D%22MN_TL_24_3-1731999761421.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-4%3APtc10(Lcu1_out11)%E3%81%AETrigmux%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_4-1731999794773.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_4-1731999794773.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311174i7D2A743CD776D6FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_4-1731999794773.png%22%20alt%3D%22MN_TL_24_4-1731999794773.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-5%3ALcu_instance%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_5-1731999870145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_5-1731999870145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311175i8C14D0B95D853F62%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_5-1731999870145.png%22%20alt%3D%22MN_TL_24_5-1731999870145.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97-6%3ALcu%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_6-1731999904508.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_6-1731999904508.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311176iB45C2DF9198BD307%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_6-1731999904508.png%22%20alt%3D%22MN_TL_24_6-1731999904508.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-7%3A%20Lcu%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E6%A7%8B%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_7-1731999930115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_7-1731999930115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311178i93DC7EABDE236D41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_7-1731999930115.png%22%20alt%3D%22MN_TL_24_7-1731999930115.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E4%BD%95%E3%81%8B%E5%B0%8F%E3%81%95%E3%81%AA%E9%96%93%E9%81%95%E3%81%84%E3%82%92%E7%8A%AF%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8CPTA0%E3%80%8D%E3%81%A7%E3%83%8F%E3%82%A4%E3%82%B5%E3%82%A4%E3%83%89%E3%81%AEpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%80%8CPTC10%E3%80%8D%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%89PWM%E3%83%91%E3%83%AB%E3%82%B9%20-%20%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%B3%A2%E5%BD%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3EMN_TL%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A8%E3%81%9D%E3%81%AE%E5%87%BA%E5%8A%9Bpwm%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%3CSPAN%3ESaleae%20Logic%208(%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC)%3C%2FSPAN%3E%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E9%81%85%E5%BB%B6%E3%81%8C%E6%B8%9B%E5%B0%91%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E5%86%85%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81PTD2%E3%81%8A%E3%82%88%E3%81%B3PTA0%E3%81%AE%E5%A4%89%E8%AA%BF%E5%99%A8%E3%83%91%E3%83%AB%E3%82%B9)%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%97%E7%B6%9A%E3%81%91%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A8%E3%81%9D%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A8%E5%91%A8%E6%9C%9F%E3%82%92%E4%B8%8E%E3%81%88%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E5%A4%89%E8%AA%BF%E5%99%A8%E3%83%91%E3%83%AB%E3%82%B9%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELCU%E5%87%BA%E5%8A%9B%E3%83%94%E3%83%B3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E5%AE%9F%E7%8F%BE%E5%8F%AF%E8%83%BD)%E3%81%AE%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%85%A5%E5%8A%9B%2F%E5%87%BA%E5%8A%9B%E3%81%8C%E6%97%A2%E5%AD%98%E3%81%AELCU0%E3%83%94%E3%83%B3%E3%81%A8%E5%AF%86%E6%8E%A5%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1731437169645.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1731437169645.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310089i20E9151A7DC2FFEB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1731437169645.png%22%20alt%3D%22stefanvlad_2-1731437169645.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81TrgMux%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20%3CSTRONG%3EPTA3%3C%2FSTRONG%3E%20%E5%87%BA%E5%8A%9B%E3%82%92%3CSTRONG%3EPTA0%3C%2FSTRONG%3E%20%E3%81%AB%E5%86%8D%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%8C%E8%A4%87%E6%95%B0%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20MCL%20Configuration%E3%80%81Trgmux%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%A7%E3%80%81%E5%85%A5%E5%8A%9BLCU0_LC0_OUT_I2%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1731436994058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1731436994058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310086i743705CD02B110D1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1731436994058.png%22%20alt%3D%22stefanvlad_0-1731436994058.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20LCU%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81Lcu%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%85%A5%E5%8A%9B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%20%3CSTRONG%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99LCU_IP_MUX_SEL_LU_IN_2%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1731437340855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1731437340855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310091i34E91FC8DFBB4BE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1731437340855.png%22%20alt%3D%22stefanvlad_3-1731437340855.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E3.%20LCU%20Logic%20Output%E3%80%81LC_1%E3%81%AB%E5%88%A5%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%3CSTRONG%3ELCU_IP_HW_OUTPUT_0%3C%2FSTRONG%3E%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1731437436087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1731437436087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310094i15604CC0391A4027%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1731437436087.png%22%20alt%3D%22stefanvlad_4-1731437436087.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E4.%20Simulink%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AEInitialize%20Function%E3%81%A7%E3%80%81%E5%88%A5%E3%81%AE%20%3CSTRONG%3EMCL_LCU%E5%87%BA%E5%8A%9B%3C%2FSTRONG%3E%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1731437557652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1731437557652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310095iD5FF712C26317984%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1731437557652.png%22%20alt%3D%22stefanvlad_5-1731437557652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%85%83%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%82%82%E4%BD%BF%E7%94%A8(%E9%81%A9%E7%94%A8)%E3%81%A7%E3%81%8D%E3%82%8B%3CSTRONG%3EPWM_FastUpdate%3C%2FSTRONG%3E%E9%96%A2%E6%95%B0%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E6%9B%B4%E6%96%B0%E6%99%82%E9%96%93%E3%82%92%E6%94%B9%E5%96%84%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%81%AF2%E3%81%A4%E3%81%AEPWM%3C%2FSTRONG%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E7%B4%84%3CSTRONG%3E7us%3C%2FSTRONG%3E%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_8-1731438119981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_8-1731438119981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310102i94BF74EF435147C0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_8-1731438119981.png%22%20alt%3D%22stefanvlad_8-1731438119981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC(Saleae%20Logic%208%E3%81%BE%E3%81%9F%E3%81%AFebay%2FAliexp%E3%81%AA%E3%81%A9)%E3%81%AELogic2%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%96%E8%A6%9A%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1731437774328.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1731437774328.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310100iE0EB1499354F2CDE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1731437774328.png%22%20alt%3D%22stefanvlad_6-1731437774328.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81FreeMASTER%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A8%E5%90%8C%E3%81%98%E6%9C%9F%E9%96%93%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1731437885339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1731437885339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310101iAD335AD20160D0F7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1731437885339.png%22%20alt%3D%22stefanvlad_7-1731437885339.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CSTRONG%3Es32k312_pwm_lcu_mod_carrier_s32ct%3C%2FSTRONG%3E.zip%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_9-1731438229164.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_9-1731438229164.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310103i47A0D30234C7D34E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_9-1731438229164.png%22%20alt%3D%22stefanvlad_9-1731438229164.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%B3%A2%E5%BD%A2%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E4%BB%8A%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AELCU%E3%83%94%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.MCL%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%20%26gt%3B%20LCU%20%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%E4%BD%95%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F(%E3%83%94%E3%83%B3%E4%BA%A4%E6%8F%9B%E7%94%A8)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BE%8B%3A%E3%83%94%E3%83%B3%E3%82%92%20%3CSTRONG%3EPTA3%E3%81%8B%E3%82%89PTA0%3C%2FSTRONG%3E%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%A8%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%83%94%E3%83%B3%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81%20%3CSTRONG%3ELcu%E3%81%A7%E3%81%9D%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%8B%E3%82%89%E3%81%AEPWM%E4%BF%A1%E5%8F%B7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A9%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%82%88%E3%82%8A%E8%89%AF%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E3%81%86%E3%82%8C%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E7%B4%B9%E4%BB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AFFreeMASTER%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B8%80%E5%AE%9A%E3%81%AB%E4%BF%9D%E3%81%9F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1730827343375.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1730827343375.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308743iAB46DC7B22F59043%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1730827343375.png%22%20alt%3D%22stefanvlad_1-1730827343375.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E5%90%8C%E3%81%98%E3%83%94%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1987745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1987745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E5%91%A8%E6%9C%9F%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E6%B3%A2%E5%BD%A2%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E6%B3%A2%E5%86%85%E3%81%AE%E5%A4%89%E8%AA%BF%E6%B3%A2%E3%81%8C%E6%9B%B4%E6%96%B0(%E5%AE%9F%E8%A1%8C)%E3%81%97%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E7%96%91%E5%95%8F%E3%81%A7%E3%81%99%26gt%3B%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%89%E8%AA%BF%E5%99%A8%E3%81%AE%E6%B3%A2%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8B%95%E3%81%84%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%9D%E3%82%8C%E3%82%92%E6%AD%A2%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3C%2FP%3E%3CP%3E%E3%83%93%E3%82%B8%E3%82%A7%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E1.%E6%9C%80%E5%88%9D%E3%81%AE%20%3CSTRONG%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%2F%E7%84%A1%E5%8A%B9%E5%8C%96%20%3C%2FSTRONG%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1730226807702.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1730226807702.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307521iE1A4DBC64A8C3583%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1730226807702.png%22%20alt%3D%22stefanvlad_4-1730226807702.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8A%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3E%20%E3%83%A2%E3%83%87%E3%83%AB%3C%2FSPAN%3E%3CSTRONG%3E%20s32k344_mc_bldc_s32ct%3C%2FSTRONG%3E%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%3CSTRONG%3E%20PWM_FastUpdate%3C%2FSTRONG%3E%3CSTRONG%3E%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSTRONG%3E%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8B%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E8%A9%B3%E3%81%97%E3%81%8F%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1730225879850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1730225879850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307517i3F589127E284E689%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1730225879850.png%22%20alt%3D%22stefanvlad_0-1730225879850.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E1%E3%81%A4%E3%81%AEPWM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3C%2FSTRONG%3E%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%3CSTRONG%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSTRONG%3E%E3%81%AF4%E3%81%A4%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%3CSTRONG%3E%E9%A0%86%E5%BA%8F%E3%81%A7%3C%2FSTRONG%3E%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EPwm_FastUpdateDisableOU%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateSetUCRegA%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateSetUCRegB%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateEnableOU%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%9E%E3%82%B9%E3%82%AF%E5%80%A4%E3%81%AF%20%3CSTRONG%3Es32k344_mc_bldc_s32ct%20%3C%2FSTRONG%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%20%220%22%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%3CSPAN%3EMBD_APP_PWM_MASK%20%3D%20uint32(0xE00)%3C%2FSPAN%3E%20%E3%81%A8%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%E7%B5%90%E6%9E%9C%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E9%81%A9%E5%88%87%E3%81%AA%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20PWM_Carrier%E3%81%AE%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E7%94%9F%E6%88%90%3C%2FSTRONG%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3CSPAN%3E%E3%80%81eMIOS%20%E3%81%A8%20TRGMUX%20%E3%81%8A%E3%82%88%E3%81%B3%20LCU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81OPWFMB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1730226281277.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1730226281277.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307518i1EAAD753EB7261C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1730226281277.png%22%20alt%3D%22stefanvlad_1-1730226281277.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPWM_Mod%2B%20PWM_Carrier%20Period%20%E3%81%A8%20Duty%20cycle%20%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%81%AB%20FreeMASTER%20%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1730226406368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1730226406368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307519i6EF0F8CAEEB45302%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1730226406368.png%22%20alt%3D%22stefanvlad_2-1730226406368.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E5%8F%AF%E5%A4%89%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1730226465678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1730226465678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307520iF1BE059E82CE8DAC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1730226465678.png%22%20alt%3D%22stefanvlad_3-1730226465678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%98%E5%B1%9E%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%20%3CSTRONG%3Es32k312_pwm_lcu_mod_carrier_s32ct%3C%2FSTRONG%3E%E3%81%A7%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84.zip%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1983521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81Teams%E3%81%AE%E9%80%9A%E8%A9%B1%E3%81%A7%E8%A9%B1%E3%81%97%E5%90%88%E3%81%86%E3%81%A8%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%A7%E3%81%82%E3%82%8B%20%3CSTRONG%3E%E9%AB%98%E9%80%9F%E6%9B%B4%E6%96%B0%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E9%AB%98%E9%80%9F%E6%9B%B4%E6%96%B0%E6%A9%9F%E8%83%BD%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81pwm%202%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AB%E5%8F%AF%E5%A4%89%E9%81%85%E5%BB%B6%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%89%8D%E8%BF%B0%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8CTest_in_new%E3%80%8D%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1728903881304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1728903881304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304536i411B8B19125FA065%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1728903881304.png%22%20alt%3D%22Esakki_0-1728903881304.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%E3%81%9D%E3%81%97%E3%81%A62%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AFopwmb%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81bcde%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%90%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%E6%9C%9F%E9%96%93%E3%81%AE%E5%A4%89%E5%8C%96%E3%81%AF%E3%80%81%E5%A4%89%E5%8B%95%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BC%B4%E3%81%86%E5%9B%BA%E5%AE%9A%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CU%3E%E5%85%B1%E6%9C%89%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E8%A6%B3%E6%B8%AC(S32k312_pwm_icu_S32ct)%3A%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E1.%E9%AB%98%E3%81%84%E5%81%B4%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%E5%B8%B8%E3%81%AB259.63HZ%E3%81%A7%E3%80%81%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CU%3E(%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A6%81%E4%BB%B6%3A0.1HZ%E3%81%8B%E3%82%89150HZ%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FU%3E%3C%2FP%3E%3CP%3E2.%E4%BD%8E%E5%81%B4%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%E5%B8%B8%E3%81%AB2.8Khz%E3%81%A7%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CU%3E(%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A6%81%E4%BB%B6%3A%E3%83%8F%E3%82%A4%E3%82%B5%E3%82%A4%E3%83%89%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AEON%E6%99%82%E9%96%93%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A60.1Hz%E3%81%8B%E3%82%8912Khz%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FU%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_1-1728906825360.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_1-1728906825360.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304542i8FD100362F0DC56A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_1-1728906825360.jpeg%22%20alt%3D%22Esakki_1-1728906825360.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%90%E3%82%B9%E3%82%92%20OPWFMB%20%E3%81%A8%20%E5%86%85%E9%83%A8%E3%83%90%E3%82%B9%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81PWM-2%20%E3%83%91%E3%83%AB%E3%82%B9%E3%81%8C%20PWM1%20%E3%83%91%E3%83%AB%E3%82%B9%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%891%E3%81%A4%E3%81%AEPWM(PWM-1)%E3%82%92%E7%95%B0%E3%81%AA%E3%82%8B%E5%91%A8%E6%B3%A2%E6%95%B0(OPWFMB)%E3%81%AE%E5%91%A8%E6%9C%9F%E3%81%A8%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81PWM-1%E3%81%AEON%E6%99%82%E9%96%93%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6PWM-2%E3%82%92%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%80%8CNxp_pwm%E3%80%8D%E3%81%A8%E3%81%97%E3%81%A6%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226537%22%20target%3D%22_blank%22%3E%40Kavin_raj_mbd%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1966480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1966480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1727971560612.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1727971560612.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302616iE8CA6CC7F6BEF6D3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1727971560612.png%22%20alt%3D%22stefanvlad_0-1727971560612.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92S32K312EVB-Q172%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1727971604512.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1727971604512.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302617i569DC3408491E1AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1727971604512.png%22%20alt%3D%22stefanvlad_1-1727971604512.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81PTC10%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%8C%E5%86%99%E7%9C%9F-2%3Apwm%202%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AA%E3%81%97%E3%80%8D%E3%81%8B%E3%82%89%E9%80%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1727971655097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1727971655097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302618i8DA76FBD9319E560%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1727971655097.png%22%20alt%3D%22stefanvlad_2-1727971655097.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E9%81%94%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AFPWM_Modulator%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B%E4%BD%8E%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AEPWM%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%80%81PWM_Carrier%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84(11x)%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%9FPWM_Modulator%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%3CSTRONG%3EPWM_Carrier%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%2F%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FSTRONG%3E%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A9%A6%E3%81%97%E3%81%9F%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%99%E3%80%82%E6%AC%A0%E7%82%B9%E3%81%AF%E3%80%81%E3%81%94%E8%A6%A7%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E9%81%85%E5%BB%B6%E3%81%8C%E4%B8%80%E5%AE%9A%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B1%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%A7%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E5%84%AA%E5%85%88%E9%A0%86%E4%BD%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AFPWM%E3%81%AEFastUpdate%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%A2%E3%83%87%E3%83%AB%3CSTRONG%3Es32k344_mc_bldc_s32ct%3C%2FSTRONG%3E%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1727972253418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1727972253418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302620iE50FE8C92F1E184D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1727972253418.png%22%20alt%3D%22stefanvlad_3-1727972253418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EPWM_Carrier%E3%81%AE%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E7%94%9F%E6%88%90%3C%2FSTRONG%3E%20(eMIOS%20%E3%81%A8%20TRGMUX%20%E3%81%8A%E3%82%88%E3%81%B3%20LCU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90)%3A%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1728053964163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1728053964163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302735i186728247778382E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1728053964163.png%22%20alt%3D%22stefanvlad_0-1728053964163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E9%81%A9%E5%88%87%E3%81%AAPWM%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1728054330569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1728054330569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302737i69DD0AB018E8FBD4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1728054330569.png%22%20alt%3D%22stefanvlad_2-1728054330569.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E5%B0%91%E3%81%97%E8%A4%87%E9%9B%91%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E9%81%85%E5%BB%B6%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%81%A6%E5%88%B6%E5%BE%A1%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7FastUpdatePWM%E3%81%AE%E5%AE%9F%E8%A3%85%E3%82%92%E8%A9%A6%E3%81%99%E3%81%8B%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%3CSTRONG%3Es32k312_pwm_lcu_s32ct.zip%3A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1728055832787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1728055832787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302738i3BB3C97D80177C57%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1728055832787.png%22%20alt%3D%22stefanvlad_0-1728055832787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%80%81%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E9%80%B1%E6%9C%AB%E3%82%92%E9%81%8E%E3%81%94%E3%81%99%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A7%81%E3%81%AB%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Dragos%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%3CSTRONG%3EOPWFMB%3C%2FSTRONG%3E%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%3CSTRONG%3Eemios1_ch0%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3Eemios0_ch0%3C%2FSTRONG%3E%E3%81%AE%E5%86%85%E9%83%A8%3CSTRONG%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3CSTRONG%3Epwm%E4%BF%A1%E5%8F%B7%3C%2FSTRONG%3E%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%80%81mcl%3C%2FSTRONG%3E%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8%E5%99%A8%E3%81%AE%E5%80%A4%3C%2FSTRONG%3E%E3%81%AE%E3%81%BF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7pwm%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%90%8C%E3%81%98%E6%A7%8B%E6%88%90%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1949425%2Fhighlight%2Ftrue%23M9454%22%20target%3D%22_blank%22%3ERe%3AReg%3A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E4%B8%8A%E6%98%87%E3%81%A8%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E6%A4%9C%E5%87%BA%20issue_S32k344%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3Epwm%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81pwm1%E3%83%91%E3%83%AB%E3%82%B9%E3%82%AA%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E5%86%85%E3%81%A7pwm2%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81pwm2%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AFpwm2%E3%83%91%E3%83%AB%E3%82%B9%E3%81%A7%E4%B8%80%E5%AE%9A%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F-1%3Apwm%202%E3%81%AE820uS%E9%81%85%E5%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1726804764065.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1726804764065.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300226i21D570FBFC7BC415%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1726804764065.png%22%20alt%3D%22Esakki_0-1726804764065.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%86%99%E7%9C%9F-2%3Apwm%202%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_1-1726804764536.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_1-1726804764536.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300228i995AA772836D2AA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_1-1726804764536.png%22%20alt%3D%22Esakki_1-1726804764536.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%86%99%E7%9C%9F-3%3Apwm%202%E3%81%AE520uS%E9%81%85%E5%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_2-1726804764103.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_2-1726804764103.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300227i0F64F164A6E6EF10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_2-1726804764103.png%22%20alt%3D%22Esakki_2-1726804764103.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E9%81%85%E5%BB%B6%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E6%96%B9%E6%B3%95%E3%82%84%E3%80%81%E4%B8%80%E5%AE%9A%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A8%E6%A7%8B%E6%88%90%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9A%E7%AC%AC%E4%B8%80%E3%81%AB%E3%80%81%E5%BE%97%E3%82%89%E3%82%8C%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E9%81%85%E5%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1943519%2Fhighlight%2Ftrue%23M9416%22%20target%3D%22_blank%22%3E%3CSTRONG%3E%E6%8A%95%E7%A8%BF%3C%2FSTRONG%3E%3C%2FA%3E%E3%81%8B%E3%82%89%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%82%82%E8%80%83%E6%85%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%80%81eMIOS%201%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AE%20MCL%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%90%E3%82%B9%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%84%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E4%BA%8B%E5%AE%9F%E3%81%AB%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dragostoma_0-1726755404693.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dragostoma_0-1726755404693.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300056i911F443E37A717DA%2Fimage-dimensions%2F697x512%3Fv%3Dv2%22%20width%3D%22697%22%20height%3D%22512%22%20role%3D%22button%22%20title%3D%22dragostoma_0-1726755404693.png%22%20alt%3D%22dragostoma_0-1726755404693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%80%E6%96%B9%E3%80%81PWM%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%20eMIOS%201%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%A7%E5%86%85%E9%83%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%90%E3%82%B9%E3%81%B8%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%AF%E8%80%83%E6%85%AE%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E8%A8%88%E7%AE%97%E3%81%AF%E5%86%85%E9%83%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dragostoma_1-1726755451081.png%22%20style%3D%22width%3A%20715px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dragostoma_1-1726755451081.png%22%20style%3D%22width%3A%20715px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300057i9FD61F8FB539FDFE%2Fimage-dimensions%2F715x592%3Fv%3Dv2%22%20width%3D%22715%22%20height%3D%22592%22%20role%3D%22button%22%20title%3D%22dragostoma_1-1726755451081.png%22%20alt%3D%22dragostoma_1-1726755451081.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E8%A8%88%E7%AE%97%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%86%85%E9%83%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%96%E9%83%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%90%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81PWM%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E5%91%A8%E6%9C%9F%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%90%E3%82%B9%E3%81%AE%E5%91%A8%E6%9C%9F%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8%E5%99%A8%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%90%E3%82%B9%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%80%86%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%81%93%E3%81%A8%E3%81%AF%E5%86%85%E9%83%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E4%BB%96%E3%81%AE%E5%90%8C%E6%A7%98%E3%81%AE%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1949425%2Fhighlight%2Ftrue%23M9454%22%20target%3D%22_blank%22%3E%3CSTRONG%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%3C%2FSTRONG%3E%3C%2FA%3E%E3%81%A8%E5%90%8C%E3%81%98%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%A8%E6%A7%8B%E6%88%90%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A8%E5%85%B1%E3%81%AB%E6%A7%8B%E6%88%90%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%80%B2%E6%8D%97%E7%8A%B6%E6%B3%81%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%89%E3%83%A9%E3%82%B4%E3%82%B9%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
