Error installing MQX Eclipse plugin
6,913 次查看
tim_09
i'm trying to install the MQX Eclipse plugin 4.0.2 for the DS-5 Vybrid Tower System Starter Kit Version 5.22.0 under Ubuntu 14.04 running in a virtual machine. During the installation process I get the error message you can see on the attached image.
Do I have the rigth plugin version? What can I do to solve this problem?
Thanks and best regards
Tim
8 回复数
6,284 次查看
tim_09
Hi Alejandro and Richard,
thanks for your help. Installing the plugin from the community in a clean install of DS-5 helped me solving this problem. Seems like everything works fine now.
Alejandro you could close the service request now as the solution solved the problem.
Thank you a lot. Great support.
Tim
6,284 次查看
RossMcLuckie
Hi Alejandro,
Unfortunately I no longer support Vybrid, haven't done for quite some time, added richard_stulens​ who can hopefully help.
Ross
6,284 次查看
alejandrolozan1
Got it Ross!!!
Thank you so much!
Alejandro
6,284 次查看
richard_stulens
Hi Alejandro,
We do not maintain that plugin anymore, but out engineer in the MQX team checked it anyway.
Here's his findings:
I’ve tried to install version of “MQX support” plug-in from this thread (https://community.freescale.com/thread/323233) into clean install of ARM DS-5 v5.22.0 (build: 5220021) under Ubuntu 14.04 and Windows7 without any problem and plug-ins works fine.
I would suggest to try install of plug-in again in clean DS-5 because “No repository found containing” problem makes no sense when all mentioned missing plug-ins are bundled in “MQX support.zip” file (which is in fact Eclipse update site containing these plug-ins).
Richard
6,284 次查看
alejandrolozan1
Thanks Richard, I wil check it out!!!
/Alejandro
6,284 次查看
alejandrolozan1
Have you checked this?
MQX4.1/tools/ds-5/ds5_update_site.zip updated and new name "MQX Support.zip"
MQX Plug-in not compatible with DS-5.18
Please try that plug-in and let me know how it goes.
/Alejandro
6,284 次查看
tim_09
Hi Alejandro,
thanks for your answer. Unfortunately installing this plugin generates a different error. error2.PNG
What could I do?
Tim
6,284 次查看
alejandrolozan1
RossMcLuckie​, I hope you are doing well. Sorry to bother you but do you know it there is a problem with the MQX plug-in with version 5.22 of DS-5?
Is there someone that can provide a new plug-in?
Thanks a lot!!
Alejandro
