zyh@kszn-rd:~/work/copy/branch/imx6dl/kernel_imx$ git am --ignore-space-change --ignore-whitespace *.patch previous rebase directory /home/zyh/work/copy/branch/imx6dl/.git/rebase-apply still exists but mbox given. zyh@kszn-rd:~/work/copy/branch/imx6dl/ker
yuehanzhu
i.MX 6 Android JB 4.3_1.1.1 Patch,I follow the i.MX 6 Android JB 4.3_1.1.1 Patch Release Notes,but following a problem
zyh@kszn-rd:~/work/copy/branch/imx6dl/kernel_imx$ git am --abort
Applying: ENGR00306257 [#1027]fix system hang up issue caused by GPU
error: drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_event.c: does not exist in index
Patch failed at 0001 ENGR00306257 [#1027]fix system hang up issue caused by GPU
When you have resolved this problem run "git am --resolved".
If you would prefer to skip this patch, instead run "git am --skip".
To restore the original branch and stop patching run "git am --abort".
gusarambula
Hello Yuehan Zhu,
Are you following the steps on the Android User’s Guide? Would you please let us know exactly at which step are you finding this issue and the configuration you’re using?
