I see that in TFML_cifar NXP members implemented image resizing method with NEREAST. I trained my method with INTER_LINEAR resizing method. Do you have this implementation for the method. Please share with me.
Thank you.
This is source code for nearest method of resizing. File name is `image_resize_nearest.c`, it is in the project tflm_cifar10 fro MIMXRT1060-EVKB board.
* Copyright 2018-2020 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "image_utils.h"
* Code
* @brief Simple resizes using nearest neighbor.
* @param srcData to original image data
* @param srcWidth original image width
* @param srcHeight original image height
* @param dstData to destination image data
* @param dstWidth destination image width
* @param dstHeight destination image height
* @param channels count
void IMAGE_Resize(uint8_t* srcData, int srcWidth, int srcHeight,
uint8_t* dstData, int dstWidth, int dstHeight, int channels)
double dx = 1.0 * dstWidth / srcWidth;
double dy = 1.0 * dstHeight / srcHeight;
int step = channels * srcWidth;
int scale_step = channels * dstWidth;
int i, j, k, pre_i, pre_j, after_i, after_j;
if (channels == 1)
for (i = 0; i < dstHeight; i++)
for (j = 0; j < dstWidth; j++)
dstData[(dstHeight - 1 - i) * scale_step + j] = 0;
after_i = i;
after_j = j;
pre_i = (int)(after_i / dy + 0);
pre_j = (int)(after_j / dx + 0);
if (pre_i >= 0 && pre_i < srcHeight && pre_j >= 0 && pre_j < srcWidth)
dstData[i * scale_step + j] = srcData[pre_i * step + pre_j];
else if (channels == 3)
for (k = 0; k < 3; k++)
dstData[(dstHeight - 1 - i) * scale_step + j * 3 + k] = 0;
after_i = i;
after_j = j;
pre_i = (int)(after_i / dy + 0.5);
pre_j = (int)(after_j / dx + 0.5);
dstData[i * scale_step + j * 3 + k] = srcData[pre_i * step + pre_j * 3 + k];
}If possible, please add implementation of method INTER_LINEAR - a bilinear interpolation same as OpenCV. I think that it is more popular and used in Computer vision problem. Thanks
Hi, @nnxxpp
We have understood your requirement. If convenient, could you please tell me the background and advantage of using INTER_LINEAR - a bilinear interpolation? We will respond to this problem as soon as possible. If there is any news, I will inform you in the first place.
Best regards, Alex
