Implementation of image resizing with a method INTER_LINEAR - a bilinear interpolation?
1,280 次查看
nnxxpp
I see that in TFML_cifar NXP members implemented image resizing method with NEREAST. I trained my method with INTER_LINEAR resizing method. Do you have this implementation for the method. Please share with me.
Thank you.
1,240 次查看
Alex_Wang
Hi, @nnxxpp
Could you please provide me with a link about NEREAST so that I can check it for you?
Please let me know more details.
Best regards, Alex
1,238 次查看
nnxxpp
@Alex_Wang
This is source code for nearest method of resizing. File name is `image_resize_nearest.c`, it is in the project tflm_cifar10 fro MIMXRT1060-EVKB board.
 * Copyright 2018-2020 NXP
 * All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
#include "image_utils.h"
 * Code
 * @brief Simple resizes using nearest neighbor.
 * @param srcData to original image data
 * @param srcWidth original image width
 * @param srcHeight original image height
 * @param dstData to destination image data
 * @param dstWidth destination image width
 * @param dstHeight destination image height
 * @param channels count
void IMAGE_Resize(uint8_t* srcData, int srcWidth, int srcHeight,
                  uint8_t* dstData, int dstWidth, int dstHeight, int channels)
    double dx = 1.0 * dstWidth / srcWidth;
    double dy = 1.0 * dstHeight / srcHeight;
    int step = channels * srcWidth;
    int scale_step = channels * dstWidth;
    int i, j, k, pre_i, pre_j, after_i, after_j;
    if (channels == 1)
        for (i = 0; i < dstHeight; i++)
            for (j = 0; j < dstWidth; j++)
                dstData[(dstHeight - 1 - i) * scale_step + j] = 0;
              after_i = i;
              after_j = j;
              pre_i = (int)(after_i / dy + 0);
              pre_j = (int)(after_j / dx + 0);
              if (pre_i >= 0 && pre_i < srcHeight && pre_j >= 0 && pre_j < srcWidth)
                  dstData[i * scale_step + j] = srcData[pre_i * step + pre_j];
    else if (channels == 3)
                for (k = 0; k < 3; k++)
                    dstData[(dstHeight - 1 - i) * scale_step + j * 3 + k] = 0;
                after_i = i;
                after_j = j;
                pre_i = (int)(after_i / dy + 0.5);
                pre_j = (int)(after_j / dx + 0.5);
                        dstData[i * scale_step + j * 3 + k] = srcData[pre_i * step + pre_j * 3 + k];
 If possible, please add implementation of method INTER_LINEAR - a bilinear interpolation same as OpenCV. I think that it is more popular and used in Computer vision problem. Thanks
标记 (1)
1,227 次查看
Alex_Wang
Hi, @nnxxpp
We have understood your requirement. If convenient, could you please tell me the background and advantage of using INTER_LINEAR - a bilinear interpolation? We will respond to this problem as soon as possible. If there is any news, I will inform you in the first place.
Best regards, Alex
