LPCXpressoActivationcode
Gene_A
お世話になります。
Gene_Aと申します。
(Below you'll find the English translation.)
表題の件で、質問があります。
LPCXpresso のActivationCodeの取得のためのHPへ接続することが出来ません。
LPCXpresso上からリンクを辿ると下記のアドレスになるのですが、
ページが見つかりませんというエラーとなります。
<https://www.nxp.jp/lpcxpresso/activate>
上記のリンク以外でActivationCodeを発行する方法はあるのでしょうか。
現状、少し前に開発されたソースコードを使用して新規の案件をスタートさせようとしています。
その際に、客先との契約の関係で、開発環境を変えることが出来ず、古い環境を再現する必要があります。
LPCXpresso V7.0.0.を使用する必要があり、その際に上記のActivationCodeが必要になります。
どうかお知恵をお貸し頂ければ幸いです。
(english)
I have a question regarding the subject.
I cannot connect to the website to obtain the LPCXpresso Activation Code.
When I follow the link from LPCXpresso, I get the address below, but I get an error saying the page cannot be found.
Is there a way to issue an Activation Code other than the above link?
Currently, I am trying to start a new project using source code developed a while ago.
Due to a contract with the client, I cannot change the development environment and need to reproduce the old environment.
I need to use LPCXpresso V7.0.0., which requires the above Activation Code.
I would appreciate your advice.
ZhangJennie
Hi Gene_A,
I tested the registration process, there is no issue.
So could you try it again with following instruction:
If you can't log in automatically with the IDE generated activation code, navigate to https://lpcxpresso-activation.nxp.com, and enter the product’s serial number.
Hope this helps,
Jun Zhang
ZhangJennie
Hi Gene_A,
Hope this helps,
Jun Zhang
Gene_A
Hi Jun Zhang,
Thank you for your response.
I activated it using the link you provided,
and it completed successfully.
It seems the link I was trying to open with LPCXpresso was old.
(Probably because I was using an old version)
Thank you very much.
Gene_A
%3CLINGO-SUB%20id%3D%22lingo-sub-2087096%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3ELPCXpressoActivationcode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2087096%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3ENice%20to%20meet%20you.%3CBR%20%2F%3EMy%20name%20is%20Gene_A.%3C%2FP%3E%3CP%3E%EF%BC%88Below%20you'll%20find%20the%20English%20translation.%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3EI%20have%20a%20question%20about%20the%20title.%3CBR%20%2F%3EI%20can't%20connect%20to%20the%20website%20to%20get%20the%20ActivationCode%20of%20LPCXpresso.%3CBR%20%2F%3EIf%20you%20follow%20the%20link%20from%20LPCXpresso%2C%20it%20will%20be%20the%20following%20address.%3CBR%20%2F%3EYou%20will%20get%20an%20error%20that%20the%20page%20cannot%20be%20found.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%26lt%3B%20https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%20%26gt%3B%3C%2FA%3E%3CBR%20%2F%3EIs%20there%20a%20way%20to%20issue%20an%20ActivationCode%20other%20than%20the%20link%20above%3F%3CBR%20%2F%3E%3CBR%20%2F%3ECurrently%2C%20we%20are%20trying%20to%20start%20a%20new%20project%20using%20the%20source%20code%20developed%20some%20time%20ago.%3CBR%20%2F%3EAt%20that%20time%2C%20due%20to%20the%20contract%20with%20the%20customer%2C%20it%20is%20not%20possible%20to%20change%20the%20development%20environment%2C%20and%20it%20is%20necessary%20to%20recreate%20the%20old%20environment.%3CBR%20%2F%3EYou%20need%20to%20use%20LPCXpresso%20V7.0.0.%2C%20and%20you%20will%20need%20the%20above%20ActivationCode%20to%20do%20so.%3CBR%20%2F%3EI%20would%20be%20grateful%20if%20you%20could%20lend%20me%20your%20wisdom.%3CBR%20%2F%3E%3CBR%20%2F%3E(english)%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20have%20a%20question%20regarding%20the%20subject.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20cannot%20connect%20to%20the%20website%20to%20obtain%20the%20LPCXpresso%20Activation%20Code.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EWhen%20I%20follow%20the%20link%20from%20LPCXpresso%2C%20I%20get%20the%20address%20below%2C%20but%20I%20get%20an%20error%20saying%20the%20page%20cannot%20be%20found.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%26lt%3B%20https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%3C%2FA%3E%20%26gt%3B%3CBR%20%2F%3EIs%20there%20a%20way%20to%20issue%20an%20Activation%20Code%20other%20than%20the%20above%20link%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ECurrently%2C%20I%20am%20trying%20to%20start%20a%20new%20project%20using%20source%20code%20developed%20a%20while%20ago.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EDue%20to%20a%20contract%20with%20the%20client%2C%20I%20cannot%20change%20the%20development%20environment%20and%20need%20to%20reproduce%20the%20old%20environment.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EI%20need%20to%20use%20LPCXpresso%20V7.0.0.%2C%20which%20requires%20the%20above%20Activation%20Code.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EI%20would%20appreciate%20your%20advice.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPCXpressoActivationcode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jun%20Zhang%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20response.%3CBR%20%2F%3EI%20activated%20it%20using%20the%20link%20you%20provided%2C%3CBR%20%2F%3Eand%20it%20completed%20successfully.%3CBR%20%2F%3EIt%20seems%20the%20link%20I%20was%20trying%20to%20open%20with%20LPCXpresso%20was%20old.%3CBR%20%2F%3E(Probably%20because%20I%20was%20using%20an%20old%20version)%3C%2FP%3E%3CP%3EThank%20you%20very%20much.%3C%2FP%3E%3CP%3EGene_A%3C%2FP%3E%3C%2FLINGO-BODY%3E
