LPCXpressoActivationcode
2,855 次查看
Gene_A
お世話になります。
Gene_Aと申します。
(Below you'll find the English translation.)
表題の件で、質問があります。
LPCXpresso のActivationCodeの取得のためのHPへ接続することが出来ません。
LPCXpresso上からリンクを辿ると下記のアドレスになるのですが、
ページが見つかりませんというエラーとなります。
<https://www.nxp.jp/lpcxpresso/activate>
上記のリンク以外でActivationCodeを発行する方法はあるのでしょうか。
現状、少し前に開発されたソースコードを使用して新規の案件をスタートさせようとしています。
その際に、客先との契約の関係で、開発環境を変えることが出来ず、古い環境を再現する必要があります。
LPCXpresso V7.0.0.を使用する必要があり、その際に上記のActivationCodeが必要になります。
どうかお知恵をお貸し頂ければ幸いです。
(english)
I have a question regarding the subject.
I cannot connect to the website to obtain the LPCXpresso Activation Code.
When I follow the link from LPCXpresso, I get the address below, but I get an error saying the page cannot be found.
Is there a way to issue an Activation Code other than the above link?
Currently, I am trying to start a new project using source code developed a while ago.
Due to a contract with the client, I cannot change the development environment and need to reproduce the old environment.
I need to use LPCXpresso V7.0.0., which requires the above Activation Code.
I would appreciate your advice.
标记 (2)
2,849 次查看
ZhangJennie
Hi Gene_A,
I tested the registration process, there is no issue.
So could you try it again with following instruction:
If you can't log in automatically with the IDE generated activation code, navigate to https://lpcxpresso-activation.nxp.com, and enter the product’s serial number.
Hope this helps,
Jun Zhang
2,850 次查看
ZhangJennie
Hi Gene_A,
Hope this helps,
Jun Zhang
2,802 次查看
Gene_A
Hi Jun Zhang,
Thank you for your response.
I activated it using the link you provided,
and it completed successfully.
It seems the link I was trying to open with LPCXpresso was old.
(Probably because I was using an old version)
Thank you very much.
Gene_A
%3CLINGO-SUB%20id%3D%22lingo-sub-2087096%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3ELPCXpressoActivationcode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2087096%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E5%90%8D%E5%AD%97%E6%98%AF%20Gene_A%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E4%B8%8B%E9%9D%A2%E6%98%AF%E8%8B%B1%E6%96%87%E7%BF%BB%E8%AF%91%E3%80%82%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%AF%B9%E6%A0%87%E9%A2%98%E6%9C%89%E7%96%91%E9%97%AE%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%BD%91%E7%AB%99%E6%9D%A5%E8%8E%B7%E5%8F%96%20LPCXpresso%20%E6%BF%80%E6%B4%BB%E7%A0%81%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%82%B9%E5%87%BB%20LPCXpresso%20%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%82%A8%E5%B0%86%E5%88%B0%E8%BE%BE%E4%BB%A5%E4%B8%8B%E5%9C%B0%E5%9D%80%EF%BC%8C%3CBR%20%2F%3E%E5%AE%83%E7%BB%99%E5%87%BA%E4%BA%86%E9%A1%B5%E9%9D%A2%E6%9C%AA%E6%89%BE%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%3CBR%20%2F%3E%20%26lt%3B%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%3C%2FA%3E%20%26gt%3B%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%E4%BD%BF%E7%94%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E9%93%BE%E6%8E%A5%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%8F%91%E5%87%BA%E6%BF%80%E6%B4%BB%E7%A0%81%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E6%AD%A3%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%8D%E4%B9%85%E5%89%8D%E5%BC%80%E5%8F%91%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%AF%E5%8A%A8%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E7%94%B1%E4%BA%8E%E5%92%8C%E5%AE%A2%E6%88%B7%E5%90%88%E5%90%8C%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E6%97%A0%E6%B3%95%E6%94%B9%E5%8F%98%EF%BC%8C%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E6%9E%84%E5%BB%BA%E6%97%A7%E7%8E%AF%E5%A2%83%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E5%B0%86%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20LPCXpresso%20V7.0.0%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E4%B8%8A%E8%BF%B0%E6%BF%80%E6%B4%BB%E7%A0%81%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E6%BF%80%E6%82%A8%E8%83%BD%E7%BB%99%E6%88%91%E7%9A%84%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%EF%BC%88%E8%8B%B1%E8%AF%AD%EF%BC%89%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%AF%B9%E6%AD%A4%E4%B8%BB%E9%A2%98%E6%9C%89%E4%B8%80%E4%B8%AA%E7%96%91%E9%97%AE%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%BD%91%E7%AB%99%E6%9D%A5%E8%8E%B7%E5%8F%96%20LPCXpresso%20%E6%BF%80%E6%B4%BB%E7%A0%81%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%BD%93%E6%88%91%E7%82%B9%E5%87%BB%20LPCXpresso%20%E7%9A%84%E9%93%BE%E6%8E%A5%E6%97%B6%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%8C%E4%BD%86%E6%94%B6%E5%88%B0%E4%B8%80%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E6%8F%90%E7%A4%BA%E6%89%BE%E4%B8%8D%E5%88%B0%E8%AF%A5%E9%A1%B5%E9%9D%A2%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.jp%2Flpcxpresso%2Factivate%3C%2FA%3E%20%26gt%3B%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%E4%B8%8A%E8%BF%B0%E9%93%BE%E6%8E%A5%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%8F%91%E5%87%BA%E6%BF%80%E6%B4%BB%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ECurrently%2C%20I%20am%20trying%20to%20start%20a%20new%20project%20using%20source%20code%20developed%20a%20while%20ago.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EDue%20to%20a%20contract%20with%20the%20client%2C%20I%20cannot%20change%20the%20development%20environment%20and%20need%20to%20reproduce%20the%20old%20environment.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EI%20need%20to%20use%20LPCXpresso%20V7.0.0.%2C%20which%20requires%20the%20above%20Activation%20Code.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EI%20would%20appreciate%20your%20advice.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPCXpresso%E6%BF%80%E6%B4%BB%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BC%A0%E5%86%9B%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E9%93%BE%E6%8E%A5%E6%BF%80%E6%B4%BB%E4%BA%86%E5%AE%83%EF%BC%8C%3CBR%20%2F%3E%E5%B9%B6%E4%B8%94%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E%E7%9C%8B%E6%9D%A5%E6%88%91%E5%B0%9D%E8%AF%95%E7%94%A8%20LPCXpresso%20%E6%89%93%E5%BC%80%E7%9A%84%E9%93%BE%E6%8E%A5%E5%B7%B2%E7%BB%8F%E5%BE%88%E6%97%A7%E4%BA%86%E3%80%82%3CBR%20%2F%3E%20%EF%BC%88%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E6%88%91%E7%94%A8%E7%9A%84%E6%98%AF%E6%97%A7%E7%89%88%E6%9C%AC%EF%BC%89%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%BA%E5%9B%A0A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2087202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPCXpresso%E6%BF%80%E6%B4%BB%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2087202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3BGene_A%EF%BC%8C%3C%2FP%3E%0A%3CDIV%3E%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E6%B3%A8%E5%86%8C%E8%BF%87%E7%A8%8B%EF%BC%8C%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E9%82%A3%E4%B9%88%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9A%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPCXpresso-IDE-FAQs%2FActivating-LPCXpresso-Free-Edition%2Fm-p%2F467947%22%20target%3D%22_blank%22%20shape%3D%22rect%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPCXpresso-IDE-FAQs%2FActivating-LPCXpresso-Free-Edition%2Fmp%2F467947%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CBR%20clear%3D%22none%22%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20IDE%20%E7%94%9F%E6%88%90%E7%9A%84%E6%BF%80%E6%B4%BB%E7%A0%81%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%EF%BC%8C%E8%AF%B7%E5%AF%BC%E8%88%AA%E8%87%B3%3CA%20href%3D%22https%3A%2F%2Flpcxpresso-activation.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20shape%3D%22rect%22%3Ehttps%3A%2F%2Flpcxpresso-activation.nxp.com%3C%2FA%3E%20%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BE%93%E5%85%A5%E4%BA%A7%E5%93%81%E7%9A%84%E5%BA%8F%E5%88%97%E5%8F%B7%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FDIV%3E%0A%3CDIV%3E%E5%BC%A0%E5%86%9B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
