56F8300 programming software
5,083 次查看
Fduch
Hi. Need to read out firmware from 56F8323. Can any expland what SW are used for that task?
Can I use 56800E Flash Programmer User Guide for that?
5,065 次查看
Celeste_Liu
Hello @Fduch ,
Thanks for your support.
Yes, you can use 56800E Flash Programmer User Guide to read memory from 56F8323.
Please download the 56F8XXXFP software:
EVK for MC56F832x and MC56F812x DSCs | NXP Semiconductors
Then open the file 56800EFPUG and follow the steps of section “2.2.3 Viewing Memory”:
Hope it can help you.
BRs,
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
12 回复数
4,813 次查看
Fduch
I have add some info for cloning MCU. You need to readout only 2 files from 568323:
1)fflash 568323_flash.cfg program flash.S -rp0x00000:0x03FFF -p0x378
2)fflash 568323_flash.cfg boot flash.S -rp0x20000:0x20FFF -p0x378
As I understand, data flash area (0x01000 0x01FFF) is not so needit
4,894 次查看
Fduch
Finally, SOLVED! Need to be install CodeWarrior for 56800E Digital Signal Controllers v8.3.exe + FLSHPROGRAMMER_V1.2_WIN32.exe and move to directory like here:
C:\Program Files\Freescale\FlashProgrammer v1.2\bin>fflash 568323_flash.cfg 1623
0_p.S -rp0x0:0xfff -s -p0x378
56800E Flash Programmer v1.1
Program ran on: Mon Jul 21 14:45:06 2025
Connected to local CCS server
Configured to use Parallel Command Converter at port LPT1
Using Configuration File: 568323_flash.cfg
3 flash unit(s) defined in the config file.
Chip ID: 0x01f4001d
Core ID: 0x02211004, 1 - Normal Mode
Placing the device into debug mode, please wait...
Reading Memory: ****************, Done
Resetting the device to user mode...
Init: 2907ms, Read Memory: 3297ms, Exit Debug: 921ms, Total: 7125ms
4,883 次查看
Celeste_Liu
Hello @Fduch , I am very glad to hear that.  Any new issues, welcome to create the new post.
4,902 次查看
Fduch
Well, here the correct CMD and what I have with yours *cfg:
C:\JtagV2>fflash 568323_flash.cfg 16230_x.S -rx0x0:0xfff -p0x378
56800E Flash Programmer v1.0
Program ran on: Mon Jul 21 13:48:18 2025
CCCSClient::Open: Connection refused
C:\JtagV2>
4,900 次查看
Celeste_Liu
What version is your 56F8300 programming software, and which version of CodeWarrior is it a plug-in for? Additionally, what is your Windows OS?
I noticed there is "CCCSClient::Open: Connection refused" in the log.
It might be related to CCS; please refer to it. Windows 7/10: Using USB TAP on CodeWarrior for DSC - NXP Community
4,897 次查看
Fduch
OS is Win XP. And I had not install CodeWarrior on it. Just only 56800E Flash Programmer.exe & FFLASH.exe from archive 56800E Flash Programmer User Guide. Does need to install CodeWarrior?
4,909 次查看
Fduch
Well, some actions:
C:\JtagV2>flashJtagLoader 568323_flash.cfg 16230_x.S -rX0x0:0xfff -p0x378
DSP56F801x Flash loader. Compiled on Nov 3 2006, 18:00:59.
version Alpha 2.0
(c) Freescale, TIC, 2006 by William Jiang
Partial Copyright 2000-2002, Zloba Alexander
I/O port driver started
Using printer port at address 0x378.
Chip ID: 0x01f4001d
After reseting the part in programming, JTAG paths now are as follows:
JTAG IR path length: 8
JTAG DR path length: 1 (BYPASS)
Core ID: 0x02211004 Core Status: 0x0d - Debug
After selecting the core TAP of the part in programming, JTAG paths are changed
now!!!
JTAG IR path length: 4
Debug Request status: 0xd - Debug
Enable OnCE status: 0xd - Debug
Enable OnCE successful, target chip is in Debug mode
Trim relaxation oscillator successful!, trim value =0x026c
Chip is not secured
Flash config file command ignored: target_code_sets_hfmclkd 1
Flash config file command ignored: set_hfm_config_base 0x003FF7
Flash config file command ignored: set_hfm_programmer_base 0x2F800
Flash config file command ignored: set_hfm_prog_buffer_base 0
Flash config file command ignored: set_hfm_prog_buffer_size 512
3 flash units defined in the config file.
Downloading of code failed, verify PRAM base address
C:\JtagV2>
What' wrong?
4,906 次查看
Celeste_Liu
Hello, I found another 56F8323 configuration file in Codewarrior v8.3, could you please have another try?
4,919 次查看
Fduch
Hi again! I come back... and as I see i need flash.cfg file for that operations. But is havn't any *cfg files in 56800E Flash Programmer.exe
Where I can get it? If to be moore exactly - flash8323.cfg
5,058 次查看
Fduch
There will definitely be questions later. Need some investigations for that
5,056 次查看
Celeste_Liu
Hello @Fduch ,
Since this is a LPC channel, for any other DSC related questions, please help to create a new post on Digital Signal Controllers - NXP Community
Thanks for your understanding in advance.
BRs,
Celeste
5,066 次查看
Celeste_Liu
Hello @Fduch ,
BRs,
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2124067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E56F8300%20%E7%BC%96%E7%A8%8B%E8%BD%AF%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E9%9C%80%E8%A6%81%E8%AF%BB%E5%87%BA%2056F8323%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%E3%80%8A56800E%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%8B%EF%BC%9F%20%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1269955055%22%20id%3D%22toc-hId-1299573107%22%3E%26nbsp%3B%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%BA%9B%E5%85%8B%E9%9A%86%20MCU%20%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E4%BD%A0%E5%8F%AA%E9%9C%80%E8%A6%81%E8%AF%BB%E5%87%BA%20568323%20%E4%B8%AD%E7%9A%84%202%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E1)%20flash%20568323_flash.cfg%20%E7%A8%8B%E5%BA%8F%20Flash.s-rp0x%2000000%3A0%20x03fff-p0x378%20%3CBR%20%2F%3E%202)%20flash%20568323_flash.cfg%20%E5%90%AF%E5%8A%A8%20flash.s-rp0x%2020000%3A0%20x20fff-p0x378%20%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%20(0x01000%200x01FFF)%20%E4%B8%8D%E6%98%AF%E9%82%A3%E4%B9%88%E9%9C%80%E8%A6%81%E5%AE%83%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%EF%BC%8C%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E5%90%AC%E5%88%B0%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%E3%80%82%20%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E6%96%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E6%AC%A2%E8%BF%8E%E5%88%9B%E5%BB%BA%E6%96%B0%E5%B8%96%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%BB%88%E4%BA%8E%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20CodeWarrior%20for%2056800E%20%E6%95%B0%E5%AD%97%E4%BF%A1%E5%8F%B7%E6%8E%A7%E5%88%B6%E5%99%A8%20v8.3.exe%2B%20FLSHPROGRAMMER_V1.2_WIN32.exe%EF%BC%8C%E5%B9%B6%E7%A7%BB%E5%8A%A8%E5%88%B0%E5%A6%82%E4%B8%8B%E7%9B%AE%E5%BD%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3EC%3A%5CProgram%20Files%5C%20Freescale%5C%20FlashProgrammer%20v1.2%5C%20bin%20%26gt%3B%20fflash%20568323_flash.cfg%201623%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%200_p.s-rp0x%200%3A0%20xfff-s-p0x378%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%2056800E%20Flash%20%E7%A8%8B%E5%BA%8F%E5%91%98%20v1.1%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%20%E7%A8%8B%E5%BA%8F%20%E8%BF%90%E8%A1%8C%20%E6%97%B6%E9%97%B4%EF%BC%9A2025%20%E5%B9%B4%207%20%E6%9C%88%2021%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%80%2014%3A45%3A06%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9C%AC%E5%9C%B0%20CCS%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%9C%A8%20LP%20T1%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%20%E7%AB%AF%E5%8F%A3%E4%BD%BF%E7%94%A8%E5%B9%B6%E8%A1%8C%E5%91%BD%E4%BB%A4%E8%BD%AC%E6%8D%A2%E5%99%A8%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%9A568323_flash.cfg%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%203%20%E4%B8%AA%E9%97%AA%E5%AD%98%E5%8D%95%E5%85%83%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E8%8A%AF%E7%89%87%20ID%EF%BC%9A0x01f4001d%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E6%A0%B8%E5%BF%83%20ID%EF%BC%9A0x02211004%2C%201%20-%20%E6%99%AE%E9%80%9A%E6%A8%A1%E5%BC%8F%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E5%B0%86%E8%AE%BE%E5%A4%87%E7%BD%AE%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%8C%E8%AF%B7%E7%A8%8D%E5%80%99...%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E8%AF%BB%E5%8F%96%E5%86%85%E5%AD%98%EF%BC%9A****************%EF%BC%8C%E5%AE%8C%E6%88%90%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E5%B0%86%E8%AE%BE%E5%A4%87%E9%87%8D%E7%BD%AE%E4%B8%BA%E7%94%A8%E6%88%B7%E6%A8%A1%E5%BC%8F...%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9A2907%20%E6%AF%AB%E7%A7%92%EF%BC%8C%E8%AF%BB%E5%8F%96%E5%86%85%E5%AD%98%EF%BC%9A3297%20%E6%AF%AB%E7%A7%92%EF%BC%8C%E9%80%80%E5%87%BA%E8%B0%83%E8%AF%95%EF%BC%9A921%20%E6%AF%AB%E7%A7%92%EF%BC%8C%E6%80%BB%E8%AE%A1%EF%BC%9A7125%20%E6%AF%AB%E7%A7%92%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%98%AF%20Win%20XP%E3%80%82%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E5%9C%A8%E4%B8%8A%E9%9D%A2%E5%AE%89%E8%A3%85%20CodeWarrior%E3%80%82%E5%8F%AA%E9%9C%80%E5%9C%A8%2056800E%20Flash%20Programmer.exe%26amp%3B%20FFLASH.exe%20%E6%A1%A3%E6%A1%88%E4%B8%AD%E4%B8%8B%E8%BD%BD%2056800E%20Flash%20Programmer%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%82%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20CodeWarrior%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%9A%84%2056F8300%20%E7%BC%96%E7%A8%8B%E8%BD%AF%E4%BB%B6%E6%98%AF%E4%BB%80%E4%B9%88%E7%89%88%E6%9C%AC%EF%BC%8C%E5%AE%83%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20CodeWarrior%20%E6%8F%92%E4%BB%B6%EF%BC%9F%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E7%9A%84%20Windows%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E6%97%A5%E5%BF%97%E4%B8%AD%E6%9C%89%22%20CCCSClient%3CEM%3E%3A%3AOpen%EF%BC%9AConnection%20refused%3C%2FEM%3E%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E4%B8%8E%E4%B8%AD%E5%A4%AE%E6%A1%88%E4%BE%8B%E7%A0%94%E7%A9%B6%E6%9C%89%E5%85%B3%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FCodeWarrior-Development-Tools%2FWindows-7-10-Using-USB-TAP-on-CodeWarrior-for-DSC%2Fta-p%2F1126441%22%20target%3D%22_blank%22%3EWindows%207%2F10%EF%BC%9A%E5%9C%A8%E9%80%82%E7%94%A8%E4%BA%8E%20DSC%20%E7%9A%84%20CodeWarrior%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20USB%20TAP-%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%20CMD%20%E5%92%8C%E6%88%91%E4%B8%8E%E4%BD%A0%E7%9A%84%20*cfg%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CEM%3EC%3A%5CJtagV2%26gt%3Bfflash%20568323_flash.cfg%2016230_x.S%20-rx0x0%3A0xfff%20-p0x378%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E56800E%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%20v1.0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E4%BA%8EMon%20Jul%2021%2013%3A48%3A18%202025%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ECCCSClient%3A%3AOpen%EF%BC%9A%E6%8B%92%E7%BB%9D%E8%BF%9E%E6%8E%A5%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EC%3A%5CJtagV2%26gt%3B%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20Codewarrior%20v8.3%20%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%2056F8323%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%AF%EF%BC%8C%E6%9C%89%E4%BA%9B%E8%A1%8C%E5%8A%A8%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EC%3A%5CJtagV2%26gt%3BflashJtagLoader%20568323_flash.cfg%2016230_x.S%20-rX0x0%3A0xfff%20-p0x378%3CBR%20%2F%3EDSP56F801x%20%E9%97%AA%E5%AD%98%E5%8A%A0%E8%BD%BD%E5%99%A8%E3%80%82%E7%BC%96%E8%AF%91%E4%BA%8E%202006%20%E5%B9%B4%2011%20%E6%9C%88%203%20%E6%97%A5%2018%3A00%3A59%E3%80%82%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%20Alpha%202.0%3CBR%20%2F%3E(c)%20Freescale%2C%20TIC%2C%202006%20by%20William%20Jiang%3CBR%20%2F%3E%E9%83%A8%E5%88%86%E7%89%88%E6%9D%83%202000-2002%EF%BC%8CZloba%20Alexander%3CBR%20%2F%3EI%2FO%20%E7%AB%AF%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%9C%B0%E5%9D%80%E4%B8%BA%200x378%20%E7%9A%84%E6%89%93%E5%8D%B0%E6%9C%BA%E7%AB%AF%E5%8F%A3%E3%80%82%3CBR%20%2F%3E%E8%8A%AF%E7%89%87%20ID%EF%BC%9A0x01f4001d%3CBR%20%2F%3E%20%E5%9C%A8%E7%BC%96%E7%A8%8B%E4%B8%AD%E9%87%8D%E7%BD%AE%E9%83%A8%E4%BB%B6%E5%90%8E%EF%BC%8CJTAG%20%E8%B7%AF%E5%BE%84%E7%8E%B0%E5%9C%A8%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3CBR%20%2F%3E%20JTAG%20IR%20%E8%B7%AF%E5%BE%84%E9%95%BF%E5%BA%A6%EF%BC%9A8%3CBR%20%2F%3E%20JTAG%20DR%20%E8%B7%AF%E5%BE%84%E9%95%BF%E5%BA%A6%EF%BC%9A1%20(BYPASS)%3CBR%20%2F%3E%20%E6%A0%B8%E5%BF%83%20ID%EF%BC%9A0x02211004%20%E6%A0%B8%E5%BF%83%E7%8A%B6%E6%80%81%EF%BC%9A0x0d%20-%20%E8%B0%83%E8%AF%95%3CBR%20%2F%3E%20%E5%9C%A8%E7%BC%96%E7%A8%8B%E4%B8%AD%E9%80%89%E6%8B%A9%E8%AF%A5%E9%83%A8%E4%BB%B6%E7%9A%84%E6%A0%B8%E5%BF%83%20TAP%20%E5%90%8E%EF%BC%8CJTAG%3CBR%20%2F%3E%20%E8%B7%AF%E5%BE%84%E7%8E%B0%E5%9C%A8%E6%9B%B4%E6%94%B9%E4%BA%86%EF%BC%81%EF%BC%81%EF%BC%81%3CBR%20%2F%3E%20JTAG%20IR%20%E8%B7%AF%E5%BE%84%E9%95%BF%E5%BA%A6%EF%BC%9A4%3CBR%20%2F%3E%20JTAG%20DR%20%E8%B7%AF%E5%BE%84%E9%95%BF%E5%BA%A6%EF%BC%9A1%20(BYPASS)%3CBR%20%2F%3E%20%E8%B0%83%E8%AF%95%E8%AF%B7%E6%B1%82%E7%8A%B6%E6%80%81%EF%BC%9A0xd%20-%20%E8%B0%83%E8%AF%95%3CBR%20%2F%3E%20%E5%90%AF%E7%94%A8%20OnCE%20%E7%8A%B6%E6%80%81%EF%BC%9A0xd%20-%20%E8%B0%83%E8%AF%95%3CBR%20%2F%3E%20%E5%90%AF%E7%94%A8%20OnCE%20%E6%88%90%E5%8A%9F%EF%BC%8C%E7%9B%AE%E6%A0%87%E8%8A%AF%E7%89%87%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%20%E4%BF%AE%E5%89%AA%E6%9D%BE%E5%BC%9B%E6%8C%AF%E8%8D%A1%E5%99%A8%E6%88%90%E5%8A%9F%EF%BC%81%EF%BC%8C%E8%B0%83%E6%95%B4%E5%80%BC%20%3D0x026c%3CBR%20%2F%3E%20%E8%8A%AF%E7%89%87%E4%B8%8D%E5%AE%89%E5%85%A8%3CBR%20%2F%3E%20%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%91%BD%E4%BB%A4%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%9Atarget_code_sets_hfmclkd%201%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%91%BD%E4%BB%A4%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%9Aset_hfm_config_base%200x003FF7%3CBR%20%2F%3E%20%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%91%BD%E4%BB%A4%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%9Aset_hfm_programmer_base%200x2F800%20%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%91%BD%E4%BB%A4%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%9Aset_hfm_prog_buffer_base%200%3CBR%20%2F%3E%20%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%91%BD%E4%BB%A4%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%9Aset_hfm_prog_buffer_size%20512%3CBR%20%2F%3E%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%203%20%E4%B8%AA%E9%97%AA%E5%AD%98%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E4%B8%8B%E8%BD%BD%E4%BB%A3%E7%A0%81%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%AA%8C%E8%AF%81%20PRAM%20%E5%9F%BA%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EC%3A%5CJtagV2%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%80%8E%E4%B9%88%E4%BA%86%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%88%E8%A7%81%E9%9D%A2%E4%BA%86%E6%88%91%E5%8F%88%E5%9B%9E%E6%9D%A5%E4%BA%86......%E6%88%91%E7%9C%8B%E5%88%B0%E6%88%91%E9%9C%80%E8%A6%81%20flash.cfg%20%E6%96%87%E4%BB%B6%E6%9D%A5%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E4%BD%86%2056800E%20Flash%20Programmer.exe%3CBR%20%2F%3E%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%20*cfg%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%EF%BC%9F%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E7%B2%BE%E7%A1%AE%E4%B8%80%E4%BA%9B%20-%20flash8323.cfg%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%20LPC%20%E9%A2%91%E9%81%93%EF%BC%8C%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E4%B8%8E%20DSC%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FDigital-Signal-Controllers%2Fbd-p%2Fdsc%22%20target%3D%22_blank%22%3E%E6%95%B0%E5%AD%97%E4%BF%A1%E5%8F%B7%E6%8E%A7%E5%88%B6%E5%99%A8%20-%20%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%E4%B8%8A%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E5%B8%96%E5%AD%90%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E9%A2%84%E5%85%88%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%90%86%E8%A7%A3%E3%80%82%3C%2FP%3E%0A%3CP%3EBRs%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E5%90%8E%E8%82%AF%E5%AE%9A%E4%BC%9A%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E4%B8%BA%E6%AD%A4%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E8%B0%83%E6%9F%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%3CSPAN%3E%E4%BD%BF%E7%94%A8%E3%80%8A56800E%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%99%A8%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%8B%E4%BB%8E%2056F8323%20%E8%AF%BB%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%AF%B7%E4%B8%8B%E8%BD%BD%2056F8XXXFP%20%E8%BD%AF%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fadditional-mpu-mcus-architectures%2Fdigital-signal-controllers%2Fevaluation-kit-for-mc56f832x-and-mc56f812x-digital-signal-controllers%3AMC56F8323EVME%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E9%80%82%E7%94%A8%E4%BA%8E%20mc56f832x%20%E5%92%8C%20mc56f812x%20DSC%20%E7%9A%84%20EVK%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1750990273384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1750990273384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344961iAE955B499A3F700F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1750990273384.png%22%20alt%3D%22Celeste_Liu_0-1750990273384.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECeleste_Liu_0-1750990273384.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E6%89%93%E5%BC%80%E6%96%87%E4%BB%B6%2056800EFPUG%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%20%222.2.3%20%E6%9F%A5%E7%9C%8B%E5%86%85%E5%AD%98%20%22%E9%83%A8%E5%88%86%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%9A%20%E6%89%93%E5%BC%80%E6%96%87%E4%BB%B6%2056800EFPUG%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%20%222.2.3%20%E6%9F%A5%E7%9C%8B%E5%86%85%E5%AD%98%20%22%E9%83%A8%E5%88%86%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_2-1750990460798.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1750990460798.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344963i999F5CABF24DCF73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_2-1750990460798.png%22%20alt%3D%22Celeste_Liu_2-1750990460798.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECeleste_Liu_2-1750990460798.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBRs%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E-------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22ACCEPT%20AS%20SOLUTION%22%20%E6%8C%89%E9%92%AE%E3%80%82Thank%20you!%3CBR%20%2F%3E-------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
