56F8300 programming software
5,486件の閲覧回数
Fduch
Hi. Need to read out firmware from 56F8323. Can any expland what SW are used for that task?
Can I use 56800E Flash Programmer User Guide for that?
5,468件の閲覧回数
Celeste_Liu
Hello @Fduch ,
Thanks for your support.
Yes, you can use 56800E Flash Programmer User Guide to read memory from 56F8323.
Please download the 56F8XXXFP software:
EVK for MC56F832x and MC56F812x DSCs | NXP Semiconductors
Then open the file 56800EFPUG and follow the steps of section “2.2.3 Viewing Memory”:
Hope it can help you.
BRs,
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
12 返答(返信)
5,216件の閲覧回数
Fduch
I have add some info for cloning MCU. You need to readout only 2 files from 568323:
1)fflash 568323_flash.cfg program flash.S -rp0x00000:0x03FFF -p0x378
2)fflash 568323_flash.cfg boot flash.S -rp0x20000:0x20FFF -p0x378
As I understand, data flash area (0x01000 0x01FFF) is not so needit
5,297件の閲覧回数
Fduch
Finally, SOLVED! Need to be install CodeWarrior for 56800E Digital Signal Controllers v8.3.exe + FLSHPROGRAMMER_V1.2_WIN32.exe and move to directory like here:
C:\Program Files\Freescale\FlashProgrammer v1.2\bin>fflash 568323_flash.cfg 1623
0_p.S -rp0x0:0xfff -s -p0x378
56800E Flash Programmer v1.1
Program ran on: Mon Jul 21 14:45:06 2025
Connected to local CCS server
Configured to use Parallel Command Converter at port LPT1
Using Configuration File: 568323_flash.cfg
3 flash unit(s) defined in the config file.
Chip ID: 0x01f4001d
Core ID: 0x02211004, 1 - Normal Mode
Placing the device into debug mode, please wait...
Reading Memory: ****************, Done
Resetting the device to user mode...
Init: 2907ms, Read Memory: 3297ms, Exit Debug: 921ms, Total: 7125ms
5,286件の閲覧回数
Celeste_Liu
Hello @Fduch , I am very glad to hear that.  Any new issues, welcome to create the new post.
5,305件の閲覧回数
Fduch
Well, here the correct CMD and what I have with yours *cfg:
C:\JtagV2>fflash 568323_flash.cfg 16230_x.S -rx0x0:0xfff -p0x378
56800E Flash Programmer v1.0
Program ran on: Mon Jul 21 13:48:18 2025
CCCSClient::Open: Connection refused
C:\JtagV2>
5,303件の閲覧回数
Celeste_Liu
What version is your 56F8300 programming software, and which version of CodeWarrior is it a plug-in for? Additionally, what is your Windows OS?
I noticed there is "CCCSClient::Open: Connection refused" in the log.
It might be related to CCS; please refer to it. Windows 7/10: Using USB TAP on CodeWarrior for DSC - NXP Community
5,300件の閲覧回数
Fduch
OS is Win XP. And I had not install CodeWarrior on it. Just only 56800E Flash Programmer.exe & FFLASH.exe from archive 56800E Flash Programmer User Guide. Does need to install CodeWarrior?
5,312件の閲覧回数
Fduch
Well, some actions:
C:\JtagV2>flashJtagLoader 568323_flash.cfg 16230_x.S -rX0x0:0xfff -p0x378
DSP56F801x Flash loader. Compiled on Nov 3 2006, 18:00:59.
version Alpha 2.0
(c) Freescale, TIC, 2006 by William Jiang
Partial Copyright 2000-2002, Zloba Alexander
I/O port driver started
Using printer port at address 0x378.
Chip ID: 0x01f4001d
After reseting the part in programming, JTAG paths now are as follows:
JTAG IR path length: 8
JTAG DR path length: 1 (BYPASS)
Core ID: 0x02211004 Core Status: 0x0d - Debug
After selecting the core TAP of the part in programming, JTAG paths are changed
now!!!
JTAG IR path length: 4
Debug Request status: 0xd - Debug
Enable OnCE status: 0xd - Debug
Enable OnCE successful, target chip is in Debug mode
Trim relaxation oscillator successful!, trim value =0x026c
Chip is not secured
Flash config file command ignored: target_code_sets_hfmclkd 1
Flash config file command ignored: set_hfm_config_base 0x003FF7
Flash config file command ignored: set_hfm_programmer_base 0x2F800
Flash config file command ignored: set_hfm_prog_buffer_base 0
Flash config file command ignored: set_hfm_prog_buffer_size 512
3 flash units defined in the config file.
Downloading of code failed, verify PRAM base address
C:\JtagV2>
What' wrong?
5,309件の閲覧回数
Celeste_Liu
Hello, I found another 56F8323 configuration file in Codewarrior v8.3, could you please have another try?
5,322件の閲覧回数
Fduch
Hi again! I come back... and as I see i need flash.cfg file for that operations. But is havn't any *cfg files in 56800E Flash Programmer.exe
Where I can get it? If to be moore exactly - flash8323.cfg
5,461件の閲覧回数
Fduch
There will definitely be questions later. Need some investigations for that
5,459件の閲覧回数
Celeste_Liu
Hello @Fduch ,
Since this is a LPC channel, for any other DSC related questions, please help to create a new post on Digital Signal Controllers - NXP Community.
Thanks for your understanding in advance.
BRs,
Celeste
5,468件の閲覧回数
Celeste_Liu
Hello @Fduch ,
BRs,
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2124067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E56F8300%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%8256F8323%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%2056800E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1269955055%22%20id%3D%22toc-hId-1299573075%22%3E%26nbsp%3B%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCU%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E4%BD%9C%E6%88%90%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82568323%20%E3%81%8B%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%81%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%201)fflash%20568323_flash.cfg%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20flash.S%20-rp0x00000%3A0x03FFF%20-p0x378%3CBR%20%2F%3E%202)fflash%20568323_flash.cfg%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5.S%20-rp0x20000%3A0x20FFF%20-p0x378%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%EF%BC%880x01000%200x01FFF%EF%BC%89%E3%81%AFSO%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%20%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%81%9E%E3%81%84%E3%81%A6%E3%81%A8%E3%81%A6%E3%82%82%E5%AC%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A4%E3%81%84%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81CodeWarrior%20for%2056800E%20%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20v8.3.exe%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%2B%20FLSHPROGRAMMER_V1.2_WIN32.exe%20%E3%82%92%E6%AC%A1%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3EC%3A%5CProgram%20Files%5CFreescale%5CFlashProgrammer%20v1.2%5Cbin%26gt%3Bfflash%20568323_flash.cfg%201623%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E0_p.S%20-rp0x0%3A0xfff%20-s%20-p0x378%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E56800E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20v1.1%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%97%A5%3A%202025%20%E5%B9%B4%207%20%E6%9C%88%2021%20%E6%97%A5%E6%9C%88%E6%9B%9C%E6%97%A5%2014%3A45%3A06%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%ABCCS%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%9D%E3%83%BC%E3%83%88LPT1%E3%81%A7%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E4%BD%BF%E7%94%A8%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20568323_flash.cfg%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%203%20%E3%81%A4%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%81%E3%83%83%E3%83%97ID%3A%200x01f4001d%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%82%B3%E3%82%A2ID%3A%200x02211004%2C%201%20-%20%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E8%AA%AD%E6%9B%B8%E3%83%A1%E3%83%A2%E3%83%AA%3A%20****************%E3%80%81%E5%AE%8C%E4%BA%86%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3E%E5%88%9D%E6%9C%9F%E5%8C%96%3A%202907ms%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%203297ms%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%B5%82%E4%BA%86%3A%20921ms%E3%80%81%E5%90%88%E8%A8%88%3A%207125ms%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOS%E3%81%AFWinXP%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81CodeWarrior%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%2056800E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%8B%E3%82%89%2056800E%20Flash%20Programmer.exe%20%E3%81%A8%20FFLASH.exe%20%E3%81%AE%E3%81%BF%E3%80%82CodeWarrior%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E56F8300%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%20CodeWarrior%20%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81Windows%20OS%20%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%80%8C%20%3CEM%3ECCCSClient%3A%3AOpen%3A%20%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%E3%80%8D%E3%81%A8%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3ECCS%20%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%99%E3%82%8B%E3%81%8B%E3%82%82%E7%9F%A5%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%80%81%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E4%B8%8B%E3%81%95%E3%81%84%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FCodeWarrior-Development-Tools%2FWindows-7-10-Using-USB-TAP-on-CodeWarrior-for-DSC%2Fta-p%2F1126441%22%20target%3D%22_blank%22%3EWindows%207%2F10%3A%20CodeWarrior%20for%20DSC%20%E3%81%A7%20USB%20TAP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20-%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20CMD%20%E3%81%A8%E3%80%81%E7%A7%81%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%20*cfg%20%E3%81%A7%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CEM%3EC%3A%5CJtagV2%26gt%3Bfflash%20568323_flash.cfg%2016230_x.S%20-rx0x0%3A0xfff%20-p0x378%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E56800E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20v1.0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%97%A5%3A%202025%20%E5%B9%B4%207%20%E6%9C%88%2021%20%E6%97%A5%E6%9C%88%E6%9B%9C%E6%97%A5%2013%3A48%3A18%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3ECCCSClient%3A%3AOpen%3A%20%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EC%3A%5CJtagV2%26gt%3B%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82Codewarrior%20v8.3%20%E3%81%A7%E5%88%A5%E3%81%AE%2056F8323%20%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EC%3A%5CJtagV2%26gt%3BflashJtagLoader%20568323_flash.cfg%2016230_x.S%20-rX0x0%3A0xfff%20-p0x378%3CBR%20%2F%3E%20DSP56F801x%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%822006%E5%B9%B411%E6%9C%883%E6%97%A518%3A00%3A59%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%E3%82%A2%E3%83%AB%E3%83%95%E3%82%A1%202.0%3CBR%20%2F%3E%20(c)%20Freescale%2C%20TIC%2C%202006%20%E3%82%A6%E3%82%A3%E3%83%AA%E3%82%A2%E3%83%A0%E3%83%BB%E3%82%B8%E3%83%A3%E3%83%B3%3CBR%20%2F%3E%E9%83%A8%E5%88%86%E8%91%97%E4%BD%9C%E6%A8%A9%202000-2002%E3%80%81Zloba%20Alexander%3CBR%20%2F%3E%20I%2FO%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x378%20%E3%81%AE%E3%83%97%E3%83%AA%E3%83%B3%E3%82%BF%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97ID%3A%200x01f4001d%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E6%99%82%E3%81%AB%E9%83%A8%E5%93%81%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81JTAG%20%E3%83%91%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20JTAG%20IR%E3%83%91%E3%82%B9%E9%95%B7%3A%208%3CBR%20%2F%3E%20JTAG%20DR%20%E3%83%91%E3%82%B9%E9%95%B7%3A%201%20(BYPASS)%3CBR%20%2F%3E%E3%82%B3%E3%82%A2ID%3A%200x02211004%20%E3%82%B3%E3%82%A2%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x0d%20-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E6%99%82%E3%81%AB%E9%83%A8%E5%93%81%E3%81%AE%E3%82%B3%E3%82%A2TAP%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81JTAG%E3%83%91%E3%82%B9%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%8A%EF%BC%81%EF%BC%81%EF%BC%81%3CBR%20%2F%3E%20JTAG%20IR%E3%83%91%E3%82%B9%E9%95%B7%3A%204%3CBR%20%2F%3E%20JTAG%20DR%20%E3%83%91%E3%82%B9%E9%95%B7%3A%201%20(BYPASS)%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A6%81%E6%B1%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200xd%20-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3CBR%20%2F%3EOnCE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3A%200xd%20-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3CBR%20%2F%3EOnCE%20%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%B7%A9%E5%92%8C%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AE%E3%83%88%E3%83%AA%E3%83%A0%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E3%80%81%E3%83%88%E3%83%AA%E3%83%A0%E5%80%A4%20%3D%200x026c%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20target_code_sets_hfmclkd%201%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20set_hfm_config_base%200x003FF7%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20set_hfm_programmer_base%200x2F800%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20set_hfm_prog_buffer_base%200%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20set_hfm_prog_buffer_size%20512%3CBR%20%2F%3E%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%203%20%E3%81%A4%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82PRAM%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EC%3A%5CJtagV2%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%81%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F...%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AB%E3%81%AF%20flash.cfg%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%8156800E%20Flash%20Programmer.exe%E3%81%AB%E3%81%AF*cfg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%A8%80%E3%81%88%E3%81%B0%20-%20flash8323.cfg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20LPC%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%20DSC%20%E9%96%A2%E9%80%A3%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FDigital-Signal-Controllers%2Fbd-p%2Fdsc%22%20target%3D%22_blank%22%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%89%E3%81%8B%E3%81%98%E3%82%81%E3%81%94%E4%BA%86%E6%89%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BE%8C%E3%81%A7%E5%BF%85%E3%81%9A%E8%B3%AA%E5%95%8F%E3%81%8C%E5%87%BA%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E8%AA%BF%E6%9F%BB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2056F8300%20programming%20software%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231663%22%20target%3D%22_blank%22%3E%40Fduch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%20%3CSPAN%3E56800E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%8156F8323%20%E3%81%8B%E3%82%89%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E56F8XXXFP%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fadditional-mpu-mcus-architectures%2Fdigital-signal-controllers%2Fevaluation-kit-for-mc56f832x-and-mc56f812x-digital-signal-controllers%3AMC56F8323EVME%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMC56F832x%E3%81%8A%E3%82%88%E3%81%B3MC56F812x%20DSC%E7%94%A8EVK%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1750990273384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1750990273384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344961iAE955B499A3F700F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1750990273384.png%22%20alt%3D%22Celeste_Liu_0-1750990273384.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB56800EFPUG%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%80%8C2.2.3%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_2-1750990460798.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1750990460798.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344963i999F5CABF24DCF73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_2-1750990460798.png%22%20alt%3D%22Celeste_Liu_2-1750990460798.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E-------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%AE%E7%AD%94%E3%81%88%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E6%89%BF%E8%AA%8D%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
